Other Parts Discussed in Thread: TPS62912
I have a power rail requirement of below
| Polarity | Voltage | Load Current | |
| + | 2.5 | 400 | mA |
| - | 2.5 | 400 | mA |
| + | 5 | 620 | mA |
| - | 5 | 330 | mA |
Its already disucssed at Ultra Low Noise Power Chain for Photo Sensitive applications - Power management forum - Power management - TI E2E support forums
so i have finalised with recomendations and went forward with 62912 for both inverting and non inverting dcdc and LDO-TPS7A3301 and TPS7A9401
but due to the maximum voltage limitations of 62912 in inverting mode, Engineers have awared me of risk in operating at neck level
hence i wish to use the TPS63710, which is supposed to be ultra low noise DCDC as indicated by Steve Schnier at Ultra Low Noise Power Chain for Photo Sensitive applications - Power management forum - Power management - TI E2E support forums
I request to help more on designing using TPS63710, can i directly replace TPS63710 in placed of TPS62912 ? (not pin to pin but design level)
I am going currently with a DCDC > Line Filter > LDO for better SNR performance( schematic )
so in same line can i use TPS63710 Followed by CLC Filter followed by LDO for better SNR performance ?
Kindly respond with necessary suggestions
