I am using 3S Li-Po battery. It has two conenctors coming out.
One connector is A/K and second connector has charge balancing outputs for each cell.
How i can achieve balanced charge charging with BQ24617 ?
ATharva
ATharva
Hello Atharva,
You do not need to connect the second connector to the BQ24617. The BQ24617 can fully charge the battery using only the A/K connector.
Christian.
