Other Parts Discussed in Thread: TPS2372-4EVM-006, TPS23753
Hi Team,
I'm trying to create a schematic for at hot-swappable PSU that can seamlessly switch between being powered by a battery or PoE (With a preference for the battery)
The design is a bit space constrained so I want to use FDMQ8205A as rectifiers.
So far the rough concept behind the schematic looks like this:
I've looked at the schematic for the TPS2372-4EVM-006 as it came close to what I think could be a solution, but it wouldn't turn off the TPS2373-4 and communicate power requirements to PSE
So therefore I found another solution to my hot-swappable solution.
I found the schematic below in the datasheet for TPS23753, and figured it was the best way to handle turning off the power delivery of the PoE
To sum it up, my questions are:
- What is the purpose of BR_OFF and can the transistor and BR_OFF be left out?
- How should the setup be around FDMQ8205A to get the desired result?
- Is there a better approach to solving both issues?
Thanks in advance :-)
Søren M
