Other Parts Discussed in Thread: LM26420-Q1,
Hi Friend ,
AS LM26420-Q1 Spec, I can find the DMAX just below the pic . but I can't find the same parameter in the TPS62442-Q1. so can you give me this parameter of TPS62442-Q1?
Hi Friend ,
hi Farheen,
Thanks for your reply, I know the datasheet write 100% duty cycle. when duty reach 100%, the low-side switch is turned off. I want the IC can work in PWM mode.Put it another way, I want to know the Toff time range, then equation=1-Toff*frequency, the result is duty on. am I right?
Hello Yuming Shao,
I have to check this if we can provide this parameter.
Farheen
Hello Yuming Shao,
This data is not available. Can I ask why you need this data?
Farheen
