Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS2660: UVLO & OVP is not required should the pins connected to IN?
Part Number: TPS2660
Under-Voltage Lock-Out function is not needed, the UVLO terminal must be connected to the IN terminal as per datasheet recommendation.
Similarly if OVP is not required should the pin connected to IN?
