We are considering to use BQ29737DSER in an existing design, but the main track would currently ground the pin that is defined as "NC" for the BQ29737DSER. The BQ29737DSER datasheet states "No Connection (electrically open, do not connect to BAT or VSS)".
It is in other words clear the NC pin should not be grounded, but left open. Still, we are curious about this detail:
- Is it correct to understand that the pin description means "leave electrically open", not that the pin is electrically open (internally)?
Thanks!
