Other Parts Discussed in Thread: TLV61046,
Hi everyone:
As the title, I assembly circuit with datasheet example circuit
I replace R1 and R2 with 470k and 82k to output voltage about 5.38 voltage.
This picture is my actually circuit and component, I added 100 ohm load
I've tested the circuit for both short and open.
I'm sure that connection of circuit is no problem.
But result is no current and voltage output.
This picture is test at Vo
This picture show no current output for my power supply(sourcing TLV61046)
Actually, I doubt this IC is fault, so I take 5 tlv61046 for test same circuit
Result is the same: No current and voltage output.
Does anyone help me?
Many thanks!
