I am designing a low voltage high current traction inverter (72V, 150A) switching at 20kHz using UCC21755-Q1 driver ICs. I am planning to use bootstrap circuitry for all the top switches and split the bootstrap voltage thereafter using back to back zener connection and coupling capacitors as shown in one of the Ti documents. Can you please verify the schematic (1-leg drivre circuit of the inverter) I attach below for the correct operation.
