Other Parts Discussed in Thread: TLC6A598
Hi
The following is a comparison of the waveform differences between fail IC and good IC
After only replacing the 1st LED IC U11, you can see that the ser_out output of pin15 of the first U11 is different. If you check the setup time and hold time, there is nothing abnormal.
Could you help the check below TPIC6A596 schematic and any need to adjust ,
Only change failed IC to U11 the 1st LED chip
CH1: CH1: U11.pin22 SER_IN; CH2:U11.pin10 SRCK; CH3: U11.PIN9 RCK ; CH4: U11.Pin15 SER_OUT
Good IC
