I am using tip and barrel method to measure the output voltage ripple at the moment, and I am seeing this. I was expecting something more triangular any thoughts on this?
Hi Eduardo,
Have you done some rework or directly test on our EVM? It seems the ESR and ESL of output capacitors are large than normal.
If you directly test on the EVM, please try to adjust the direction of the barrel to see if there's any difference.
