Other Parts Discussed in Thread: TPS62810
Can the level of the TPS62810 EN exceed the VIN? Currently VIN=3V3; EN=5V, if it is possible to cause a current drain
In the circuit, the EN pin is not directly connected to the Vin pin, but an additional 5V voltage is given, what is the possible consequence?
Hi Cassius Dai,
It should not create any critical problem as far as voltage is below abs value and follow the leakage current spec.
Tanvee
