Other Parts Discussed in Thread: TPS562208,
Dear team,
For regulator TPS562200 and TPS562208 application issue, I found regulator operate normally when Vin=3.9V and EN pin voltage is 1.25V that lower than EN logic voltage 1.6V.
From datasheet as below description.
I think the Voltage Regulator TPS562200 and TPS562208 should keep shut down stauts. Could you help explain it?
Thank you very much.
Kind regards,
Andrey
