UCD90160A: Resequnce is not happening
Part Number: UCD90160A
In my case, i am using MON1 pin used for the 3.3V monitoring Purpose, in GUI, as a fault response, if Under voltage or Over Voltage fault is happened, we are disabling all other rails by making enable pin low.
so 3.3V fault happened , UCD device disabling other power supply rails to making enable signal is low and its diabling its own rail 3.3V enable singal also, so that resequencing is not happening.
So kindly advice how to achive this one in the UCD platform.
Arulmani V
