Other Parts Discussed in Thread: LM5143
If I use more than one LM5143 and the input is the same VBAT. Should them share one Pi filter or use individual PI filter for each device?
Hello Zehui,
If the converters you are using are not synchronized by a clock, then I would use separate input filters to avoid beat frequency interactions between the two switching converters. If all the switchers are clock synchronized, then I would use a single filter.
Hope this helps.
David.
