Hi Team,
Please help to review the customer design and input your comments.
Thanks.
Hi Team,
Thanks.
Hello Peter,
please can you fill out the design calculator, attached below. This will help me understand your spec to check your design against, thanks.
4214.LM5148-LM25148 Quickstart Calculator.xlsm
David.
Hello Peter,
Recommend the following.
Set Ilimit to 9A as you max IOUT is set to 6A. This means using a Rsense of 6mR and Lbuck of 12uH.
The calculator can be set up for internal Compensation as you have configured, this should a cross over frequency of 10kHz and a PM of 60 degrees which should provide a stable loop response.
Recommend a small RC filter at the current sense input also.
Hope this helps.
David.
