Thank You,
Niranjan Kumar
I want to use Part Number:-CSD95492QVM for our New design, But recommended thermal data ( Junction Temperature (Tj), θJB (°C/W), θJC (°C/W)) and power in watt are not available in data sheet, so can you please suggest recommended value for CSD95492QVM ASAP?
Hi Niranjan,
The recommended thermal data information can be found in the full datasheet of the device. You can obtain the full datasheet by emailing vr [at] list [dot] ti [dot] com.
Dhanya Prem
Hi Prem,
Please can you share the link of full data sheet here ASAP?
Niranjan
Hi Niranjan,
I am unable to share the full datasheet on a public forum. You can obtain the full datasheet by emailing vr [at] list [dot] ti [dot] com.
Dhanya Prem
Hi Prem,
I already mailed above mention email id, but its seems there are no any response from your side can you please suggest?
Niranjan
Hi Niranjan,
The reason why we cannot provide the datasheet on the forum is because it is NDA protected. Are you trying to email vr@list.ti.com?
Give it this weekend, if it does not come through, I will look into this and get back to you.
Thank you for understanding,
Dhanya Prem
Hi Prem,
I already emaild vr@list.ti.com and I am waiting for response from your side. There are some delay in my design due to non availability of required thermal data.
can you please respond ASAP?.
Niranjan
Hi prem,
Can you also suggest Thermal information of Part No:-CSD95495QVM??
Niranjan
Hi Niranjan,
I am really sorry for the delay. I will get back to you by EoD (1/16) to see if I can provide just the thermal data and send it to your email (kindly respond with your email). As I said, it is NDA protected, so I will double confirm and get back to you on this.
Thank you,
Dhanya Prem
Hi Prem,
please find my email id is niranjan.kumar@logic-fruit.com please attached full data sheet in my mail.
regards,
Niranjan
