TPSM63606E: power management
Part Number: TPSM63606E
Dear Sir/.Madum,
We Are Using  TPSM63606 IC for Generating 5 V ,10 V . But The Calculation For Frequency Is Confusion. As Per The Datasheet Give The Value For 5 V But Not For 10 V ,
Kindly Give The Calculation For Frequency Resistor And Switching Frequency.
Waiting For Your Valuable Response
Thanks & Regards
Mahendra Deshmukh
  • Hello Mahendra,
    Let me take a look at this and get back to you tomorrow EOB (PST).
    Thank you for your patience.
    Jimmy
  • Hello Mahendra,
    Because the power module has an integrated inductor, there is a limited range of switch frequency recommended depending on the output voltage.
    It is suggested to be in a switching frequency range between 1.6MHz to 2.0 MHz for 10Vout.
    These recommendation are based on an inductor peak-to-peak ripple current in the range of 20% to 40% of the 6-A rated output current at a nominal input voltage of 24V.
    Jimmy
