Other Parts Discussed in Thread: BQ24725
Hi Team,
BQ24725 have MPS MP2760 Trickle charge function? Or do you have other better suggestions?
When the battery is dead, the battery has a protective board that cuts off the power path. At this time, the battery voltage is 0 volts. Can I use trickle charge to charge it at this time?
Because when the battery is out of power, the voltage is 0V,The charger will judge that there is no battery. So, it can’t be charged battery.
