Hello Texas Instruments Community,
In my design, I used 2 NMOS in parallel for PU and 2 NMOS in parallel for PD. When I used it with this configuration it did not work properly but when I removed one of the NMOS it worked. I used all the components as in TPS1211Q1EVM. What could be the reason for this issue? Also, what are the advantages or disadvantages of using 2 NMOS instead of one NMOS for each of PD and PU pins?
Thank you very much in advance,
Burcu
