We are using a TPS546D24A device based on Tables 7-8. MSEL1 Divider Code for Programming. The switching frequency is set at 325KHz using code 3 (Resistor value 42.2K ), but when we measured it was 550KHz.
We have simulated in TI web bench with 42.2K pull-up and 5.62L pull-down resistor, and the switching frequency is 325KHz. Could you please clarify why simulated and measured switching frequencies are not matching?
Gajendiran A
