Other Parts Discussed in Thread: LM25185
Hi Expert,
I would like to know the compatibility of the LM25185-Q1 using as the Separate supply IC for two switch flyback (HS, LS )?
Thanks and regards
Unnimaya.V
Hi Expert,
Thanks and regards
Unnimaya.V
Hi Unnimaya,
No, the Lm25185 does not support the two-switch flyback. You will need a circuit that has two gate outputs.
Richard
Hi Richard,
With 2 Lm25185 IC, can I drive the 2 switch flyback?
Thanks and regards
Unnimaya.V
Hi Unnimaya,
No, that is not recommended since there is no easy way to synchronize the two gates due to tolerances in the internal error amplifier.
Richard
