Dear sir,
Please help to provide the simple method to see the default voltage of LP8758-B0.
For example, to set en1,en2 and then key in some code in i2c tool.
Let me quickly to make sure the pcb assembly is good. Thanks!
Dear sir,
Good Morning Kevin,
I will review the device documentation and provide you with an update tomorrow EOB at the latest.
Kind regards,
Conner Gillette
You can read register 0x0A BUCK0_VOUT upon startup of the PMIC to determine the output voltage value loaded from the one-time programmable memory. This is detailed in Section 8.6.1.8 of the datasheet. Section 8.5 details how to communicate using I2C to read registers.
Kind regards,
Conner Gillette
