We wish to use the LM25148 as a synch buck. But we need also to have an output current clamp, which can clamp the output current by pulling down the comp pin..(eg an opamp error amp, to pull down the COMP pin via a diode)....the thing is, to do this, you first need to know the COMP pin range of control voltages?.....but datasheet doesnt tell. Do you know these values?
