BQ40Z50-R2: BQ40Z50 R2 - substantial difference between ASOC and RSOC
Part Number: BQ40Z50-R2
Other Parts Discussed in Thread: BQ40Z50, , GPCCHEM, BQSTUDIO
Good morning,
on a batch of BQ40Z50 I detect a difference of many percentage points between RSOC (which reaches 95/100%) and ASOC (which stops at around 65/70%).
Board temperatures vary between 25 and 50°C.
The power supply voltage, generated by an external solar charge regulator, is 15 Vdc.
    This is expected behavior. RSOC is based on the full charge capacity which changes over time, so RSOC can reach 100% regardless of the age of the pack.
    ASOC depends on the design capacity which is based on the cell datasheet.  As the pack ages, ASOC can never reach 100%.
    RSOC = Remaining Capacity / Full Charge Capacity
    ASOC = Remaining Capacity / Design Capacity
    Siddharth
  • And so, how is calculated Full Charge Capacity?
    is this due to the temperature of the BMS?
  • The gauge automatically updates FCC and Remaining Capacity values throughout the course of a cycle.
    One of the factors that affect FCC is the temperature, there are other factors such as rate of charge/discharge and battery impedance.
    Siddharth
  • Dear Siddarth, thanks for support.
    Is it possibile a difference of 30/40% points? Am I wrong in the BMS configuration? What parameters should I check?
    Calibration,"Voltage","Cell Gain","12101","-"
    Calibration,"Voltage","Pack Gain","49669","-"
    Calibration,"Voltage","BAT Gain","48936","-"
    Calibration,"Current","CC Gain","1.036","mOhm"
    Calibration,"Current","Capacity Gain","1.036","mOhm"
    Calibration,"Current Offset","CC Offset","0","-"
    Calibration,"Current Offset","Coulomb Counter Offset Samples","64","-"
    Calibration,"Current Offset","Board Offset","0","-"
    Calibration,"Current Offset","CC Auto Config","03","hex"
    Calibration,"Current Offset","CC Auto Offset","0","-"
    Calibration,"Temperature","Internal Temp Offset","0.0","°C"
    Calibration,"Temperature","External1 Temp Offset","0.0","°C"
    Calibration,"Temperature","External2 Temp Offset","0.0","°C"
    Calibration,"Temperature","External3 Temp Offset","0.0","°C"
    Calibration,"Temperature","External4 Temp Offset","0.0","°C"
    Calibration,"Internal Temp Model","Int Gain","-12143","-"
    Calibration,"Internal Temp Model","Int base offset","6232","-"
    Calibration,"Internal Temp Model","Int Minimum AD","0","-"
    Calibration,"Internal Temp Model","Int Maximum Temp","6232","0.1°K"
    Calibration,"Cell Temperature Model","Coeff a1","-11130","-"
    Calibration,"Cell Temperature Model","Coeff a2","19142","-"
    Calibration,"Cell Temperature Model","Coeff a3","-19262","-"
    Calibration,"Cell Temperature Model","Coeff a4","28203","-"
    Calibration,"Cell Temperature Model","Coeff a5","892","-"
    Calibration,"Cell Temperature Model","Coeff b1","328","-"
    Calibration,"Cell Temperature Model","Coeff b2","-605","-"
    Calibration,"Cell Temperature Model","Coeff b3","-2443","-"
    Calibration,"Cell Temperature Model","Coeff b4","4696","-"
    Calibration,"Cell Temperature Model","Rc0","11703","-"
    Calibration,"Cell Temperature Model","Adc0","11703","-"
    Calibration,"Cell Temperature Model","Rpad","0","-"
    Calibration,"Cell Temperature Model","Rint","0","-"
    Calibration,"Fet Temperature Model","Coeff a1","-11130","-"
    Calibration,"Fet Temperature Model","Coeff a2","19142","-"
    Calibration,"Fet Temperature Model","Coeff a3","-19262","-"
    Calibration,"Fet Temperature Model","Coeff a4","28203","-"
    Calibration,"Fet Temperature Model","Coeff a5","892","-"
    Calibration,"Fet Temperature Model","Coeff b1","328","-"
    Calibration,"Fet Temperature Model","Coeff b2","-605","-"
    Calibration,"Fet Temperature Model","Coeff b3","-2443","-"
    Calibration,"Fet Temperature Model","Coeff b4","4696","-"
    Calibration,"Fet Temperature Model","Rc0","11703","-"
    Calibration,"Fet Temperature Model","Adc0","11703","-"
    Calibration,"Fet Temperature Model","Rpad","0","-"
    Calibration,"Fet Temperature Model","Rint","0","-"
    Calibration,"Current Deadband","Deadband","3","mA"
    Calibration,"Current Deadband","Coulomb Counter Deadband","9","116nV"
    Settings,"Configuration","Charging Configuration","00","hex"
    Settings,"Configuration","FET Options","20","hex"
    Settings,"Configuration","Sbs Gauging Configuration","04","hex"
    Settings,"Configuration","Sbs Configuration","20","hex"
    Settings,"Configuration","Auth Config","00","hex"
    Settings,"Configuration","Power Config","0000","hex"
    Settings,"Configuration","IO Config","00","hex"
    Settings,"Configuration","LED Configuration","00d0","hex"
    Settings,"Configuration","Temperature Enable","1e","hex"
    Settings,"Configuration","Temperature Mode","04","hex"
    Settings,"Configuration","DA Configuration","0013","hex"
    Settings,"Configuration","SOC Flag Config A","0c8c","hex"
    Settings,"Configuration","SOC Flag Config B","8c","hex"
    Settings,"Configuration","Balancing Configuration","01","hex"
    Settings,"Configuration","IT Gauging Configuration","d1fe","hex"
    Settings,"Configuration","IT Gauging Ext","001a","hex"
    Settings,"Fuse","PF Fuse A","00","hex"
    Settings,"Fuse","PF Fuse B","00","hex"
    Settings,"Fuse","PF Fuse C","00","hex"
    Settings,"Fuse","PF Fuse D","00","hex"
    Settings,"Fuse","Min Blow Fuse Voltage","3500","mV"
    Settings,"Fuse","Fuse Blow Timeout","30","s"
    Settings,"BTP","Init Discharge Set","150","mAh"
    Settings,"BTP","Init Charge Set","175","mAh"
    Settings,"SMBus","Address","16","-"
    Settings,"SMBus","Address Check","ea","-"
    Settings,"Protection","Protection Configuration","00","hex"
    Settings,"Protection","Enabled Protections A","ff","hex"
    Settings,"Protection","Enabled Protections B","7f","hex"
    Settings,"Protection","Enabled Protections C","d5","hex"
    Settings,"Protection","Enabled Protections D","0f","hex"
    Settings,"Permanent Failure","Enabled PF A","00","hex"
    Settings,"Permanent Failure","Enabled PF B","00","hex"
    Settings,"Permanent Failure","Enabled PF C","00","hex"
    Settings,"Permanent Failure","Enabled PF D","00","hex"
    Settings,"AFE","AFE Protection Control","70","hex"
    Settings,"AFE","ZVCHG Exit Threshold","2200","mV"
    Settings,"Manufacturing","Mfg Status init","02b8","hex"
    Advanced Charge Algorithm,"Temperature Ranges","T1 Temp","0.0","°C"
    Advanced Charge Algorithm,"Temperature Ranges","T2 Temp","12.0","°C"
    Advanced Charge Algorithm,"Temperature Ranges","T5 Temp","20.0","°C"
    Advanced Charge Algorithm,"Temperature Ranges","T6 Temp","25.0","°C"
    Advanced Charge Algorithm,"Temperature Ranges","T3 Temp","30.0","°C"
    Advanced Charge Algorithm,"Temperature Ranges","T4 Temp","55.0","°C"
    Advanced Charge Algorithm,"Temperature Ranges","Hysteresis Temp","1.0","°C"
    Advanced Charge Algorithm,"Low Temp Charging","Voltage","3600","mV"
    Advanced Charge Algorithm,"Low Temp Charging","Current Low","132","mA"
    Advanced Charge Algorithm,"Low Temp Charging","Current Med","352","mA"
    Advanced Charge Algorithm,"Low Temp Charging","Current High","264","mA"
    Advanced Charge Algorithm,"Standard Temp Low Charging","Voltage","3600","mV"
    Advanced Charge Algorithm,"Standard Temp Low Charging","Current Low","1980","mA"
    Advanced Charge Algorithm,"Standard Temp Low Charging","Current Med","4004","mA"
    Advanced Charge Algorithm,"Standard Temp Low Charging","Current High","2992","mA"
    Advanced Charge Algorithm,"Standard Temp High Charging","Voltage","3600","mV"
    Advanced Charge Algorithm,"Standard Temp High Charging","Current Low","1980","mA"
    Advanced Charge Algorithm,"Standard Temp High Charging","Current Med","4004","mA"
    Advanced Charge Algorithm,"Standard Temp High Charging","Current High","2992","mA"
    Advanced Charge Algorithm,"High Temp Charging","Voltage","3600","mV"
    Advanced Charge Algorithm,"High Temp Charging","Current Low","1012","mA"
    Advanced Charge Algorithm,"High Temp Charging","Current Med","1980","mA"
    Advanced Charge Algorithm,"High Temp Charging","Current High","1496","mA"
    Advanced Charge Algorithm,"Rec Temp Charging","Voltage","3600","mV"
    Advanced Charge Algorithm,"Rec Temp Charging","Current Low","2508","mA"
    Advanced Charge Algorithm,"Rec Temp Charging","Current Med","4488","mA"
    Advanced Charge Algorithm,"Rec Temp Charging","Current High","3520","mA"
    Advanced Charge Algorithm,"Pre-Charging","Current","45","mA"
    Advanced Charge Algorithm,"Maintenance Charging","Current","44","mA"
    Advanced Charge Algorithm,"Voltage Range","Precharge Start Voltage","2000","mV"
    Advanced Charge Algorithm,"Voltage Range","Charging Voltage Low","2500","mV"
    Advanced Charge Algorithm,"Voltage Range","Charging Voltage Med","3200","mV"
    Advanced Charge Algorithm,"Voltage Range","Charging Voltage High","3600","mV"
    Advanced Charge Algorithm,"Voltage Range","Charging Voltage Hysteresis","0","mV"
    Advanced Charge Algorithm,"SoC Range","Charging SoC Med","50","%"
    Advanced Charge Algorithm,"SoC Range","Charging SoC High","75","%"
    Advanced Charge Algorithm,"SoC Range","Charging SoC Hysteresis","1","%"
    Advanced Charge Algorithm,"Degrade Mode 1","Cycle Threshold","50","-"
    Advanced Charge Algorithm,"Degrade Mode 1","SOH Threshold","95","%"
    Advanced Charge Algorithm,"Degrade Mode 1","Voltage Degradation","10","mV"
    Advanced Charge Algorithm,"Degrade Mode 1","Current Degradation","10","%"
    Advanced Charge Algorithm,"Degrade Mode 2","Cycle Threshold","150","-"
    Advanced Charge Algorithm,"Degrade Mode 2","SOH Threshold","80","%"
    Advanced Charge Algorithm,"Degrade Mode 2","Voltage Degradation","40","mV"
    Advanced Charge Algorithm,"Degrade Mode 2","Current Degradation","20","%"
    Advanced Charge Algorithm,"Degrade Mode 3","Cycle Threshold","350","-"
    Advanced Charge Algorithm,"Degrade Mode 3","SOH Threshold","60","%"
    Advanced Charge Algorithm,"Degrade Mode 3","Voltage Degradation","70","mV"
    Advanced Charge Algorithm,"Degrade Mode 3","Current Degradation","40","%"
    Advanced Charge Algorithm,"CS Degrade","Temperature Threshold","50.0","°C"
    Advanced Charge Algorithm,"CS Degrade","Voltage Threshold","3400","mV"
    Advanced Charge Algorithm,"CS Degrade","Time Interval","300","s"
    Advanced Charge Algorithm,"CS Degrade","Delta Voltage","25","mV"
    Advanced Charge Algorithm,"CS Degrade","Min CV","3000","mV"
    Advanced Charge Algorithm,"Termination Config","Charge Term Taper Current","100","mA"
    Advanced Charge Algorithm,"Termination Config","Charge Term Voltage","100","mV"
    Advanced Charge Algorithm,"Charging Rate of Change","Current Rate","1","steps"
    Advanced Charge Algorithm,"Charging Rate of Change","Voltage Rate","1","steps"
    Advanced Charge Algorithm,"Charge Loss Compensation","CCC Current Threshold","3520","mA"
    Advanced Charge Algorithm,"Charge Loss Compensation","CCC Voltage Threshold","3600","mV"
    Advanced Charge Algorithm,"IR Correction","Averaging Interval","12","s"
    Advanced Charge Algorithm,"Cell Balancing Config","Bal Time/mAh Cell 1","367","s/mAh"
    Advanced Charge Algorithm,"Cell Balancing Config","Bal Time/mAh Cell 2-4","514","s/mAh"
    Advanced Charge Algorithm,"Cell Balancing Config","Min Start Balance Delta","3","mV"
    Advanced Charge Algorithm,"Cell Balancing Config","Relax Balance Interval","18000","s"
    Advanced Charge Algorithm,"Cell Balancing Config","Min Rsoc for Balancing","80","%"
    Advanced Charge Algorithm,"Cell Balancing Config","Start Rsoc for Bal in Sleep","95","%"
    Advanced Charge Algorithm,"Cell Balancing Config","End Rsoc for Bal in Sleep","60","%"
    Advanced Charge Algorithm,"Cell Balancing Config","Start Time for Bal in Sleep","100","hrs"
    Power,"Power","Valid Update Voltage","3500","mV"
    Power,"Shutdown","Shutdown Voltage","1750","mV"
    Power,"Shutdown","Shutdown Time","10","s"
    Power,"Shutdown","PF Shutdown Voltage","1750","mV"
    Power,"Shutdown","PF Shutdown Time","10","s"
    Power,"Shutdown","PS Shutdown Voltage","2500","mV"
    Power,"Shutdown","PS NoLoadResCap Threshold","0","mAh"
    Power,"Shutdown","Charger Present Threshold","2700","mV"
    Power,"Shutdown","Valid Wake up Comm Check Delay","100","s"
    Power,"Sleep","Sleep Current","10","mA"
    Power,"Sleep","Bus Timeout","5","s"
    Power,"Sleep","Voltage Time","5","s"
    Power,"Sleep","Current Time","20","s"
    Power,"Sleep","Wake Comparator","00","hex"
    Power,"Ship","FET Off Time","10","s"
    Power,"Ship","Delay","20","s"
    Power,"Ship","Auto Ship Time","1440","min"
    Power,"Power Off","Timeout","30","min"
    Power,"Manual FET Control","MFC Delay","60","0.25s"
    Power,"IATA","IATA Config","03","-"
    Power,"IATA","IATA Delay Time","10","s"
    Power,"IATA","IATA RSOC Threshold","30","%"
    Power,"IATA","IATA DeltaV Threshold","50","mV"
    Power,"IATA","IATA Delta RSOC","3","%"
    Power,"IATA","IATA Wake AbsRsoc","10","%"
    Power,"IATA","IATA Min Temperature","10.0","°C"
    Power,"IATA","IATA Max Temperature","40.0","°C"
    Power,"IATA","IATA Min Voltage","3000","mV"
    Power,"IATA","IATA Max Voltage","3600","mV"
    Power,"IATA STORE","IATA RM mAh","0","mAh"
    Power,"IATA STORE","IATA RM cWh","0","cWh"
    Power,"IATA STORE","IATA FCC mAh","0","mAh"
    Power,"IATA STORE","IATA FCC cWh","0","cWh"
    Power,"IATA STORE","IATA Flag","00","-"
    Power,"Unintended Wakeup","Delay","2","s"
    Power,"Unintended Wakeup","Count","3","-"
    LED Support,"LED Config","LED Flash Period","512","488us"
    LED Support,"LED Config","LED Blink Period","1024","488us"
    LED Support,"LED Config","LED Delay","100","488us"
    LED Support,"LED Config","LED Hold Time","4","s"
    LED Support,"LED Config","LED FC Time","60","mins"
    LED Support,"LED Config","CHG Flash Alarm","10","%"
    LED Support,"LED Config","CHG Thresh 1","0","%"
    LED Support,"LED Config","CHG Thresh 2","20","%"
    LED Support,"LED Config","CHG Thresh 3","40","%"
    LED Support,"LED Config","CHG Thresh 4","60","%"
    LED Support,"LED Config","CHG Thresh 5","80","%"
    LED Support,"LED Config","DSG Flash Alarm","10","%"
    LED Support,"LED Config","DSG Thresh 1","0","%"
    LED Support,"LED Config","DSG Thresh 2","20","%"
    LED Support,"LED Config","DSG Thresh 3","40","%"
    LED Support,"LED Config","DSG Thresh 4","60","%"
    LED Support,"LED Config","DSG Thresh 5","80","%"
    System Data,"Manufacturer Data","Manufacturer Info A Length","32","-"
    System Data,"Manufacturer Data","Manufacturer Info Block A01","61","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A02","62","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A03","63","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A04","64","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A05","65","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A06","66","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A07","67","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A08","68","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A09","69","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A10","6a","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A11","6b","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A12","6c","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A13","6d","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A14","6e","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A15","6f","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A16","70","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A17","71","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A18","72","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A19","73","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A20","74","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A21","75","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A22","76","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A23","77","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A24","7a","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A25","78","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A26","79","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A27","30","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A28","31","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A29","32","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A30","33","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A31","34","Hex"
    System Data,"Manufacturer Data","Manufacturer Info Block A32","35","Hex"
    System Data,"Manufacturer Info B","Manufacturer Info Block B01","01","Hex"
    System Data,"Manufacturer Info B","Manufacturer Info Block B02","23","Hex"
    System Data,"Manufacturer Info B","Manufacturer Info Block B03","45","Hex"
    System Data,"Manufacturer Info B","Manufacturer Info Block B04","67","Hex"
    System Data,"Integrity","Static DF Signature","0000","hex"
    System Data,"Integrity","Static Chem DF Signature","1bde","hex"
    System Data,"Integrity","All DF Signature","0000","hex"
    SBS Configuration,"Data","Remaining AH Cap. Alarm","0","mAh"
    SBS Configuration,"Data","Remaining WH Cap. Alarm","0","cWh"
    SBS Configuration,"Data","Remaining Time Alarm","10","min"
    SBS Configuration,"Data","Initial Battery Mode","0081","hex"
    SBS Configuration,"Data","Specification Information","0031","hex"
    SBS Configuration,"Data","Manufacture Date","2021-10-7","date"
    SBS Configuration,"Data","Serial Number","0001","hex"
    SBS Configuration,"Data","Manufacturer Name","Netsens","-"
    SBS Configuration,"Data","Device Name","bq40z50-R2","-"
    SBS Configuration,"Data","Device Chemistry","LIFE","-"
    Lifetimes,"Voltage","Cell 1 Max Voltage","4175","mV"
    Lifetimes,"Voltage","Cell 2 Max Voltage","3866","mV"
    Lifetimes,"Voltage","Cell 3 Max Voltage","4363","mV"
    Lifetimes,"Voltage","Cell 4 Max Voltage","3663","mV"
    Lifetimes,"Voltage","Cell 1 Min Voltage","3142","mV"
    Lifetimes,"Voltage","Cell 2 Min Voltage","3045","mV"
    Lifetimes,"Voltage","Cell 3 Min Voltage","2959","mV"
    Lifetimes,"Voltage","Cell 4 Min Voltage","0","mV"
    Lifetimes,"Voltage","Max Delta Cell Voltage","3788","mV"
    Lifetimes,"Current","Max Charge Current","2031","mA"
    Lifetimes,"Current","Max Discharge Current","-1859","mA"
    Lifetimes,"Current","Max Avg Dsg Current","-1325","mA"
    Lifetimes,"Current","Max Avg Dsg Power","-1699","cW"
    Lifetimes,"Temperature","Max Temp Cell","67","°C"
    Lifetimes,"Temperature","Min Temp Cell","13","°C"
    Lifetimes,"Temperature","Max Delta Cell Temp","44","°C"
    Lifetimes,"Temperature","Max Temp Int Sensor","44","°C"
    Lifetimes,"Temperature","Min Temp Int Sensor","13","°C"
    Lifetimes,"Temperature","Max Temp Fet","42","°C"
    Lifetimes,"Safety Events","No Of COV Events","20","events"
    Lifetimes,"Safety Events","Last COV Event","1","cycles"
    Lifetimes,"Safety Events","No Of CUV Events","2","events"
    Lifetimes,"Safety Events","Last CUV Event","0","cycles"
    Lifetimes,"Safety Events","No Of OCD1 Events","0","events"
    Lifetimes,"Safety Events","Last OCD1 Event","0","cycles"
    Lifetimes,"Safety Events","No Of OCD2 Events","0","events"
    Lifetimes,"Safety Events","Last OCD2 Event","0","cycles"
    Lifetimes,"Safety Events","No Of OCC1 Events","0","events"
    Lifetimes,"Safety Events","Last OCC1 Event","0","cycles"
    Lifetimes,"Safety Events","No Of OCC2 Events","0","events"
    Lifetimes,"Safety Events","Last OCC2 Event","0","cycles"
    Lifetimes,"Safety Events","No Of AOLD Events","1","events"
    Lifetimes,"Safety Events","Last AOLD Event","0","cycles"
    Lifetimes,"Safety Events","No Of ASCD Events","0","events"
    Lifetimes,"Safety Events","Last ASCD Event","0","cycles"
    Lifetimes,"Safety Events","No Of ASCC Events","0","events"
    Lifetimes,"Safety Events","Last ASCC Event","0","cycles"
    Lifetimes,"Safety Events","No Of OTC Events","0","events"
    Lifetimes,"Safety Events","Last OTC Event","0","cycles"
    Lifetimes,"Safety Events","No Of OTD Events","1","events"
    Lifetimes,"Safety Events","Last OTD Event","0","cycles"
    Lifetimes,"Safety Events","No Of OTF Events","0","events"
    Lifetimes,"Safety Events","Last OTF Event","0","cycles"
    Lifetimes,"Charging Events","No Valid Charge Term","2","events"
    Lifetimes,"Charging Events","Last Valid Charge Term","1","cycles"
    Lifetimes,"Gauging Events","No Of Qmax Updates","1","events"
    Lifetimes,"Gauging Events","Last Qmax Update","0","cycles"
    Lifetimes,"Gauging Events","No Of Ra Updates","2","events"
    Lifetimes,"Gauging Events","Last Ra Update","1","cycles"
    Lifetimes,"Gauging Events","No Of Ra Disable","6","events"
    Lifetimes,"Gauging Events","Last Ra Disable","1","cycles"
    Lifetimes,"Power Events","No Of Shutdowns","2","events"
    Lifetimes,"Cell Balancing","Cb Time Cell 1","4","h"
    Lifetimes,"Cell Balancing","Cb Time Cell 2","10","h"
    Lifetimes,"Cell Balancing","Cb Time Cell 3","0","h"
    Lifetimes,"Cell Balancing","Cb Time Cell 4","2","h"
    Lifetimes,"Time","Total Fw Runtime","6768","h"
    Lifetimes,"Time","Time Spent In UT","0","h"
    Lifetimes,"Time","Time Spent In LT","0","h"
    Lifetimes,"Time","Time Spent In STL","2828","h"
    Lifetimes,"Time","Time Spent In RT","980","h"
    Lifetimes,"Time","Time Spent In STH","2572","h"
    Lifetimes,"Time","Time Spent In HT","382","h"
    Lifetimes,"Time","Time Spent In OT","0","h"
    Protections,"CUV","Threshold","2800","mV"
    Protections,"CUV","Delay","2","s"
    Protections,"CUV","Recovery","3000","mV"
    Protections,"CUVC","Threshold","2800","mV"
    Protections,"CUVC","Delay","2","s"
    Protections,"CUVC","Recovery","3000","mV"
    Protections,"COV","Threshold Low Temp","3750","mV"
    Protections,"COV","Threshold Standard Temp Low","3750","mV"
    Protections,"COV","Threshold Standard Temp High","3750","mV"
    Protections,"COV","Threshold High Temp","3750","mV"
    Protections,"COV","Threshold Rec Temp","3750","mV"
    Protections,"COV","Delay","60","s"
    Protections,"COV","Recovery Low Temp","3650","mV"
    Protections,"COV","Recovery Standard Temp Low","3650","mV"
    Protections,"COV","Recovery Standard Temp High","3650","mV"
    Protections,"COV","Recovery High Temp","3650","mV"
    Protections,"COV","Recovery Rec Temp","3650","mV"
    Protections,"COV","Latch Limit","0","-"
    Protections,"COV","Counter Dec Delay","10","s"
    Protections,"COV","Reset","15","s"
    Protections,"OCC1","Threshold","3650","mA"
    Protections,"OCC1","Delay","30","s"
    Protections,"OCC2","Threshold","5000","mA"
    Protections,"OCC2","Delay","3","s"
    Protections,"OCC","Recovery Threshold","-200","mA"
    Protections,"OCC","Recovery Delay","5","s"
    Protections,"OCD1","Threshold","-6400","mA"
    Protections,"OCD1","Delay","6","s"
    Protections,"OCD2","Threshold","-8000","mA"
    Protections,"OCD2","Delay","3","s"
    Protections,"OCD","Recovery Threshold","200","mA"
    Protections,"OCD","Recovery Delay","5","s"
    Protections,"OCD","Latch Limit","0","-"
    Protections,"OCD","Counter Dec Delay","10","s"
    Protections,"OCD","Reset","15","s"
    Protections,"AOLD","Latch Limit","0","-"
    Protections,"AOLD","Counter Dec Delay","10","s"
    Protections,"AOLD","Recovery","5","s"
    Protections,"AOLD","Reset","15","s"
    Protections,"AOLD","Threshold","f4","hex"
    Protections,"ASCC","Latch Limit","0","-"
    Protections,"ASCC","Counter Dec Delay","10","s"
    Protections,"ASCC","Recovery","5","s"
    Protections,"ASCC","Reset","15","s"
    Protections,"ASCC","Threshold","77","hex"
    Protections,"ASCD","Latch Limit","0","-"
    Protections,"ASCD","Counter Dec Delay","10","s"
    Protections,"ASCD","Recovery","5","s"
    Protections,"ASCD","Reset","15","s"
    Protections,"ASCD","Threshold 1","77","hex"
    Protections,"ASCD","Threshold 2","e7","hex"
    Protections,"OTC","Threshold","55.0","°C"
    Protections,"OTC","Delay","2","s"
    Protections,"OTC","Recovery","50.0","°C"
    Protections,"OTD","Threshold","60.0","°C"
    Protections,"OTD","Delay","2","s"
    Protections,"OTD","Recovery","55.0","°C"
    Protections,"OTF","Threshold","80.0","°C"
    Protections,"OTF","Delay","2","s"
    Protections,"OTF","Recovery","65.0","°C"
    Protections,"UTC","Threshold","0.0","°C"
    Protections,"UTC","Delay","2","s"
    Protections,"UTC","Recovery","5.0","°C"
    Protections,"UTD","Threshold","0.0","°C"
    Protections,"UTD","Delay","2","s"
    Protections,"UTD","Recovery","5.0","°C"
    Protections,"HWD","Delay","10","s"
    Protections,"PTO","Charge Threshold","2000","mA"
    Protections,"PTO","Suspend Threshold","1800","mA"
    Protections,"PTO","Delay","1800","s"
    Protections,"PTO","Reset","2","mAh"
    Protections,"CTO","Charge Threshold","2500","mA"
    Protections,"CTO","Suspend Threshold","2000","mA"
    Protections,"CTO","Delay","54000","s"
    Protections,"CTO","Reset","2","mAh"
    Protections,"OC","Threshold","4500","mAh"
    Protections,"OC","Recovery","2","mAh"
    Protections,"OC","RSOC Recovery","90","%"
    Protections,"CHGV","Threshold","500","mV"
    Protections,"CHGV","Delay","30","s"
    Protections,"CHGV","Recovery","-500","mV"
    Protections,"CHGC","Threshold","1500","mA"
    Protections,"CHGC","Delay","2","s"
    Protections,"CHGC","Recovery Threshold","100","mA"
    Protections,"CHGC","Recovery Delay","2","s"
    Protections,"PCHGC","Threshold","100","mA"
    Protections,"PCHGC","Delay","30","s"
    Protections,"PCHGC","Recovery Threshold","10","mA"
    Protections,"PCHGC","Recovery Delay","2","s"
    Permanent Fail,"SUV","Threshold","2200","mV"
    Permanent Fail,"SUV","Delay","5","s"
    Permanent Fail,"SOV","Threshold","3700","mV"
    Permanent Fail,"SOV","Delay","5","s"
    Permanent Fail,"SOCC","Threshold","10000","mA"
    Permanent Fail,"SOCC","Delay","5","s"
    Permanent Fail,"SOCD","Threshold","-10000","mA"
    Permanent Fail,"SOCD","Delay","5","s"
    Permanent Fail,"SOT","Threshold","65.0","°C"
    Permanent Fail,"SOT","Delay","5","s"
    Permanent Fail,"SOTF","Threshold","100.0","°C"
    Permanent Fail,"SOTF","Delay","5","s"
    Permanent Fail,"Open Thermistor","Threshold","-50.0","°C"
    Permanent Fail,"Open Thermistor","Delay","5","s"
    Permanent Fail,"Open Thermistor","Fet Delta","20.0","°C"
    Permanent Fail,"Open Thermistor","Cell Delta","20.0","°C"
    Permanent Fail,"QIM","Delta Threshold","15.0","%"
    Permanent Fail,"QIM","Delay","2","updates"
    Permanent Fail,"CB","Max Threshold","240","h"
    Permanent Fail,"CB","Delta Threshold","40","h"
    Permanent Fail,"CB","Delay","2","cycles"
    Permanent Fail,"VIMR","Check Voltage","3200","mV"
    Permanent Fail,"VIMR","Check Current","10","mA"
    Permanent Fail,"VIMR","Delta Threshold","500","mV"
    Permanent Fail,"VIMR","Delta Delay","5","s"
    Permanent Fail,"VIMR","Duration","100","s"
    Permanent Fail,"VIMA","Check Voltage","3500","mV"
    Permanent Fail,"VIMA","Check Current","50","mA"
    Permanent Fail,"VIMA","Delta Threshold","200","mV"
    Permanent Fail,"VIMA","Delay","5","s"
    Permanent Fail,"IMP","Delta Threshold","300","%"
    Permanent Fail,"IMP","Max Threshold","400","%"
    Permanent Fail,"IMP","Ra Update Counts","2","Counts"
    Permanent Fail,"CD","Threshold","0","mAh"
    Permanent Fail,"CD","Delay","2","cycles"
    Permanent Fail,"CFET","OFF Threshold","5","mA"
    Permanent Fail,"CFET","OFF Delay","5","s"
    Permanent Fail,"DFET","OFF Threshold","-5","mA"
    Permanent Fail,"DFET","OFF Delay","5","s"
    Permanent Fail,"FUSE","Threshold","5","mA"
    Permanent Fail,"FUSE","Delay","5","s"
    Permanent Fail,"AFER","Threshold","100","-"
    Permanent Fail,"AFER","Delay Period","2","s"
    Permanent Fail,"AFER","Compare Period","5","s"
    Permanent Fail,"AFEC","Threshold","100","-"
    Permanent Fail,"AFEC","Delay Period","5","s"
    Permanent Fail,"2LVL","Delay","5","s"
    PF Status,"Device Status Data","Safety Alert A","00","hex"
    PF Status,"Device Status Data","Safety Status A","00","hex"
    PF Status,"Device Status Data","Safety Alert B","00","hex"
    PF Status,"Device Status Data","Safety Status B","00","hex"
    PF Status,"Device Status Data","Safety Alert C","00","hex"
    PF Status,"Device Status Data","Safety Status C","00","hex"
    PF Status,"Device Status Data","Safety Alert D","00","hex"
    PF Status,"Device Status Data","Safety Status D","00","hex"
    PF Status,"Device Status Data","PF Alert A","00","hex"
    PF Status,"Device Status Data","PF Status A","00","hex"
    PF Status,"Device Status Data","PF Alert B","00","hex"
    PF Status,"Device Status Data","PF Status B","00","hex"
    PF Status,"Device Status Data","PF Alert C","00","hex"
    PF Status,"Device Status Data","PF Status C","00","hex"
    PF Status,"Device Status Data","PF Alert D","00","hex"
    PF Status,"Device Status Data","PF Status D","00","hex"
    PF Status,"Device Status Data","Fuse Flag","0000","hex"
    PF Status,"Device Status Data","Operation Status A","0000","hex"
    PF Status,"Device Status Data","Operation Status B","0000","hex"
    PF Status,"Device Status Data","Temp Range","00","hex"
    PF Status,"Device Status Data","Charging Status A","00","hex"
    PF Status,"Device Status Data","Charging Status B","00","hex"
    PF Status,"Device Status Data","Gauging Status","00","hex"
    PF Status,"Device Status Data","IT Status","0000","hex"
    PF Status,"Device Voltage Data","Cell 1 Voltage","3200","mV"
    PF Status,"Device Voltage Data","Cell 2 Voltage","3200","mV"
    PF Status,"Device Voltage Data","Cell 3 Voltage","3200","mV"
    PF Status,"Device Voltage Data","Cell 4 Voltage","3200","mV"
    PF Status,"Device Voltage Data","Battery Direct Voltage","0","mV"
    PF Status,"Device Voltage Data","Pack Voltage","12800","mV"
    PF Status,"Device Current Data","Current","6400","mA"
    PF Status,"Device Temperature Data","Internal Temperature","-273.2","°C"
    PF Status,"Device Temperature Data","External 1 Temperature","-273.2","°C"
    PF Status,"Device Temperature Data","External 2 Temperature","-273.2","°C"
    PF Status,"Device Temperature Data","External 3 Temperature","-273.2","°C"
    PF Status,"Device Temperature Data","External 4 Temperature","-273.2","°C"
    PF Status,"Device Gauging Data","Cell 1 Dod0","0","-"
    PF Status,"Device Gauging Data","Cell 2 Dod0","0","-"
    PF Status,"Device Gauging Data","Cell 3 Dod0","0","-"
    PF Status,"Device Gauging Data","Cell 4 Dod0","0","-"
    PF Status,"Device Gauging Data","Passed Charge","0","mAh"
    PF Status,"AFE Regs","AFE Interrupt Status","00","hex"
    PF Status,"AFE Regs","AFE FET Status","00","hex"
    PF Status,"AFE Regs","AFE RXIN","00","hex"
    PF Status,"AFE Regs","AFE Latch Status","00","hex"
    PF Status,"AFE Regs","AFE Interrupt Enable","00","hex"
    PF Status,"AFE Regs","AFE FET Control","00","hex"
    PF Status,"AFE Regs","AFE RXIEN","00","hex"
    PF Status,"AFE Regs","AFE RLOUT","00","hex"
    PF Status,"AFE Regs","AFE RHOUT","00","hex"
    PF Status,"AFE Regs","AFE RHINT","00","hex"
    PF Status,"AFE Regs","AFE Cell Balance","00","hex"
    PF Status,"AFE Regs","AFE AD/CC Control","00","hex"
    PF Status,"AFE Regs","AFE ADC Mux","00","hex"
    PF Status,"AFE Regs","AFE LED Output","00","hex"
    PF Status,"AFE Regs","AFE State Control","00","hex"
    PF Status,"AFE Regs","AFE LED/Wake Control","00","hex"
    PF Status,"AFE Regs","AFE Protection Control","00","hex"
    PF Status,"AFE Regs","AFE OCD","00","hex"
    PF Status,"AFE Regs","AFE SCC","00","hex"
    PF Status,"AFE Regs","AFE SCD1","00","hex"
    PF Status,"AFE Regs","AFE SCD2","00","hex"
    Black Box,"Safety Status","1st Status Status A","00","hex"
    Black Box,"Safety Status","1st Status Status B","00","hex"
    Black Box,"Safety Status","1st Safety Status C","00","hex"
    Black Box,"Safety Status","1st Safety Status D","00","hex"
    Black Box,"Safety Status","1st Time to Next Event","0","s"
    Black Box,"Safety Status","2nd Status Status A","00","hex"
    Black Box,"Safety Status","2nd Status Status B","00","hex"
    Black Box,"Safety Status","2nd Safety Status C","00","hex"
    Black Box,"Safety Status","2nd Safety Status D","00","hex"
    Black Box,"Safety Status","2nd Time to Next Event","0","s"
    Black Box,"Safety Status","3rd Status Status A","00","hex"
    Black Box,"Safety Status","3rd Status Status B","00","hex"
    Black Box,"Safety Status","3rd Safety Status C","00","hex"
    Black Box,"Safety Status","3rd Safety Status D","00","hex"
    Black Box,"Safety Status","3rd Time to Next Event","0","s"
    Black Box,"PF Status","1st PF Status A","00","hex"
    Black Box,"PF Status","1st PF Status B","00","hex"
    Black Box,"PF Status","1st PF Status C","00","hex"
    Black Box,"PF Status","1st PF Status D","00","hex"
    Black Box,"PF Status","1st Time to Next Event","0","s"
    Black Box,"PF Status","2nd PF Status A","00","hex"
    Black Box,"PF Status","2nd PF Status B","00","hex"
    Black Box,"PF Status","2nd PF Status C","00","hex"
    Black Box,"PF Status","2nd PF Status D","00","hex"
    Black Box,"PF Status","2nd Time to Next Event","0","s"
    Black Box,"PF Status","3rd PF Status A","00","hex"
    Black Box,"PF Status","3rd PF Status B","00","hex"
    Black Box,"PF Status","3rd PF Status C","00","hex"
    Black Box,"PF Status","3rd PF Status D","00","hex"
    Black Box,"PF Status","3rd Time to Next Event","0","s"
    Gas Gauging,"Current Thresholds","Dsg Current Threshold","25","mA"
    Gas Gauging,"Current Thresholds","Chg Current Threshold","30","mA"
    Gas Gauging,"Current Thresholds","Quit Current","20","mA"
    Gas Gauging,"Current Thresholds","Dsg Relax Time","1","s"
    Gas Gauging,"Current Thresholds","Chg Relax Time","60","s"
    Gas Gauging,"Design","Design Capacity mAh","4000","mAh"
    Gas Gauging,"Design","Design Capacity cWh","5120","cWh"
    Gas Gauging,"Design","Design Voltage","12800","mV"
    Gas Gauging,"Cycle","Cycle Count Percentage","90","%"
    Gas Gauging,"FD","Set Voltage Threshold","2500","mV"
    Gas Gauging,"FD","Clear Voltage Threshold","2600","mV"
    Gas Gauging,"FD","Set % RSOC Threshold","0","%"
    Gas Gauging,"FD","Clear % RSOC Threshold","5","%"
    Gas Gauging,"FC","Set Voltage Threshold","3600","mV"
    Gas Gauging,"FC","Clear Voltage Threshold","3500","mV"
    Gas Gauging,"FC","Set % RSOC Threshold","100","%"
    Gas Gauging,"FC","Clear % RSOC Threshold","95","%"
    Gas Gauging,"TD","Set Voltage Threshold","2600","mV"
    Gas Gauging,"TD","Clear Voltage Threshold","2700","mV"
    Gas Gauging,"TD","Set % RSOC Threshold","6","%"
    Gas Gauging,"TD","Clear % RSOC Threshold","8","%"
    Gas Gauging,"TC","Set Voltage Threshold","3600","mV"
    Gas Gauging,"TC","Clear Voltage Threshold","3500","mV"
    Gas Gauging,"TC","Set % RSOC Threshold","100","%"
    Gas Gauging,"TC","Clear % RSOC Threshold","95","%"
    Gas Gauging,"State","Cycle Count","2","-"
    Gas Gauging,"State","Qmax Cell 1","3356","mAh"
    Gas Gauging,"State","Qmax Cell 2","3333","mAh"
    Gas Gauging,"State","Qmax Cell 3","3371","mAh"
    Gas Gauging,"State","Qmax Cell 4","3388","mAh"
    Gas Gauging,"State","Qmax Pack","3333","mAh"
    Gas Gauging,"State","Qmax Cycle Count","0","-"
    Gas Gauging,"State","Update Status","0e","-"
    Gas Gauging,"State","Cell 1 Chg Voltage at EoC","3354","mV"
    Gas Gauging,"State","Cell 2 Chg Voltage at EoC","3334","mV"
    Gas Gauging,"State","Cell 3 Chg Voltage at EoC","3566","mV"
    Gas Gauging,"State","Cell 4 Chg Voltage at EoC","3331","mV"
    Gas Gauging,"State","Current at EoC","64","mA"
    Gas Gauging,"State","Avg I Last Run","-94","mA"
    Gas Gauging,"State","Avg P Last Run","-124","cW"
    Gas Gauging,"State","Delta Voltage","13","mV"
    Gas Gauging,"State","Temp k","10.00","°C/256mW"
    Gas Gauging,"State","Temp a","440","s"
    Gas Gauging,"State","Max Avg I Last Run","-114","mA"
    Gas Gauging,"State","Max Avg P Last Run","-150","cW"
    Gas Gauging,"Turbo Cfg","Min Turbo Power","0","cW"
    Gas Gauging,"Turbo Cfg","Ten Second Max C Rate","-2.0","C"
    Gas Gauging,"Turbo Cfg","Ten Millisecond Max C Rate","-4.0","C"
    Gas Gauging,"Turbo Cfg","High Frequency Resistance","0","mOhm"
    Gas Gauging,"Turbo Cfg","Reserve Energy %","0","%"
    Gas Gauging,"Turbo Cfg","Turbo Adjustment Factor","1.00","-"
    Gas Gauging,"IT Cfg","Load Select","7","-"
    Gas Gauging,"IT Cfg","Fast Scale Load Select","3","-"
    Gas Gauging,"IT Cfg","Load Mode","0","-"
    Gas Gauging,"IT Cfg","User Rate-mA","0","mA"
    Gas Gauging,"IT Cfg","User Rate-cW","0","cW"
    Gas Gauging,"IT Cfg","Reserve Cap-mAh","0","mAh"
    Gas Gauging,"IT Cfg","Reserve Cap-cWh","0","cWh"
    Gas Gauging,"IT Cfg","Predict Ambient Time","2000","s"
    Gas Gauging,"IT Cfg","Design Resistance","104","2^-10ohm"
    Gas Gauging,"IT Cfg","Pack Resistance","0","2^-10ohm"
    Gas Gauging,"IT Cfg","System Resistance","0","2^-10ohm"
    Gas Gauging,"IT Cfg","Ra Filter","80.0","%"
    Gas Gauging,"IT Cfg","Ra Max Delta","15","%"
    Gas Gauging,"IT Cfg","Reference Grid","4","-"
    Gas Gauging,"IT Cfg","Resistance Parameter Filter","65142","-"
    Gas Gauging,"IT Cfg","Near EDV Ra Param Filter","59220","-"
    Gas Gauging,"IT Cfg","Cell 1 Interconnect Resistance","0","2^-10ohm"
    Gas Gauging,"IT Cfg","Cell 2 Interconnect Resistance","0","2^-10ohm"
    Gas Gauging,"IT Cfg","Cell 3 Interconnect Resistance","0","2^-10ohm"
    Gas Gauging,"IT Cfg","Cell 4 Interconnect Resistance","0","2^-10ohm"
    Gas Gauging,"IT Cfg","Max Current Change %","10","%"
    Gas Gauging,"IT Cfg","Resistance Update Voltage","50","mV"
    Gas Gauging,"IT Cfg","Qmax Delta","5","%"
    Gas Gauging,"IT Cfg","Qmax Upper Bound","130","%"
    Gas Gauging,"IT Cfg","Term Voltage","12000","mV"
    Gas Gauging,"IT Cfg","Term V Hold Time","1","s"
    Gas Gauging,"IT Cfg","Term Voltage Delta","300","mV"
    Gas Gauging,"IT Cfg","Term Min Cell V","2800","mV"
    Gas Gauging,"IT Cfg","Max Simulation Iterations","30","-"
    Gas Gauging,"IT Cfg","Fast Scale Start SOC","10","%"
    Gas Gauging,"IT Cfg","Min Delta Voltage","0","mV"
    Gas Gauging,"IT Cfg","Max Delta Voltage","200","mV"
    Gas Gauging,"IT Cfg","DeltaV Max Voltage Delta","10","mV"
    Gas Gauging,"Smoothing","Smooth Relax Time","1000","s"
    Gas Gauging,"Smoothing","Term Smooth Start Cell V Delta","150","mV"
    Gas Gauging,"Smoothing","Term Smooth Final Cell V Delta","100","mV"
    Gas Gauging,"Smoothing","Term Smooth Time","20","s"
    Gas Gauging,"Condition Flag","Max Error Limit","100","%"
    Gas Gauging,"Max Error","Time Cycle Equivalent","24","h"
    Gas Gauging,"Max Error","Cycle Delta","0.05","%"
    Gas Gauging,"SoH","SoH Load Rate","5.0","Hr rate"
    Ra Table,"R_a0","Cell0 R_a flag","0055","-"
    Ra Table,"R_a0","Cell0 R_a 0","93","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 1","100","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 2","112","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 3","119","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 4","106","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 5","122","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 6","125","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 7","122","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 8","127","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 9","135","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 10","143","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 11","146","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 12","178","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 13","247","2^-10ohm"
    Ra Table,"R_a0","Cell0 R_a 14","60","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a flag","0000","-"
    Ra Table,"R_a1","Cell1 R_a 0","101","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 1","109","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 2","122","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 3","130","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 4","115","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 5","116","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 6","119","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 7","116","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 8","120","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 9","127","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 10","135","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 11","138","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 12","169","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 13","234","2^-10ohm"
    Ra Table,"R_a1","Cell1 R_a 14","57","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a flag","0000","-"
    Ra Table,"R_a2","Cell2 R_a 0","101","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 1","109","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 2","122","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 3","130","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 4","115","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 5","116","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 6","119","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 7","116","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 8","120","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 9","127","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 10","135","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 11","138","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 12","169","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 13","234","2^-10ohm"
    Ra Table,"R_a2","Cell2 R_a 14","57","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a flag","0055","-"
    Ra Table,"R_a3","Cell3 R_a 0","92","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 1","99","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 2","111","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 3","118","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 4","105","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 5","122","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 6","124","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 7","122","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 8","125","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 9","134","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 10","142","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 11","145","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 12","177","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 13","245","2^-10ohm"
    Ra Table,"R_a3","Cell3 R_a 14","60","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a flag","0000","-"
    Ra Table,"R_a0x","xCell0 R_a 0","93","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 1","100","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 2","112","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 3","119","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 4","106","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 5","106","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 6","109","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 7","106","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 8","110","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 9","117","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 10","124","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 11","127","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 12","155","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 13","215","2^-10ohm"
    Ra Table,"R_a0x","xCell0 R_a 14","52","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a flag","0055","-"
    Ra Table,"R_a1x","xCell1 R_a 0","91","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 1","98","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 2","110","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 3","117","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 4","104","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 5","105","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 6","107","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 7","105","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 8","108","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 9","115","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 10","122","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 11","124","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 12","152","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 13","211","2^-10ohm"
    Ra Table,"R_a1x","xCell1 R_a 14","51","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a flag","0055","-"
    Ra Table,"R_a2x","xCell2 R_a 0","90","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 1","97","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 2","109","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 3","116","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 4","103","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 5","104","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 6","106","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 7","104","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 8","107","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 9","113","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 10","121","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 11","123","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 12","151","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 13","209","2^-10ohm"
    Ra Table,"R_a2x","xCell2 R_a 14","51","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a flag","0000","-"
    Ra Table,"R_a3x","xCell3 R_a 0","92","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 1","99","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 2","111","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 3","118","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 4","105","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 5","106","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 6","108","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 7","106","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 8","109","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 9","116","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 10","123","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 11","126","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 12","154","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 13","213","2^-10ohm"
    Ra Table,"R_a3x","xCell3 R_a 14","52","2^-10ohm"
    Thank you again.
    If possible, can you please send the .gg file in an excel format? This will allow us to expedite the process of checking through the settings.
    Regarding the FCC, can you please tell us how the chemID was chosen for the device? If the GPCCHEM tool was used, can you please tell us the error % of the chosen chemID?
    Also, can you please confirm that a learning cycle has been completed on the device?
    Anthony Baldino
  • Dear Anthony, thanks for the support you are providing me.
    Below I report the configuration file in excel format.
    The chemistry ID is 0456; it was the default ID that was provided to us by a previous supplier, and for the moment I have not changed it, but tell me eventually what you think.
    The battery model we are using is JGCFR26650-4000mAh-3.2V.
    My email is m.giorgi@netsens.it: if you have the possibility answer me on this channel, so that I can provide all the information and the necessary files.
    Thank you very much.
    * Texas Instruments Data Flash File
    * File created Mon Mar 04 11:30:50 2024
    * Device Number 4500
    * Firmware Version 2.08
    * Build Number 50
    * Order Number 0
    * bqz Device Number 4500
    * bqz Firmware Version 2.08
    * bqz Build Number 50
    * Field Order: Class name  Subclass name  Parameter name  Parameter Value  Display Units
    Calibration Voltage Cell Gain 12101 -
    Calibration Voltage Pack Gain 49669 -
    Calibration Voltage BAT Gain 48936 -
    Calibration Current CC Gain 1.036 mOhm
    Calibration Current Capacity Gain 1.036 mOhm
    Calibration Current Offset CC Offset 0 -
    Calibration Current Offset Coulomb Counter Offset Samples 64 -
    Calibration Current Offset Board Offset 0 -
    Calibration Current Offset CC Auto Config 3 hex
    Calibration Current Offset CC Auto Offset 0 -
    Calibration Temperature Internal Temp Offset 0.0 °C
    Calibration Temperature External1 Temp Offset 0.0 °C
    Calibration Temperature External2 Temp Offset 0.0 °C
    Calibration Temperature External3 Temp Offset 0.0 °C
    Calibration Temperature External4 Temp Offset 0.0 °C
    Calibration Internal Temp Model Int Gain -12143 -
    Calibration Internal Temp Model Int base offset 6232 -
    Calibration Internal Temp Model Int Minimum AD 0 -
    Calibration Internal Temp Model Int Maximum Temp 6232 0.1°K
    Calibration Cell Temperature Model Coeff a1 -11130 -
    Calibration Cell Temperature Model Coeff a2 19142 -
    Calibration Cell Temperature Model Coeff a3 -19262 -
    Calibration Cell Temperature Model Coeff a4 28203 -
    Calibration Cell Temperature Model Coeff a5 892 -
    Calibration Cell Temperature Model Coeff b1 328 -
    Calibration Cell Temperature Model Coeff b2 -605 -
    Calibration Cell Temperature Model Coeff b3 -2443 -
    Calibration Cell Temperature Model Coeff b4 4696 -
    Calibration Cell Temperature Model Rc0 11703 -
    Calibration Cell Temperature Model Adc0 11703 -
    Calibration Cell Temperature Model Rpad 0 -
    Calibration Cell Temperature Model Rint 0 -
    Calibration Fet Temperature Model Coeff a1 -11130 -
    Calibration Fet Temperature Model Coeff a2 19142 -
    Calibration Fet Temperature Model Coeff a3 -19262 -
    Calibration Fet Temperature Model Coeff a4 28203 -
    Calibration Fet Temperature Model Coeff a5 892 -
    Calibration Fet Temperature Model Coeff b1 328 -
    Calibration Fet Temperature Model Coeff b2 -605 -
    Calibration Fet Temperature Model Coeff b3 -2443 -
    Calibration Fet Temperature Model Coeff b4 4696 -
    Calibration Fet Temperature Model Rc0 11703 -
    Calibration Fet Temperature Model Adc0 11703 -
    Calibration Fet Temperature Model Rpad 0 -
    Calibration Fet Temperature Model Rint 0 -
    Calibration Current Deadband Deadband 3 mA
    Calibration Current Deadband Coulomb Counter Deadband 9 116nV
    Settings Configuration Charging Configuration 0 hex
    Settings Configuration FET Options 20 hex
    Settings Configuration Sbs Gauging Configuration 4 hex
    Settings Configuration Sbs Configuration 20 hex
    Settings Configuration Auth Config 0 hex
    Settings Configuration Power Config 0 hex
    Settings Configuration IO Config 0 hex
    Settings Configuration LED Configuration 00d0 hex
    Settings Configuration Temperature Enable 1e hex
    Settings Configuration Temperature Mode 4 hex
    Settings Configuration DA Configuration 13 hex
    Settings Configuration SOC Flag Config A 0c8c hex
    Settings Configuration SOC Flag Config B 8c hex
    Settings Configuration Balancing Configuration 1 hex
    Settings Configuration IT Gauging Configuration d1fe hex
    Settings Configuration IT Gauging Ext 001a hex
    Settings Fuse PF Fuse A 0 hex
    Settings Fuse PF Fuse B 0 hex
    Settings Fuse PF Fuse C 0 hex
    Settings Fuse PF Fuse D 0 hex
    Settings Fuse Min Blow Fuse Voltage 3500 mV
    Settings Fuse Fuse Blow Timeout 30 s
    Settings BTP Init Discharge Set 150 mAh
    Settings BTP Init Charge Set 175 mAh
    Settings SMBus Address 16 -
    Settings SMBus Address Check ea -
    Settings Protection Protection Configuration 0 hex
    Settings Protection Enabled Protections A ff hex
    Settings Protection Enabled Protections B 7f hex
    Settings Protection Enabled Protections C d5 hex
    Settings Protection Enabled Protections D 0f hex
    Settings Permanent Failure Enabled PF A 0 hex
    Settings Permanent Failure Enabled PF B 0 hex
    Settings Permanent Failure Enabled PF C 0 hex
    Settings Permanent Failure Enabled PF D 0 hex
    Settings AFE AFE Protection Control 70 hex
    Settings AFE ZVCHG Exit Threshold 2200 mV
    Settings Manufacturing Mfg Status init 02b8 hex
    Advanced Charge Algorithm Temperature Ranges T1 Temp 0.0 °C
    Advanced Charge Algorithm Temperature Ranges T2 Temp 12.0 °C
    Advanced Charge Algorithm Temperature Ranges T5 Temp 20.0 °C
    Advanced Charge Algorithm Temperature Ranges T6 Temp 25.0 °C
    Advanced Charge Algorithm Temperature Ranges T3 Temp 30.0 °C
    Advanced Charge Algorithm Temperature Ranges T4 Temp 55.0 °C
    Advanced Charge Algorithm Temperature Ranges Hysteresis Temp 1.0 °C
    Advanced Charge Algorithm Low Temp Charging Voltage 3600 mV
    Advanced Charge Algorithm Low Temp Charging Current Low 132 mA
    Advanced Charge Algorithm Low Temp Charging Current Med 352 mA
    Advanced Charge Algorithm Low Temp Charging Current High 264 mA
    Advanced Charge Algorithm Standard Temp Low Charging Voltage 3600 mV
    Advanced Charge Algorithm Standard Temp Low Charging Current Low 1980 mA
    Advanced Charge Algorithm Standard Temp Low Charging Current Med 4004 mA
    Advanced Charge Algorithm Standard Temp Low Charging Current High 2992 mA
    Advanced Charge Algorithm Standard Temp High Charging Voltage 3600 mV
    Advanced Charge Algorithm Standard Temp High Charging Current Low 1980 mA
    Advanced Charge Algorithm Standard Temp High Charging Current Med 4004 mA
    Advanced Charge Algorithm Standard Temp High Charging Current High 2992 mA
    Advanced Charge Algorithm High Temp Charging Voltage 3600 mV
    Advanced Charge Algorithm High Temp Charging Current Low 1012 mA
    Advanced Charge Algorithm High Temp Charging Current Med 1980 mA
    Advanced Charge Algorithm High Temp Charging Current High 1496 mA
    Advanced Charge Algorithm Rec Temp Charging Voltage 3600 mV
    Advanced Charge Algorithm Rec Temp Charging Current Low 2508 mA
    Advanced Charge Algorithm Rec Temp Charging Current Med 4488 mA
    Advanced Charge Algorithm Rec Temp Charging Current High 3520 mA
    Advanced Charge Algorithm Pre-Charging Current 45 mA
    Advanced Charge Algorithm Maintenance Charging Current 44 mA
    Advanced Charge Algorithm Voltage Range Precharge Start Voltage 2000 mV
    Advanced Charge Algorithm Voltage Range Charging Voltage Low 2500 mV
    Advanced Charge Algorithm Voltage Range Charging Voltage Med 3200 mV
    Advanced Charge Algorithm Voltage Range Charging Voltage High 3600 mV
    Advanced Charge Algorithm Voltage Range Charging Voltage Hysteresis 0 mV
    Advanced Charge Algorithm SoC Range Charging SoC Med 50 %
    Advanced Charge Algorithm SoC Range Charging SoC High 75 %
    Advanced Charge Algorithm SoC Range Charging SoC Hysteresis 1 %
    Advanced Charge Algorithm Degrade Mode 1 Cycle Threshold 50 -
    Advanced Charge Algorithm Degrade Mode 1 SOH Threshold 95 %
    Advanced Charge Algorithm Degrade Mode 1 Voltage Degradation 10 mV
    Advanced Charge Algorithm Degrade Mode 1 Current Degradation 10 %
    Advanced Charge Algorithm Degrade Mode 2 Cycle Threshold 150 -
    Advanced Charge Algorithm Degrade Mode 2 SOH Threshold 80 %
    Advanced Charge Algorithm Degrade Mode 2 Voltage Degradation 40 mV
    Advanced Charge Algorithm Degrade Mode 2 Current Degradation 20 %
    Advanced Charge Algorithm Degrade Mode 3 Cycle Threshold 350 -
    Advanced Charge Algorithm Degrade Mode 3 SOH Threshold 60 %
    Advanced Charge Algorithm Degrade Mode 3 Voltage Degradation 70 mV
    Advanced Charge Algorithm Degrade Mode 3 Current Degradation 40 %
    Advanced Charge Algorithm CS Degrade Temperature Threshold 50.0 °C
    Advanced Charge Algorithm CS Degrade Voltage Threshold 3400 mV
    Advanced Charge Algorithm CS Degrade Time Interval 300 s
    Advanced Charge Algorithm CS Degrade Delta Voltage 25 mV
    Advanced Charge Algorithm CS Degrade Min CV 3000 mV
    Advanced Charge Algorithm Termination Config Charge Term Taper Current 100 mA
    Advanced Charge Algorithm Termination Config Charge Term Voltage 100 mV
    Advanced Charge Algorithm Charging Rate of Change Current Rate 1 steps
    Advanced Charge Algorithm Charging Rate of Change Voltage Rate 1 steps
    Advanced Charge Algorithm Charge Loss Compensation CCC Current Threshold 3520 mA
    Advanced Charge Algorithm Charge Loss Compensation CCC Voltage Threshold 3600 mV
    Advanced Charge Algorithm IR Correction Averaging Interval 12 s
    Advanced Charge Algorithm Cell Balancing Config Bal Time/mAh Cell 1 367 s/mAh
    Advanced Charge Algorithm Cell Balancing Config Bal Time/mAh Cell 2-4 514 s/mAh
    Advanced Charge Algorithm Cell Balancing Config Min Start Balance Delta 3 mV
    Advanced Charge Algorithm Cell Balancing Config Relax Balance Interval 18000 s
    Advanced Charge Algorithm Cell Balancing Config Min Rsoc for Balancing 80 %
    Advanced Charge Algorithm Cell Balancing Config Start Rsoc for Bal in Sleep 95 %
    Advanced Charge Algorithm Cell Balancing Config End Rsoc for Bal in Sleep 60 %
    Advanced Charge Algorithm Cell Balancing Config Start Time for Bal in Sleep 100 hrs
    Power Power Valid Update Voltage 3500 mV
    Power Shutdown Shutdown Voltage 1750 mV
    Power Shutdown Shutdown Time 10 s
    Power Shutdown PF Shutdown Voltage 1750 mV
    Power Shutdown PF Shutdown Time 10 s
    Power Shutdown PS Shutdown Voltage 2500 mV
    Power Shutdown PS NoLoadResCap Threshold 0 mAh
    Power Shutdown Charger Present Threshold 2700 mV
    Power Shutdown Valid Wake up Comm Check Delay 100 s
    Power Sleep Sleep Current 10 mA
    Power Sleep Bus Timeout 5 s
    Power Sleep Voltage Time 5 s
    Power Sleep Current Time 20 s
    Power Sleep Wake Comparator 0 hex
    Power Ship FET Off Time 10 s
    Power Ship Delay 20 s
    Power Ship Auto Ship Time 1440 min
    Power Power Off Timeout 30 min
    Power Manual FET Control MFC Delay 60 0.25s
    Power IATA IATA Config 3 -
    Power IATA IATA Delay Time 10 s
    Power IATA IATA RSOC Threshold 30 %
    Power IATA IATA DeltaV Threshold 50 mV
    Power IATA IATA Delta RSOC 3 %
    Power IATA IATA Wake AbsRsoc 10 %
    Power IATA IATA Min Temperature 10.0 °C
    Power IATA IATA Max Temperature 40.0 °C
    Power IATA IATA Min Voltage 3000 mV
    Power IATA IATA Max Voltage 3600 mV
    Power IATA STORE IATA RM mAh 0 mAh
    Power IATA STORE IATA RM cWh 0 cWh
    Power IATA STORE IATA FCC mAh 0 mAh
    Power IATA STORE IATA FCC cWh 0 cWh
    Power IATA STORE IATA Flag 0 -
    Power Unintended Wakeup Delay 2 s
    Power Unintended Wakeup Count 3 -
    LED Support LED Config LED Flash Period 512 488us
    LED Support LED Config LED Blink Period 1024 488us
    LED Support LED Config LED Delay 100 488us
    LED Support LED Config LED Hold Time 4 s
    LED Support LED Config LED FC Time 60 mins
    LED Support LED Config CHG Flash Alarm 10 %
    LED Support LED Config CHG Thresh 1 0 %
    LED Support LED Config CHG Thresh 2 20 %
    LED Support LED Config CHG Thresh 3 40 %
    LED Support LED Config CHG Thresh 4 60 %
    LED Support LED Config CHG Thresh 5 80 %
    LED Support LED Config DSG Flash Alarm 10 %
    LED Support LED Config DSG Thresh 1 0 %
    LED Support LED Config DSG Thresh 2 20 %
    LED Support LED Config DSG Thresh 3 40 %
    LED Support LED Config DSG Thresh 4 60 %
    LED Support LED Config DSG Thresh 5 80 %
    System Data Manufacturer Data Manufacturer Info A Length 32 -
    System Data Manufacturer Data Manufacturer Info Block A01 61 Hex
    System Data Manufacturer Data Manufacturer Info Block A02 62 Hex
    System Data Manufacturer Data Manufacturer Info Block A03 63 Hex
    System Data Manufacturer Data Manufacturer Info Block A04 64 Hex
    System Data Manufacturer Data Manufacturer Info Block A05 65 Hex
    System Data Manufacturer Data Manufacturer Info Block A06 66 Hex
    System Data Manufacturer Data Manufacturer Info Block A07 67 Hex
    System Data Manufacturer Data Manufacturer Info Block A08 68 Hex
    System Data Manufacturer Data Manufacturer Info Block A09 69 Hex
    System Data Manufacturer Data Manufacturer Info Block A10 6a Hex
    System Data Manufacturer Data Manufacturer Info Block A11 6b Hex
    System Data Manufacturer Data Manufacturer Info Block A12 6c Hex
    System Data Manufacturer Data Manufacturer Info Block A13 6d Hex
    System Data Manufacturer Data Manufacturer Info Block A14 6e Hex
    System Data Manufacturer Data Manufacturer Info Block A15 6f Hex
    System Data Manufacturer Data Manufacturer Info Block A16 70 Hex
    System Data Manufacturer Data Manufacturer Info Block A17 71 Hex
    System Data Manufacturer Data Manufacturer Info Block A18 72 Hex
    System Data Manufacturer Data Manufacturer Info Block A19 73 Hex
    System Data Manufacturer Data Manufacturer Info Block A20 74 Hex
    System Data Manufacturer Data Manufacturer Info Block A21 75 Hex
    System Data Manufacturer Data Manufacturer Info Block A22 76 Hex
    System Data Manufacturer Data Manufacturer Info Block A23 77 Hex
    System Data Manufacturer Data Manufacturer Info Block A24 7a Hex
    System Data Manufacturer Data Manufacturer Info Block A25 78 Hex
    System Data Manufacturer Data Manufacturer Info Block A26 79 Hex
    System Data Manufacturer Data Manufacturer Info Block A27 30 Hex
    System Data Manufacturer Data Manufacturer Info Block A28 31 Hex
    System Data Manufacturer Data Manufacturer Info Block A29 32 Hex
    System Data Manufacturer Data Manufacturer Info Block A30 33 Hex
    System Data Manufacturer Data Manufacturer Info Block A31 34 Hex
    System Data Manufacturer Data Manufacturer Info Block A32 35 Hex
    System Data Manufacturer Info B Manufacturer Info Block B01 1 Hex
    System Data Manufacturer Info B Manufacturer Info Block B02 23 Hex
    System Data Manufacturer Info B Manufacturer Info Block B03 45 Hex
    System Data Manufacturer Info B Manufacturer Info Block B04 67 Hex
    System Data Integrity Static DF Signature 0 hex
    System Data Integrity Static Chem DF Signature 1bde hex
    System Data Integrity All DF Signature 0 hex
    SBS Configuration Data Remaining AH Cap. Alarm 0 mAh
    SBS Configuration Data Remaining WH Cap. Alarm 0 cWh
    SBS Configuration Data Remaining Time Alarm 10 min
    SBS Configuration Data Initial Battery Mode 81 hex
    SBS Configuration Data Specification Information 31 hex
    SBS Configuration Data Manufacture Date 07/10/2021 date
    SBS Configuration Data Serial Number 1 hex
    SBS Configuration Data Manufacturer Name Netsens -
    SBS Configuration Data Device Name bq40z50-R2 -
    SBS Configuration Data Device Chemistry LIFE -
    Lifetimes Voltage Cell 1 Max Voltage 4175 mV
    Lifetimes Voltage Cell 2 Max Voltage 3866 mV
    Lifetimes Voltage Cell 3 Max Voltage 4363 mV
    Lifetimes Voltage Cell 4 Max Voltage 3663 mV
    Lifetimes Voltage Cell 1 Min Voltage 3142 mV
    Lifetimes Voltage Cell 2 Min Voltage 3045 mV
    Lifetimes Voltage Cell 3 Min Voltage 2959 mV
    Lifetimes Voltage Cell 4 Min Voltage 0 mV
    Lifetimes Voltage Max Delta Cell Voltage 3788 mV
    Lifetimes Current Max Charge Current 2031 mA
    Lifetimes Current Max Discharge Current -1859 mA
    Lifetimes Current Max Avg Dsg Current -1325 mA
    Lifetimes Current Max Avg Dsg Power -1699 cW
    Lifetimes Temperature Max Temp Cell 67 °C
    Lifetimes Temperature Min Temp Cell 13 °C
    Lifetimes Temperature Max Delta Cell Temp 44 °C
    Lifetimes Temperature Max Temp Int Sensor 44 °C
    Lifetimes Temperature Min Temp Int Sensor 13 °C
    Lifetimes Temperature Max Temp Fet 42 °C
    Lifetimes Safety Events No Of COV Events 20 events
    Lifetimes Safety Events Last COV Event 1 cycles
    Lifetimes Safety Events No Of CUV Events 2 events
    Lifetimes Safety Events Last CUV Event 0 cycles
    Lifetimes Safety Events No Of OCD1 Events 0 events
    Lifetimes Safety Events Last OCD1 Event 0 cycles
    Lifetimes Safety Events No Of OCD2 Events 0 events
    Lifetimes Safety Events Last OCD2 Event 0 cycles
    Lifetimes Safety Events No Of OCC1 Events 0 events
    Lifetimes Safety Events Last OCC1 Event 0 cycles
    Lifetimes Safety Events No Of OCC2 Events 0 events
    Lifetimes Safety Events Last OCC2 Event 0 cycles
    Lifetimes Safety Events No Of AOLD Events 1 events
    Lifetimes Safety Events Last AOLD Event 0 cycles
    Lifetimes Safety Events No Of ASCD Events 0 events
    Lifetimes Safety Events Last ASCD Event 0 cycles
    Lifetimes Safety Events No Of ASCC Events 0 events
    Lifetimes Safety Events Last ASCC Event 0 cycles
    Lifetimes Safety Events No Of OTC Events 0 events
    Lifetimes Safety Events Last OTC Event 0 cycles
    Lifetimes Safety Events No Of OTD Events 1 events
    Lifetimes Safety Events Last OTD Event 0 cycles
    Lifetimes Safety Events No Of OTF Events 0 events
    Lifetimes Safety Events Last OTF Event 0 cycles
    Lifetimes Charging Events No Valid Charge Term 2 events
    Lifetimes Charging Events Last Valid Charge Term 1 cycles
    Lifetimes Gauging Events No Of Qmax Updates 1 events
    Lifetimes Gauging Events Last Qmax Update 0 cycles
    Lifetimes Gauging Events No Of Ra Updates 2 events
    Lifetimes Gauging Events Last Ra Update 1 cycles
    Lifetimes Gauging Events No Of Ra Disable 6 events
    Lifetimes Gauging Events Last Ra Disable 1 cycles
    Lifetimes Power Events No Of Shutdowns 2 events
    Lifetimes Cell Balancing Cb Time Cell 1 4 h
    Lifetimes Cell Balancing Cb Time Cell 2 10 h
    Lifetimes Cell Balancing Cb Time Cell 3 0 h
    Lifetimes Cell Balancing Cb Time Cell 4 2 h
    Lifetimes Time Total Fw Runtime 6768 h
    Lifetimes Time Time Spent In UT 0 h
    Lifetimes Time Time Spent In LT 0 h
    Lifetimes Time Time Spent In STL 2828 h
    Lifetimes Time Time Spent In RT 980 h
    Lifetimes Time Time Spent In STH 2572 h
    Lifetimes Time Time Spent In HT 382 h
    Lifetimes Time Time Spent In OT 0 h
    Protections CUV Threshold 2800 mV
    Protections CUV Delay 2 s
    Protections CUV Recovery 3000 mV
    Protections CUVC Threshold 2800 mV
    Protections CUVC Delay 2 s
    Protections CUVC Recovery 3000 mV
    Protections COV Threshold Low Temp 3750 mV
    Protections COV Threshold Standard Temp Low 3750 mV
    Protections COV Threshold Standard Temp High 3750 mV
    Protections COV Threshold High Temp 3750 mV
    Protections COV Threshold Rec Temp 3750 mV
    Protections COV Delay 60 s
    Protections COV Recovery Low Temp 3650 mV
    Protections COV Recovery Standard Temp Low 3650 mV
    Protections COV Recovery Standard Temp High 3650 mV
    Protections COV Recovery High Temp 3650 mV
    Protections COV Recovery Rec Temp 3650 mV
    Protections COV Latch Limit 0 -
    Protections COV Counter Dec Delay 10 s
    Protections COV Reset 15 s
    Protections OCC1 Threshold 3650 mA
    Protections OCC1 Delay 30 s
    Protections OCC2 Threshold 5000 mA
    Protections OCC2 Delay 3 s
    Protections OCC Recovery Threshold -200 mA
    Protections OCC Recovery Delay 5 s
    Protections OCD1 Threshold -6400 mA
    Protections OCD1 Delay 6 s
    Protections OCD2 Threshold -8000 mA
    Protections OCD2 Delay 3 s
    Protections OCD Recovery Threshold 200 mA
    Protections OCD Recovery Delay 5 s
    Protections OCD Latch Limit 0 -
    Protections OCD Counter Dec Delay 10 s
    Protections OCD Reset 15 s
    Protections AOLD Latch Limit 0 -
    Protections AOLD Counter Dec Delay 10 s
    Protections AOLD Recovery 5 s
    Protections AOLD Reset 15 s
    Protections AOLD Threshold f4 hex
    Protections ASCC Latch Limit 0 -
    Protections ASCC Counter Dec Delay 10 s
    Protections ASCC Recovery 5 s
    Protections ASCC Reset 15 s
    Protections ASCC Threshold 77 hex
    Protections ASCD Latch Limit 0 -
    Protections ASCD Counter Dec Delay 10 s
    Protections ASCD Recovery 5 s
    Protections ASCD Reset 15 s
    Protections ASCD Threshold 1 77 hex
    Protections ASCD Threshold 2 e7 hex
    Protections OTC Threshold 55.0 °C
    Protections OTC Delay 2 s
    Protections OTC Recovery 50.0 °C
    Protections OTD Threshold 60.0 °C
    Protections OTD Delay 2 s
    Protections OTD Recovery 55.0 °C
    Protections OTF Threshold 80.0 °C
    Protections OTF Delay 2 s
    Protections OTF Recovery 65.0 °C
    Protections UTC Threshold 0.0 °C
    Protections UTC Delay 2 s
    Protections UTC Recovery 5.0 °C
    Protections UTD Threshold 0.0 °C
    Protections UTD Delay 2 s
    Protections UTD Recovery 5.0 °C
    Protections HWD Delay 10 s
    Protections PTO Charge Threshold 2000 mA
    Protections PTO Suspend Threshold 1800 mA
    Protections PTO Delay 1800 s
    Protections PTO Reset 2 mAh
    Protections CTO Charge Threshold 2500 mA
    Protections CTO Suspend Threshold 2000 mA
    Protections CTO Delay 54000 s
    Protections CTO Reset 2 mAh
    Protections OC Threshold 4500 mAh
    Protections OC Recovery 2 mAh
    Protections OC RSOC Recovery 90 %
    Protections CHGV Threshold 500 mV
    Protections CHGV Delay 30 s
    Protections CHGV Recovery -500 mV
    Protections CHGC Threshold 1500 mA
    Protections CHGC Delay 2 s
    Protections CHGC Recovery Threshold 100 mA
    Protections CHGC Recovery Delay 2 s
    Protections PCHGC Threshold 100 mA
    Protections PCHGC Delay 30 s
    Protections PCHGC Recovery Threshold 10 mA
    Protections PCHGC Recovery Delay 2 s
    Permanent Fail SUV Threshold 2200 mV
    Permanent Fail SUV Delay 5 s
    Permanent Fail SOV Threshold 3700 mV
    Permanent Fail SOV Delay 5 s
    Permanent Fail SOCC Threshold 10000 mA
    Permanent Fail SOCC Delay 5 s
    Permanent Fail SOCD Threshold -10000 mA
    Permanent Fail SOCD Delay 5 s
    Permanent Fail SOT Threshold 65.0 °C
    Permanent Fail SOT Delay 5 s
    Permanent Fail SOTF Threshold 100.0 °C
    Permanent Fail SOTF Delay 5 s
    Permanent Fail Open Thermistor Threshold -50.0 °C
    Permanent Fail Open Thermistor Delay 5 s
    Permanent Fail Open Thermistor Fet Delta 20.0 °C
    Permanent Fail Open Thermistor Cell Delta 20.0 °C
    Permanent Fail QIM Delta Threshold 15.0 %
    Permanent Fail QIM Delay 2 updates
    Permanent Fail CB Max Threshold 240 h
    Permanent Fail CB Delta Threshold 40 h
    Permanent Fail CB Delay 2 cycles
    Permanent Fail VIMR Check Voltage 3200 mV
    Permanent Fail VIMR Check Current 10 mA
    Permanent Fail VIMR Delta Threshold 500 mV
    Permanent Fail VIMR Delta Delay 5 s
    Permanent Fail VIMR Duration 100 s
    Permanent Fail VIMA Check Voltage 3500 mV
    Permanent Fail VIMA Check Current 50 mA
    Permanent Fail VIMA Delta Threshold 200 mV
    Permanent Fail VIMA Delay 5 s
    Permanent Fail IMP Delta Threshold 300 %
    Permanent Fail IMP Max Threshold 400 %
    Permanent Fail IMP Ra Update Counts 2 Counts
    Permanent Fail CD Threshold 0 mAh
    Permanent Fail CD Delay 2 cycles
    Permanent Fail CFET OFF Threshold 5 mA
    Permanent Fail CFET OFF Delay 5 s
    Permanent Fail DFET OFF Threshold -5 mA
    Permanent Fail DFET OFF Delay 5 s
    Permanent Fail FUSE Threshold 5 mA
    Permanent Fail FUSE Delay 5 s
    Permanent Fail AFER Threshold 100 -
    Permanent Fail AFER Delay Period 2 s
    Permanent Fail AFER Compare Period 5 s
    Permanent Fail AFEC Threshold 100 -
    Permanent Fail AFEC Delay Period 5 s
    Permanent Fail 2LVL Delay 5 s
    PF Status Device Status Data Safety Alert A 0 hex
    PF Status Device Status Data Safety Status A 0 hex
    PF Status Device Status Data Safety Alert B 0 hex
    PF Status Device Status Data Safety Status B 0 hex
    PF Status Device Status Data Safety Alert C 0 hex
    PF Status Device Status Data Safety Status C 0 hex
    PF Status Device Status Data Safety Alert D 0 hex
    PF Status Device Status Data Safety Status D 0 hex
    PF Status Device Status Data PF Alert A 0 hex
    PF Status Device Status Data PF Status A 0 hex
    PF Status Device Status Data PF Alert B 0 hex
    PF Status Device Status Data PF Status B 0 hex
    PF Status Device Status Data PF Alert C 0 hex
    PF Status Device Status Data PF Status C 0 hex
    PF Status Device Status Data PF Alert D 0 hex
    PF Status Device Status Data PF Status D 0 hex
    PF Status Device Status Data Fuse Flag 0 hex
    PF Status Device Status Data Operation Status A 0 hex
    PF Status Device Status Data Operation Status B 0 hex
    PF Status Device Status Data Temp Range 0 hex
    PF Status Device Status Data Charging Status A 0 hex
    PF Status Device Status Data Charging Status B 0 hex
    PF Status Device Status Data Gauging Status 0 hex
    PF Status Device Status Data IT Status 0 hex
    PF Status Device Voltage Data Cell 1 Voltage 3200 mV
    PF Status Device Voltage Data Cell 2 Voltage 3200 mV
    PF Status Device Voltage Data Cell 3 Voltage 3200 mV
    PF Status Device Voltage Data Cell 4 Voltage 3200 mV
    PF Status Device Voltage Data Battery Direct Voltage 0 mV
    PF Status Device Voltage Data Pack Voltage 12800 mV
    PF Status Device Current Data Current 6400 mA
    PF Status Device Temperature Data Internal Temperature -273.2 °C
    PF Status Device Temperature Data External 1 Temperature -273.2 °C
    PF Status Device Temperature Data External 2 Temperature -273.2 °C
    PF Status Device Temperature Data External 3 Temperature -273.2 °C
    PF Status Device Temperature Data External 4 Temperature -273.2 °C
    PF Status Device Gauging Data Cell 1 Dod0 0 -
    PF Status Device Gauging Data Cell 2 Dod0 0 -
    PF Status Device Gauging Data Cell 3 Dod0 0 -
    PF Status Device Gauging Data Cell 4 Dod0 0 -
    PF Status Device Gauging Data Passed Charge 0 mAh
    PF Status AFE Regs AFE Interrupt Status 0 hex
    PF Status AFE Regs AFE FET Status 0 hex
    PF Status AFE Regs AFE RXIN 0 hex
    PF Status AFE Regs AFE Latch Status 0 hex
    PF Status AFE Regs AFE Interrupt Enable 0 hex
    PF Status AFE Regs AFE FET Control 0 hex
    PF Status AFE Regs AFE RXIEN 0 hex
    PF Status AFE Regs AFE RLOUT 0 hex
    PF Status AFE Regs AFE RHOUT 0 hex
    PF Status AFE Regs AFE RHINT 0 hex
    PF Status AFE Regs AFE Cell Balance 0 hex
    PF Status AFE Regs AFE AD/CC Control 0 hex
    PF Status AFE Regs AFE ADC Mux 0 hex
    PF Status AFE Regs AFE LED Output 0 hex
    PF Status AFE Regs AFE State Control 0 hex
    PF Status AFE Regs AFE LED/Wake Control 0 hex
    PF Status AFE Regs AFE Protection Control 0 hex
    PF Status AFE Regs AFE OCD 0 hex
    PF Status AFE Regs AFE SCC 0 hex
    PF Status AFE Regs AFE SCD1 0 hex
    PF Status AFE Regs AFE SCD2 0 hex
    Black Box Safety Status 1st Status Status A 0 hex
    Black Box Safety Status 1st Status Status B 0 hex
    Black Box Safety Status 1st Safety Status C 0 hex
    Black Box Safety Status 1st Safety Status D 0 hex
    Black Box Safety Status 1st Time to Next Event 0 s
    Black Box Safety Status 2nd Status Status A 0 hex
    Black Box Safety Status 2nd Status Status B 0 hex
    Black Box Safety Status 2nd Safety Status C 0 hex
    Black Box Safety Status 2nd Safety Status D 0 hex
    Black Box Safety Status 2nd Time to Next Event 0 s
    Black Box Safety Status 3rd Status Status A 0 hex
    Black Box Safety Status 3rd Status Status B 0 hex
    Black Box Safety Status 3rd Safety Status C 0 hex
    Black Box Safety Status 3rd Safety Status D 0 hex
    Black Box Safety Status 3rd Time to Next Event 0 s
    Black Box PF Status 1st PF Status A 0 hex
    Black Box PF Status 1st PF Status B 0 hex
    Black Box PF Status 1st PF Status C 0 hex
    Black Box PF Status 1st PF Status D 0 hex
    Black Box PF Status 1st Time to Next Event 0 s
    Black Box PF Status 2nd PF Status A 0 hex
    Black Box PF Status 2nd PF Status B 0 hex
    Black Box PF Status 2nd PF Status C 0 hex
    Black Box PF Status 2nd PF Status D 0 hex
    Black Box PF Status 2nd Time to Next Event 0 s
    Black Box PF Status 3rd PF Status A 0 hex
    Black Box PF Status 3rd PF Status B 0 hex
    Black Box PF Status 3rd PF Status C 0 hex
    Black Box PF Status 3rd PF Status D 0 hex
    Black Box PF Status 3rd Time to Next Event 0 s
    Gas Gauging Current Thresholds Dsg Current Threshold 25 mA
    Gas Gauging Current Thresholds Chg Current Threshold 30 mA
    Gas Gauging Current Thresholds Quit Current 20 mA
    Gas Gauging Current Thresholds Dsg Relax Time 1 s
    Gas Gauging Current Thresholds Chg Relax Time 60 s
    Gas Gauging Design Design Capacity mAh 4000 mAh
    Gas Gauging Design Design Capacity cWh 5120 cWh
    Gas Gauging Design Design Voltage 12800 mV
    Gas Gauging Cycle Cycle Count Percentage 90 %
    Gas Gauging FD Set Voltage Threshold 2500 mV
    Gas Gauging FD Clear Voltage Threshold 2600 mV
    Gas Gauging FD Set % RSOC Threshold 0 %
    Gas Gauging FD Clear % RSOC Threshold 5 %
    Gas Gauging FC Set Voltage Threshold 3600 mV
    Gas Gauging FC Clear Voltage Threshold 3500 mV
    Gas Gauging FC Set % RSOC Threshold 100 %
    Gas Gauging FC Clear % RSOC Threshold 95 %
    Gas Gauging TD Set Voltage Threshold 2600 mV
    Gas Gauging TD Clear Voltage Threshold 2700 mV
    Gas Gauging TD Set % RSOC Threshold 6 %
    Gas Gauging TD Clear % RSOC Threshold 8 %
    Gas Gauging TC Set Voltage Threshold 3600 mV
    Gas Gauging TC Clear Voltage Threshold 3500 mV
    Gas Gauging TC Set % RSOC Threshold 100 %
    Gas Gauging TC Clear % RSOC Threshold 95 %
    Gas Gauging State Cycle Count 2 -
    Gas Gauging State Qmax Cell 1 3356 mAh
    Gas Gauging State Qmax Cell 2 3333 mAh
    Gas Gauging State Qmax Cell 3 3371 mAh
    Gas Gauging State Qmax Cell 4 3388 mAh
    Gas Gauging State Qmax Pack 3333 mAh
    Gas Gauging State Qmax Cycle Count 0 -
    Gas Gauging State Update Status 0e -
    Gas Gauging State Cell 1 Chg Voltage at EoC 3354 mV
    Gas Gauging State Cell 2 Chg Voltage at EoC 3334 mV
    Gas Gauging State Cell 3 Chg Voltage at EoC 3566 mV
    Gas Gauging State Cell 4 Chg Voltage at EoC 3331 mV
    Gas Gauging State Current at EoC 64 mA
    Gas Gauging State Avg I Last Run -94 mA
    Gas Gauging State Avg P Last Run -124 cW
    Gas Gauging State Delta Voltage 13 mV
    Gas Gauging State Temp k 10.00 °C/256mW
    Gas Gauging State Temp a 440 s
    Gas Gauging State Max Avg I Last Run -114 mA
    Gas Gauging State Max Avg P Last Run -150 cW
    Gas Gauging Turbo Cfg Min Turbo Power 0 cW
    Gas Gauging Turbo Cfg Ten Second Max C Rate -2.0 C
    Gas Gauging Turbo Cfg Ten Millisecond Max C Rate -4.0 C
    Gas Gauging Turbo Cfg High Frequency Resistance 0 mOhm
    Gas Gauging Turbo Cfg Reserve Energy % 0 %
    Gas Gauging Turbo Cfg Turbo Adjustment Factor 1.00 -
    Gas Gauging IT Cfg Load Select 7 -
    Gas Gauging IT Cfg Fast Scale Load Select 3 -
    Gas Gauging IT Cfg Load Mode 0 -
    Gas Gauging IT Cfg User Rate-mA 0 mA
    Gas Gauging IT Cfg User Rate-cW 0 cW
    Gas Gauging IT Cfg Reserve Cap-mAh 0 mAh
    Gas Gauging IT Cfg Reserve Cap-cWh 0 cWh
    Gas Gauging IT Cfg Predict Ambient Time 2000 s
    Gas Gauging IT Cfg Design Resistance 104 2^-10ohm
    Gas Gauging IT Cfg Pack Resistance 0 2^-10ohm
    Gas Gauging IT Cfg System Resistance 0 2^-10ohm
    Gas Gauging IT Cfg Ra Filter 80.0 %
    Gas Gauging IT Cfg Ra Max Delta 15 %
    Gas Gauging IT Cfg Reference Grid 4 -
    Gas Gauging IT Cfg Resistance Parameter Filter 65142 -
    Gas Gauging IT Cfg Near EDV Ra Param Filter 59220 -
    Gas Gauging IT Cfg Cell 1 Interconnect Resistance 0 2^-10ohm
    Gas Gauging IT Cfg Cell 2 Interconnect Resistance 0 2^-10ohm
    Gas Gauging IT Cfg Cell 3 Interconnect Resistance 0 2^-10ohm
    Gas Gauging IT Cfg Cell 4 Interconnect Resistance 0 2^-10ohm
    Gas Gauging IT Cfg Max Current Change % 10 %
    Gas Gauging IT Cfg Resistance Update Voltage 50 mV
    Gas Gauging IT Cfg Qmax Delta 5 %
    Gas Gauging IT Cfg Qmax Upper Bound 130 %
    Gas Gauging IT Cfg Term Voltage 12000 mV
    Gas Gauging IT Cfg Term V Hold Time 1 s
    Gas Gauging IT Cfg Term Voltage Delta 300 mV
    Gas Gauging IT Cfg Term Min Cell V 2800 mV
    Gas Gauging IT Cfg Max Simulation Iterations 30 -
    Gas Gauging IT Cfg Fast Scale Start SOC 10 %
    Gas Gauging IT Cfg Min Delta Voltage 0 mV
    Gas Gauging IT Cfg Max Delta Voltage 200 mV
    Gas Gauging IT Cfg DeltaV Max Voltage Delta 10 mV
    Gas Gauging Smoothing Smooth Relax Time 1000 s
    Gas Gauging Smoothing Term Smooth Start Cell V Delta 150 mV
    Gas Gauging Smoothing Term Smooth Final Cell V Delta 100 mV
    Gas Gauging Smoothing Term Smooth Time 20 s
    Gas Gauging Condition Flag Max Error Limit 100 %
    Gas Gauging Max Error Time Cycle Equivalent 24 h
    Gas Gauging Max Error Cycle Delta 0.05 %
    Gas Gauging SoH SoH Load Rate 5.0 Hr rate
    Ra Table R_a0 Cell0 R_a flag 55 -
    Ra Table R_a0 Cell0 R_a 0 93 2^-10ohm
    Ra Table R_a0 Cell0 R_a 1 100 2^-10ohm
    Ra Table R_a0 Cell0 R_a 2 112 2^-10ohm
    Ra Table R_a0 Cell0 R_a 3 119 2^-10ohm
    Ra Table R_a0 Cell0 R_a 4 106 2^-10ohm
    Ra Table R_a0 Cell0 R_a 5 122 2^-10ohm
    Ra Table R_a0 Cell0 R_a 6 125 2^-10ohm
    Ra Table R_a0 Cell0 R_a 7 122 2^-10ohm
    Ra Table R_a0 Cell0 R_a 8 127 2^-10ohm
    Ra Table R_a0 Cell0 R_a 9 135 2^-10ohm
    Ra Table R_a0 Cell0 R_a 10 143 2^-10ohm
    Ra Table R_a0 Cell0 R_a 11 146 2^-10ohm
    Ra Table R_a0 Cell0 R_a 12 178 2^-10ohm
    Ra Table R_a0 Cell0 R_a 13 247 2^-10ohm
    Ra Table R_a0 Cell0 R_a 14 60 2^-10ohm
    Ra Table R_a1 Cell1 R_a flag 0 -
    Ra Table R_a1 Cell1 R_a 0 101 2^-10ohm
    Ra Table R_a1 Cell1 R_a 1 109 2^-10ohm
    Ra Table R_a1 Cell1 R_a 2 122 2^-10ohm
    Ra Table R_a1 Cell1 R_a 3 130 2^-10ohm
    Ra Table R_a1 Cell1 R_a 4 115 2^-10ohm
    Ra Table R_a1 Cell1 R_a 5 116 2^-10ohm
    Ra Table R_a1 Cell1 R_a 6 119 2^-10ohm
    Ra Table R_a1 Cell1 R_a 7 116 2^-10ohm
    Ra Table R_a1 Cell1 R_a 8 120 2^-10ohm
    Ra Table R_a1 Cell1 R_a 9 127 2^-10ohm
    Ra Table R_a1 Cell1 R_a 10 135 2^-10ohm
    Ra Table R_a1 Cell1 R_a 11 138 2^-10ohm
    Ra Table R_a1 Cell1 R_a 12 169 2^-10ohm
    Ra Table R_a1 Cell1 R_a 13 234 2^-10ohm
    Ra Table R_a1 Cell1 R_a 14 57 2^-10ohm
    Ra Table R_a2 Cell2 R_a flag 0 -
    Ra Table R_a2 Cell2 R_a 0 101 2^-10ohm
    Ra Table R_a2 Cell2 R_a 1 109 2^-10ohm
    Ra Table R_a2 Cell2 R_a 2 122 2^-10ohm
    Ra Table R_a2 Cell2 R_a 3 130 2^-10ohm
    Ra Table R_a2 Cell2 R_a 4 115 2^-10ohm
    Ra Table R_a2 Cell2 R_a 5 116 2^-10ohm
    Ra Table R_a2 Cell2 R_a 6 119 2^-10ohm
    Ra Table R_a2 Cell2 R_a 7 116 2^-10ohm
    Ra Table R_a2 Cell2 R_a 8 120 2^-10ohm
    Ra Table R_a2 Cell2 R_a 9 127 2^-10ohm
    Ra Table R_a2 Cell2 R_a 10 135 2^-10ohm
    Ra Table R_a2 Cell2 R_a 11 138 2^-10ohm
    Ra Table R_a2 Cell2 R_a 12 169 2^-10ohm
    Ra Table R_a2 Cell2 R_a 13 234 2^-10ohm
    Ra Table R_a2 Cell2 R_a 14 57 2^-10ohm
    Ra Table R_a3 Cell3 R_a flag 55 -
    Ra Table R_a3 Cell3 R_a 0 92 2^-10ohm
    Ra Table R_a3 Cell3 R_a 1 99 2^-10ohm
    Ra Table R_a3 Cell3 R_a 2 111 2^-10ohm
    Ra Table R_a3 Cell3 R_a 3 118 2^-10ohm
    Ra Table R_a3 Cell3 R_a 4 105 2^-10ohm
    Ra Table R_a3 Cell3 R_a 5 122 2^-10ohm
    Ra Table R_a3 Cell3 R_a 6 124 2^-10ohm
    Ra Table R_a3 Cell3 R_a 7 122 2^-10ohm
    Ra Table R_a3 Cell3 R_a 8 125 2^-10ohm
    Ra Table R_a3 Cell3 R_a 9 134 2^-10ohm
    Ra Table R_a3 Cell3 R_a 10 142 2^-10ohm
    Ra Table R_a3 Cell3 R_a 11 145 2^-10ohm
    Ra Table R_a3 Cell3 R_a 12 177 2^-10ohm
    Ra Table R_a3 Cell3 R_a 13 245 2^-10ohm
    Ra Table R_a3 Cell3 R_a 14 60 2^-10ohm
    Ra Table R_a0x xCell0 R_a flag 0 -
    Ra Table R_a0x xCell0 R_a 0 93 2^-10ohm
    Ra Table R_a0x xCell0 R_a 1 100 2^-10ohm
    Ra Table R_a0x xCell0 R_a 2 112 2^-10ohm
    Ra Table R_a0x xCell0 R_a 3 119 2^-10ohm
    Ra Table R_a0x xCell0 R_a 4 106 2^-10ohm
    Ra Table R_a0x xCell0 R_a 5 106 2^-10ohm
    Ra Table R_a0x xCell0 R_a 6 109 2^-10ohm
    Ra Table R_a0x xCell0 R_a 7 106 2^-10ohm
    Ra Table R_a0x xCell0 R_a 8 110 2^-10ohm
    Ra Table R_a0x xCell0 R_a 9 117 2^-10ohm
    Ra Table R_a0x xCell0 R_a 10 124 2^-10ohm
    Ra Table R_a0x xCell0 R_a 11 127 2^-10ohm
    Ra Table R_a0x xCell0 R_a 12 155 2^-10ohm
    Ra Table R_a0x xCell0 R_a 13 215 2^-10ohm
    Ra Table R_a0x xCell0 R_a 14 52 2^-10ohm
    Ra Table R_a1x xCell1 R_a flag 55 -
    Ra Table R_a1x xCell1 R_a 0 91 2^-10ohm
    Ra Table R_a1x xCell1 R_a 1 98 2^-10ohm
    Ra Table R_a1x xCell1 R_a 2 110 2^-10ohm
    Ra Table R_a1x xCell1 R_a 3 117 2^-10ohm
    Ra Table R_a1x xCell1 R_a 4 104 2^-10ohm
    Ra Table R_a1x xCell1 R_a 5 105 2^-10ohm
    Ra Table R_a1x xCell1 R_a 6 107 2^-10ohm
    Ra Table R_a1x xCell1 R_a 7 105 2^-10ohm
    Ra Table R_a1x xCell1 R_a 8 108 2^-10ohm
    Ra Table R_a1x xCell1 R_a 9 115 2^-10ohm
    Ra Table R_a1x xCell1 R_a 10 122 2^-10ohm
    Ra Table R_a1x xCell1 R_a 11 124 2^-10ohm
    Ra Table R_a1x xCell1 R_a 12 152 2^-10ohm
    Ra Table R_a1x xCell1 R_a 13 211 2^-10ohm
    Ra Table R_a1x xCell1 R_a 14 51 2^-10ohm
    Ra Table R_a2x xCell2 R_a flag 55 -
    Ra Table R_a2x xCell2 R_a 0 90 2^-10ohm
    Ra Table R_a2x xCell2 R_a 1 97 2^-10ohm
    Ra Table R_a2x xCell2 R_a 2 109 2^-10ohm
    Ra Table R_a2x xCell2 R_a 3 116 2^-10ohm
    Ra Table R_a2x xCell2 R_a 4 103 2^-10ohm
    Ra Table R_a2x xCell2 R_a 5 104 2^-10ohm
    Ra Table R_a2x xCell2 R_a 6 106 2^-10ohm
    Ra Table R_a2x xCell2 R_a 7 104 2^-10ohm
    Ra Table R_a2x xCell2 R_a 8 107 2^-10ohm
    Ra Table R_a2x xCell2 R_a 9 113 2^-10ohm
    Ra Table R_a2x xCell2 R_a 10 121 2^-10ohm
    Ra Table R_a2x xCell2 R_a 11 123 2^-10ohm
    Ra Table R_a2x xCell2 R_a 12 151 2^-10ohm
    Ra Table R_a2x xCell2 R_a 13 209 2^-10ohm
    Ra Table R_a2x xCell2 R_a 14 51 2^-10ohm
    Ra Table R_a3x xCell3 R_a flag 0 -
    Ra Table R_a3x xCell3 R_a 0 92 2^-10ohm
    Ra Table R_a3x xCell3 R_a 1 99 2^-10ohm
    Ra Table R_a3x xCell3 R_a 2 111 2^-10ohm
    Ra Table R_a3x xCell3 R_a 3 118 2^-10ohm
    Ra Table R_a3x xCell3 R_a 4 105 2^-10ohm
    Ra Table R_a3x xCell3 R_a 5 106 2^-10ohm
    Ra Table R_a3x xCell3 R_a 6 108 2^-10ohm
    Ra Table R_a3x xCell3 R_a 7 106 2^-10ohm
    Ra Table R_a3x xCell3 R_a 8 109 2^-10ohm
    Ra Table R_a3x xCell3 R_a 9 116 2^-10ohm
    Ra Table R_a3x xCell3 R_a 10 123 2^-10ohm
    Ra Table R_a3x xCell3 R_a 11 126 2^-10ohm
    Ra Table R_a3x xCell3 R_a 12 154 2^-10ohm
    Ra Table R_a3x xCell3 R_a 13 213 2^-10ohm
    Ra Table R_a3x xCell3 R_a 14 52 2^-10ohm
    Just to confirm, can you please complete the GPCCHEM tool steps on the cell currently being used to see if this ID is the most compatible? If we are able to confirm the chemID, then we will able to narrow down the root cause of this issue quicker.
    Anthony
  • Dear Anthony,
    I set the CHEM ID 4150, that matches exactly the battery model I am using: JGCFR26650 4000mAh. I had some issues with GPC Packager.
    RSOC stops at 76% and ASOC stops at 52%. Supply voltage is 14,30 VDC from mains AC/DC power supply.
    Below I report the new configuration:
    System Data Integrity Static Chem DF Signature 773b hex
    SBS Configuration Data Manufacture Date ######## date
    Lifetimes Voltage Cell 4 Max Voltage 3711 mV
    Lifetimes Voltage Cell 1 Min Voltage 0 mV
    Lifetimes Voltage Cell 2 Min Voltage 0 mV
    Lifetimes Voltage Cell 3 Min Voltage 1703 mV
    Lifetimes Safety Events No Of CUV Events 5 events
    Lifetimes Safety Events Last CUV Event 2 cycles
    Lifetimes Charging Events No Valid Charge Term 7 events
    Lifetimes Charging Events Last Valid Charge Term 2 cycles
    Lifetimes Gauging Events No Of Ra Updates 42 events
    Lifetimes Gauging Events Last Ra Update 2 cycles
    Lifetimes Gauging Events No Of Ra Disable 11 events
    Lifetimes Gauging Events Last Ra Disable 2 cycles
    Lifetimes Power Events No Of Shutdowns 5 events
    Lifetimes Cell Balancing Cb Time Cell 2 14 h
    Lifetimes Time Total Fw Runtime 7748 h
    Lifetimes Time Time Spent In RT 1132 h
    Lifetimes Time Time Spent In STH 3368 h
    Lifetimes Time Time Spent In HT 406 h
    Gas Gauging Design Design Capacity cWh 4352 cWh
    Gas Gauging State Cell 1 Chg Voltage at EoC 3610 mV
    Gas Gauging State Cell 2 Chg Voltage at EoC 3438 mV
    Gas Gauging State Cell 3 Chg Voltage at EoC 3752 mV
    Gas Gauging State Cell 4 Chg Voltage at EoC 3399 mV
    Gas Gauging State Current at EoC 68 mA
    Gas Gauging State Avg I Last Run -649 mA
    Gas Gauging State Avg P Last Run -847 cW
    Gas Gauging State Delta Voltage 4 mV
    Gas Gauging State Temp k 0.56 °C/256mW
    Gas Gauging State Temp a 225 s
    Gas Gauging State Max Avg I Last Run -863 mA
    Gas Gauging State Max Avg P Last Run -1122 cW
    Ra Table R_a0 Cell0 R_a flag ff55 -
    Ra Table R_a0 Cell0 R_a 0 1392 2^-10ohm
    Ra Table R_a0 Cell0 R_a 1 85 2^-10ohm
    Ra Table R_a0 Cell0 R_a 2 101 2^-10ohm
    Ra Table R_a0 Cell0 R_a 4 92 2^-10ohm
    Ra Table R_a0 Cell0 R_a 5 99 2^-10ohm
    Ra Table R_a0 Cell0 R_a 6 115 2^-10ohm
    Ra Table R_a0 Cell0 R_a 7 114 2^-10ohm
    Ra Table R_a0 Cell0 R_a 8 120 2^-10ohm
    Ra Table R_a0 Cell0 R_a 9 140 2^-10ohm
    Ra Table R_a0 Cell0 R_a 10 203 2^-10ohm
    Ra Table R_a0 Cell0 R_a 11 229 2^-10ohm
    Ra Table R_a0 Cell0 R_a 12 254 2^-10ohm
    Ra Table R_a0 Cell0 R_a 13 402 2^-10ohm
    Ra Table R_a0 Cell0 R_a 14 827 2^-10ohm
    Ra Table R_a1 Cell1 R_a flag ff55 -
    Ra Table R_a1 Cell1 R_a 0 1392 2^-10ohm
    Ra Table R_a1 Cell1 R_a 1 85 2^-10ohm
    Ra Table R_a1 Cell1 R_a 2 101 2^-10ohm
    Ra Table R_a1 Cell1 R_a 3 119 2^-10ohm
    Ra Table R_a1 Cell1 R_a 4 92 2^-10ohm
    Ra Table R_a1 Cell1 R_a 5 99 2^-10ohm
    Ra Table R_a1 Cell1 R_a 6 115 2^-10ohm
    Ra Table R_a1 Cell1 R_a 7 114 2^-10ohm
    Ra Table R_a1 Cell1 R_a 9 140 2^-10ohm
    Ra Table R_a1 Cell1 R_a 10 203 2^-10ohm
    Ra Table R_a1 Cell1 R_a 11 229 2^-10ohm
    Ra Table R_a1 Cell1 R_a 12 254 2^-10ohm
    Ra Table R_a1 Cell1 R_a 13 402 2^-10ohm
    Ra Table R_a1 Cell1 R_a 14 827 2^-10ohm
    Ra Table R_a2 Cell2 R_a flag ff55 -
    Ra Table R_a2 Cell2 R_a 0 1392 2^-10ohm
    Ra Table R_a2 Cell2 R_a 1 85 2^-10ohm
    Ra Table R_a2 Cell2 R_a 2 101 2^-10ohm
    Ra Table R_a2 Cell2 R_a 3 119 2^-10ohm
    Ra Table R_a2 Cell2 R_a 4 92 2^-10ohm
    Ra Table R_a2 Cell2 R_a 5 99 2^-10ohm
    Ra Table R_a2 Cell2 R_a 6 115 2^-10ohm
    Ra Table R_a2 Cell2 R_a 7 114 2^-10ohm
    Ra Table R_a2 Cell2 R_a 9 140 2^-10ohm
    Ra Table R_a2 Cell2 R_a 10 203 2^-10ohm
    Ra Table R_a2 Cell2 R_a 11 229 2^-10ohm
    Ra Table R_a2 Cell2 R_a 12 254 2^-10ohm
    Ra Table R_a2 Cell2 R_a 13 402 2^-10ohm
    Ra Table R_a2 Cell2 R_a 14 827 2^-10ohm
    Ra Table R_a3 Cell3 R_a flag ff55 -
    Ra Table R_a3 Cell3 R_a 0 1392 2^-10ohm
    Ra Table R_a3 Cell3 R_a 1 85 2^-10ohm
    Ra Table R_a3 Cell3 R_a 2 101 2^-10ohm
    Ra Table R_a3 Cell3 R_a 3 119 2^-10ohm
    Ra Table R_a3 Cell3 R_a 4 92 2^-10ohm
    Ra Table R_a3 Cell3 R_a 5 99 2^-10ohm
    Ra Table R_a3 Cell3 R_a 6 115 2^-10ohm
    Ra Table R_a3 Cell3 R_a 7 114 2^-10ohm
    Ra Table R_a3 Cell3 R_a 8 120 2^-10ohm
    Ra Table R_a3 Cell3 R_a 9 140 2^-10ohm
    Ra Table R_a3 Cell3 R_a 10 203 2^-10ohm
    Ra Table R_a3 Cell3 R_a 11 229 2^-10ohm
    Ra Table R_a3 Cell3 R_a 12 254 2^-10ohm
    Ra Table R_a3 Cell3 R_a 13 402 2^-10ohm
    Ra Table R_a3 Cell3 R_a 14 827 2^-10ohm
    Ra Table R_a0x xCell0 R_a flag ffff -
    Ra Table R_a0x xCell0 R_a 0 1392 2^-10ohm
    Ra Table R_a0x xCell0 R_a 1 85 2^-10ohm
    Ra Table R_a0x xCell0 R_a 2 101 2^-10ohm
    Ra Table R_a0x xCell0 R_a 4 92 2^-10ohm
    Ra Table R_a0x xCell0 R_a 5 99 2^-10ohm
    Ra Table R_a0x xCell0 R_a 6 115 2^-10ohm
    Ra Table R_a0x xCell0 R_a 7 114 2^-10ohm
    Ra Table R_a0x xCell0 R_a 8 120 2^-10ohm
    Ra Table R_a0x xCell0 R_a 9 140 2^-10ohm
    Ra Table R_a0x xCell0 R_a 10 203 2^-10ohm
    Ra Table R_a0x xCell0 R_a 11 229 2^-10ohm
    Ra Table R_a0x xCell0 R_a 12 254 2^-10ohm
    Ra Table R_a0x xCell0 R_a 13 402 2^-10ohm
    Ra Table R_a0x xCell0 R_a 14 827 2^-10ohm
    Ra Table R_a1x xCell1 R_a flag ffff -
    Ra Table R_a1x xCell1 R_a 0 1392 2^-10ohm
    Ra Table R_a1x xCell1 R_a 1 85 2^-10ohm
    Ra Table R_a1x xCell1 R_a 2 101 2^-10ohm
    Ra Table R_a1x xCell1 R_a 3 119 2^-10ohm
    Ra Table R_a1x xCell1 R_a 4 92 2^-10ohm
    Ra Table R_a1x xCell1 R_a 5 99 2^-10ohm
    Ra Table R_a1x xCell1 R_a 6 115 2^-10ohm
    Ra Table R_a1x xCell1 R_a 7 114 2^-10ohm
    Ra Table R_a1x xCell1 R_a 8 120 2^-10ohm
    Ra Table R_a1x xCell1 R_a 9 140 2^-10ohm
    Ra Table R_a1x xCell1 R_a 10 203 2^-10ohm
    Ra Table R_a1x xCell1 R_a 11 229 2^-10ohm
    Ra Table R_a1x xCell1 R_a 12 254 2^-10ohm
    Ra Table R_a1x xCell1 R_a 13 402 2^-10ohm
    Ra Table R_a1x xCell1 R_a 14 827 2^-10ohm
    Ra Table R_a2x xCell2 R_a flag ffff -
    Ra Table R_a2x xCell2 R_a 0 1392 2^-10ohm
    Ra Table R_a2x xCell2 R_a 1 85 2^-10ohm
    Ra Table R_a2x xCell2 R_a 2 101 2^-10ohm
    Ra Table R_a2x xCell2 R_a 3 119 2^-10ohm
    Ra Table R_a2x xCell2 R_a 4 92 2^-10ohm
    Ra Table R_a2x xCell2 R_a 5 99 2^-10ohm
    Ra Table R_a2x xCell2 R_a 6 115 2^-10ohm
    Ra Table R_a2x xCell2 R_a 7 114 2^-10ohm
    Ra Table R_a2x xCell2 R_a 8 120 2^-10ohm
    Ra Table R_a2x xCell2 R_a 9 140 2^-10ohm
    Ra Table R_a2x xCell2 R_a 10 203 2^-10ohm
    Ra Table R_a2x xCell2 R_a 11 229 2^-10ohm
    Ra Table R_a2x xCell2 R_a 12 254 2^-10ohm
    Ra Table R_a2x xCell2 R_a 13 402 2^-10ohm
    Ra Table R_a2x xCell2 R_a 14 827 2^-10ohm
    Ra Table R_a3x xCell3 R_a flag ffff -
    Ra Table R_a3x xCell3 R_a 0 1392 2^-10ohm
    Ra Table R_a3x xCell3 R_a 1 85 2^-10ohm
    Ra Table R_a3x xCell3 R_a 2 101 2^-10ohm
    Ra Table R_a3x xCell3 R_a 3 119 2^-10ohm
    Ra Table R_a3x xCell3 R_a 4 92 2^-10ohm
    Ra Table R_a3x xCell3 R_a 5 99 2^-10ohm
    Ra Table R_a3x xCell3 R_a 6 115 2^-10ohm
    Ra Table R_a3x xCell3 R_a 7 114 2^-10ohm
    Ra Table R_a3x xCell3 R_a 8 120 2^-10ohm
    Ra Table R_a3x xCell3 R_a 9 140 2^-10ohm
    Ra Table R_a3x xCell3 R_a 10 203 2^-10ohm
    Ra Table R_a3x xCell3 R_a 11 229 2^-10ohm
    Ra Table R_a3x xCell3 R_a 12 254 2^-10ohm
    Ra Table R_a3x xCell3 R_a 13 402 2^-10ohm
    Ra Table R_a3x xCell3 R_a 14 827 2^-10ohm
    If possible, can you please share a bqStudio log of the SOC behavior? This will give us a better idea of what is occurring within the gauge at this time.
    Anthony
    here you are a sheet of raw data during a charge phase:
    Sample DateTime ElapsedTime ManufAccess RemCapAlarm RemTimeAlarm BattMode @Rate(@) @TimeFull @TimeEmpty @RateOK Temperature Voltage Current AvgCurr MaxErr RSOC ASOC RemCap FullChgCap RunTimeEmty AvgTimeEmty AvgTimeFull ChgCurr ChgVolt BattStat CycleCnt MaxTurboPwr SusTurboPwr MaxTurboCurr SusTurboCurr SoH OpStatA OpStatB TempRange ChgStat GaugeStat ITStat MfgStat SafetyAlertAB SafetyStatAB SafetyAlertCD SafetyStatCD PFAlertAB PFStatAB PFAlertCD PFStatCD CellVolt1 CellVolt2 CellVolt3 CellVolt4 vBAT vPACK CellCurr1 CellCurr2 CellCurr3 CellCurr4 CellPower1 CellPower2 CellPower3 CellPower4 Power AvgPow IntTemp TS1Temp TS2Temp TS3Temp TS4Temp CellTemp FETTemp GaugeTemp FltRemQ FltRemE FltFullChgQ FltFullChgE NoLoadRemCap TrueRemQ TrueRemE InitialQ InitialE TrueFullChgQ TrueFullChgE T_sim T_ambient RaScale1 RaScale2 RaScale3 RaScale4 CompRes1 CompRes2 CompRes3 CompRes4 PackGrid LStatus CellGrid1 CellGrid2 CellGrid3 CellGrid4 StateTime DOD0_1 DOD0_2 DOD0_3 DOD0_4 DOD0 Passed Q DOD0 Passed E DOD0 Time DODEOC_1 DODEOC_2 DODEOC_3 DODEOC_4 QMax1 QMax2 QMax3 QMax4 QMaxDOD0_1 QMaxDOD0_2 QMaxDOD0_3 QMaxDOD0_4 QMaxPassedQ QMaxTime Tk Ta RawDOD_1 RawDOD_2 RawDOD_3 RawDOD_4 CBTime1 CBTime2 CBTime3 CBTime4 CBDOD_1 CBDOD_2 CBDOD_3 CBDOD_4 CBTotalDODChg SOH_FC_Q SOH_FC_E LogRowTime(ms) LogStatus
    1 08/08/2024 15:05 4013 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13553 1413 723 1 64 51 2001 3144 65535 65535 153 4004 14400 0x0080 2 -9600 -10318 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3399 3387 3390 3388 13503 13664 1406 1422 1423 1413 478 482 482 479 1912 1037 26.6 27.7 27.5 27.4 27.6 27.8 27.5 27.8 2001 2547 3144 4036 2192 2001 2545 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 6 5632 5632 5632 5632 -5 -6 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -5 0 0.56 225 5632 5632 5632 5632 4037 9695 3084 0 5632 5632 5632 5632 16384 3152 4044 2529 SUCCESS
    2 08/08/2024 15:05 8020 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13586 1413 889 1 64 51 2002 3144 65535 65535 143 4004 14400 0x0080 2 -9600 -10318 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3406 3394 3397 3397 13531 13692 1405 1422 1417 1415 479 483 481 481 1918 1249 26.7 27.7 27.5 27.4 27.7 27.7 27.5 27.7 2003 2549 3144 4036 2194 2003 2548 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 10 5632 5632 5632 5632 -7 -9 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -7 0 0.56 225 5632 5632 5632 5632 4037 9691 3084 0 5632 5632 5632 5632 16384 3152 4044 2347 SUCCESS
    3 08/08/2024 15:05 12028 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13609 1412 1014 1 64 51 2004 3144 65535 65535 135 4004 14400 0x0080 2 -9600 -10321 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3411 3399 3403 3401 13548 13716 1415 1421 1421 1416 483 483 484 482 1921 1411 26.8 27.8 27.5 27.4 27.7 27.8 27.5 27.8 2005 2551 3144 4036 2195 2004 2549 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 14 5632 5632 5632 5632 -8 -10 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -8 0 0.56 225 5632 5632 5632 5632 4037 9687 3084 0 5632 5632 5632 5632 16384 3152 4044 2537 SUCCESS
    4 08/08/2024 15:05 16033 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13624 1412 1110 1 64 51 2006 3144 65535 65535 130 4004 14400 0x0080 2 -9600 -10321 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3414 3403 3406 3404 13564 13729 1410 1428 1411 1416 481 486 481 482 1924 1534 26.8 27.7 27.5 27.4 27.6 27.7 27.5 27.7 2006 2553 3144 4036 2197 2006 2552 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 18 5632 5632 5632 5632 -10 -13 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -10 0 0.56 225 5632 5632 5632 5632 4037 9683 3084 0 5632 5632 5632 5632 16384 3152 4044 2513 SUCCESS
    5 08/08/2024 15:05 20040 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13633 1413 1183 1 64 51 2007 3144 65535 65535 126 4004 14400 0x0080 2 -9600 -10321 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3405 3408 3406 13573 13734 1415 1425 1416 1415 484 485 483 482 1927 1628 26.9 27.7 27.5 27.4 27.7 27.7 27.5 27.7 2008 2555 3144 4036 2198 2007 2553 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 22 5632 5632 5632 5632 -12 -15 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -12 0 0.56 225 5632 5632 5632 5632 4037 9679 3084 0 5632 5632 5632 5632 16384 3152 4044 2462 SUCCESS
    6 08/08/2024 15:05 24052 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13640 1412 1238 1 64 51 2009 3144 65535 65535 124 4004 14400 0x0080 2 -9600 -10321 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3409 3408 13577 13741 1428 1413 1418 1419 488 481 483 484 1927 1700 26.8 27.7 27.5 27.4 27.6 27.7 27.5 27.7 2009 2557 3144 4036 2200 2009 2555 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 26 5632 5632 5632 5632 -13 -16 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -13 0 0.56 225 5632 5632 5632 5632 4037 9675 3084 0 5632 5632 5632 5632 16384 3152 4044 2436 SUCCESS
    7 08/08/2024 15:05 28054 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13644 1413 1280 1 64 51 2010 3144 65535 65535 119 4004 14400 0x0080 2 -9600 -10321 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3407 3410 3409 13583 13747 1418 1406 1421 1423 485 479 485 485 1929 1755 26.8 27.7 27.5 27.5 27.7 27.7 27.5 27.7 2011 2559 3144 4036 2201 2011 2558 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 30 5632 5632 5632 5632 -15 -19 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -15 0 0.56 225 5632 5632 5632 5632 4037 9671 3084 0 5632 5632 5632 5632 16384 3152 4044 2589 SUCCESS
    8 08/08/2024 15:05 32062 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13648 1412 1312 1 64 51 2012 3144 65535 65535 116 4004 14400 0x0080 2 -9600 -10324 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3408 3411 3410 13586 13749 1431 1413 1416 1410 489 482 483 481 1929 1796 26.9 27.7 27.5 27.5 27.6 27.7 27.5 27.7 2012 2561 3144 4036 2203 2012 2559 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 34 5632 5632 5632 5632 -16 -20 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -16 0 0.56 225 5632 5632 5632 5632 4037 9667 3084 0 5632 5632 5632 5632 16384 3152 4044 2474 SUCCESS
    9 08/08/2024 15:05 36066 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13650 1414 1336 1 65 51 2013 3144 65535 65535 114 4004 14400 0x0080 2 -9600 -10324 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3409 3411 3411 13589 13753 1415 1426 1415 1410 484 486 483 481 1929 1828 26.9 27.7 27.5 27.4 27.6 27.7 27.5 27.7 2014 2564 3144 4036 2204 2014 2562 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 38 5632 5632 5632 5632 -18 -23 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -18 0 0.56 225 5632 5632 5632 5632 4037 9663 3084 0 5632 5632 5632 5632 16384 3152 4044 2671 SUCCESS
    10 08/08/2024 15:05 40067 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13651 1412 1355 1 65 51 2015 3144 65535 65535 112 4004 14400 0x0080 2 -9600 -10324 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3409 3412 3411 13589 13753 1420 1420 1418 1415 486 484 484 483 1931 1853 26.9 27.7 27.5 27.4 27.6 27.7 27.5 27.7 2015 2565 3144 4036 2206 2015 2563 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 42 5632 5632 5632 5632 -19 -24 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -19 0 0.56 225 5632 5632 5632 5632 4037 9659 3084 0 5632 5632 5632 5632 16384 3152 4044 2589 SUCCESS
    11 08/08/2024 15:06 44075 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13653 1414 1369 1 65 51 2017 3144 65535 65535 111 4004 14400 0x0080 2 -9600 -10323 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3410 3412 3412 13596 13757 1421 1431 1420 1420 486 488 485 485 1931 1900 27.0 27.7 27.5 27.5 27.6 27.7 27.5 27.7 2021 2573 3144 4036 2212 2021 2571 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 57 5632 5632 5632 5632 -25 -32 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -25 0 0.56 225 5632 5632 5632 5632 4037 9645 3084 0 5632 5632 5632 5632 16384 3152 4044 13406 SUCCESS
    12 08/08/2024 15:06 57985 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13657 1412 1395 1 65 51 2022 3144 65535 65535 108 4004 14400 0x0080 2 -9600 -10325 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3410 3414 3412 13597 13756 1414 1416 1430 1405 484 483 488 479 1930 1906 27.0 27.7 27.6 27.5 27.6 27.7 27.6 27.7 2022 2574 3144 4036 2213 2022 2572 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 60 5632 5632 5632 5632 -26 -33 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -26 0 0.56 225 5632 5632 5632 5632 4037 9642 3084 0 5632 5632 5632 5632 16384 3152 4044 2223 SUCCESS
    13 08/08/2024 15:06 60473 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13661 1411 1398 1 65 51 2023 3144 65535 65535 108 4004 14400 0x0080 2 -9600 -10325 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3410 3413 3412 13593 13757 1410 1420 1417 1414 482 484 484 482 1927 1910 27.0 27.7 27.6 27.5 27.6 27.7 27.6 27.7 2023 2576 3144 4036 2214 2023 2574 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 62 5632 5632 5632 5632 -27 -35 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -27 0 0.56 225 5632 5632 5632 5632 4037 9639 3084 0 5632 5632 5632 5632 16384 3152 4044 2373 SUCCESS
    14 08/08/2024 15:06 64109 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13656 1411 1401 1 65 51 2024 3144 65535 65535 108 4004 14400 0x0080 2 -9600 -10325 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3410 3413 3412 13597 13759 1422 1413 1406 1410 487 482 480 481 1926 1913 27.0 27.7 27.6 27.5 27.6 27.7 27.6 27.7 2025 2578 3144 4036 2215 2025 2576 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 66 5632 5632 5632 5632 -29 -37 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -29 0 0.56 225 5632 5632 5632 5632 4037 9636 3084 0 5632 5632 5632 5632 16384 3152 4044 2399 SUCCESS
    15 08/08/2024 15:06 68114 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13657 1410 1403 1 65 51 2026 3144 65535 65535 107 4004 14400 0x0080 2 -9600 -10325 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3413 3412 13595 13758 1415 1417 1424 1409 484 483 486 481 1923 1916 27.0 27.7 27.6 27.5 27.6 27.7 27.6 27.7 2026 2580 3144 4036 2217 2026 2578 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 70 5632 5632 5632 5632 -30 -39 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -30 0 0.56 225 5632 5632 5632 5632 4037 9632 3084 0 5632 5632 5632 5632 16384 3152 4044 2291 SUCCESS
    16 08/08/2024 15:06 72128 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13657 1409 1404 1 65 51 2027 3144 65535 65535 107 4004 14400 0x0080 2 -9600 -10326 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3410 3413 3412 13594 13762 1409 1411 1407 1414 482 481 480 482 1923 1918 27.0 27.7 27.6 27.5 27.7 27.7 27.6 27.7 2028 2582 3144 4036 2219 2028 2580 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 74 5632 5632 5632 5632 -32 -41 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -32 0 0.56 225 5632 5632 5632 5632 4037 9627 3084 0 5632 5632 5632 5632 16384 3152 4044 2570 SUCCESS
    17 08/08/2024 15:06 76140 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13657 1409 1405 1 65 51 2029 3144 65535 65535 107 4004 14400 0x0080 2 -9600 -10328 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3410 3413 3413 13595 13759 1428 1410 1411 1405 489 481 482 480 1923 1919 27.0 27.7 27.6 27.5 27.7 27.7 27.6 27.7 2030 2584 3144 4036 2221 2030 2583 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 79 5632 5632 5632 5632 -34 -44 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -34 0 0.56 225 5632 5632 5632 5632 4037 9623 3084 0 5632 5632 5632 5632 16384 3152 4044 3500 SUCCESS
    18 08/08/2024 15:06 80329 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13658 1409 1406 1 65 51 2031 3144 65535 65535 107 4004 14400 0x0080 2 -9600 -10328 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3413 3412 13596 13763 1414 1404 1420 1421 484 479 485 485 1926 1920 27.0 27.8 27.6 27.5 27.6 27.8 27.6 27.8 2031 2586 3144 4036 2222 2031 2584 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 83 5632 5632 5632 5632 -35 -45 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -35 0 0.56 225 5632 5632 5632 5632 4037 9618 3084 0 5632 5632 5632 5632 16384 3152 4044 3425 SUCCESS
    19 08/08/2024 15:06 84508 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13664 1410 1407 1 65 51 2032 3144 65535 65535 106 4004 14400 0x0080 2 -9600 -10328 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3410 3414 3412 13598 13760 1419 1408 1415 1413 486 480 483 482 1924 1922 27.0 27.8 27.6 27.5 27.6 27.7 27.6 27.7 2033 2589 3144 4036 2224 2033 2587 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 87 5632 5632 5632 5632 -37 -48 0 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -37 0 0.56 225 5632 5632 5632 5632 4037 9614 3084 0 5632 5632 5632 5632 16384 3152 4044 3460 SUCCESS
    20 08/08/2024 15:06 88711 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13660 1411 1408 1 65 51 2034 3144 65535 65535 106 4004 14400 0x0080 2 -9600 -10328 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3413 3413 13597 13759 1405 1410 1414 1422 481 481 483 485 1927 1923 27.0 27.7 27.6 27.5 27.6 27.7 27.6 27.7 2035 2591 3144 4036 2225 2034 2588 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 91 5632 5632 5632 5632 -39 -50 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -39 1 0.56 225 5632 5632 5632 5632 4037 9610 3084 0 5632 5632 5632 5632 16384 3152 4044 3449 SUCCESS
    21 08/08/2024 15:06 92895 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13659 1410 1408 1 65 51 2035 3144 65535 65535 106 4004 14400 0x0080 2 -9600 -10328 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3412 13596 13760 1414 1409 1413 1414 484 481 482 482 1926 1924 27.0 27.7 27.6 27.5 27.6 27.7 27.6 27.7 2036 2593 3144 4036 2227 2036 2591 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 96 5632 5632 5632 5632 -40 -52 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -40 1 0.56 225 5632 5632 5632 5632 4037 9606 3084 0 5632 5632 5632 5632 16384 3152 4044 3526 SUCCESS
    22 08/08/2024 15:06 97111 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13659 1411 1409 1 65 51 2037 3144 65535 65535 106 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3412 3415 3414 13597 13762 1422 1416 1413 1419 487 483 483 484 1927 1924 27.1 27.8 27.6 27.6 27.6 27.8 27.6 27.8 2038 2595 3144 4036 2228 2038 2593 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 100 5632 5632 5632 5632 -42 -54 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -42 1 0.56 225 5632 5632 5632 5632 4037 9602 3084 0 5632 5632 5632 5632 16384 3152 4044 3445 SUCCESS
    23 08/08/2024 15:06 101205 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13659 1413 1409 1 65 51 2039 3144 65535 65535 106 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3415 3414 13597 13763 1413 1416 1414 1417 484 483 483 484 1927 1925 27.2 27.8 27.6 27.6 27.7 27.8 27.6 27.8 2040 2597 3144 4036 2230 2039 2595 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 104 5632 5632 5632 5632 -43 -56 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -43 1 0.56 225 5632 5632 5632 5632 4037 9598 3084 0 5632 5632 5632 5632 16384 3152 4044 3225 SUCCESS
    24 08/08/2024 15:07 105157 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13661 1412 1410 1 65 52 2041 3144 65535 65535 105 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3415 3415 13600 13763 1418 1406 1424 1419 485 480 486 485 1928 1926 27.0 27.8 27.6 27.6 27.7 27.8 27.6 27.8 2041 2599 3144 4036 2232 2041 2597 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 108 5632 5632 5632 5632 -45 -58 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -45 1 0.56 225 5632 5632 5632 5632 4037 9594 3084 0 5632 5632 5632 5632 16384 3152 4044 3479 SUCCESS
    25 08/08/2024 15:07 109250 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13660 1411 1410 1 65 52 2042 3144 65535 65535 105 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3415 3414 13598 13760 1417 1415 1422 1430 485 483 486 488 1928 1926 27.1 27.8 27.6 27.6 27.7 27.8 27.6 27.8 2043 2601 3144 4036 2233 2042 2598 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 112 5632 5632 5632 5632 -47 -61 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -47 1 0.56 225 5632 5632 5632 5632 4037 9590 3084 0 5632 5632 5632 5632 16384 3152 4044 3074 SUCCESS
    26 08/08/2024 15:07 113086 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13660 1412 1410 1 65 52 2044 3144 65535 65535 105 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13597 13762 1418 1426 1416 1424 485 486 483 486 1929 1926 27.1 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2044 2603 3144 4036 2235 2044 2601 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 115 5632 5632 5632 5632 -48 -62 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -48 1 0.56 225 5632 5632 5632 5632 4037 9586 3084 0 5632 5632 5632 5632 16384 3152 4044 3310 SUCCESS
    27 08/08/2024 15:07 117155 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13661 1411 1411 1 66 52 2045 3144 65535 65535 105 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3416 3415 13600 13762 1415 1419 1416 1407 484 484 484 480 1929 1927 27.2 27.8 27.7 27.7 27.8 27.8 27.7 27.8 2046 2605 3144 4036 2236 2046 2604 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 120 5632 5632 5632 5632 -50 -65 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -50 1 0.56 225 5632 5632 5632 5632 4037 9582 3084 0 5632 5632 5632 5632 16384 3152 4044 3456 SUCCESS
    28 08/08/2024 15:07 121366 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13661 1414 1411 1 66 52 2047 3144 65535 65535 105 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3415 3415 13600 13761 1420 1421 1426 1416 486 485 487 484 1931 1928 27.2 27.8 27.6 27.6 27.8 27.8 27.6 27.8 2047 2607 3144 4036 2238 2047 2605 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 124 5632 5632 5632 5632 -51 -66 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -51 1 0.56 225 5632 5632 5632 5632 4037 9578 3084 0 5632 5632 5632 5632 16384 3152 4044 3293 SUCCESS
    29 08/08/2024 15:07 125358 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13661 1413 1412 1 66 52 2048 3144 65535 65535 105 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3415 3415 13598 13764 1420 1414 1411 1402 486 483 482 479 1931 1928 27.2 27.8 27.6 27.6 27.8 27.8 27.6 27.8 2049 2609 3144 4036 2239 2049 2608 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 128 5632 5632 5632 5632 -53 -69 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -53 1 0.56 225 5632 5632 5632 5632 4037 9574 3084 0 5632 5632 5632 5632 16384 3152 4044 3300 SUCCESS
    30 08/08/2024 15:07 129397 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13661 1413 1412 1 66 52 2050 3144 65535 65535 104 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3415 3414 13601 13763 1424 1420 1418 1409 487 485 484 481 1931 1929 27.2 27.8 27.7 27.7 27.8 27.8 27.7 27.8 2051 2611 3144 4036 2241 2050 2609 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 132 5632 5632 5632 5632 -54 -70 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -54 1 0.56 225 5632 5632 5632 5632 4037 9570 3084 0 5632 5632 5632 5632 16384 3152 4044 3286 SUCCESS
    31 08/08/2024 15:07 133457 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13661 1411 1412 1 66 52 2052 3144 65535 65535 104 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13600 13763 1420 1399 1419 1423 486 477 484 486 1930 1929 27.2 27.8 27.7 27.8 27.8 27.8 27.7 27.8 2052 2613 3144 4036 2243 2052 2611 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 136 5632 5632 5632 5632 -56 -72 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -56 1 0.56 225 5632 5632 5632 5632 4037 9566 3084 0 5632 5632 5632 5632 16384 3152 4044 3237 SUCCESS
    32 08/08/2024 15:07 137437 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13661 1412 1412 1 66 52 2053 3144 65535 65535 104 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13765 1422 1401 1431 1420 487 478 489 485 1933 1929 27.3 27.8 27.7 27.8 27.9 27.9 27.7 27.9 2054 2615 3144 4036 2244 2053 2613 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 140 5632 5632 5632 5632 -58 -75 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -58 1 0.56 225 5632 5632 5632 5632 4037 9562 3084 0 5632 5632 5632 5632 16384 3152 4044 3493 SUCCESS
    33 08/08/2024 15:07 141681 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13661 1415 1413 1 66 52 2055 3144 65535 65535 104 4004 14400 0x0080 2 -9600 -10331 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13601 13762 1424 1417 1404 1423 487 483 479 486 1932 1930 27.2 27.9 27.8 27.8 27.9 27.9 27.8 27.9 2055 2618 3144 4036 2246 2055 2615 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 144 5632 5632 5632 5632 -59 -76 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -59 1 0.56 225 5632 5632 5632 5632 4037 9557 3084 0 5632 5632 5632 5632 16384 3152 4044 3474 SUCCESS
    34 08/08/2024 15:07 145920 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1413 1413 1 66 52 2056 3144 65535 65535 104 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13599 13763 1423 1425 1419 1435 487 486 484 490 1932 1931 27.3 27.9 27.8 27.8 27.9 27.9 27.8 27.9 2057 2620 3144 4036 2248 2057 2618 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 148 5632 5632 5632 5632 -61 -79 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -61 1 0.56 225 5632 5632 5632 5632 4037 9553 3084 0 5632 5632 5632 5632 16384 3152 4044 3553 SUCCESS
    35 08/08/2024 15:07 150184 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13662 1414 1413 1 66 52 2058 3144 65535 65535 104 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13764 1426 1423 1421 1422 488 485 485 485 1933 1931 27.4 27.9 27.8 27.9 27.9 27.9 27.8 27.9 2059 2622 3144 4036 2249 2058 2619 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 152 5632 5632 5632 5632 -63 -82 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -63 1 0.56 225 5632 5632 5632 5632 4037 9549 3084 0 5632 5632 5632 5632 16384 3152 4044 3372 SUCCESS
    36 08/08/2024 15:07 154355 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13661 1414 1414 1 66 52 2059 3144 65535 65535 103 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3415 3413 13600 13763 1421 1421 1426 1421 486 485 487 485 1932 1931 27.4 27.9 27.8 27.9 27.9 27.9 27.8 27.9 2060 2624 3144 4036 2251 2060 2622 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 156 5632 5632 5632 5632 -64 -83 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -64 1 0.56 225 5632 5632 5632 5632 4037 9545 3084 0 5632 5632 5632 5632 16384 3152 4044 3069 SUCCESS
    37 08/08/2024 15:07 158180 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1414 1414 1 66 52 2061 3144 65535 65535 103 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13599 13763 1414 1408 1401 1417 484 480 478 484 1930 1931 27.3 27.9 27.8 27.9 27.9 27.9 27.8 27.9 2062 2626 3144 4036 2252 2061 2623 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 160 5632 5632 5632 5632 -66 -86 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -66 1 0.56 225 5632 5632 5632 5632 4037 9542 3084 0 5632 5632 5632 5632 16384 3152 4044 2931 SUCCESS
    38 08/08/2024 15:07 161759 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13661 1413 1414 1 66 52 2063 3144 65535 65535 103 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13763 1421 1408 1417 1411 486 480 484 482 1933 1931 27.5 27.9 27.8 27.9 27.9 27.9 27.8 27.9 2063 2627 3144 4036 2254 2063 2626 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 163 5632 5632 5632 5632 -67 -87 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -67 1 0.56 225 5632 5632 5632 5632 4037 9539 3084 0 5632 5632 5632 5632 16384 3152 4044 2316 SUCCESS
    39 08/08/2024 15:08 164329 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1413 1414 1 66 52 2063 3144 65535 65535 103 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3415 3415 13599 13763 1413 1411 1424 1411 484 482 486 482 1932 1932 27.4 27.9 27.8 27.9 27.9 27.9 27.8 27.9 2064 2629 3144 4036 2254 2064 2627 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 166 5632 5632 5632 5632 -68 -88 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -68 1 0.56 225 5632 5632 5632 5632 4037 9536 3084 0 5632 5632 5632 5632 16384 3152 4044 2409 SUCCESS
    40 08/08/2024 15:08 168334 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13662 1414 1414 1 66 52 2065 3144 65535 65535 103 4004 14400 0x0080 2 -9600 -10334 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3416 3415 13600 13769 1409 1427 1420 1414 482 487 485 483 1932 1932 27.4 27.9 27.8 27.9 27.9 27.9 27.8 27.9 2066 2631 3144 4036 2256 2065 2628 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 170 5632 5632 5632 5632 -69 -89 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -69 1 0.56 225 5632 5632 5632 5632 4037 9532 3084 0 5632 5632 5632 5632 16384 3152 4044 2565 SUCCESS
    41 08/08/2024 15:08 172343 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13662 1414 1414 1 66 52 2066 3144 65535 65535 103 4004 14400 0x0080 2 -9600 -10338 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3415 3413 13599 13763 1430 1420 1416 1424 489 485 484 486 1930 1932 27.4 27.9 27.8 27.9 28.0 28.0 27.8 28.0 2067 2633 3144 4036 2258 2067 2631 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 175 5632 5632 5632 5632 -71 -92 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -71 1 0.56 225 5632 5632 5632 5632 4037 9527 3084 0 5632 5632 5632 5632 16384 3152 4044 3373 SUCCESS
    42 08/08/2024 15:08 176409 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13662 1415 1414 1 66 52 2068 3144 65535 65535 103 4004 14400 0x0080 2 -9600 -10338 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3415 3415 13599 13766 1413 1417 1426 1419 484 484 487 485 1934 1932 27.5 27.9 27.8 27.9 28.0 28.0 27.8 28.0 2069 2635 3144 4036 2259 2069 2634 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 179 5632 5632 5632 5632 -73 -95 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -73 1 0.56 225 5632 5632 5632 5632 4037 9523 3084 0 5632 5632 5632 5632 16384 3152 4044 3501 SUCCESS
    43 08/08/2024 15:08 180656 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13661 1416 1414 1 66 52 2070 3144 65535 65535 102 4004 14400 0x0080 2 -9600 -10339 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3412 3415 3415 13602 13763 1418 1407 1421 1422 486 480 485 486 1934 1932 27.4 28.0 27.8 28.0 28.0 28.0 27.8 28.0 2071 2637 3144 4036 2261 2070 2635 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 183 5632 5632 5632 5632 -74 -96 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -74 1 0.56 225 5632 5632 5632 5632 4037 9519 3084 0 5632 5632 5632 5632 16384 3152 4044 3327 SUCCESS
    44 08/08/2024 15:08 184730 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13662 1414 1414 1 66 52 2072 3144 65535 65535 102 4004 14400 0x0080 2 -9600 -10339 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13598 13762 1416 1419 1423 1413 485 484 486 482 1933 1932 27.4 27.9 27.9 28.0 28.0 28.0 27.9 28.0 2072 2640 3144 4036 2263 2072 2638 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 187 5632 5632 5632 5632 -76 -99 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -76 1 0.56 225 5632 5632 5632 5632 4037 9514 3084 0 5632 5632 5632 5632 16384 3152 4044 3702 SUCCESS
    45 08/08/2024 15:08 189220 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13666 1414 1414 1 66 52 2073 3144 65535 65535 102 4004 14400 0x0080 2 -9600 -10339 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13600 13762 1410 1424 1420 1415 483 486 485 483 1933 1932 27.4 28.0 27.9 28.0 28.0 28.0 27.9 28.0 2074 2642 3144 4036 2265 2074 2640 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 191 5632 5632 5632 5632 -78 -101 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -78 1 0.56 225 5632 5632 5632 5632 4037 9510 3084 0 5632 5632 5632 5632 16384 3152 4044 3428 SUCCESS
    46 08/08/2024 15:08 193411 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13662 1415 1414 1 66 52 2075 3144 65535 65535 102 4004 14400 0x0080 2 -9600 -10342 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3414 3413 13599 13763 1423 1416 1417 1422 487 483 484 485 1932 1932 27.4 28.0 27.9 28.0 28.0 28.0 27.9 28.0 2076 2644 3144 4036 2266 2075 2641 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 195 5632 5632 5632 5632 -79 -102 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -80 1 0.56 225 5632 5632 5632 5632 4037 9506 3084 0 5632 5632 5632 5632 16384 3152 4044 3369 SUCCESS
    47 08/08/2024 15:08 197523 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13663 1413 1414 1 67 52 2076 3144 65535 65535 102 4004 14400 0x0080 2 -9600 -10342 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3415 3415 13599 13766 1420 1430 1422 1416 486 488 486 484 1932 1932 27.5 28.0 27.9 28.0 28.0 28.0 27.9 28.0 2077 2646 3144 4036 2268 2077 2644 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 200 5632 5632 5632 5632 -81 -105 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -81 1 0.56 225 5632 5632 5632 5632 4037 9502 3084 0 5632 5632 5632 5632 16384 3152 4044 3880 SUCCESS
    48 08/08/2024 15:08 202126 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13666 1414 1414 1 67 52 2078 3144 65535 65535 102 4004 14400 0x0080 2 -9600 -10342 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13763 1409 1414 1423 1425 482 482 486 486 1932 1932 27.4 28.0 27.9 28.0 28.0 28.0 27.9 28.0 2079 2648 3144 4036 2270 2079 2647 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 204 5632 5632 5632 5632 -83 -108 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -83 1 0.56 225 5632 5632 5632 5632 4037 9498 3084 0 5632 5632 5632 5632 16384 3152 4044 3214 SUCCESS
    49 08/08/2024 15:08 206030 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13661 1415 1414 1 67 52 2080 3144 65535 65535 101 4004 14400 0x0080 2 -9600 -10344 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3415 3413 13599 13763 1422 1412 1412 1423 487 482 482 486 1933 1932 27.4 28.0 27.9 28.0 28.1 28.1 27.9 28.1 2081 2650 3144 4036 2271 2080 2648 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 208 5632 5632 5632 5632 -84 -109 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -84 1 0.56 225 5632 5632 5632 5632 4037 9494 3084 0 5632 5632 5632 5632 16384 3152 4044 3239 SUCCESS
    50 08/08/2024 15:08 209985 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13661 1415 1414 1 67 53 2081 3144 65535 65535 101 4004 14400 0x0080 2 -9600 -10344 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3415 3415 13599 13764 1426 1427 1418 1421 488 487 484 485 1934 1932 27.5 28.0 27.9 28.1 28.1 28.1 27.9 28.1 2082 2652 3144 4036 2272 2082 2651 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 212 5632 5632 5632 5632 -86 -112 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -86 1 0.56 225 5632 5632 5632 5632 4037 9490 3084 0 5632 5632 5632 5632 16384 3152 4044 3145 SUCCESS
    51 08/08/2024 15:08 213281 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13665 1414 1414 1 67 53 2083 3144 65535 65535 101 4004 14400 0x0080 2 -9600 -10344 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13764 1415 1421 1424 1416 484 485 486 483 1932 1932 27.5 28.0 27.9 28.1 28.1 28.1 27.9 28.1 2083 2654 3144 4036 2274 2083 2652 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 215 5632 5632 5632 5632 -87 -113 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -87 1 0.56 225 5632 5632 5632 5632 4037 9486 3084 0 5632 5632 5632 5632 16384 3152 4044 3197 SUCCESS
    52 08/08/2024 15:08 217219 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13666 1414 1414 1 67 53 2084 3144 65535 65535 101 4004 14400 0x0080 2 -9600 -10346 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13601 13761 1428 1422 1418 1415 489 485 484 483 1933 1932 27.5 28.0 27.9 28.1 28.1 28.1 27.9 28.1 2085 2656 3144 4036 2276 2085 2654 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 219 5632 5632 5632 5632 -89 -115 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -89 1 0.56 225 5632 5632 5632 5632 4037 9482 3084 0 5632 5632 5632 5632 16384 3152 4044 3384 SUCCESS
    53 08/08/2024 15:08 221336 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13666 1413 1414 1 67 53 2086 3144 65535 65535 101 4004 14400 0x0080 2 -9600 -10347 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3414 3413 13598 13763 1419 1420 1417 1421 486 485 484 485 1933 1932 27.6 28.0 27.9 28.1 28.1 28.1 27.9 28.1 2087 2658 3144 4036 2277 2086 2656 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 223 5632 5632 5632 5632 -90 -117 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -90 1 0.56 225 5632 5632 5632 5632 4037 9478 3084 0 5632 5632 5632 5632 16384 3152 4044 3400 SUCCESS
    54 08/08/2024 15:09 225461 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13662 1414 1414 1 67 53 2087 3144 65535 65535 101 4004 14400 0x0080 2 -9600 -10347 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3415 3414 13600 13763 1420 1421 1421 1416 486 485 485 483 1932 1932 27.5 28.0 28.0 28.1 28.1 28.1 28.0 28.1 2088 2660 3144 4036 2279 2088 2658 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 228 5632 5632 5632 5632 -92 -119 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -92 1 0.56 225 5632 5632 5632 5632 4037 9474 3084 0 5632 5632 5632 5632 16384 3152 4044 3636 SUCCESS
    55 08/08/2024 15:09 229794 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13661 1415 1414 1 67 53 2089 3144 65535 65535 101 4004 14400 0x0080 2 -9600 -10347 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3415 3415 13599 13762 1422 1423 1419 1407 487 486 485 480 1934 1932 27.5 28.0 28.0 28.1 28.1 28.1 27.9 28.1 2090 2663 3144 4036 2280 2090 2661 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 232 5632 5632 5632 5632 -94 -122 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -94 1 0.56 225 5632 5632 5632 5632 4037 9470 3084 0 5632 5632 5632 5632 16384 3152 4044 3499 SUCCESS
    56 08/08/2024 15:09 234037 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13661 1414 1414 1 67 53 2091 3144 65535 65535 100 4004 14400 0x0080 2 -9600 -10347 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3414 3413 13599 13766 1417 1429 1414 1429 485 488 483 488 1935 1932 27.6 28.0 28.0 28.1 28.1 28.1 28.0 28.1 2092 2665 3144 4036 2282 2091 2662 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 236 5632 5632 5632 5632 -95 -123 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -95 1 0.56 225 5632 5632 5632 5632 4037 9466 3084 0 5632 5632 5632 5632 16384 3152 4044 3286 SUCCESS
    57 08/08/2024 15:09 238065 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13662 1414 1414 1 67 53 2092 3144 65535 65535 100 4004 14400 0x0080 2 -9600 -10347 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3415 3415 13601 13761 1428 1421 1420 1413 489 485 485 483 1935 1932 27.6 28.0 28.0 28.1 28.1 28.1 28.0 28.1 2093 2667 3144 4036 2283 2093 2665 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 240 5632 5632 5632 5632 -97 -126 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -97 1 0.56 225 5632 5632 5632 5632 4037 9462 3084 0 5632 5632 5632 5632 16384 3152 4044 3335 SUCCESS
    58 08/08/2024 15:09 242119 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13661 1414 1414 1 67 53 2094 3144 65535 65535 100 4004 14400 0x0080 2 -9600 -10351 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3415 3415 13599 13763 1422 1420 1422 1426 487 485 486 487 1934 1932 27.6 28.0 28.0 28.1 28.2 28.1 28.0 28.1 2095 2669 3144 4036 2285 2094 2666 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 244 5632 5632 5632 5632 -98 -127 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -99 1 0.56 225 5632 5632 5632 5632 4037 9458 3084 0 5632 5632 5632 5632 16384 3152 4044 3322 SUCCESS
    59 08/08/2024 15:09 246158 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13661 1416 1415 1 67 53 2096 3144 65535 65535 100 4004 14400 0x0080 2 -9600 -10352 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13599 13764 1426 1422 1427 1432 488 485 487 489 1933 1932 27.5 28.0 28.0 28.1 28.2 28.2 28.0 28.2 2096 2671 3144 4036 2287 2096 2669 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 248 5632 5632 5632 5632 -100 -130 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -100 1 0.56 225 5632 5632 5632 5632 4037 9453 3084 0 5632 5632 5632 5632 16384 3152 4044 3650 SUCCESS
    60 08/08/2024 15:09 250512 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13665 1415 1415 1 67 53 2097 3144 65535 65535 100 4004 14400 0x0080 2 -9600 -10352 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3414 13599 13762 1421 1407 1415 1409 486 480 483 481 1933 1933 27.5 28.1 28.0 28.1 28.2 28.2 28.0 28.2 2098 2673 3144 4036 2289 2098 2671 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 252 5632 5632 5632 5632 -102 -132 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -102 1 0.56 225 5632 5632 5632 5632 4037 9449 3084 0 5632 5632 5632 5632 16384 3152 4044 3426 SUCCESS
    61 08/08/2024 15:09 254663 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13663 1413 1415 1 67 53 2099 3144 65535 65535 100 4004 14400 0x0080 2 -9600 -10352 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3414 3413 13599 13762 1410 1432 1423 1410 483 489 486 481 1933 1933 27.5 28.1 28.0 28.1 28.2 28.2 28.0 28.2 2100 2675 3144 4036 2290 2099 2673 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 257 5632 5632 5632 5632 -104 -135 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -104 1 0.56 225 5632 5632 5632 5632 4037 9445 3084 0 5632 5632 5632 5632 16384 3152 4044 3904 SUCCESS
    62 08/08/2024 15:09 259241 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13661 1414 1415 1 67 53 2101 3144 65535 65535 99 4004 14400 0x0080 2 -9600 -10352 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13762 1433 1422 1426 1414 491 485 487 483 1933 1933 27.6 28.1 28.0 28.2 28.2 28.2 28.0 28.2 2101 2678 3144 4036 2292 2101 2675 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 261 5632 5632 5632 5632 -105 -136 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -105 1 0.56 225 5632 5632 5632 5632 4037 9440 3084 0 5632 5632 5632 5632 16384 3152 4044 3596 SUCCESS
    63 08/08/2024 15:09 263582 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13665 1414 1415 1 67 53 2102 3144 65535 65535 99 4004 14400 0x0080 2 -9600 -10353 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3414 13598 13763 1411 1423 1418 1425 483 485 484 486 1936 1933 27.5 28.1 28.0 28.2 28.2 28.2 28.0 28.2 2103 2680 3144 4036 2294 2103 2678 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 265 5632 5632 5632 5632 -107 -139 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -107 1 0.56 225 5632 5632 5632 5632 4037 9436 3084 0 5632 5632 5632 5632 16384 3152 4044 3448 SUCCESS
    64 08/08/2024 15:09 267781 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13662 1415 1415 1 67 53 2104 3144 65535 65535 99 4004 14400 0x0080 2 -9600 -10355 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3415 3415 13600 13763 1420 1429 1411 1419 486 488 482 485 1934 1933 27.5 28.1 28.0 28.2 28.2 28.2 28.0 28.2 2105 2682 3144 4036 2295 2104 2679 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 270 5632 5632 5632 5632 -109 -142 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -109 1 0.56 225 5632 5632 5632 5632 4037 9432 3084 0 5632 5632 5632 5632 16384 3152 4044 3940 SUCCESS
    65 08/08/2024 15:09 272396 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13661 1416 1415 1 67 53 2106 3144 65535 65535 99 4004 14400 0x0080 2 -9600 -10355 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13763 1431 1413 1418 1422 490 482 484 485 1933 1933 27.5 28.1 28.0 28.2 28.2 28.2 28.0 28.2 2107 2684 3144 4036 2297 2106 2682 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 274 5632 5632 5632 5632 -110 -143 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -110 1 0.56 225 5632 5632 5632 5632 4037 9428 3084 0 5632 5632 5632 5632 16384 3152 4044 3239 SUCCESS
    66 08/08/2024 15:09 276421 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13661 1415 1415 1 68 53 2107 3144 65535 65535 99 4004 14400 0x0080 2 -9600 -10355 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13763 1431 1417 1418 1419 490 483 484 484 1933 1933 27.5 28.1 28.0 28.2 28.2 28.2 28.0 28.2 2108 2686 3144 4036 2299 2108 2684 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 278 5632 5632 5632 5632 -112 -145 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -112 1 0.56 225 5632 5632 5632 5632 4037 9424 3084 0 5632 5632 5632 5632 16384 3152 4044 3311 SUCCESS
    67 08/08/2024 15:09 280447 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13660 1414 1415 1 68 53 2109 3144 65535 65535 99 4004 14400 0x0080 2 -9600 -10355 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13601 13763 1415 1417 1413 1421 484 483 482 485 1933 1933 27.6 28.1 28.0 28.2 28.2 28.2 28.0 28.2 2110 2688 3144 4036 2300 2109 2686 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 282 5632 5632 5632 5632 -113 -147 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -114 1 0.56 225 5632 5632 5632 5632 4037 9420 3084 0 5632 5632 5632 5632 16384 3152 4044 3709 SUCCESS
    68 08/08/2024 15:10 284913 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13661 1414 1415 1 68 53 2111 3144 65535 65535 98 4004 14400 0x0080 2 -9600 -10355 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13600 13763 1417 1425 1418 1413 485 486 484 482 1932 1933 27.6 28.1 28.0 28.2 28.2 28.2 28.1 28.2 2112 2691 3144 4036 2302 2111 2688 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 287 5632 5632 5632 5632 -116 -151 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -116 1 0.56 225 5632 5632 5632 5632 4037 9414 3084 0 5632 5632 5632 5632 16384 3152 4044 4360 SUCCESS
    69 08/08/2024 15:10 289947 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13661 1414 1415 1 68 53 2112 3144 65535 65535 98 4004 14400 0x0080 2 -9600 -10356 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13598 13762 1417 1415 1420 1433 485 483 485 489 1932 1933 27.6 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2113 2693 3144 4036 2304 2113 2691 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 291 5632 5632 5632 5632 -117 -152 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -117 1 0.56 225 5632 5632 5632 5632 4037 9410 3084 0 5632 5632 5632 5632 16384 3152 4044 3317 SUCCESS
    70 08/08/2024 15:10 293954 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13662 1415 1415 1 68 53 2114 3144 65535 65535 98 4004 14400 0x0080 2 -9600 -10358 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13597 13762 1426 1419 1417 1428 488 484 484 487 1932 1933 27.6 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2115 2695 3144 4036 2305 2115 2694 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 296 5632 5632 5632 5632 -119 -155 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -119 1 0.56 225 5632 5632 5632 5632 4037 9406 3084 0 5632 5632 5632 5632 16384 3152 4044 3651 SUCCESS
    71 08/08/2024 15:10 298325 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13661 1415 1415 1 68 53 2116 3144 65535 65535 98 4004 14400 0x0080 2 -9600 -10358 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3416 3414 13600 13762 1428 1410 1422 1429 489 481 486 488 1932 1933 27.7 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2117 2697 3144 4036 2307 2116 2695 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 300 5632 5632 5632 5632 -120 -156 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -121 1 0.56 225 5632 5632 5632 5632 4037 9402 3084 0 5632 5632 5632 5632 16384 3152 4044 3348 SUCCESS
    72 08/08/2024 15:10 302433 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13661 1415 1415 1 68 53 2118 3144 65535 65535 98 4004 14400 0x0080 2 -9600 -10358 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13598 13763 1424 1418 1432 1421 487 484 489 485 1932 1933 27.6 28.1 28.1 28.2 28.3 28.3 28.1 28.3 2118 2700 3144 4036 2309 2118 2698 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 304 5632 5632 5632 5632 -122 -159 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -122 1 0.56 225 5632 5632 5632 5632 4037 9397 3084 0 5632 5632 5632 5632 16384 3152 4044 3724 SUCCESS
    73 08/08/2024 15:10 306870 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13662 1415 1415 1 68 53 2119 3144 65535 65535 98 4004 14400 0x0080 2 -9600 -10358 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13598 13763 1411 1417 1422 1420 483 483 485 485 1936 1933 27.7 28.1 28.1 28.2 28.3 28.3 28.1 28.3 2120 2702 3144 4036 2311 2120 2700 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 308 5632 5632 5632 5632 -124 -161 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -124 1 0.56 225 5632 5632 5632 5632 4037 9393 3084 0 5632 5632 5632 5632 16384 3152 4044 3240 SUCCESS
    74 08/08/2024 15:10 310814 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13665 1415 1415 1 68 54 2121 3144 65535 65535 97 4004 14400 0x0080 2 -9600 -10358 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3413 13601 13762 1414 1421 1428 1421 484 485 488 485 1934 1933 27.7 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2122 2704 3144 4036 2312 2121 2701 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 312 5632 5632 5632 5632 -125 -162 1 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -125 1 0.56 225 5632 5632 5632 5632 4037 9390 3084 0 5632 5632 5632 5632 16384 3152 4044 3155 SUCCESS
    75 08/08/2024 15:10 314730 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13665 1416 1415 1 68 54 2122 3144 65535 65535 97 4004 14400 0x0080 2 -9600 -10358 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3413 3413 13597 13763 1412 1421 1432 1418 483 485 489 484 1933 1933 27.7 28.1 28.1 28.2 28.3 28.3 28.1 28.3 2123 2706 3144 4036 2314 2123 2704 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 316 5632 5632 5632 5632 -127 -165 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -127 2 0.56 225 5632 5632 5632 5632 4037 9385 3084 0 5632 5632 5632 5632 16384 3152 4044 3391 SUCCESS
    76 08/08/2024 15:10 318862 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13665 1413 1415 1 68 54 2124 3144 65535 65535 97 4004 14400 0x0080 2 -9600 -10361 -8000 -8000 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3412 3413 3413 13599 13763 1425 1415 1419 1420 488 483 484 485 1933 1933 27.7 28.1 28.1 28.3 28.3 28.3 28.1 28.3 2125 2708 3144 4036 2315 2124 2705 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 320 5632 5632 5632 5632 -129 -168 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -129 2 0.56 225 5632 5632 5632 5632 4037 9381 3084 0 5632 5632 5632 5632 16384 3152 4044 3486 SUCCESS
    77 08/08/2024 15:10 323074 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13641 1272 1401 1 68 54 2125 3144 65535 65535 98 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13579 13739 1282 1281 1285 1281 438 436 438 437 1745 1891 27.6 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2126 2710 3144 4036 2317 2126 2708 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 324 5632 5632 5632 5632 -130 -169 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -130 2 0.56 225 5632 5632 5632 5632 4037 9377 3084 0 5632 5632 5632 5632 16384 3152 4044 3238 SUCCESS
    78 08/08/2024 15:10 327080 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13640 1283 1372 1 68 54 2127 3144 65535 65535 100 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13740 1295 1288 1297 1292 443 439 442 440 1751 1857 27.7 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2128 2712 3144 4036 2318 2127 2709 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 328 5632 5632 5632 5632 -131 -170 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -131 2 0.56 225 5632 5632 5632 5632 4037 9373 3084 0 5632 5632 5632 5632 16384 3152 4044 3299 SUCCESS
    79 08/08/2024 15:10 331188 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13640 1286 1351 1 68 54 2128 3144 65535 65535 101 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3408 3407 13577 13738 1294 1294 1284 1298 442 441 438 442 1753 1832 27.7 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2129 2713 3144 4036 2320 2129 2712 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 332 5632 5632 5632 5632 -133 -173 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -133 2 0.56 225 5632 5632 5632 5632 4037 9369 3084 0 5632 5632 5632 5632 16384 3152 4044 3375 SUCCESS
    80 08/08/2024 15:10 335299 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1287 1335 1 68 54 2130 3144 65535 65535 103 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13577 13737 1292 1286 1283 1289 442 438 438 439 1754 1814 27.7 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2131 2715 3144 4036 2321 2130 2713 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 337 5632 5632 5632 5632 -134 -174 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -134 2 0.56 225 5632 5632 5632 5632 4037 9365 3084 0 5632 5632 5632 5632 16384 3152 4044 3397 SUCCESS
    81 08/08/2024 15:10 339402 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13638 1287 1324 1 68 54 2131 3144 65535 65535 103 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13576 13738 1299 1292 1290 1292 444 440 440 440 1757 1800 27.7 28.2 28.2 28.3 28.3 28.3 28.1 28.3 2132 2717 3144 4036 2322 2132 2716 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 340 5632 5632 5632 5632 -136 -177 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -136 2 0.56 225 5632 5632 5632 5632 4037 9361 3084 0 5632 5632 5632 5632 16384 3152 4044 3061 SUCCESS
    82 08/08/2024 15:10 343158 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1289 1315 1 68 54 2133 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13577 13737 1292 1293 1301 1298 441 440 443 442 1759 1790 27.7 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2133 2719 3144 4036 2324 2133 2717 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 345 5632 5632 5632 5632 -137 -178 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -137 2 0.56 225 5632 5632 5632 5632 4037 9357 3084 0 5632 5632 5632 5632 16384 3152 4044 3695 SUCCESS
    83 08/08/2024 15:11 347604 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13638 1290 1308 1 68 54 2134 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13577 13738 1301 1290 1300 1304 444 439 443 444 1761 1783 27.6 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2135 2721 3144 4036 2326 2135 2720 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 349 5632 5632 5632 5632 -139 -181 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -139 2 0.56 225 5632 5632 5632 5632 4037 9352 3084 0 5632 5632 5632 5632 16384 3152 4044 3789 SUCCESS
    84 08/08/2024 15:11 352183 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13640 1291 1304 1 68 54 2136 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13577 13741 1296 1294 1295 1300 443 441 441 443 1765 1778 27.7 28.2 28.2 28.3 28.3 28.3 28.2 28.3 2137 2723 3144 4036 2327 2136 2721 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 353 5632 5632 5632 5632 -140 -182 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -140 2 0.56 225 5632 5632 5632 5632 4037 9348 3084 0 5632 5632 5632 5632 16384 3152 4044 3390 SUCCESS
    85 08/08/2024 15:11 356315 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1293 1301 1 68 54 2137 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13576 13737 1300 1302 1289 1289 444 443 439 439 1763 1774 27.7 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2138 2725 3144 4036 2328 2138 2724 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 357 5632 5632 5632 5632 -142 -185 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -142 2 0.56 225 5632 5632 5632 5632 4037 9344 3084 0 5632 5632 5632 5632 16384 3152 4044 3133 SUCCESS
    86 08/08/2024 15:11 360128 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13643 1294 1300 1 69 54 2139 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13576 13737 1307 1298 1300 1296 446 442 443 442 1765 1771 27.7 28.2 28.2 28.3 28.3 28.3 28.2 28.3 2140 2727 3144 4036 2330 2139 2725 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 361 5632 5632 5632 5632 -143 -186 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -143 2 0.56 225 5632 5632 5632 5632 4037 9340 3084 0 5632 5632 5632 5632 16384 3152 4044 3560 SUCCESS
    87 08/08/2024 15:11 364354 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1296 1298 1 69 54 2140 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13577 13738 1301 1301 1301 1294 445 443 443 441 1766 1770 27.6 28.2 28.1 28.3 28.3 28.3 28.1 28.3 2141 2729 3144 4036 2331 2141 2727 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 365 5632 5632 5632 5632 -145 -188 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -145 2 0.56 225 5632 5632 5632 5632 4037 9336 3084 0 5632 5632 5632 5632 16384 3152 4044 3293 SUCCESS
    88 08/08/2024 15:11 368384 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1295 1298 1 69 54 2142 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13575 13739 1314 1300 1295 1304 449 443 442 445 1767 1769 27.8 28.2 28.2 28.3 28.3 28.3 28.2 28.3 2142 2731 3144 4036 2333 2142 2729 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 370 5632 5632 5632 5632 -146 -190 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -146 2 0.56 225 5632 5632 5632 5632 4037 9332 3084 0 5632 5632 5632 5632 16384 3152 4044 3623 SUCCESS
    89 08/08/2024 15:11 372821 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13638 1295 1297 1 69 54 2143 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13577 13741 1307 1294 1308 1304 447 441 446 445 1768 1769 27.8 28.2 28.2 28.4 28.3 28.3 28.2 28.3 2144 2733 3144 4036 2334 2144 2731 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 374 5632 5632 5632 5632 -148 -192 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -148 2 0.56 225 5632 5632 5632 5632 4037 9328 3084 0 5632 5632 5632 5632 16384 3152 4044 3213 SUCCESS
    90 08/08/2024 15:11 376826 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13637 1296 1297 1 69 54 2145 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13581 13737 1301 1299 1310 1309 445 443 447 446 1768 1768 27.7 28.2 28.2 28.4 28.3 28.4 28.2 28.4 2145 2735 3144 4036 2336 2145 2733 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 378 5632 5632 5632 5632 -149 -194 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -149 2 0.56 225 5632 5632 5632 5632 4037 9324 3084 0 5632 5632 5632 5632 16384 3152 4044 3572 SUCCESS
    91 08/08/2024 15:11 381140 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13642 1297 1296 1 69 54 2146 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13577 13737 1299 1298 1304 1303 444 442 444 444 1767 1768 27.7 28.2 28.2 28.4 28.3 28.4 28.2 28.4 2147 2737 3144 4036 2337 2147 2735 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 382 5632 5632 5632 5632 -151 -196 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -151 2 0.56 225 5632 5632 5632 5632 4037 9319 3084 0 5632 5632 5632 5632 16384 3152 4044 3613 SUCCESS
    92 08/08/2024 15:11 385409 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1298 1297 1 69 54 2148 3144 65535 65535 104 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3407 13575 13738 1302 1303 1307 1296 445 444 446 442 1769 1768 27.7 28.2 28.2 28.4 28.3 28.4 28.2 28.4 2149 2739 3144 4036 2339 2148 2737 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 386 5632 5632 5632 5632 -152 -198 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -152 2 0.56 225 5632 5632 5632 5632 4037 9315 3084 0 5632 5632 5632 5632 16384 3152 4044 3331 SUCCESS
    93 08/08/2024 15:11 389434 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13638 1297 1297 1 69 54 2149 3144 65535 65535 103 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3409 13575 13739 1312 1302 1301 1311 448 444 444 447 1770 1768 27.7 28.2 28.2 28.4 28.3 28.4 28.2 28.4 2150 2741 3144 4036 2340 2150 2739 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 391 5632 5632 5632 5632 -154 -200 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -154 2 0.56 225 5632 5632 5632 5632 4037 9311 3084 0 5632 5632 5632 5632 16384 3152 4044 3556 SUCCESS
    94 08/08/2024 15:11 393742 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13638 1298 1297 1 69 54 2151 3144 65535 65535 103 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13577 13737 1310 1298 1292 1302 447 442 440 444 1772 1769 27.8 28.2 28.2 28.4 28.3 28.4 28.2 28.4 2151 2743 3144 4036 2342 2151 2741 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 394 5632 5632 5632 5632 -155 -202 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -155 2 0.56 225 5632 5632 5632 5632 4037 9307 3084 0 5632 5632 5632 5632 16384 3152 4044 2968 SUCCESS
    95 08/08/2024 15:11 397492 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1298 1297 1 69 54 2152 3144 65535 65535 103 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3408 13577 13738 1304 1303 1295 1298 445 444 441 442 1772 1769 27.8 28.2 28.2 28.4 28.4 28.4 28.2 28.4 2153 2745 3144 4036 2343 2152 2742 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 398 5632 5632 5632 5632 -157 -204 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -157 2 0.56 225 5632 5632 5632 5632 4037 9303 3084 0 5632 5632 5632 5632 16384 3152 4044 3360 SUCCESS
    96 08/08/2024 15:11 401519 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1297 1297 1 69 54 2153 3144 65535 65535 103 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3405 3408 3407 13575 13738 1302 1294 1303 1298 445 441 444 442 1772 1769 27.8 28.2 28.2 28.4 28.3 28.4 28.2 28.4 2154 2746 3144 4036 2345 2154 2744 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 402 5632 5632 5632 5632 -158 -205 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -158 2 0.56 225 5632 5632 5632 5632 4037 9299 3084 0 5632 5632 5632 5632 16384 3152 4044 3308 SUCCESS
    97 08/08/2024 15:12 405475 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1299 1298 1 69 54 2155 3144 65535 65535 103 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3408 13577 13738 1303 1303 1309 1305 445 444 446 445 1770 1770 27.8 28.2 28.2 28.4 28.3 28.4 28.2 28.4 2156 2748 3144 4036 2346 2155 2746 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 406 5632 5632 5632 5632 -159 -207 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -159 2 0.56 225 5632 5632 5632 5632 4037 9295 3084 0 5632 5632 5632 5632 16384 3152 4044 3193 SUCCESS
    98 08/08/2024 15:12 409450 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1299 1298 1 69 54 2156 3144 65535 65535 103 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13575 13737 1309 1304 1295 1295 447 444 441 441 1771 1770 27.7 28.2 28.2 28.4 28.3 28.4 28.2 28.4 2157 2750 3144 4036 2348 2157 2748 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 410 5632 5632 5632 5632 -161 -209 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -161 2 0.56 225 5632 5632 5632 5632 4037 9291 3084 0 5632 5632 5632 5632 16384 3152 4044 3317 SUCCESS
    99 08/08/2024 15:12 413501 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1300 1298 1 69 54 2158 3144 65535 65535 102 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13576 13738 1297 1306 1294 1307 443 445 441 445 1772 1770 27.7 28.2 28.2 28.4 28.4 28.4 28.2 28.4 2159 2752 3144 4036 2349 2158 2750 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 414 5632 5632 5632 5632 -162 -211 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -162 2 0.56 225 5632 5632 5632 5632 4037 9287 3084 0 5632 5632 5632 5632 16384 3152 4044 3351 SUCCESS
    100 08/08/2024 15:12 417520 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13638 1300 1298 1 69 54 2159 3144 65535 65535 102 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13577 13739 1311 1306 1304 1306 448 445 444 445 1770 1771 27.8 28.2 28.2 28.4 28.4 28.4 28.2 28.4 2160 2754 3144 4036 2350 2160 2752 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 418 5632 5632 5632 5632 -164 -213 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -164 2 0.56 225 5632 5632 5632 5632 4037 9283 3084 0 5632 5632 5632 5632 16384 3152 4044 3462 SUCCESS
    101 08/08/2024 15:12 421700 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1299 1299 1 69 55 2161 3144 65535 65535 102 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13577 13740 1294 1297 1307 1302 442 442 445 444 1773 1771 27.8 28.2 28.2 28.4 28.4 28.4 28.2 28.4 2161 2756 3144 4036 2352 2161 2754 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 422 5632 5632 5632 5632 -165 -215 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -165 2 0.56 225 5632 5632 5632 5632 4037 9279 3084 0 5632 5632 5632 5632 16384 3152 4044 3147 SUCCESS
    102 08/08/2024 15:12 425592 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1299 1299 1 69 55 2162 3144 65535 65535 102 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3407 13577 13738 1304 1292 1307 1302 445 440 446 444 1776 1771 27.8 28.3 28.2 28.4 28.4 28.4 28.2 28.4 2163 2758 3144 4036 2353 2163 2756 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 426 5632 5632 5632 5632 -167 -217 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -167 2 0.56 225 5632 5632 5632 5632 4037 9275 3084 0 5632 5632 5632 5632 16384 3152 4044 3425 SUCCESS
    103 08/08/2024 15:12 429759 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13639 1300 1299 1 69 55 2164 3144 65535 65535 102 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3407 13575 13739 1295 1300 1310 1305 442 443 447 445 1774 1772 27.6 28.3 28.2 28.3 28.4 28.4 28.2 28.4 2164 2759 3144 4036 2355 2164 2757 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 430 5632 5632 5632 5632 -168 -218 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -168 2 0.56 225 5632 5632 5632 5632 4037 9271 3084 0 5632 5632 5632 5632 16384 3152 4044 3342 SUCCESS
    104 08/08/2024 15:12 433843 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13638 1300 1299 1 69 55 2165 3144 65535 65535 102 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3407 13577 13739 1300 1303 1304 1296 444 444 444 442 1773 1772 27.8 28.3 28.2 28.3 28.4 28.3 28.2 28.3 2166 2761 3144 4036 2356 2165 2759 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 434 5632 5632 5632 5632 -170 -221 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -170 2 0.56 225 5632 5632 5632 5632 4037 9267 3084 0 5632 5632 5632 5632 16384 3152 4044 3484 SUCCESS
    105 08/08/2024 15:12 437953 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1301 1300 1 69 55 2166 3144 65535 65535 101 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3409 13577 13737 1308 1312 1295 1310 447 447 442 447 1774 1773 27.7 28.2 28.2 28.3 28.3 28.3 28.2 28.3 2167 2763 3144 4036 2358 2167 2761 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 439 5632 5632 5632 5632 -171 -222 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -171 2 0.56 225 5632 5632 5632 5632 4037 9262 3084 0 5632 5632 5632 5632 16384 3152 4044 3739 SUCCESS
    106 08/08/2024 15:12 442402 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13638 1301 1300 1 69 55 2168 3144 65535 65535 101 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3407 13578 13740 1309 1308 1310 1306 447 446 447 445 1774 1773 27.7 28.2 28.2 28.2 28.3 28.3 28.2 28.3 2169 2766 3144 4036 2360 2169 2764 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 443 5632 5632 5632 5632 -173 -225 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -173 2 0.56 225 5632 5632 5632 5632 4037 9258 3084 0 5632 5632 5632 5632 16384 3152 4044 3541 SUCCESS
    107 08/08/2024 15:12 446642 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1300 1300 1 70 55 2170 3144 65535 65535 101 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3407 13579 13738 1305 1317 1308 1299 446 449 446 443 1776 1773 27.6 28.2 28.2 28.2 28.3 28.3 28.2 28.3 2171 2767 3144 4036 2361 2170 2765 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 447 5632 5632 5632 5632 -174 -226 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -174 2 0.56 225 5632 5632 5632 5632 4037 9254 3084 0 5632 5632 5632 5632 16384 3152 4044 3384 SUCCESS
    108 08/08/2024 15:12 450753 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1302 1300 1 70 55 2171 3144 65535 65535 101 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3405 3409 3408 13577 13738 1297 1297 1306 1308 443 442 445 446 1774 1774 27.6 28.2 28.1 28.1 28.3 28.3 28.1 28.3 2172 2769 3144 4036 2362 2172 2768 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 451 5632 5632 5632 5632 -176 -229 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -176 2 0.56 225 5632 5632 5632 5632 4037 9250 3084 0 5632 5632 5632 5632 16384 3152 4044 3364 SUCCESS
    109 08/08/2024 15:12 454836 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1302 1301 1 70 55 2173 3144 65535 65535 101 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3407 13577 13739 1298 1310 1309 1309 444 446 446 446 1777 1774 27.5 28.2 28.1 28.1 28.3 28.3 28.1 28.3 2173 2771 3144 4036 2364 2173 2769 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 455 5632 5632 5632 5632 -177 -230 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -177 2 0.56 225 5632 5632 5632 5632 4037 9246 3084 0 5632 5632 5632 5632 16384 3152 4044 3267 SUCCESS
    110 08/08/2024 15:12 458841 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13639 1302 1301 1 70 55 2174 3144 65535 65535 100 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13577 13739 1308 1318 1306 1321 447 449 445 450 1776 1775 27.5 28.2 28.1 28.0 28.2 28.2 28.1 28.2 2175 2773 3144 4036 2365 2174 2770 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 459 5632 5632 5632 5632 -179 -233 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -179 2 0.56 225 5632 5632 5632 5632 4037 9242 3084 0 5632 5632 5632 5632 16384 3152 4044 3505 SUCCESS
    111 08/08/2024 15:12 463070 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13638 1303 1302 1 70 55 2176 3144 65535 65535 100 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13577 13742 1300 1304 1314 1316 444 444 448 449 1778 1775 27.5 28.2 28.1 28.0 28.2 28.2 28.1 28.2 2176 2775 3144 4036 2367 2176 2773 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 464 5632 5632 5632 5632 -180 -234 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -180 2 0.56 225 5632 5632 5632 5632 4037 9238 3084 0 5632 5632 5632 5632 16384 3152 4044 3702 SUCCESS
    112 08/08/2024 15:13 467389 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13639 1303 1302 1 70 55 2177 3144 65535 65535 100 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3407 13582 13737 1310 1303 1317 1301 448 444 449 443 1777 1776 27.4 28.2 28.1 28.0 28.2 28.2 28.0 28.2 2178 2777 3144 4036 2369 2178 2776 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 468 5632 5632 5632 5632 -182 -237 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -182 2 0.56 225 5632 5632 5632 5632 4037 9233 3084 0 5632 5632 5632 5632 16384 3152 4044 3643 SUCCESS
    113 08/08/2024 15:13 471738 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13640 1304 1302 1 70 55 2179 3144 65535 65535 100 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13578 13737 1314 1304 1310 1303 449 444 446 444 1777 1776 27.4 28.1 28.0 28.0 28.2 28.2 28.0 28.2 2180 2779 3144 4036 2370 2179 2777 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 473 5632 5632 5632 5632 -183 -238 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -183 2 0.56 225 5632 5632 5632 5632 4037 9229 3084 0 5632 5632 5632 5632 16384 3152 4044 4050 SUCCESS
    114 08/08/2024 15:13 476389 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13639 1303 1302 1 70 55 2181 3144 65535 65535 100 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13577 13740 1294 1303 1314 1304 442 444 448 444 1777 1776 27.4 28.2 28.0 27.9 28.2 28.2 28.0 28.2 2181 2782 3144 4036 2372 2181 2780 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 477 5632 5632 5632 5632 -185 -241 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -185 2 0.56 225 5632 5632 5632 5632 4037 9224 3084 0 5632 5632 5632 5632 16384 3152 4044 3978 SUCCESS
    115 08/08/2024 15:13 480993 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13640 1304 1303 1 70 55 2182 3144 65535 65535 99 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13738 1313 1310 1309 1308 449 446 446 446 1779 1777 27.3 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2183 2784 3144 4036 2373 2183 2782 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 482 5632 5632 5632 5632 -187 -243 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -187 2 0.56 225 5632 5632 5632 5632 4037 9220 3084 0 5632 5632 5632 5632 16384 3152 4044 3619 SUCCESS
    116 08/08/2024 15:13 485342 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13639 1305 1303 1 70 55 2184 3144 65535 65535 99 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13738 1320 1301 1306 1313 451 443 445 447 1779 1778 27.3 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2185 2786 3144 4036 2375 2184 2784 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 486 5632 5632 5632 5632 -188 -245 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -188 2 0.56 225 5632 5632 5632 5632 4037 9215 3084 0 5632 5632 5632 5632 16384 3152 4044 3914 SUCCESS
    117 08/08/2024 15:13 489918 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13640 1304 1303 1 70 55 2185 3144 65535 65535 99 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3407 13577 13739 1311 1310 1315 1295 448 446 448 441 1779 1778 27.2 28.1 27.9 27.9 28.1 28.1 27.9 28.1 2186 2788 3144 4036 2377 2186 2786 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 490 5632 5632 5632 5632 -190 -247 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -190 2 0.56 225 5632 5632 5632 5632 4037 9211 3084 0 5632 5632 5632 5632 16384 3152 4044 3429 SUCCESS
    118 08/08/2024 15:13 494053 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13639 1304 1304 1 70 55 2187 3144 65535 65535 99 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13741 1304 1313 1314 1311 446 447 448 447 1779 1778 27.3 28.1 27.9 27.9 28.1 28.1 27.9 28.1 2188 2790 3144 4036 2378 2187 2787 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 494 5632 5632 5632 5632 -191 -248 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -191 2 0.56 225 5632 5632 5632 5632 4037 9207 3084 0 5632 5632 5632 5632 16384 3152 4044 2976 SUCCESS
    119 08/08/2024 15:13 497876 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13640 1303 1304 1 70 55 2188 3144 65535 65535 99 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13740 1307 1312 1301 1318 447 447 444 449 1779 1778 27.4 28.1 27.9 27.9 28.0 28.1 28.0 28.1 2189 2792 3144 4036 2379 2189 2790 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 498 5632 5632 5632 5632 -193 -251 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -193 2 0.56 225 5632 5632 5632 5632 4037 9203 3084 0 5632 5632 5632 5632 16384 3152 4044 3580 SUCCESS
    120 08/08/2024 15:13 502117 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13640 1304 1304 1 70 55 2190 3144 65535 65535 99 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3407 13577 13739 1307 1313 1295 1305 447 447 441 445 1780 1779 27.3 28.1 27.9 27.9 28.0 28.1 27.9 28.1 2191 2794 3144 4036 2381 2190 2791 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 502 5632 5632 5632 5632 -194 -252 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -194 2 0.56 225 5632 5632 5632 5632 4037 9199 3084 0 5632 5632 5632 5632 16384 3152 4044 3357 SUCCESS
    121 08/08/2024 15:13 506200 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13639 1306 1304 1 70 55 2191 3144 65535 65535 98 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13579 13739 1310 1319 1304 1312 448 449 445 447 1780 1779 27.3 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2192 2796 3144 4036 2382 2192 2794 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 507 5632 5632 5632 5632 -196 -255 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -196 2 0.56 225 5632 5632 5632 5632 4037 9195 3084 0 5632 5632 5632 5632 16384 3152 4044 3668 SUCCESS
    122 08/08/2024 15:13 510512 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13638 1305 1304 1 70 55 2193 3144 65535 65535 98 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13577 13739 1306 1307 1295 1309 446 445 441 446 1779 1779 27.4 28.1 27.9 27.9 28.0 28.1 27.9 28.1 2194 2797 3144 4036 2384 2193 2795 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 511 5632 5632 5632 5632 -197 -256 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -197 2 0.56 225 5632 5632 5632 5632 4037 9191 3084 0 5632 5632 5632 5632 16384 3152 4044 3456 SUCCESS
    123 08/08/2024 15:13 514717 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13643 1305 1304 1 70 55 2194 3144 65535 65535 98 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13742 1305 1315 1301 1307 446 448 444 445 1779 1779 27.4 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2195 2799 3144 4036 2386 2195 2798 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 515 5632 5632 5632 5632 -199 -259 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -199 2 0.56 225 5632 5632 5632 5632 4037 9186 3084 0 5632 5632 5632 5632 16384 3152 4044 3516 SUCCESS
    124 08/08/2024 15:13 518976 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1304 1305 1 70 55 2196 3144 65535 65535 98 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13580 13739 1313 1313 1313 1305 449 447 447 445 1779 1779 27.3 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2197 2801 3144 4036 2387 2196 2799 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 519 5632 5632 5632 5632 -200 -260 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -200 2 0.56 225 5632 5632 5632 5632 4037 9182 3084 0 5632 5632 5632 5632 16384 3152 4044 3296 SUCCESS
    125 08/08/2024 15:13 522997 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1305 1305 1 70 55 2197 3144 65535 65535 98 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13579 13738 1317 1315 1304 1323 450 448 444 451 1780 1780 27.2 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2198 2803 3144 4036 2388 2198 2802 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 523 5632 5632 5632 5632 -202 -263 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -202 2 0.56 225 5632 5632 5632 5632 4037 9178 3084 0 5632 5632 5632 5632 16384 3152 4044 3227 SUCCESS
    126 08/08/2024 15:14 526946 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1305 1305 1 70 55 2199 3144 65535 65535 98 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13577 13743 1319 1303 1312 1315 451 444 447 448 1781 1780 27.4 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2200 2805 3144 4036 2390 2199 2803 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 527 5632 5632 5632 5632 -203 -264 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -203 2 0.56 225 5632 5632 5632 5632 4037 9174 3084 0 5632 5632 5632 5632 16384 3152 4044 3699 SUCCESS
    127 08/08/2024 15:14 531393 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1305 1305 1 70 55 2200 3144 65535 65535 97 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3409 13577 13740 1299 1322 1319 1324 444 451 450 451 1782 1780 27.2 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2201 2807 3144 4036 2391 2201 2806 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 532 5632 5632 5632 5632 -205 -267 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -205 2 0.56 225 5632 5632 5632 5632 4037 9170 3084 0 5632 5632 5632 5632 16384 3152 4044 3600 SUCCESS
    128 08/08/2024 15:14 535732 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1307 1305 1 71 56 2202 3144 65535 65535 97 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13741 1300 1318 1308 1315 444 449 446 448 1780 1780 27.3 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2203 2809 3144 4036 2393 2202 2807 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 536 5632 5632 5632 5632 -206 -268 2 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -206 2 0.56 225 5632 5632 5632 5632 4037 9165 3084 0 5632 5632 5632 5632 16384 3152 4044 3580 SUCCESS
    129 08/08/2024 15:14 540016 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1307 1306 1 71 56 2203 3144 65535 65535 97 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13579 13740 1303 1308 1305 1308 445 446 445 446 1781 1781 27.3 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2204 2811 3144 4036 2395 2204 2810 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 540 5632 5632 5632 5632 -208 -271 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -208 3 0.56 225 5632 5632 5632 5632 4037 9161 3084 0 5632 5632 5632 5632 16384 3152 4044 3408 SUCCESS
    130 08/08/2024 15:14 544166 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1306 1 71 56 2205 3144 65535 65535 97 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13738 1301 1311 1313 1317 445 447 448 449 1781 1781 27.2 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2206 2813 3144 4036 2396 2205 2811 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 544 5632 5632 5632 5632 -209 -272 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -209 3 0.56 225 5632 5632 5632 5632 4037 9157 3084 0 5632 5632 5632 5632 16384 3152 4044 3448 SUCCESS
    131 08/08/2024 15:14 548340 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1306 1 71 56 2206 3144 65535 65535 97 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13740 1304 1314 1302 1302 446 448 444 444 1783 1781 27.3 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2207 2815 3144 4036 2398 2207 2813 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 548 5632 5632 5632 5632 -211 -274 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -211 3 0.56 225 5632 5632 5632 5632 4037 9153 3084 0 5632 5632 5632 5632 16384 3152 4044 3364 SUCCESS
    132 08/08/2024 15:14 552397 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1306 1 71 56 2208 3144 65535 65535 97 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3409 13577 13739 1316 1318 1321 1305 450 449 450 445 1783 1781 27.3 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2209 2817 3144 4036 2399 2208 2815 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 553 5632 5632 5632 5632 -212 -276 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -212 3 0.56 225 5632 5632 5632 5632 4037 9149 3084 0 5632 5632 5632 5632 16384 3152 4044 3453 SUCCESS
    133 08/08/2024 15:14 556537 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1306 1 71 56 2209 3144 65535 65535 96 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13577 13742 1313 1327 1314 1317 449 452 448 449 1782 1781 27.2 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2210 2819 3144 4036 2400 2210 2817 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 557 5632 5632 5632 5632 -214 -278 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -214 3 0.56 225 5632 5632 5632 5632 4037 9145 3084 0 5632 5632 5632 5632 16384 3152 4044 3327 SUCCESS
    134 08/08/2024 15:14 560593 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1306 1306 1 71 56 2211 3144 65535 65535 96 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13580 13739 1317 1323 1305 1326 450 451 445 452 1785 1781 27.3 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2212 2821 3144 4036 2402 2211 2819 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 561 5632 5632 5632 5632 -215 -280 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -215 3 0.56 225 5632 5632 5632 5632 4037 9141 3084 0 5632 5632 5632 5632 16384 3152 4044 3362 SUCCESS
    135 08/08/2024 15:14 564716 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1307 1306 1 71 56 2213 3144 65535 65535 96 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3407 13576 13738 1316 1311 1308 1315 450 447 446 448 1780 1782 27.3 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2213 2823 3144 4036 2403 2213 2821 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 565 5632 5632 5632 5632 -217 -282 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -217 3 0.56 225 5632 5632 5632 5632 4037 9137 3084 0 5632 5632 5632 5632 16384 3152 4044 3478 SUCCESS
    136 08/08/2024 15:14 568987 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1307 1306 1 71 56 2214 3144 65535 65535 96 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3406 3409 3408 13577 13743 1312 1316 1306 1309 448 448 445 446 1783 1782 27.1 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2215 2825 3144 4036 2405 2214 2823 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 569 5632 5632 5632 5632 -218 -284 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -218 3 0.56 225 5632 5632 5632 5632 4037 9132 3084 0 5632 5632 5632 5632 16384 3152 4044 3447 SUCCESS
    137 08/08/2024 15:14 573129 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1306 1306 1 71 56 2215 3144 65535 65535 96 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13581 13740 1323 1313 1310 1308 452 447 447 446 1781 1782 27.2 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2216 2827 3144 4036 2407 2216 2825 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 573 5632 5632 5632 5632 -220 -286 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -220 3 0.56 225 5632 5632 5632 5632 4037 9128 3084 0 5632 5632 5632 5632 16384 3152 4044 3290 SUCCESS
    138 08/08/2024 15:14 577144 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1307 1306 1 71 56 2217 3144 65535 65535 96 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13578 13739 1314 1306 1306 1307 449 445 445 445 1783 1782 27.2 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2218 2829 3144 4036 2408 2217 2827 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 577 5632 5632 5632 5632 -221 -288 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -221 3 0.56 225 5632 5632 5632 5632 4037 9124 3084 0 5632 5632 5632 5632 16384 3152 4044 3436 SUCCESS
    139 08/08/2024 15:14 581338 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1308 1306 1 71 56 2218 3144 65535 65535 96 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13743 1316 1311 1309 1313 450 447 446 447 1781 1782 27.3 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2219 2831 3144 4036 2410 2219 2829 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 581 5632 5632 5632 5632 -223 -290 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -223 3 0.56 225 5632 5632 5632 5632 4037 9120 3084 0 5632 5632 5632 5632 16384 3152 4044 3393 SUCCESS
    140 08/08/2024 15:15 585483 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1307 1306 1 71 56 2220 3144 65535 65535 95 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13741 1313 1310 1310 1299 449 446 447 443 1781 1782 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2221 2833 3144 4036 2411 2220 2830 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 586 5632 5632 5632 5632 -224 -291 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -224 3 0.56 225 5632 5632 5632 5632 4037 9116 3084 0 5632 5632 5632 5632 16384 3152 4044 3516 SUCCESS
    141 08/08/2024 15:15 589739 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1307 1 71 56 2222 3144 65535 65535 95 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13577 13744 1312 1306 1309 1306 448 445 446 445 1782 1782 27.3 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2222 2835 3144 4036 2412 2222 2833 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 590 5632 5632 5632 5632 -226 -294 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -226 3 0.56 225 5632 5632 5632 5632 4037 9112 3084 0 5632 5632 5632 5632 16384 3152 4044 3546 SUCCESS
    142 08/08/2024 15:15 594016 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1305 1306 1 71 56 2223 3144 65535 65535 95 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13580 13740 1315 1308 1313 1313 449 446 447 447 1783 1782 27.3 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2224 2837 3144 4036 2414 2223 2834 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 594 5632 5632 5632 5632 -227 -295 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -227 3 0.56 225 5632 5632 5632 5632 4037 9108 3084 0 5632 5632 5632 5632 16384 3152 4044 3255 SUCCESS
    143 08/08/2024 15:15 598006 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1306 1307 1 71 56 2224 3144 65535 65535 95 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13577 13738 1311 1314 1306 1306 448 448 445 445 1784 1782 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2225 2839 3144 4036 2416 2225 2837 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 598 5632 5632 5632 5632 -229 -298 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -229 3 0.56 225 5632 5632 5632 5632 4037 9104 3084 0 5632 5632 5632 5632 16384 3152 4044 3528 SUCCESS
    144 08/08/2024 15:15 602300 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1307 1307 1 71 56 2226 3144 65535 65535 95 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3406 3409 3408 13577 13741 1308 1316 1316 1313 447 448 449 447 1783 1782 27.3 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2227 2841 3144 4036 2417 2226 2838 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 602 5632 5632 5632 5632 -230 -299 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -230 3 0.56 225 5632 5632 5632 5632 4037 9099 3084 0 5632 5632 5632 5632 16384 3152 4044 3418 SUCCESS
    145 08/08/2024 15:15 606456 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1307 1307 1 71 56 2227 3144 65535 65535 94 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13580 13741 1321 1311 1309 1307 451 447 446 445 1783 1782 27.3 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2228 2843 3144 4036 2419 2228 2841 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 606 5632 5632 5632 5632 -232 -302 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -232 3 0.56 225 5632 5632 5632 5632 4037 9095 3084 0 5632 5632 5632 5632 16384 3152 4044 3377 SUCCESS
    146 08/08/2024 15:15 610560 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1307 1307 1 71 56 2229 3144 65535 65535 94 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3408 13578 13740 1309 1314 1303 1317 447 448 444 449 1783 1782 27.3 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2230 2844 3144 4036 2420 2229 2842 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 610 5632 5632 5632 5632 -233 -303 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -233 3 0.56 225 5632 5632 5632 5632 4037 9091 3084 0 5632 5632 5632 5632 16384 3152 4044 3266 SUCCESS
    147 08/08/2024 15:15 614530 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1307 1307 1 71 56 2230 3144 65535 65535 94 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13741 1311 1313 1304 1312 448 447 445 447 1781 1782 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2231 2846 3144 4036 2422 2231 2845 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 614 5632 5632 5632 5632 -235 -306 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -235 3 0.56 225 5632 5632 5632 5632 4037 9087 3084 0 5632 5632 5632 5632 16384 3152 4044 3391 SUCCESS
    148 08/08/2024 15:15 618678 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1307 1307 1 71 56 2232 3144 65535 65535 94 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13579 13739 1315 1315 1306 1314 449 448 445 448 1784 1782 27.3 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2233 2848 3144 4036 2423 2232 2846 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 618 5632 5632 5632 5632 -236 -307 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -236 3 0.56 225 5632 5632 5632 5632 4037 9083 3084 0 5632 5632 5632 5632 16384 3152 4044 3242 SUCCESS
    149 08/08/2024 15:15 622684 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1306 1307 1 72 56 2233 3144 65535 65535 94 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13578 13741 1310 1307 1322 1310 448 445 451 446 1783 1782 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2234 2850 3144 4036 2424 2234 2849 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 623 5632 5632 5632 5632 -238 -310 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -238 3 0.56 225 5632 5632 5632 5632 4037 9079 3084 0 5632 5632 5632 5632 16384 3152 4044 3529 SUCCESS
    150 08/08/2024 15:15 626957 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1307 1 72 56 2235 3144 65535 65535 94 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13580 13741 1316 1323 1311 1300 450 451 447 443 1785 1782 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2236 2852 3144 4036 2426 2235 2850 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 627 5632 5632 5632 5632 -239 -311 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -239 3 0.56 225 5632 5632 5632 5632 4037 9075 3084 0 5632 5632 5632 5632 16384 3152 4044 3325 SUCCESS
    151 08/08/2024 15:15 631061 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1307 1307 1 72 56 2236 3144 65535 65535 94 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3410 13579 13739 1304 1317 1309 1310 446 449 446 447 1783 1782 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2237 2854 3144 4036 2427 2237 2853 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 630 5632 5632 5632 5632 -241 -314 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -241 3 0.56 225 5632 5632 5632 5632 4037 9071 3084 0 5632 5632 5632 5632 16384 3152 4044 2969 SUCCESS
    152 08/08/2024 15:15 634831 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1307 1307 1 72 56 2238 3144 65535 65535 93 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3410 13577 13742 1319 1313 1322 1300 451 447 451 443 1783 1783 27.3 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2239 2856 3144 4036 2429 2238 2854 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 635 5632 5632 5632 5632 -242 -315 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -242 3 0.56 225 5632 5632 5632 5632 4037 9067 3084 0 5632 5632 5632 5632 16384 3152 4044 3636 SUCCESS
    153 08/08/2024 15:15 639199 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1307 1307 1 72 56 2239 3144 65535 65535 93 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13580 13741 1312 1315 1311 1306 448 448 447 445 1783 1783 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2240 2858 3144 4036 2430 2240 2857 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 639 5632 5632 5632 5632 -244 -318 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -244 3 0.56 225 5632 5632 5632 5632 4037 9063 3084 0 5632 5632 5632 5632 16384 3152 4044 3243 SUCCESS
    154 08/08/2024 15:15 643132 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1307 1 72 57 2241 3144 65535 65535 93 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3410 13579 13739 1313 1320 1307 1305 449 450 446 445 1783 1783 27.3 27.9 27.8 27.7 27.9 27.9 27.8 27.9 2241 2860 3144 4036 2432 2241 2858 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 643 5632 5632 5632 5632 -245 -319 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -245 3 0.56 225 5632 5632 5632 5632 4037 9059 3084 0 5632 5632 5632 5632 16384 3152 4044 3251 SUCCESS
    155 08/08/2024 15:16 647099 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1307 1 72 57 2242 3144 65535 65535 93 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13741 1311 1311 1310 1319 448 447 447 450 1784 1783 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2243 2862 3144 4036 2433 2242 2859 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 647 5632 5632 5632 5632 -246 -320 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -247 3 0.56 225 5632 5632 5632 5632 4037 9055 3084 0 5632 5632 5632 5632 16384 3152 4044 3184 SUCCESS
    156 08/08/2024 15:16 650964 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13641 1307 1307 1 72 57 2243 3144 65535 65535 93 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13579 13741 1315 1308 1319 1318 449 446 450 449 1781 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2244 2864 3144 4036 2435 2244 2862 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 651 5632 5632 5632 5632 -248 -323 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -248 3 0.56 225 5632 5632 5632 5632 4037 9051 3084 0 5632 5632 5632 5632 16384 3152 4044 3331 SUCCESS
    157 08/08/2024 15:16 655070 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13640 1307 1307 1 72 57 2245 3144 65535 65535 93 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3410 13579 13740 1304 1311 1297 1311 446 447 442 447 1783 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2246 2866 3144 4036 2436 2245 2863 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 655 5632 5632 5632 5632 -249 -324 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -249 3 0.56 225 5632 5632 5632 5632 4037 9047 3084 0 5632 5632 5632 5632 16384 3152 4044 3343 SUCCESS
    158 08/08/2024 15:16 659133 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1307 1307 1 72 57 2247 3144 65535 65535 93 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13577 13741 1314 1313 1317 1316 449 447 449 448 1783 1783 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2247 2867 3144 4036 2437 2247 2866 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 659 5632 5632 5632 5632 -251 -327 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -251 3 0.56 225 5632 5632 5632 5632 4037 9043 3084 0 5632 5632 5632 5632 16384 3152 4044 3312 SUCCESS
    159 08/08/2024 15:16 663110 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1307 1 72 57 2248 3144 65535 65535 92 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3410 13580 13741 1310 1301 1307 1306 448 443 446 445 1783 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2249 2869 3144 4036 2439 2248 2867 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 663 5632 5632 5632 5632 -252 -328 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -252 3 0.56 225 5632 5632 5632 5632 4037 9039 3084 0 5632 5632 5632 5632 16384 3152 4044 3310 SUCCESS
    160 08/08/2024 15:16 667158 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1307 1307 1 72 57 2249 3144 65535 65535 92 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3410 13578 13740 1311 1306 1309 1318 448 445 446 449 1785 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2250 2871 3144 4036 2440 2250 2870 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 667 5632 5632 5632 5632 -254 -331 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -254 3 0.56 225 5632 5632 5632 5632 4037 9035 3084 0 5632 5632 5632 5632 16384 3152 4044 3244 SUCCESS
    161 08/08/2024 15:16 671156 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1306 1307 1 72 57 2251 3144 65535 65535 92 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3410 13578 13743 1302 1301 1316 1307 445 443 449 446 1783 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2252 2873 3144 4036 2442 2251 2871 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 671 5632 5632 5632 5632 -255 -332 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -255 3 0.56 225 5632 5632 5632 5632 4037 9031 3084 0 5632 5632 5632 5632 16384 3152 4044 3562 SUCCESS
    162 08/08/2024 15:16 675401 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1307 1307 1 72 57 2252 3144 65535 65535 92 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13580 13741 1318 1321 1323 1309 450 450 451 446 1786 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2253 2875 3144 4036 2444 2253 2873 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 675 5632 5632 5632 5632 -257 -334 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -257 3 0.56 225 5632 5632 5632 5632 4037 9027 3084 0 5632 5632 5632 5632 16384 3152 4044 3553 SUCCESS
    163 08/08/2024 15:16 679677 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1308 1307 1 72 57 2254 3144 65535 65535 92 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3409 3408 13578 13740 1320 1320 1305 1318 451 450 445 449 1783 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2255 2877 3144 4036 2445 2254 2875 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 679 5632 5632 5632 5632 -258 -336 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -258 3 0.56 225 5632 5632 5632 5632 4037 9023 3084 0 5632 5632 5632 5632 16384 3152 4044 3214 SUCCESS
    164 08/08/2024 15:16 683574 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13640 1307 1307 1 72 57 2255 3144 65535 65535 92 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13744 1325 1306 1310 1314 453 445 447 448 1783 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2256 2879 3144 4036 2447 2256 2877 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 683 5632 5632 5632 5632 -260 -338 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -260 3 0.56 225 5632 5632 5632 5632 4037 9019 3084 0 5632 5632 5632 5632 16384 3152 4044 3332 SUCCESS
    165 08/08/2024 15:16 687656 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13645 1307 1307 1 72 57 2257 3144 65535 65535 91 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3406 3409 3408 13582 13741 1302 1310 1315 1311 445 446 448 447 1783 1783 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2258 2881 3144 4036 2448 2257 2879 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 687 5632 5632 5632 5632 -261 -340 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -261 3 0.56 225 5632 5632 5632 5632 4037 9014 3084 0 5632 5632 5632 5632 16384 3152 4044 3454 SUCCESS
    166 08/08/2024 15:16 691831 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13645 1307 1307 1 72 57 2258 3144 65535 65535 91 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13579 13741 1307 1312 1311 1303 447 447 447 444 1781 1783 27.3 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2259 2883 3144 4036 2449 2259 2881 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 691 5632 5632 5632 5632 -263 -342 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -263 3 0.56 225 5632 5632 5632 5632 4037 9010 3084 0 5632 5632 5632 5632 16384 3152 4044 3351 SUCCESS
    167 08/08/2024 15:16 695926 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13644 1307 1307 1 72 57 2260 3144 65535 65535 91 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13743 1313 1305 1308 1302 449 444 446 444 1783 1783 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2261 2885 3144 4036 2451 2260 2883 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 695 5632 5632 5632 5632 -264 -344 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -264 3 0.56 225 5632 5632 5632 5632 4037 9006 3084 0 5632 5632 5632 5632 16384 3152 4044 3431 SUCCESS
    168 08/08/2024 15:16 700018 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1306 1307 1 72 57 2261 3144 65535 65535 91 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13580 13741 1308 1316 1302 1315 447 448 444 448 1781 1783 27.1 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2262 2887 3144 4036 2452 2261 2884 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 699 5632 5632 5632 5632 -266 -346 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -266 3 0.56 225 5632 5632 5632 5632 4037 9002 3084 0 5632 5632 5632 5632 16384 3152 4044 3111 SUCCESS
    169 08/08/2024 15:17 703875 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13644 1307 1307 1 72 57 2263 3144 65535 65535 91 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13579 13740 1314 1302 1307 1319 449 443 446 450 1783 1782 27.2 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2263 2888 3144 4036 2454 2263 2886 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 703 5632 5632 5632 5632 -267 -347 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -267 3 0.56 225 5632 5632 5632 5632 4037 8998 3084 0 5632 5632 5632 5632 16384 3152 4044 3321 SUCCESS
    170 08/08/2024 15:17 707903 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13645 1307 1307 1 73 57 2264 3144 65535 65535 91 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13579 13741 1313 1306 1321 1307 449 445 450 445 1783 1782 27.2 27.9 27.8 27.6 27.9 27.9 27.8 27.9 2265 2890 3144 4036 2455 2264 2888 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 707 5632 5632 5632 5632 -268 -349 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -269 3 0.56 225 5632 5632 5632 5632 4037 8994 3084 0 5632 5632 5632 5632 16384 3152 4044 3448 SUCCESS
    171 08/08/2024 15:17 712045 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13645 1306 1307 1 73 57 2266 3144 65535 65535 91 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13580 13740 1315 1310 1317 1305 449 446 449 445 1782 1782 27.2 27.9 27.8 27.6 27.9 27.9 27.8 27.9 2266 2892 3144 4036 2457 2266 2890 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 711 5632 5632 5632 5632 -270 -351 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -270 3 0.56 225 5632 5632 5632 5632 4037 8990 3084 0 5632 5632 5632 5632 16384 3152 4044 3094 SUCCESS
    172 08/08/2024 15:17 715887 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13645 1306 1307 1 73 57 2267 3144 65535 65535 90 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13580 13741 1322 1305 1311 1299 452 444 447 443 1783 1782 27.2 27.9 27.8 27.6 27.9 27.9 27.8 27.9 2268 2894 3144 4036 2458 2267 2892 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 715 5632 5632 5632 5632 -271 -353 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -271 3 0.56 225 5632 5632 5632 5632 4037 8987 3084 0 5632 5632 5632 5632 16384 3152 4044 3236 SUCCESS
    173 08/08/2024 15:17 719861 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13644 1307 1306 1 73 57 2268 3144 65535 65535 90 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13579 13742 1315 1304 1309 1310 449 444 446 446 1783 1782 27.2 27.9 27.8 27.7 27.9 27.9 27.8 27.9 2269 2896 3144 4036 2460 2269 2894 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 719 5632 5632 5632 5632 -273 -355 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -273 3 0.56 225 5632 5632 5632 5632 4037 8983 3084 0 5632 5632 5632 5632 16384 3152 4044 3206 SUCCESS
    174 08/08/2024 15:17 723788 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13641 1306 1306 1 73 57 2270 3144 65535 65535 90 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13582 13741 1319 1306 1308 1304 451 445 446 444 1783 1782 27.2 27.9 27.8 27.7 27.9 27.9 27.8 27.9 2271 2898 3144 4036 2461 2270 2896 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 723 5632 5632 5632 5632 -274 -357 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -274 3 0.56 225 5632 5632 5632 5632 4037 8979 3084 0 5632 5632 5632 5632 16384 3152 4044 3304 SUCCESS
    175 08/08/2024 15:17 727805 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13640 1306 1306 1 73 57 2271 3144 65535 65535 90 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13580 13740 1315 1312 1295 1323 449 447 442 451 1782 1782 27.2 27.9 27.8 27.7 27.9 27.9 27.8 27.9 2272 2900 3144 4036 2462 2272 2898 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 727 5632 5632 5632 5632 -276 -359 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -276 3 0.56 225 5632 5632 5632 5632 4037 8975 3084 0 5632 5632 5632 5632 16384 3152 4044 3079 SUCCESS
    176 08/08/2024 15:17 731588 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13641 1305 1306 1 73 57 2273 3144 65535 65535 90 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3410 13577 13743 1319 1306 1317 1311 451 445 449 447 1782 1782 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2273 2901 3144 4036 2464 2273 2900 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 731 5632 5632 5632 5632 -277 -361 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -277 3 0.56 225 5632 5632 5632 5632 4037 8971 3084 0 5632 5632 5632 5632 16384 3152 4044 3230 SUCCESS
    177 08/08/2024 15:17 735538 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13641 1306 1306 1 73 57 2274 3144 65535 65535 90 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3409 13581 13742 1310 1305 1309 1301 448 445 446 444 1782 1782 27.3 27.9 27.8 27.8 27.9 27.9 27.8 27.9 2275 2903 3144 4036 2465 2274 2901 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 735 5632 5632 5632 5632 -278 -362 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -279 3 0.56 225 5632 5632 5632 5632 4037 8967 3084 0 5632 5632 5632 5632 16384 3152 4044 3371 SUCCESS
    178 08/08/2024 15:17 739585 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13641 1306 1306 1 73 57 2276 3144 65535 65535 90 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3410 13580 13739 1308 1310 1309 1304 447 446 446 445 1782 1782 27.3 27.9 27.8 27.8 27.9 27.9 27.8 27.9 2276 2905 3144 4036 2467 2276 2903 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 739 5632 5632 5632 5632 -280 -364 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -280 3 0.56 225 5632 5632 5632 5632 4037 8963 3084 0 5632 5632 5632 5632 16384 3152 4044 3366 SUCCESS
    179 08/08/2024 15:17 743704 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1305 1306 1 73 57 2277 3144 65535 65535 89 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3406 3409 3408 13579 13744 1308 1315 1299 1311 447 448 443 447 1783 1781 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2278 2907 3144 4036 2468 2277 2905 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 743 5632 5632 5632 5632 -281 -366 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -282 3 0.56 225 5632 5632 5632 5632 4037 8959 3084 0 5632 5632 5632 5632 16384 3152 4044 3499 SUCCESS
    180 08/08/2024 15:17 747912 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1305 1306 1 73 57 2279 3144 65535 65535 89 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3409 13582 13741 1305 1311 1299 1326 446 447 443 452 1783 1781 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2279 2909 3144 4036 2469 2279 2907 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 747 5632 5632 5632 5632 -283 -368 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -283 3 0.56 225 5632 5632 5632 5632 4037 8955 3084 0 5632 5632 5632 5632 16384 3152 4044 3216 SUCCESS
    181 08/08/2024 15:17 751844 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1305 1306 1 73 57 2280 3144 65535 65535 89 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3409 13578 13741 1314 1315 1314 1303 449 448 448 444 1782 1781 27.3 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2281 2911 3144 4036 2471 2280 2909 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 751 5632 5632 5632 5632 -284 -370 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -284 3 0.56 225 5632 5632 5632 5632 4037 8951 3084 0 5632 5632 5632 5632 16384 3152 4044 3557 SUCCESS
    182 08/08/2024 15:17 756107 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13645 1305 1306 1 73 58 2282 3144 65535 65535 89 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3409 3408 13580 13744 1309 1305 1311 1307 447 445 447 445 1782 1781 27.3 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2282 2913 3144 4036 2473 2282 2911 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 755 5632 5632 5632 5632 -286 -372 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -286 3 0.56 225 5632 5632 5632 5632 4037 8946 3084 0 5632 5632 5632 5632 16384 3152 4044 3254 SUCCESS
    183 08/08/2024 15:17 760045 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13642 1306 1306 1 73 58 2283 3144 65535 65535 89 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3409 13582 13741 1307 1318 1310 1326 447 449 447 452 1780 1781 27.2 28.0 27.8 27.8 27.9 28.0 27.8 28.0 2284 2915 3144 4036 2474 2283 2913 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 759 5632 5632 5632 5632 -287 -374 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -287 3 0.56 225 5632 5632 5632 5632 4037 8943 3084 0 5632 5632 5632 5632 16384 3152 4044 3303 SUCCESS
    184 08/08/2024 15:18 764142 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13645 1304 1305 1 73 58 2284 3144 65535 65535 89 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3406 3409 3408 13580 13741 1314 1305 1303 1301 449 444 444 443 1779 1781 27.3 28.0 27.9 27.8 27.9 28.0 27.8 28.0 2285 2917 3144 4036 2476 2285 2915 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 763 5632 5632 5632 5632 -289 -376 3 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -289 3 0.56 225 5632 5632 5632 5632 4037 8938 3084 0 5632 5632 5632 5632 16384 3152 4044 3319 SUCCESS
    185 08/08/2024 15:18 768188 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13645 1306 1305 1 73 58 2286 3144 65535 65535 89 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13580 13742 1304 1310 1303 1299 446 446 444 443 1782 1781 27.3 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2287 2919 3144 4036 2477 2286 2916 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 767 5632 5632 5632 5632 -290 -377 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -290 4 0.56 225 5632 5632 5632 5632 4037 8934 3084 0 5632 5632 5632 5632 16384 3152 4044 3474 SUCCESS
    186 08/08/2024 15:18 772396 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13643 1306 1305 1 73 58 2287 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13580 13741 1318 1301 1300 1316 450 443 443 448 1782 1781 27.3 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2288 2921 3144 4036 2478 2288 2919 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 771 5632 5632 5632 5632 -292 -380 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -292 4 0.56 225 5632 5632 5632 5632 4037 8930 3084 0 5632 5632 5632 5632 16384 3152 4044 3375 SUCCESS
    187 08/08/2024 15:18 776541 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13643 1306 1305 1 73 58 2289 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13578 13741 1313 1316 1304 1309 449 448 445 446 1779 1781 27.3 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2290 2923 3144 4036 2480 2289 2920 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 775 5632 5632 5632 5632 -293 -381 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -293 4 0.56 225 5632 5632 5632 5632 4037 8926 3084 0 5632 5632 5632 5632 16384 3152 4044 3377 SUCCESS
    188 08/08/2024 15:18 780727 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13641 1306 1305 1 73 58 2290 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13580 13743 1318 1312 1309 1309 450 447 446 446 1780 1781 27.3 28.0 27.9 27.8 27.9 28.0 27.9 28.0 2291 2925 3144 4036 2481 2291 2923 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 779 5632 5632 5632 5632 -295 -384 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -295 4 0.56 225 5632 5632 5632 5632 4037 8922 3084 0 5632 5632 5632 5632 16384 3152 4044 3265 SUCCESS
    189 08/08/2024 15:18 784713 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13643 1305 1305 1 73 58 2292 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13581 13740 1316 1314 1309 1304 450 448 446 444 1779 1780 27.3 28.0 27.9 27.9 27.9 28.0 27.9 28.0 2293 2927 3144 4036 2483 2292 2924 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 783 5632 5632 5632 5632 -296 -385 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -296 4 0.56 225 5632 5632 5632 5632 4037 8918 3084 0 5632 5632 5632 5632 16384 3152 4044 3217 SUCCESS
    190 08/08/2024 15:18 788670 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13643 1304 1305 1 73 58 2293 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13578 13741 1322 1304 1315 1305 452 444 448 445 1779 1780 27.3 28.0 27.9 27.9 27.9 28.0 27.9 28.0 2294 2928 3144 4036 2484 2293 2926 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 787 5632 5632 5632 5632 -298 -388 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -298 4 0.56 225 5632 5632 5632 5632 4037 8914 3084 0 5632 5632 5632 5632 16384 3152 4044 3298 SUCCESS
    191 08/08/2024 15:18 792681 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13642 1303 1305 1 73 58 2295 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13580 13742 1303 1311 1299 1307 445 447 443 445 1779 1780 27.3 28.0 27.9 27.9 27.9 28.0 27.9 28.0 2295 2930 3144 4036 2486 2295 2928 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 791 5632 5632 5632 5632 -299 -389 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -299 4 0.56 225 5632 5632 5632 5632 4037 8910 3084 0 5632 5632 5632 5632 16384 3152 4044 3315 SUCCESS
    192 08/08/2024 15:18 796681 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13642 1304 1305 1 74 58 2296 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3409 13581 13741 1315 1309 1309 1308 449 446 446 446 1779 1780 27.3 28.0 27.9 27.9 27.9 28.0 27.9 28.0 2297 2932 3144 4036 2487 2296 2929 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 795 5632 5632 5632 5632 -300 -390 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -301 4 0.56 225 5632 5632 5632 5632 4037 8906 3084 0 5632 5632 5632 5632 16384 3152 4044 3290 SUCCESS
    193 08/08/2024 15:18 800705 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13643 1303 1305 1 74 58 2297 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13579 13742 1309 1311 1312 1310 447 447 447 446 1779 1780 27.3 28.0 27.9 27.9 27.9 28.0 27.9 28.0 2298 2934 3144 4036 2489 2298 2932 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 799 5632 5632 5632 5632 -302 -393 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -302 4 0.56 225 5632 5632 5632 5632 4037 8902 3084 0 5632 5632 5632 5632 16384 3152 4044 3343 SUCCESS
    194 08/08/2024 15:18 804792 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13642 1305 1305 1 74 58 2299 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3409 13580 13741 1310 1310 1311 1321 448 446 447 450 1777 1780 27.4 28.0 27.9 27.9 27.9 28.0 27.9 28.0 2300 2936 3144 4036 2490 2299 2933 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 804 5632 5632 5632 5632 -303 -394 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -304 4 0.56 225 5632 5632 5632 5632 4037 8898 3084 0 5632 5632 5632 5632 16384 3152 4044 3368 SUCCESS
    195 08/08/2024 15:18 808862 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13638 1280 1305 1 74 58 2300 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13577 13737 1284 1280 1281 1289 439 436 437 439 1739 1774 27.3 28.0 27.9 27.9 27.9 28.0 27.9 28.0 2301 2938 3144 4036 2492 2301 2936 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 807 5632 5632 5632 5632 -305 -397 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -305 4 0.56 225 5632 5632 5632 5632 4037 8894 3084 0 5632 5632 5632 5632 16384 3152 4044 3227 SUCCESS
    196 08/08/2024 15:18 812808 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13638 1279 1298 1 74 58 2302 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3405 3408 3407 13576 13737 1285 1286 1289 1282 439 438 439 437 1743 1767 27.4 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2303 2940 3144 4036 2493 2302 2937 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 811 5632 5632 5632 5632 -306 -398 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -306 4 0.56 225 5632 5632 5632 5632 4037 8890 3084 0 5632 5632 5632 5632 16384 3152 4044 3270 SUCCESS
    197 08/08/2024 15:18 816860 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13637 1279 1293 1 74 58 2303 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3410 3409 13579 13737 1278 1281 1286 1284 437 436 439 438 1746 1761 27.3 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2304 2942 3144 4036 2494 2304 2940 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 816 5632 5632 5632 5632 -308 -401 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -308 4 0.56 225 5632 5632 5632 5632 4037 8886 3084 0 5632 5632 5632 5632 16384 3152 4044 3503 SUCCESS
    198 08/08/2024 15:18 821097 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13638 1281 1290 1 74 58 2305 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3409 13576 13736 1278 1278 1284 1285 437 435 438 438 1746 1758 27.3 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2306 2944 3144 4036 2496 2305 2941 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 820 5632 5632 5632 5632 -309 -402 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -309 4 0.56 225 5632 5632 5632 5632 4037 8882 3084 0 5632 5632 5632 5632 16384 3152 4044 3290 SUCCESS
    199 08/08/2024 15:19 825100 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13637 1280 1287 1 74 58 2306 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3409 13574 13741 1280 1279 1284 1291 437 436 438 440 1749 1755 27.4 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2307 2945 3144 4036 2497 2307 2944 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 824 5632 5632 5632 5632 -311 -405 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -311 4 0.56 225 5632 5632 5632 5632 4037 8878 3084 0 5632 5632 5632 5632 16384 3152 4044 3461 SUCCESS
    200 08/08/2024 15:19 829257 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13638 1280 1285 1 74 58 2308 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3407 13579 13738 1288 1288 1290 1289 440 439 440 439 1747 1753 27.2 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2308 2947 3144 4036 2499 2308 2945 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 828 5632 5632 5632 5632 -312 -406 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -312 4 0.56 225 5632 5632 5632 5632 4037 8874 3084 0 5632 5632 5632 5632 16384 3152 4044 3427 SUCCESS
    201 08/08/2024 15:19 833404 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13637 1279 1284 1 74 58 2309 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13577 13738 1295 1277 1280 1282 442 435 436 437 1746 1751 27.4 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2310 2949 3144 4036 2500 2309 2946 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 832 5632 5632 5632 5632 -313 -407 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -314 4 0.56 225 5632 5632 5632 5632 4037 8870 3084 0 5632 5632 5632 5632 16384 3152 4044 3356 SUCCESS
    202 08/08/2024 15:19 837481 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13638 1281 1283 1 74 58 2311 3144 65535 65535 88 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13577 13741 1284 1277 1292 1285 439 435 440 438 1746 1750 27.3 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2311 2951 3144 4036 2502 2311 2949 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 836 5632 5632 5632 5632 -315 -410 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -315 4 0.56 225 5632 5632 5632 5632 4037 8866 3084 0 5632 5632 5632 5632 16384 3152 4044 3275 SUCCESS
    203 08/08/2024 15:19 841501 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13637 1279 1283 1 74 58 2312 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13580 13737 1281 1282 1279 1285 438 437 436 438 1744 1749 27.4 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2313 2953 3144 4036 2503 2312 2950 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 840 5632 5632 5632 5632 -316 -411 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -316 4 0.56 225 5632 5632 5632 5632 4037 8862 3084 0 5632 5632 5632 5632 16384 3152 4044 3244 SUCCESS
    204 08/08/2024 15:19 845473 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13637 1280 1282 1 74 58 2314 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3405 3408 3408 13577 13737 1292 1288 1279 1278 441 439 436 436 1744 1748 27.3 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2314 2955 3144 4036 2505 2314 2953 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 844 5632 5632 5632 5632 -318 -414 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -318 4 0.56 225 5632 5632 5632 5632 4037 8858 3084 0 5632 5632 5632 5632 16384 3152 4044 3381 SUCCESS
    205 08/08/2024 15:19 849589 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13642 1280 1282 1 74 58 2315 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13577 13741 1284 1288 1282 1284 439 439 437 438 1744 1748 27.3 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2316 2957 3144 4036 2506 2315 2954 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 848 5632 5632 5632 5632 -319 -415 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -319 4 0.56 225 5632 5632 5632 5632 4037 8853 3084 0 5632 5632 5632 5632 16384 3152 4044 3318 SUCCESS
    206 08/08/2024 15:19 853664 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13642 1279 1281 1 74 58 2316 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13578 13737 1285 1288 1286 1287 439 439 438 439 1746 1747 27.4 28.0 27.9 27.9 28.0 28.0 27.9 28.0 2317 2959 3144 4036 2508 2317 2957 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 852 5632 5632 5632 5632 -321 -418 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -321 4 0.56 225 5632 5632 5632 5632 4037 8849 3084 0 5632 5632 5632 5632 16384 3152 4044 3407 SUCCESS
    207 08/08/2024 15:19 857798 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13642 1281 1281 1 74 58 2318 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3407 13577 13739 1286 1283 1279 1281 439 437 436 436 1747 1747 27.4 28.0 28.0 27.9 28.0 28.0 28.0 28.0 2319 2960 3144 4036 2509 2318 2958 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 856 5632 5632 5632 5632 -322 -419 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -322 4 0.56 225 5632 5632 5632 5632 4037 8845 3084 0 5632 5632 5632 5632 16384 3152 4044 3327 SUCCESS
    208 08/08/2024 15:19 861867 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1281 1281 1 74 58 2319 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3405 3409 3407 13577 13741 1284 1287 1281 1280 439 438 437 436 1748 1747 27.4 28.0 28.0 27.9 28.0 28.0 28.0 28.0 2320 2962 3144 4036 2510 2320 2961 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 860 5632 5632 5632 5632 -324 -422 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -324 4 0.56 225 5632 5632 5632 5632 4037 8841 3084 0 5632 5632 5632 5632 16384 3152 4044 3555 SUCCESS
    209 08/08/2024 15:19 866129 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13639 1281 1281 1 74 59 2321 3144 65535 65535 87 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13577 13738 1287 1292 1289 1292 440 440 439 440 1747 1747 27.5 28.1 28.0 28.0 28.0 28.1 28.0 28.1 2322 2964 3144 4036 2512 2321 2962 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 864 5632 5632 5632 5632 -325 -423 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -325 4 0.56 225 5632 5632 5632 5632 4037 8837 3084 0 5632 5632 5632 5632 16384 3152 4044 3221 SUCCESS
    210 08/08/2024 15:19 870115 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13638 1281 1281 1 74 59 2322 3144 65535 65535 86 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3408 13576 13738 1291 1276 1289 1278 441 435 439 436 1747 1747 27.5 28.1 28.0 28.0 28.0 28.1 28.0 28.1 2323 2966 3144 4036 2513 2322 2963 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 868 5632 5632 5632 5632 -326 -424 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -327 4 0.56 225 5632 5632 5632 5632 4037 8833 3084 0 5632 5632 5632 5632 16384 3152 4044 3260 SUCCESS
    211 08/08/2024 15:19 874116 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13639 1281 1281 1 74 59 2324 3144 65535 65535 86 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3407 13576 13737 1293 1277 1290 1287 442 435 440 438 1746 1747 27.5 28.1 28.0 28.0 28.0 28.1 28.0 28.1 2325 2968 3144 4036 2515 2324 2966 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 873 5632 5632 5632 5632 -328 -427 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -329 4 0.56 225 5632 5632 5632 5632 4037 8827 3084 0 5632 5632 5632 5632 16384 3152 4044 5860 SUCCESS
    212 08/08/2024 15:19 880717 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13639 1280 1281 1 74 59 2326 3144 65535 65535 86 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13577 13740 1288 1292 1283 1285 440 440 437 438 1747 1747 27.4 28.1 28.0 28.1 28.1 28.1 28.0 28.1 2328 2973 3144 4036 2519 2328 2971 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 884 5632 5632 5632 5632 -332 -432 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -332 4 0.56 225 5632 5632 5632 5632 4037 8817 3084 0 5632 5632 5632 5632 16384 3152 4044 9063 SUCCESS
    213 08/08/2024 15:20 890536 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13638 1281 1281 1 75 59 2330 3144 65535 65535 86 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3408 3410 3410 13578 13742 1286 1283 1293 1292 439 437 441 441 1749 1747 27.5 28.1 28.0 28.1 28.1 28.1 28.0 28.1 2330 2976 3144 4036 2521 2330 2974 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 890 5632 5632 5632 5632 -334 -435 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -334 4 0.56 225 5632 5632 5632 5632 4037 8812 3084 0 5632 5632 5632 5632 16384 3152 4044 4314 SUCCESS
    214 08/08/2024 15:20 895544 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13638 1282 1281 1 75 59 2331 3144 65535 65535 85 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3407 13581 13738 1286 1285 1289 1290 439 438 439 440 1749 1747 27.5 28.1 28.0 28.1 28.1 28.1 28.0 28.1 2332 2978 3144 4036 2522 2331 2975 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 894 5632 5632 5632 5632 -336 -437 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -336 4 0.56 225 5632 5632 5632 5632 4037 8808 3084 0 5632 5632 5632 5632 16384 3152 4044 3363 SUCCESS
    215 08/08/2024 15:20 899624 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13638 1281 1281 1 75 59 2333 3144 65535 65535 85 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13576 13738 1288 1278 1282 1278 440 435 437 436 1747 1747 27.5 28.1 28.0 28.1 28.1 28.1 28.0 28.1 2333 2980 3144 4036 2524 2333 2978 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 898 5632 5632 5632 5632 -337 -439 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -337 4 0.56 225 5632 5632 5632 5632 4037 8804 3084 0 5632 5632 5632 5632 16384 3152 4044 3452 SUCCESS
    216 08/08/2024 15:20 903834 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13643 1282 1281 1 75 59 2334 3144 65535 65535 85 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3408 13577 13742 1286 1289 1289 1284 439 439 439 438 1746 1747 27.6 28.1 28.0 28.1 28.1 28.1 28.0 28.1 2335 2982 3144 4036 2525 2334 2979 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 902 5632 5632 5632 5632 -338 -440 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -338 4 0.56 225 5632 5632 5632 5632 4037 8800 3084 0 5632 5632 5632 5632 16384 3152 4044 3251 SUCCESS
    217 08/08/2024 15:20 907822 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13638 1282 1281 1 75 59 2336 3144 65535 65535 85 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13581 13737 1292 1291 1279 1283 441 440 436 437 1747 1747 27.6 28.1 28.0 28.1 28.1 28.1 28.0 28.1 2336 2983 3144 4036 2527 2336 2982 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 906 5632 5632 5632 5632 -340 -443 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -340 4 0.56 225 5632 5632 5632 5632 4037 8796 3084 0 5632 5632 5632 5632 16384 3152 4044 3300 SUCCESS
    218 08/08/2024 15:20 911887 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13644 1282 1281 1 75 59 2337 3144 65535 65535 85 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3410 3408 13577 13738 1284 1287 1295 1291 439 438 442 440 1747 1747 27.6 28.1 28.1 28.2 28.1 28.2 28.1 28.2 2338 2986 3144 4036 2528 2337 2983 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 910 5632 5632 5632 5632 -341 -444 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -341 4 0.56 225 5632 5632 5632 5632 4037 8791 3084 0 5632 5632 5632 5632 16384 3152 4044 3517 SUCCESS
    219 08/08/2024 15:20 916112 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13644 1280 1281 1 75 59 2338 3144 65535 65535 85 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3408 13577 13742 1283 1289 1290 1291 438 439 440 440 1747 1747 27.5 28.1 28.1 28.2 28.1 28.2 28.1 28.2 2339 2987 3144 4036 2530 2339 2986 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 914 5632 5632 5632 5632 -343 -447 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -343 4 0.56 225 5632 5632 5632 5632 4037 8787 3084 0 5632 5632 5632 5632 16384 3152 4044 3432 SUCCESS
    220 08/08/2024 15:20 920279 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13640 1281 1281 1 75 59 2340 3144 65535 65535 85 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13581 13739 1296 1297 1286 1288 443 442 438 439 1746 1747 27.7 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2341 2989 3144 4036 2531 2340 2987 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 918 5632 5632 5632 5632 -344 -448 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -344 4 0.56 225 5632 5632 5632 5632 4037 8783 3084 0 5632 5632 5632 5632 16384 3152 4044 3257 SUCCESS
    221 08/08/2024 15:20 924262 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13640 1281 1281 1 75 59 2341 3144 65535 65535 84 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13739 1292 1292 1289 1286 441 440 439 438 1747 1747 27.6 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2342 2991 3144 4036 2532 2342 2989 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 922 5632 5632 5632 5632 -346 -450 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -346 4 0.56 225 5632 5632 5632 5632 4037 8779 3084 0 5632 5632 5632 5632 16384 3152 4044 3444 SUCCESS
    222 08/08/2024 15:20 928412 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13640 1281 1281 1 75 59 2343 3144 65535 65535 84 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3407 3409 3408 13577 13740 1286 1287 1282 1284 439 438 437 438 1746 1747 27.7 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2344 2993 3144 4036 2534 2343 2991 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 926 5632 5632 5632 5632 -347 -452 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -347 4 0.56 225 5632 5632 5632 5632 4037 8775 3084 0 5632 5632 5632 5632 16384 3152 4044 3204 SUCCESS
    223 08/08/2024 15:20 932349 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13640 1280 1281 1 75 59 2344 3144 65535 65535 84 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3408 3408 13580 13739 1291 1290 1291 1283 441 439 440 437 1747 1747 27.6 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2345 2995 3144 4036 2535 2344 2992 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 930 5632 5632 5632 5632 -348 -453 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -349 4 0.56 225 5632 5632 5632 5632 4037 8771 3084 0 5632 5632 5632 5632 16384 3152 4044 3250 SUCCESS
    224 08/08/2024 15:20 936296 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13640 1280 1281 1 75 59 2346 3144 65535 65535 84 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3406 3409 3407 13577 13739 1285 1287 1280 1287 439 438 436 438 1749 1747 27.6 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2346 2997 3144 4036 2537 2346 2995 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 934 5632 5632 5632 5632 -350 -456 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -350 4 0.56 225 5632 5632 5632 5632 4037 8767 3084 0 5632 5632 5632 5632 16384 3152 4044 3261 SUCCESS
    225 08/08/2024 15:20 940279 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13644 1280 1281 1 75 59 2347 3144 65535 65535 84 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3409 13580 13741 1296 1290 1287 1293 443 439 439 441 1750 1747 27.7 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2348 2999 3144 4036 2538 2347 2996 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 938 5632 5632 5632 5632 -351 -457 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -351 4 0.56 225 5632 5632 5632 5632 4037 8763 3084 0 5632 5632 5632 5632 16384 3152 4044 3264 SUCCESS
    226 08/08/2024 15:21 944256 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13644 1281 1281 1 75 59 2348 3144 65535 65535 84 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3408 3408 13580 13739 1297 1286 1281 1285 443 438 437 438 1749 1747 27.7 28.1 28.1 28.2 28.2 28.2 28.1 28.2 2349 3000 3144 4036 2540 2349 2999 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 942 5632 5632 5632 5632 -353 -460 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -353 4 0.56 225 5632 5632 5632 5632 4037 8759 3084 0 5632 5632 5632 5632 16384 3152 4044 3354 SUCCESS
    227 08/08/2024 15:21 948343 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13640 1280 1281 1 75 59 2350 3144 65535 65535 84 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3416 3407 3409 3408 13577 13740 1284 1281 1285 1292 439 436 438 440 1747 1747 27.7 28.2 28.1 28.2 28.2 28.2 28.1 28.2 2351 3003 3144 4036 2542 2351 3001 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 949 5632 5632 5632 5632 -355 -462 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -355 4 0.56 225 5632 5632 5632 5632 4037 8752 3084 0 5632 5632 5632 5632 16384 3152 4044 6736 SUCCESS
    228 08/08/2024 15:21 955740 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13641 1280 1281 1 75 59 2353 3144 65535 65535 83 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13740 1283 1282 1279 1283 438 437 436 437 1746 1747 27.7 28.2 28.2 28.3 28.2 28.3 28.2 28.3 2355 3007 3144 4036 2545 2354 3005 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 958 5632 5632 5632 5632 -358 -466 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -359 4 0.56 225 5632 5632 5632 5632 4037 8743 3084 0 5632 5632 5632 5632 16384 3152 4044 8255 SUCCESS
    229 08/08/2024 15:21 964685 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13641 1279 1281 1 75 59 2356 3144 65535 65535 83 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3410 3408 13578 13741 1292 1279 1284 1285 441 436 438 438 1746 1747 27.7 28.2 28.2 28.3 28.2 28.3 28.2 28.3 2356 3010 3144 4036 2547 2356 3008 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 962 5632 5632 5632 5632 -360 -469 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -360 4 0.56 225 5632 5632 5632 5632 4037 8739 3084 0 5632 5632 5632 5632 16384 3152 4044 3260 SUCCESS
    230 08/08/2024 15:21 968655 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13641 1280 1281 1 75 59 2357 3144 65535 65535 83 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13740 1285 1279 1288 1284 439 436 439 438 1746 1747 27.7 28.2 28.2 28.3 28.2 28.3 28.2 28.3 2358 3012 3144 4036 2548 2357 3009 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 966 5632 5632 5632 5632 -361 -470 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -361 4 0.56 225 5632 5632 5632 5632 4037 8735 3084 0 5632 5632 5632 5632 16384 3152 4044 3164 SUCCESS
    231 08/08/2024 15:21 972592 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13641 1280 1281 1 75 59 2358 3144 65535 65535 83 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13578 13743 1285 1289 1282 1286 439 439 437 438 1748 1747 27.7 28.2 28.2 28.3 28.2 28.3 28.2 28.3 2359 3014 3144 4036 2550 2359 3012 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 971 5632 5632 5632 5632 -363 -473 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -363 4 0.56 225 5632 5632 5632 5632 4037 8731 3084 0 5632 5632 5632 5632 16384 3152 4044 3717 SUCCESS
    232 08/08/2024 15:21 977026 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13639 1280 1280 1 76 59 2360 3144 65535 65535 82 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13581 13740 1279 1292 1287 1285 437 440 439 438 1746 1746 27.8 28.2 28.2 28.3 28.3 28.3 28.2 28.3 2361 3015 3144 4036 2551 2360 3013 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 975 5632 5632 5632 5632 -364 -474 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -364 4 0.56 225 5632 5632 5632 5632 4037 8727 3084 0 5632 5632 5632 5632 16384 3152 4044 3391 SUCCESS
    233 08/08/2024 15:21 981091 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13640 1279 1280 1 76 60 2362 3144 65535 65535 82 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13577 13739 1287 1285 1299 1283 440 438 443 437 1746 1746 27.8 28.2 28.2 28.3 28.3 28.3 28.2 28.3 2362 3017 3144 4036 2553 2362 3016 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 979 5632 5632 5632 5632 -366 -477 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -366 4 0.56 225 5632 5632 5632 5632 4037 8723 3084 0 5632 5632 5632 5632 16384 3152 4044 3430 SUCCESS
    234 08/08/2024 15:21 985197 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13641 1279 1280 1 76 60 2363 3144 65535 65535 82 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13579 13744 1287 1286 1286 1278 440 438 438 436 1746 1746 27.8 28.2 28.2 28.3 28.3 28.3 28.2 28.3 2364 3019 3144 4036 2554 2363 3017 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 983 5632 5632 5632 5632 -367 -478 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -367 4 0.56 225 5632 5632 5632 5632 4037 8718 3084 0 5632 5632 5632 5632 16384 3152 4044 3467 SUCCESS
    235 08/08/2024 15:21 989531 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13642 1281 1280 1 76 60 2364 3144 65535 65535 82 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3406 3409 3408 13577 13741 1286 1291 1286 1283 440 440 438 437 1746 1746 27.8 28.2 28.2 28.4 28.3 28.3 28.2 28.3 2365 3021 3144 4036 2556 2365 3019 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 987 5632 5632 5632 5632 -369 -480 4 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -369 4 0.56 225 5632 5632 5632 5632 4037 8714 3084 0 5632 5632 5632 5632 16384 3152 4044 3609 SUCCESS
    236 08/08/2024 15:21 993838 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13640 1280 1280 1 76 60 2366 3144 65535 65535 82 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13580 13743 1280 1286 1291 1288 438 438 440 439 1745 1746 27.7 28.2 28.3 28.4 28.3 28.4 28.3 28.4 2367 3023 3144 4036 2557 2366 3021 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 991 5632 5632 5632 5632 -370 -482 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -370 5 0.56 225 5632 5632 5632 5632 4037 8710 3084 0 5632 5632 5632 5632 16384 3152 4044 3366 SUCCESS
    237 08/08/2024 15:21 997894 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13642 1280 1280 1 76 60 2367 3144 65535 65535 82 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13578 13740 1290 1278 1284 1283 441 435 438 437 1745 1746 27.8 28.2 28.3 28.4 28.3 28.4 28.2 28.4 2368 3025 3144 4036 2558 2368 3023 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 995 5632 5632 5632 5632 -372 -484 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -372 5 0.56 225 5632 5632 5632 5632 4037 8706 3084 0 5632 5632 5632 5632 16384 3152 4044 3288 SUCCESS
    238 08/08/2024 15:21 1001907 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13641 1279 1280 1 76 60 2369 3144 65535 65535 82 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13579 13741 1286 1287 1292 1288 440 439 441 439 1745 1746 27.8 28.2 28.3 28.4 28.3 28.4 28.3 28.4 2370 3027 3144 4036 2560 2369 3025 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1000 5632 5632 5632 5632 -373 -486 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -373 5 0.56 225 5632 5632 5632 5632 4037 8702 3084 0 5632 5632 5632 5632 16384 3152 4044 3442 SUCCESS
    239 08/08/2024 15:22 1006101 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13640 1279 1279 1 76 60 2371 3144 65535 65535 81 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3408 13580 13742 1284 1287 1290 1277 439 438 440 435 1743 1745 27.8 28.2 28.3 28.4 28.3 28.4 28.3 28.4 2371 3029 3144 4036 2562 2371 3027 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1004 5632 5632 5632 5632 -375 -488 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -375 5 0.56 225 5632 5632 5632 5632 4037 8697 3084 0 5632 5632 5632 5632 16384 3152 4044 3767 SUCCESS
    240 08/08/2024 15:22 1010598 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13645 1279 1279 1 76 60 2372 3144 65535 65535 81 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3410 3408 13580 13741 1294 1277 1284 1293 442 435 438 441 1743 1745 27.9 28.2 28.3 28.4 28.3 28.4 28.3 28.4 2373 3031 3144 4036 2563 2372 3029 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1008 5632 5632 5632 5632 -376 -490 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -376 5 0.56 225 5632 5632 5632 5632 4037 8693 3084 0 5632 5632 5632 5632 16384 3152 4044 3750 SUCCESS
    241 08/08/2024 15:22 1015030 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13641 1278 1279 1 76 60 2374 3144 65535 65535 81 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13578 13742 1283 1292 1290 1282 439 440 440 437 1742 1745 27.7 28.2 28.3 28.4 28.3 28.4 28.3 28.4 2374 3033 3144 4036 2564 2374 3031 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1013 5632 5632 5632 5632 -378 -492 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -378 5 0.56 225 5632 5632 5632 5632 4037 8689 3084 0 5632 5632 5632 5632 16384 3152 4044 3474 SUCCESS
    242 08/08/2024 15:22 1019152 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13641 1278 1279 1 76 60 2375 3144 65535 65535 81 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13583 13741 1287 1288 1289 1281 440 439 440 437 1741 1744 27.8 28.3 28.3 28.5 28.3 28.5 28.3 28.5 2376 3035 3144 4036 2566 2375 3032 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1017 5632 5632 5632 5632 -379 -493 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -379 5 0.56 225 5632 5632 5632 5632 4037 8685 3084 0 5632 5632 5632 5632 16384 3152 4044 3378 SUCCESS
    243 08/08/2024 15:22 1023231 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13642 1278 1279 1 76 60 2377 3144 65535 65535 81 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13579 13741 1282 1281 1283 1280 438 437 438 436 1744 1744 27.8 28.3 28.3 28.5 28.3 28.5 28.3 28.5 2377 3037 3144 4036 2567 2377 3035 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1021 5632 5632 5632 5632 -381 -496 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -381 5 0.56 225 5632 5632 5632 5632 4037 8681 3084 0 5632 5632 5632 5632 16384 3152 4044 3237 SUCCESS
    244 08/08/2024 15:22 1027211 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13641 1278 1278 1 76 60 2378 3144 65535 65535 81 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3410 3410 13579 13746 1290 1287 1273 1289 441 439 434 440 1744 1744 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2379 3039 3144 4036 2569 2378 3036 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1025 5632 5632 5632 5632 -382 -497 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -382 5 0.56 225 5632 5632 5632 5632 4037 8677 3084 0 5632 5632 5632 5632 16384 3152 4044 3164 SUCCESS
    245 08/08/2024 15:22 1031141 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13641 1278 1278 1 76 60 2379 3144 65535 65535 81 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13582 13741 1288 1282 1287 1277 440 437 439 435 1744 1743 27.8 28.3 28.3 28.4 28.3 28.4 28.3 28.4 2380 3040 3144 4036 2570 2379 3038 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1029 5632 5632 5632 5632 -383 -499 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -384 5 0.56 225 5632 5632 5632 5632 4037 8673 3084 0 5632 5632 5632 5632 16384 3152 4044 3399 SUCCESS
    246 08/08/2024 15:22 1035257 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13642 1278 1278 1 76 60 2381 3144 65535 65535 80 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13579 13741 1289 1273 1285 1276 441 434 438 435 1743 1743 27.8 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2381 3042 3144 4036 2572 2381 3040 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1033 5632 5632 5632 5632 -385 -501 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -385 5 0.56 225 5632 5632 5632 5632 4037 8669 3084 0 5632 5632 5632 5632 16384 3152 4044 3227 SUCCESS
    247 08/08/2024 15:22 1039195 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13641 1277 1278 1 76 60 2382 3144 65535 65535 80 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13580 13744 1278 1279 1287 1278 437 436 439 436 1741 1743 27.8 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2383 3044 3144 4036 2573 2382 3042 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1037 5632 5632 5632 5632 -386 -503 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -386 5 0.56 225 5632 5632 5632 5632 4037 8665 3084 0 5632 5632 5632 5632 16384 3152 4044 3400 SUCCESS
    248 08/08/2024 15:22 1043346 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13642 1277 1278 1 76 60 2384 3144 65535 65535 80 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13583 13741 1279 1292 1276 1297 437 440 435 442 1745 1743 27.8 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2384 3046 3144 4036 2574 2384 3044 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1041 5632 5632 5632 5632 -388 -505 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -388 5 0.56 225 5632 5632 5632 5632 4037 8661 3084 0 5632 5632 5632 5632 16384 3152 4044 3293 SUCCESS
    249 08/08/2024 15:22 1047344 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13642 1276 1278 1 76 60 2385 3144 65535 65535 80 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3410 13579 13742 1276 1294 1280 1294 436 441 436 441 1745 1743 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2386 3048 3144 4036 2576 2385 3045 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1045 5632 5632 5632 5632 -389 -506 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -389 5 0.56 225 5632 5632 5632 5632 4037 8657 3084 0 5632 5632 5632 5632 16384 3152 4044 3427 SUCCESS
    250 08/08/2024 15:22 1051489 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13641 1276 1278 1 76 60 2387 3144 65535 65535 80 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3409 13579 13746 1285 1275 1280 1279 439 434 436 436 1741 1743 27.8 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2387 3050 3144 4036 2578 2387 3048 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1049 5632 5632 5632 5632 -391 -509 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -391 5 0.56 225 5632 5632 5632 5632 4037 8653 3084 0 5632 5632 5632 5632 16384 3152 4044 3360 SUCCESS
    251 08/08/2024 15:22 1055617 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13647 1277 1278 1 76 60 2388 3144 65535 65535 80 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3409 13583 13742 1278 1280 1284 1283 437 436 438 437 1742 1743 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2389 3052 3144 4036 2579 2388 3049 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1053 5632 5632 5632 5632 -392 -510 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -392 5 0.56 225 5632 5632 5632 5632 4037 8648 3084 0 5632 5632 5632 5632 16384 3152 4044 3769 SUCCESS
    252 08/08/2024 15:22 1060102 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13642 1277 1277 1 76 60 2389 3144 65535 65535 80 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13580 13741 1284 1286 1280 1272 439 438 436 433 1742 1743 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2390 3054 3144 4036 2580 2390 3052 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1057 5632 5632 5632 5632 -394 -513 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -394 5 0.56 225 5632 5632 5632 5632 4037 8644 3084 0 5632 5632 5632 5632 16384 3152 4044 3094 SUCCESS
    253 08/08/2024 15:23 1063941 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13646 1277 1277 1 77 60 2391 3144 65535 65535 79 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3408 13580 13741 1286 1280 1277 1273 439 436 435 434 1742 1743 27.8 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2392 3056 3144 4036 2582 2391 3053 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1062 5632 5632 5632 5632 -395 -514 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -395 5 0.56 225 5632 5632 5632 5632 4037 8640 3084 0 5632 5632 5632 5632 16384 3152 4044 3827 SUCCESS
    254 08/08/2024 15:23 1068403 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13642 1278 1277 1 77 60 2393 3144 65535 65535 79 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3408 13580 13742 1278 1282 1277 1281 437 437 435 437 1742 1742 27.8 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2393 3058 3144 4036 2583 2392 3055 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1065 5632 5632 5632 5632 -397 -517 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -397 5 0.56 225 5632 5632 5632 5632 4037 8636 3084 0 5632 5632 5632 5632 16384 3152 4044 3100 SUCCESS
    255 08/08/2024 15:23 1072106 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13646 1276 1277 1 77 60 2394 3144 65535 65535 79 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3411 13580 13742 1283 1286 1273 1285 439 438 434 438 1741 1742 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2394 3059 3144 4036 2584 2394 3057 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1069 5632 5632 5632 5632 -398 -518 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -398 5 0.56 225 5632 5632 5632 5632 4037 8633 3084 0 5632 5632 5632 5632 16384 3152 4044 2463 SUCCESS
    256 08/08/2024 15:23 1074836 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13641 1275 1277 1 77 60 2395 3144 65535 65535 79 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3406 3409 3409 13580 13743 1280 1278 1273 1275 437 435 434 435 1741 1742 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2395 3060 3144 4036 2585 2395 3059 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1071 5632 5632 5632 5632 -399 -520 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -399 5 0.56 225 5632 5632 5632 5632 4037 8630 3084 0 5632 5632 5632 5632 16384 3152 4044 2410 SUCCESS
    257 08/08/2024 15:23 1078027 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13647 1275 1277 1 77 60 2396 3144 65535 65535 79 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3410 3410 13580 13743 1284 1278 1279 1275 439 436 436 435 1741 1742 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2396 3062 3144 4036 2586 2396 3060 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1074 5632 5632 5632 5632 -400 -521 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -400 5 0.56 225 5632 5632 5632 5632 4037 8627 3084 0 5632 5632 5632 5632 16384 3152 4044 2391 SUCCESS
    258 08/08/2024 15:23 1082032 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13647 1276 1277 1 77 60 2397 3144 65535 65535 79 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13581 13747 1293 1275 1280 1281 442 435 437 437 1741 1741 28.0 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2398 3064 3144 4036 2588 2397 3061 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1079 5632 5632 5632 5632 -401 -522 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -401 5 0.56 225 5632 5632 5632 5632 4037 8623 3084 0 5632 5632 5632 5632 16384 3152 4044 2594 SUCCESS
    259 08/08/2024 15:23 1086033 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13647 1276 1276 1 77 60 2399 3144 65535 65535 79 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3409 3409 13580 13742 1279 1273 1280 1271 437 434 436 433 1742 1741 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2399 3065 3144 4036 2589 2398 3062 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1082 5632 5632 5632 5632 -403 -525 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -403 5 0.56 225 5632 5632 5632 5632 4037 8619 3084 0 5632 5632 5632 5632 16384 3152 4044 2371 SUCCESS
    260 08/08/2024 15:23 1090047 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13646 1275 1276 1 77 60 2400 3144 65535 65535 79 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13580 13744 1269 1280 1287 1273 434 436 439 434 1742 1741 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2400 3067 3144 4036 2591 2400 3065 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1086 5632 5632 5632 5632 -404 -526 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -404 5 0.56 225 5632 5632 5632 5632 4037 8615 3084 0 5632 5632 5632 5632 16384 3152 4044 2197 SUCCESS
    261 08/08/2024 15:23 1094051 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13647 1276 1276 1 77 61 2401 3144 65535 65535 78 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3409 3409 13581 13742 1277 1279 1280 1279 436 436 436 436 1741 1741 27.9 28.3 28.3 28.6 28.4 28.6 28.4 28.6 2402 3069 3144 4036 2592 2401 3066 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1090 5632 5632 5632 5632 -405 -527 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -405 5 0.56 225 5632 5632 5632 5632 4037 8611 3084 0 5632 5632 5632 5632 16384 3152 4044 2408 SUCCESS
    262 08/08/2024 15:23 1098062 0x0187 0 10 0x6001 0 65535 65535 1 28.6 13647 1276 1276 1 77 61 2403 3144 65535 65535 78 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3410 13584 13742 1274 1283 1280 1279 436 437 437 436 1740 1740 27.9 28.3 28.4 28.6 28.4 28.6 28.3 28.6 2403 3071 3144 4036 2594 2403 3069 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1095 5632 5632 5632 5632 -407 -530 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -407 5 0.56 225 5632 5632 5632 5632 4037 8607 3084 0 5632 5632 5632 5632 16384 3152 4044 2759 SUCCESS
    263 08/08/2024 15:23 1102065 0x0187 0 10 0x6001 0 65535 65535 1 28.6 13647 1275 1276 1 77 61 2404 3144 65535 65535 78 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13581 13743 1282 1280 1285 1284 438 436 438 438 1739 1740 28.0 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2405 3073 3144 4036 2595 2404 3070 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1098 5632 5632 5632 5632 -408 -531 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -408 5 0.56 225 5632 5632 5632 5632 4037 8603 3084 0 5632 5632 5632 5632 16384 3152 4044 2266 SUCCESS
    264 08/08/2024 15:23 1106077 0x0187 0 10 0x6001 0 65535 65535 1 28.6 13647 1276 1276 1 77 61 2406 3144 65535 65535 78 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3409 3411 3410 13581 13747 1284 1281 1288 1290 439 437 439 440 1741 1740 27.9 28.3 28.4 28.5 28.4 28.5 28.4 28.5 2406 3075 3144 4036 2596 2406 3073 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1102 5632 5632 5632 5632 -410 -534 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -410 5 0.56 225 5632 5632 5632 5632 4037 8599 3084 0 5632 5632 5632 5632 16384 3152 4044 2541 SUCCESS
    265 08/08/2024 15:23 1110081 0x0187 0 10 0x6001 0 65535 65535 1 28.6 13642 1276 1276 1 77 61 2407 3144 65535 65535 78 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13581 13743 1285 1287 1281 1280 439 438 437 436 1738 1740 27.9 28.3 28.3 28.5 28.4 28.5 28.3 28.5 2408 3076 3144 4036 2598 2407 3074 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1106 5632 5632 5632 5632 -411 -535 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -411 5 0.56 225 5632 5632 5632 5632 4037 8595 3084 0 5632 5632 5632 5632 16384 3152 4044 2342 SUCCESS
    266 08/08/2024 15:23 1114089 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13647 1276 1276 1 77 61 2409 3144 65535 65535 78 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3409 3411 3410 13582 13744 1285 1279 1288 1278 439 436 439 436 1740 1740 28.0 28.3 28.4 28.6 28.4 28.6 28.4 28.6 2409 3078 3144 4036 2599 2408 3075 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1110 5632 5632 5632 5632 -412 -536 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -413 5 0.56 225 5632 5632 5632 5632 4037 8591 3084 0 5632 5632 5632 5632 16384 3152 4044 2589 SUCCESS
    267 08/08/2024 15:23 1118091 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13643 1275 1275 1 77 61 2410 3144 65535 65535 78 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13582 13743 1285 1280 1287 1279 439 436 439 436 1740 1740 27.8 28.3 28.4 28.5 28.4 28.5 28.4 28.5 2410 3080 3144 4036 2601 2410 3078 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1114 5632 5632 5632 5632 -414 -539 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -414 5 0.56 225 5632 5632 5632 5632 4037 8587 3084 0 5632 5632 5632 5632 16384 3152 4044 2318 SUCCESS
    268 08/08/2024 15:23 1122091 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13643 1274 1275 1 77 61 2411 3144 65535 65535 77 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13581 13743 1276 1278 1279 1280 436 435 436 436 1739 1740 27.9 28.3 28.4 28.5 28.4 28.5 28.4 28.5 2412 3082 3144 4036 2602 2411 3079 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1118 5632 5632 5632 5632 -415 -540 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -415 5 0.56 225 5632 5632 5632 5632 4037 8583 3084 0 5632 5632 5632 5632 16384 3152 4044 2406 SUCCESS
    269 08/08/2024 15:24 1126102 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13643 1274 1275 1 77 61 2413 3144 65535 65535 77 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3409 3409 13581 13744 1277 1283 1273 1282 436 437 434 437 1740 1739 27.9 28.3 28.4 28.5 28.4 28.5 28.4 28.5 2413 3084 3144 4036 2603 2413 3082 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1122 5632 5632 5632 5632 -417 -543 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -417 5 0.56 225 5632 5632 5632 5632 4037 8579 3084 0 5632 5632 5632 5632 16384 3152 4044 2509 SUCCESS
    270 08/08/2024 15:24 1130113 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1274 1275 1 77 61 2414 3144 65535 65535 77 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3409 3409 13582 13744 1273 1277 1272 1278 435 435 434 436 1738 1739 27.8 28.3 28.4 28.5 28.4 28.5 28.4 28.5 2415 3086 3144 4036 2605 2414 3083 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1126 5632 5632 5632 5632 -418 -544 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -418 5 0.56 225 5632 5632 5632 5632 4037 8575 3084 0 5632 5632 5632 5632 16384 3152 4044 2510 SUCCESS
    271 08/08/2024 15:24 1134126 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13643 1275 1275 1 77 61 2416 3144 65535 65535 77 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3417 3407 3410 3409 13581 13744 1275 1276 1275 1275 436 435 435 435 1737 1739 27.9 28.3 28.4 28.5 28.4 28.5 28.4 28.5 2416 3087 3144 4036 2606 2415 3085 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1130 5632 5632 5632 5632 -419 -546 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -420 5 0.56 225 5632 5632 5632 5632 4037 8571 3084 0 5632 5632 5632 5632 16384 3152 4044 2333 SUCCESS
    272 08/08/2024 15:24 1138133 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1275 1274 1 77 61 2417 3144 65535 65535 77 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13582 13743 1286 1275 1289 1276 440 434 440 435 1737 1739 27.8 28.3 28.4 28.5 28.5 28.5 28.4 28.5 2417 3089 3144 4036 2608 2417 3087 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1134 5632 5632 5632 5632 -421 -548 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -421 5 0.56 225 5632 5632 5632 5632 4037 8567 3084 0 5632 5632 5632 5632 16384 3152 4044 2511 SUCCESS
    273 08/08/2024 15:24 1142143 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13643 1274 1274 1 77 61 2418 3144 65535 65535 77 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13582 13744 1268 1278 1285 1277 433 435 438 435 1738 1738 28.0 28.4 28.4 28.5 28.4 28.5 28.4 28.5 2419 3091 3144 4036 2609 2418 3088 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1138 5632 5632 5632 5632 -422 -549 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -422 5 0.56 225 5632 5632 5632 5632 4037 8563 3084 0 5632 5632 5632 5632 16384 3152 4044 2548 SUCCESS
    274 08/08/2024 15:24 1146153 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13643 1274 1274 1 77 61 2420 3144 65535 65535 77 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13583 13745 1270 1281 1283 1279 434 436 438 436 1737 1738 27.9 28.4 28.4 28.5 28.5 28.5 28.4 28.5 2420 3093 3144 4036 2611 2420 3091 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1142 5632 5632 5632 5632 -424 -552 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -424 5 0.56 225 5632 5632 5632 5632 4037 8559 3084 0 5632 5632 5632 5632 16384 3152 4044 2565 SUCCESS
    275 08/08/2024 15:24 1150164 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1274 1274 1 78 61 2421 3144 65535 65535 76 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13583 13743 1270 1283 1279 1272 434 437 436 434 1738 1738 27.9 28.4 28.4 28.5 28.4 28.5 28.4 28.5 2422 3095 3144 4036 2612 2421 3092 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1146 5632 5632 5632 5632 -425 -553 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -425 5 0.56 225 5632 5632 5632 5632 4037 8555 3084 0 5632 5632 5632 5632 16384 3152 4044 2404 SUCCESS
    276 08/08/2024 15:24 1154176 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1273 1274 1 78 61 2423 3144 65535 65535 76 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13581 13745 1279 1278 1277 1283 437 435 435 437 1738 1738 27.9 28.3 28.4 28.5 28.5 28.5 28.4 28.5 2423 3097 3144 4036 2613 2423 3095 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1150 5632 5632 5632 5632 -427 -556 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -427 5 0.56 225 5632 5632 5632 5632 4037 8551 3084 0 5632 5632 5632 5632 16384 3152 4044 2585 SUCCESS
    277 08/08/2024 15:24 1158190 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1273 1274 1 78 61 2424 3144 65535 65535 76 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3411 3409 13583 13746 1279 1274 1278 1271 437 434 436 433 1736 1738 27.8 28.4 28.4 28.5 28.5 28.5 28.4 28.5 2425 3099 3144 4036 2615 2424 3096 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1154 5632 5632 5632 5632 -428 -557 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -428 5 0.56 225 5632 5632 5632 5632 4037 8548 3084 0 5632 5632 5632 5632 16384 3152 4044 2249 SUCCESS
    278 08/08/2024 15:24 1162197 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1272 1273 1 78 61 2426 3144 65535 65535 76 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13583 13744 1274 1280 1283 1284 435 436 438 438 1737 1737 28.0 28.4 28.4 28.5 28.5 28.5 28.4 28.5 2426 3100 3144 4036 2616 2425 3098 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1158 5632 5632 5632 5632 -429 -559 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -430 5 0.56 225 5632 5632 5632 5632 4037 8543 3084 0 5632 5632 5632 5632 16384 3152 4044 2599 SUCCESS
    279 08/08/2024 15:24 1166210 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1272 1273 1 78 61 2427 3144 65535 65535 76 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13582 13745 1273 1271 1283 1281 435 433 438 437 1736 1737 28.0 28.3 28.4 28.5 28.5 28.5 28.4 28.5 2427 3102 3144 4036 2618 2427 3100 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1162 5632 5632 5632 5632 -431 -561 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -431 5 0.56 225 5632 5632 5632 5632 4037 8539 3084 0 5632 5632 5632 5632 16384 3152 4044 2390 SUCCESS
    280 08/08/2024 15:24 1170222 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13645 1273 1273 1 78 61 2428 3144 65535 65535 76 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13583 13746 1275 1286 1278 1274 436 438 436 434 1736 1737 28.0 28.4 28.4 28.5 28.5 28.5 28.4 28.5 2429 3104 3144 4036 2619 2428 3102 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1166 5632 5632 5632 5632 -432 -563 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -432 5 0.56 225 5632 5632 5632 5632 4037 8535 3084 0 5632 5632 5632 5632 16384 3152 4044 2423 SUCCESS
    281 08/08/2024 15:24 1174224 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1272 1273 1 78 61 2430 3144 65535 65535 76 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13585 13744 1283 1279 1279 1278 439 436 436 436 1736 1737 27.9 28.4 28.4 28.5 28.5 28.5 28.4 28.5 2430 3106 3144 4036 2620 2430 3104 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1170 5632 5632 5632 5632 -434 -565 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -434 5 0.56 225 5632 5632 5632 5632 4037 8531 3084 0 5632 5632 5632 5632 16384 3152 4044 2825 SUCCESS
    282 08/08/2024 15:24 1178225 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13645 1272 1272 1 78 61 2431 3144 65535 65535 76 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13583 13745 1279 1275 1276 1268 437 434 435 432 1736 1736 27.9 28.4 28.4 28.5 28.5 28.5 28.4 28.5 2432 3108 3144 4036 2622 2431 3105 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1174 5632 5632 5632 5632 -435 -566 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -435 5 0.56 225 5632 5632 5632 5632 4037 8527 3084 0 5632 5632 5632 5632 16384 3152 4044 2467 SUCCESS
    283 08/08/2024 15:24 1182239 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13645 1273 1272 1 78 61 2433 3144 65535 65535 75 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3411 3409 13583 13746 1294 1280 1286 1282 442 436 439 437 1734 1736 28.0 28.3 28.4 28.5 28.5 28.5 28.4 28.5 2433 3110 3144 4036 2623 2432 3107 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1178 5632 5632 5632 5632 -437 -569 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -437 5 0.56 225 5632 5632 5632 5632 4037 8523 3084 0 5632 5632 5632 5632 16384 3152 4044 2504 SUCCESS
    284 08/08/2024 15:25 1186252 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1272 1272 1 78 61 2434 3144 65535 65535 75 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13587 13744 1282 1271 1273 1279 438 433 434 436 1736 1736 27.9 28.3 28.4 28.5 28.5 28.5 28.4 28.5 2434 3111 3144 4036 2625 2434 3109 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1182 5632 5632 5632 5632 -438 -570 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -438 5 0.56 225 5632 5632 5632 5632 4037 8520 3084 0 5632 5632 5632 5632 16384 3152 4044 2344 SUCCESS
    285 08/08/2024 15:25 1190265 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13645 1270 1272 1 78 61 2435 3144 65535 65535 75 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3409 13584 13745 1278 1281 1281 1270 437 437 437 433 1736 1736 28.0 28.4 28.4 28.5 28.5 28.5 28.4 28.5 2436 3113 3144 4036 2626 2435 3111 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1186 5632 5632 5632 5632 -439 -572 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -439 5 0.56 225 5632 5632 5632 5632 4037 8515 3084 0 5632 5632 5632 5632 16384 3152 4044 2537 SUCCESS
    286 08/08/2024 15:25 1194278 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13644 1271 1272 1 78 61 2437 3144 65535 65535 75 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3410 13583 13750 1268 1272 1269 1278 433 433 433 436 1736 1735 27.9 28.4 28.4 28.5 28.4 28.5 28.4 28.5 2437 3115 3144 4036 2627 2437 3113 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1190 5632 5632 5632 5632 -441 -574 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -441 5 0.56 225 5632 5632 5632 5632 4037 8512 3084 0 5632 5632 5632 5632 16384 3152 4044 2404 SUCCESS
    287 08/08/2024 15:25 1198291 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13645 1269 1271 1 78 61 2438 3144 65535 65535 75 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13587 13746 1269 1273 1270 1269 434 434 433 433 1734 1735 27.8 28.3 28.4 28.5 28.4 28.5 28.3 28.5 2439 3117 3144 4036 2629 2438 3115 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1194 5632 5632 5632 5632 -442 -576 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -442 5 0.56 225 5632 5632 5632 5632 4037 8508 3084 0 5632 5632 5632 5632 16384 3152 4044 2257 SUCCESS
    288 08/08/2024 15:25 1202303 0x0187 0 10 0x6001 0 65535 65535 1 28.5 13645 1269 1271 1 78 61 2440 3144 65535 65535 75 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3410 3409 13585 13744 1270 1277 1274 1270 434 435 434 433 1734 1735 27.8 28.3 28.3 28.4 28.5 28.4 28.3 28.4 2440 3119 3144 4036 2630 2439 3116 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1198 5632 5632 5632 5632 -443 -577 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -444 5 0.56 225 5632 5632 5632 5632 4037 8503 3084 0 5632 5632 5632 5632 16384 3152 4044 2567 SUCCESS
    289 08/08/2024 15:25 1206304 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13645 1271 1271 1 78 62 2441 3144 65535 65535 75 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13583 13748 1273 1275 1270 1274 435 435 433 434 1736 1735 27.7 28.3 28.3 28.3 28.4 28.4 28.3 28.4 2442 3121 3144 4036 2632 2441 3118 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1202 5632 5632 5632 5632 -445 -579 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -445 5 0.56 225 5632 5632 5632 5632 4037 8499 3084 0 5632 5632 5632 5632 16384 3152 4044 2545 SUCCESS
    290 08/08/2024 15:25 1210317 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13646 1272 1271 1 78 62 2443 3144 65535 65535 74 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3410 3409 13586 13747 1275 1269 1268 1288 436 432 432 439 1734 1735 27.8 28.3 28.3 28.3 28.4 28.4 28.3 28.4 2443 3122 3144 4036 2633 2442 3120 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1206 5632 5632 5632 5632 -446 -581 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -446 5 0.56 225 5632 5632 5632 5632 4037 8496 3084 0 5632 5632 5632 5632 16384 3152 4044 2346 SUCCESS
    291 08/08/2024 15:25 1214332 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13645 1272 1271 1 78 62 2444 3144 65535 65535 74 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3409 13584 13746 1279 1273 1276 1278 437 434 435 436 1733 1735 27.7 28.3 28.3 28.2 28.4 28.4 28.3 28.4 2444 3124 3144 4036 2635 2444 3122 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1210 5632 5632 5632 5632 -448 -583 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -448 5 0.56 225 5632 5632 5632 5632 4037 8492 3084 0 5632 5632 5632 5632 16384 3152 4044 2438 SUCCESS
    292 08/08/2024 15:25 1218333 0x0187 0 10 0x6001 0 65535 65535 1 28.4 13646 1271 1271 1 78 62 2445 3144 65535 65535 74 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3407 3411 3410 13584 13747 1281 1277 1282 1283 438 435 437 438 1735 1735 27.5 28.3 28.3 28.2 28.3 28.3 28.3 28.3 2446 3126 3144 4036 2636 2445 3124 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1214 5632 5632 5632 5632 -449 -585 5 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -449 5 0.56 225 5632 5632 5632 5632 4037 8488 3084 0 5632 5632 5632 5632 16384 3152 4044 2375 SUCCESS
    293 08/08/2024 15:25 1222338 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13646 1271 1271 1 78 62 2447 3144 65535 65535 74 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3407 3411 3410 13587 13747 1274 1271 1288 1278 435 433 439 436 1733 1735 27.6 28.3 28.2 28.1 28.3 28.3 28.2 28.3 2447 3128 3144 4036 2637 2446 3125 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1218 5632 5632 5632 5632 -451 -587 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -451 6 0.56 225 5632 5632 5632 5632 4037 8483 3084 0 5632 5632 5632 5632 16384 3152 4044 2609 SUCCESS
    294 08/08/2024 15:25 1226350 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13646 1271 1271 1 78 62 2448 3144 65535 65535 74 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13585 13746 1272 1271 1274 1276 435 433 435 435 1733 1735 27.5 28.3 28.2 28.1 28.3 28.3 28.2 28.3 2449 3130 3144 4036 2639 2448 3128 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1222 5632 5632 5632 5632 -452 -589 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -452 6 0.56 225 5632 5632 5632 5632 4037 8479 3084 0 5632 5632 5632 5632 16384 3152 4044 2556 SUCCESS
    295 08/08/2024 15:25 1230357 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13647 1270 1271 1 78 62 2450 3144 65535 65535 74 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3410 3409 13585 13747 1289 1273 1262 1276 441 434 430 435 1736 1734 27.5 28.3 28.2 28.1 28.3 28.3 28.2 28.3 2450 3132 3144 4036 2640 2449 3129 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1226 5632 5632 5632 5632 -453 -590 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -454 6 0.56 225 5632 5632 5632 5632 4037 8475 3084 0 5632 5632 5632 5632 16384 3152 4044 2883 SUCCESS
    296 08/08/2024 15:25 1234362 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13647 1271 1271 1 78 62 2451 3144 65535 65535 74 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3410 13586 13746 1272 1275 1275 1281 435 435 435 437 1733 1734 27.5 28.3 28.2 28.1 28.3 28.3 28.2 28.3 2451 3133 3144 4036 2642 2451 3132 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1230 5632 5632 5632 5632 -455 -593 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -455 6 0.56 225 5632 5632 5632 5632 4037 8472 3084 0 5632 5632 5632 5632 16384 3152 4044 2455 SUCCESS
    297 08/08/2024 15:25 1238375 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13647 1271 1271 1 78 62 2452 3144 65535 65535 73 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3409 3411 3410 13585 13747 1274 1284 1273 1270 435 438 434 433 1735 1734 27.5 28.2 28.2 28.0 28.2 28.2 28.2 28.2 2453 3135 3144 4036 2643 2452 3133 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1234 5632 5632 5632 5632 -456 -594 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -456 6 0.56 225 5632 5632 5632 5632 4037 8467 3084 0 5632 5632 5632 5632 16384 3152 4044 2584 SUCCESS
    298 08/08/2024 15:25 1242383 0x0187 0 10 0x6001 0 65535 65535 1 28.3 13647 1269 1271 1 79 62 2453 3144 65535 65535 73 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3409 13586 13748 1276 1276 1273 1277 436 435 434 435 1735 1734 27.4 28.2 28.1 28.0 28.2 28.2 28.1 28.2 2454 3137 3144 4036 2644 2453 3134 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1238 5632 5632 5632 5632 -458 -596 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -458 6 0.56 225 5632 5632 5632 5632 4037 8464 3084 0 5632 5632 5632 5632 16384 3152 4044 2371 SUCCESS
    299 08/08/2024 15:26 1246397 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13647 1269 1270 1 79 62 2455 3144 65535 65535 73 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13589 13748 1268 1268 1275 1280 433 432 435 436 1733 1734 27.5 28.2 28.1 28.0 28.2 28.2 28.1 28.2 2456 3139 3144 4036 2646 2455 3137 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1242 5632 5632 5632 5632 -459 -598 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -459 6 0.56 225 5632 5632 5632 5632 4037 8460 3084 0 5632 5632 5632 5632 16384 3152 4044 2377 SUCCESS
    300 08/08/2024 15:26 1250400 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13648 1270 1270 1 79 62 2456 3144 65535 65535 73 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3410 13584 13748 1274 1278 1272 1276 436 436 434 435 1735 1733 27.5 28.2 28.1 28.0 28.2 28.2 28.1 28.2 2457 3141 3144 4036 2647 2456 3138 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1246 5632 5632 5632 5632 -460 -599 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -461 6 0.56 225 5632 5632 5632 5632 4037 8456 3084 0 5632 5632 5632 5632 16384 3152 4044 2524 SUCCESS
    301 08/08/2024 15:26 1254414 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13647 1268 1270 1 79 62 2458 3144 65535 65535 73 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3409 13586 13750 1277 1274 1268 1271 437 434 433 433 1733 1733 27.4 28.2 28.1 28.0 28.2 28.2 28.1 28.2 2458 3143 3144 4036 2649 2458 3141 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1250 5632 5632 5632 5632 -462 -602 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -462 6 0.56 225 5632 5632 5632 5632 4037 8452 3084 0 5632 5632 5632 5632 16384 3152 4044 2596 SUCCESS
    302 08/08/2024 15:26 1258426 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13648 1269 1270 1 79 62 2459 3144 65535 65535 73 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3410 13589 13747 1274 1275 1278 1271 436 435 436 433 1732 1733 27.3 28.2 28.1 28.0 28.2 28.2 28.1 28.2 2460 3144 3144 4036 2650 2459 3142 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1254 5632 5632 5632 5632 -463 -603 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -463 6 0.56 225 5632 5632 5632 5632 4037 8448 3084 0 5632 5632 5632 5632 16384 3152 4044 2348 SUCCESS
    303 08/08/2024 15:26 1262432 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13647 1268 1270 1 79 62 2461 3144 65535 65535 72 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3409 13586 13748 1270 1278 1270 1267 434 436 433 432 1732 1733 27.4 28.2 28.0 28.0 28.2 28.2 28.0 28.2 2461 3146 3144 4036 2652 2461 3145 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1258 5632 5632 5632 5632 -465 -606 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -465 6 0.56 225 5632 5632 5632 5632 4037 8444 3084 0 5632 5632 5632 5632 16384 3152 4044 2614 SUCCESS
    304 08/08/2024 15:26 1266446 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13647 1268 1270 1 79 62 2462 3144 65535 65535 72 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3409 3411 3410 13586 13752 1271 1273 1270 1267 435 434 433 432 1733 1733 27.4 28.2 28.0 27.9 28.2 28.2 28.0 28.2 2463 3148 3144 4036 2653 2462 3146 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1262 5632 5632 5632 5632 -466 -607 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -466 6 0.56 225 5632 5632 5632 5632 4037 8440 3084 0 5632 5632 5632 5632 16384 3152 4044 2474 SUCCESS
    305 08/08/2024 15:26 1270456 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13649 1268 1269 1 79 62 2463 3144 65535 65535 72 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3418 3408 3411 3410 13588 13748 1269 1274 1271 1276 434 434 434 435 1733 1732 27.4 28.1 28.0 27.9 28.2 28.2 28.0 28.2 2464 3150 3144 4036 2654 2463 3147 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1266 5632 5632 5632 5632 -467 -608 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -468 6 0.56 225 5632 5632 5632 5632 4037 8436 3084 0 5632 5632 5632 5632 16384 3152 4044 2641 SUCCESS
    306 08/08/2024 15:26 1274469 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13648 1268 1269 1 79 62 2465 3144 65535 65535 72 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3412 3410 13586 13748 1278 1269 1286 1277 437 432 439 435 1731 1732 27.3 28.2 28.0 27.9 28.1 28.2 28.0 28.2 2465 3152 3144 4036 2656 2465 3150 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1270 5632 5632 5632 5632 -469 -611 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -469 6 0.56 225 5632 5632 5632 5632 4037 8432 3084 0 5632 5632 5632 5632 16384 3152 4044 2440 SUCCESS
    307 08/08/2024 15:26 1278478 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13648 1267 1269 1 79 62 2466 3144 65535 65535 72 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3409 3411 3410 13586 13750 1274 1263 1272 1269 436 431 434 433 1731 1732 27.2 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2467 3154 3144 4036 2657 2466 3151 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1274 5632 5632 5632 5632 -470 -612 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -470 6 0.56 225 5632 5632 5632 5632 4037 8428 3084 0 5632 5632 5632 5632 16384 3152 4044 2522 SUCCESS
    308 08/08/2024 15:26 1282489 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13648 1268 1269 1 79 62 2468 3144 65535 65535 72 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3410 13588 13749 1271 1266 1271 1269 435 431 434 433 1728 1731 27.3 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2468 3155 3144 4036 2659 2468 3154 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1278 5632 5632 5632 5632 -472 -615 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -472 6 0.56 225 5632 5632 5632 5632 4037 8424 3084 0 5632 5632 5632 5632 16384 3152 4044 2448 SUCCESS
    309 08/08/2024 15:26 1286503 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13650 1267 1268 1 79 62 2469 3144 65535 65535 72 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3410 13587 13750 1269 1273 1276 1268 434 434 435 432 1728 1731 27.3 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2470 3157 3144 4036 2660 2469 3155 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1282 5632 5632 5632 5632 -473 -616 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -473 6 0.56 225 5632 5632 5632 5632 4037 8420 3084 0 5632 5632 5632 5632 16384 3152 4044 2394 SUCCESS
    310 08/08/2024 15:26 1290518 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13649 1265 1268 1 79 62 2470 3144 65535 65535 72 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3409 3411 3410 13587 13750 1276 1277 1268 1279 436 435 433 436 1729 1730 27.4 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2471 3159 3144 4036 2661 2470 3156 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1286 5632 5632 5632 5632 -474 -617 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -474 6 0.56 225 5632 5632 5632 5632 4037 8416 3084 0 5632 5632 5632 5632 16384 3152 4044 2311 SUCCESS
    311 08/08/2024 15:26 1294524 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13650 1266 1267 1 79 62 2472 3144 65535 65535 71 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3410 13587 13749 1275 1276 1274 1275 436 435 435 435 1729 1730 27.3 28.1 27.9 27.9 28.1 28.1 27.9 28.1 2473 3161 3144 4036 2663 2472 3159 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1290 5632 5632 5632 5632 -476 -620 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -476 6 0.56 225 5632 5632 5632 5632 4037 8412 3084 0 5632 5632 5632 5632 16384 3152 4044 2686 SUCCESS
    312 08/08/2024 15:26 1298532 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13649 1266 1267 1 79 62 2473 3144 65535 65535 71 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3411 3410 13588 13750 1268 1270 1269 1269 434 433 433 433 1729 1729 27.3 28.1 27.9 27.9 28.1 28.1 27.9 28.1 2474 3163 3144 4036 2664 2473 3160 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1294 5632 5632 5632 5632 -477 -621 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -477 6 0.56 225 5632 5632 5632 5632 4037 8408 3084 0 5632 5632 5632 5632 16384 3152 4044 2531 SUCCESS
    313 08/08/2024 15:26 1302534 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13650 1265 1267 1 79 62 2475 3144 65535 65535 71 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3409 3411 3410 13589 13752 1277 1263 1275 1274 437 431 435 434 1731 1729 27.2 28.1 27.9 27.8 28.1 28.1 27.9 28.1 2475 3165 3144 4036 2665 2475 3163 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1298 5632 5632 5632 5632 -479 -624 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -479 6 0.56 225 5632 5632 5632 5632 4037 8404 3084 0 5632 5632 5632 5632 16384 3152 4044 2395 SUCCESS
    314 08/08/2024 15:27 1306539 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13650 1266 1267 1 79 62 2476 3144 65535 65535 71 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3412 3410 13589 13748 1270 1272 1269 1281 434 433 433 437 1728 1729 27.3 28.1 27.9 27.8 28.1 28.1 27.9 28.1 2477 3166 3144 4036 2667 2476 3164 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1302 5632 5632 5632 5632 -480 -625 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -480 6 0.56 225 5632 5632 5632 5632 4037 8400 3084 0 5632 5632 5632 5632 16384 3152 4044 2572 SUCCESS
    315 08/08/2024 15:27 1310540 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13650 1265 1267 1 79 62 2477 3144 65535 65535 71 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3412 3410 13588 13750 1268 1266 1272 1269 434 431 434 433 1728 1728 27.3 28.1 27.9 27.8 28.1 28.1 27.9 28.1 2478 3168 3144 4036 2668 2477 3165 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1306 5632 5632 5632 5632 -482 -628 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -482 6 0.56 225 5632 5632 5632 5632 4037 8395 3084 0 5632 5632 5632 5632 16384 3152 4044 2869 SUCCESS
    316 08/08/2024 15:27 1314548 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13650 1266 1266 1 79 62 2479 3144 65535 65535 71 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3413 3412 13587 13753 1272 1278 1259 1273 435 436 430 434 1726 1728 27.2 28.1 27.9 27.7 28.0 28.1 27.9 28.1 2479 3170 3144 4036 2669 2479 3168 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1310 5632 5632 5632 5632 -483 -629 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -483 6 0.56 225 5632 5632 5632 5632 4037 8392 3084 0 5632 5632 5632 5632 16384 3152 4044 2472 SUCCESS
    317 08/08/2024 15:27 1318547 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13650 1265 1266 1 79 62 2480 3144 65535 65535 71 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3409 3412 3410 13591 13750 1274 1273 1266 1278 436 434 432 436 1727 1727 27.3 28.1 27.9 27.8 28.0 28.1 27.9 28.1 2481 3172 3144 4036 2671 2480 3169 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1314 5632 5632 5632 5632 -484 -630 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -484 6 0.56 225 5632 5632 5632 5632 4037 8388 3084 0 5632 5632 5632 5632 16384 3152 4044 2430 SUCCESS
    318 08/08/2024 15:27 1322561 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13651 1265 1265 1 79 63 2482 3144 65535 65535 71 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3408 3412 3411 13588 13750 1273 1261 1274 1279 435 430 435 436 1725 1727 27.2 28.1 27.9 27.8 28.0 28.1 27.9 28.1 2482 3174 3144 4036 2672 2482 3172 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1318 5632 5632 5632 5632 -486 -633 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -486 6 0.56 225 5632 5632 5632 5632 4037 8384 3084 0 5632 5632 5632 5632 16384 3152 4044 2502 SUCCESS
    319 08/08/2024 15:27 1326570 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13651 1264 1265 1 79 63 2483 3144 65535 65535 70 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3409 3412 3411 13589 13753 1268 1261 1281 1269 434 430 437 433 1724 1727 27.2 28.1 27.9 27.8 28.0 28.1 27.9 28.1 2484 3176 3144 4036 2674 2483 3173 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1322 5632 5632 5632 5632 -487 -634 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -487 6 0.56 225 5632 5632 5632 5632 4037 8380 3084 0 5632 5632 5632 5632 16384 3152 4044 2663 SUCCESS
    320 08/08/2024 15:27 1330578 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13651 1264 1265 1 80 63 2484 3144 65535 65535 70 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3409 3412 3411 13592 13750 1262 1270 1282 1262 431 433 437 430 1727 1727 27.2 28.0 27.9 27.8 28.0 28.1 27.9 28.1 2485 3177 3144 4036 2675 2484 3175 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1326 5632 5632 5632 5632 -489 -637 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -489 6 0.56 225 5632 5632 5632 5632 4037 8376 3084 0 5632 5632 5632 5632 16384 3152 4044 2534 SUCCESS
    321 08/08/2024 15:27 1334583 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13655 1263 1265 1 80 63 2486 3144 65535 65535 70 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3411 3414 3412 13589 13750 1263 1266 1268 1255 432 432 433 428 1726 1726 27.2 28.0 27.8 27.7 28.0 28.0 27.8 28.0 2486 3179 3144 4036 2676 2486 3177 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1329 5632 5632 5632 5632 -490 -638 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -490 6 0.56 225 5632 5632 5632 5632 4037 8372 3084 0 5632 5632 5632 5632 16384 3152 4044 2191 SUCCESS
    322 08/08/2024 15:27 1338592 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13652 1262 1265 1 80 63 2487 3144 65535 65535 70 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3419 3410 3412 3411 13589 13753 1275 1278 1265 1264 436 436 432 431 1724 1726 27.2 28.0 27.8 27.7 28.0 28.0 27.8 28.0 2488 3181 3144 4036 2678 2487 3178 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1334 5632 5632 5632 5632 -491 -639 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -491 6 0.56 225 5632 5632 5632 5632 4037 8368 3084 0 5632 5632 5632 5632 16384 3152 4044 2504 SUCCESS
    323 08/08/2024 15:27 1342596 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13651 1263 1264 1 80 63 2489 3144 65535 65535 70 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3412 3412 13592 13751 1269 1270 1259 1264 434 433 430 431 1723 1725 27.1 28.0 27.8 27.7 28.0 28.0 27.8 28.0 2489 3183 3144 4036 2679 2489 3181 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1338 5632 5632 5632 5632 -493 -642 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -493 6 0.56 225 5632 5632 5632 5632 4037 8364 3084 0 5632 5632 5632 5632 16384 3152 4044 2406 SUCCESS
    324 08/08/2024 15:27 1346602 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13655 1263 1264 1 80 63 2490 3144 65535 65535 70 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3414 3412 13589 13750 1268 1264 1268 1267 434 431 433 432 1725 1725 27.2 28.0 27.8 27.6 28.0 28.0 27.8 28.0 2491 3185 3144 4036 2681 2490 3182 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1342 5632 5632 5632 5632 -494 -643 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -494 6 0.56 225 5632 5632 5632 5632 4037 8360 3084 0 5632 5632 5632 5632 16384 3152 4044 2419 SUCCESS
    325 08/08/2024 15:27 1350614 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13655 1264 1264 1 80 63 2491 3144 65535 65535 69 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3414 3412 13589 13756 1270 1264 1270 1268 434 431 434 433 1725 1725 27.2 28.0 27.8 27.6 28.0 28.0 27.8 28.0 2492 3186 3144 4036 2682 2491 3184 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1346 5632 5632 5632 5632 -495 -645 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -496 6 0.56 225 5632 5632 5632 5632 4037 8356 3084 0 5632 5632 5632 5632 16384 3152 4044 2392 SUCCESS
    326 08/08/2024 15:27 1354624 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13652 1262 1264 1 80 63 2493 3144 65535 65535 69 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3410 3413 3412 13594 13752 1270 1263 1272 1261 434 431 434 430 1725 1725 27.2 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2494 3188 3144 4036 2683 2493 3186 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1350 5632 5632 5632 5632 -497 -647 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -497 6 0.56 225 5632 5632 5632 5632 4037 8352 3084 0 5632 5632 5632 5632 16384 3152 4044 2455 SUCCESS
    327 08/08/2024 15:27 1358636 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13656 1262 1263 1 80 63 2494 3144 65535 65535 69 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3413 3413 13589 13751 1271 1271 1262 1270 435 434 431 433 1723 1724 27.1 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2495 3190 3144 4036 2685 2494 3188 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1354 5632 5632 5632 5632 -498 -649 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -498 6 0.56 225 5632 5632 5632 5632 4037 8348 3084 0 5632 5632 5632 5632 16384 3152 4044 2404 SUCCESS
    328 08/08/2024 15:27 1362649 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13656 1262 1263 1 80 63 2496 3144 65535 65535 69 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3413 3413 13589 13756 1264 1272 1260 1267 432 434 430 432 1723 1724 27.1 28.0 27.7 27.6 27.9 28.0 27.7 28.0 2496 3192 3144 4036 2686 2496 3190 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1358 5632 5632 5632 5632 -500 -651 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -500 6 0.56 225 5632 5632 5632 5632 4037 8344 3084 0 5632 5632 5632 5632 16384 3152 4044 2431 SUCCESS
    329 08/08/2024 15:28 1366661 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13656 1262 1263 1 80 63 2497 3144 65535 65535 69 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3414 3413 13592 13752 1262 1260 1270 1268 432 430 434 433 1722 1723 27.0 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2498 3194 3144 4036 2688 2497 3191 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1361 5632 5632 5632 5632 -501 -652 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -501 6 0.56 225 5632 5632 5632 5632 4037 8340 3084 0 5632 5632 5632 5632 16384 3152 4044 2329 SUCCESS
    330 08/08/2024 15:28 1370668 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13656 1262 1262 1 80 63 2499 3144 65535 65535 69 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3412 13590 13752 1265 1259 1264 1260 433 429 432 430 1722 1723 27.1 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2499 3196 3144 4036 2689 2498 3193 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1366 5632 5632 5632 5632 -502 -654 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -503 6 0.56 225 5632 5632 5632 5632 4037 8336 3084 0 5632 5632 5632 5632 16384 3152 4044 2618 SUCCESS
    331 08/08/2024 15:28 1374675 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13656 1262 1262 1 80 63 2500 3144 65535 65535 69 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13589 13754 1268 1264 1259 1271 434 431 430 434 1721 1723 27.1 28.0 27.7 27.6 27.9 28.0 27.7 28.0 2500 3197 3144 4036 2691 2500 3195 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1370 5632 5632 5632 5632 -504 -656 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -504 6 0.56 225 5632 5632 5632 5632 4037 8332 3084 0 5632 5632 5632 5632 16384 3152 4044 2495 SUCCESS
    332 08/08/2024 15:28 1378680 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13657 1261 1262 1 80 63 2501 3144 65535 65535 69 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13594 13752 1263 1270 1262 1265 432 433 431 432 1721 1723 27.1 28.0 27.7 27.6 27.8 28.0 27.7 28.0 2502 3199 3144 4036 2692 2501 3197 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1374 5632 5632 5632 5632 -505 -658 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -505 6 0.56 225 5632 5632 5632 5632 4037 8328 3084 0 5632 5632 5632 5632 16384 3152 4044 2543 SUCCESS
    333 08/08/2024 15:28 1382693 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13656 1261 1262 1 80 63 2503 3144 65535 65535 68 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3414 3413 13591 13752 1265 1258 1273 1271 433 429 435 434 1722 1723 27.1 27.9 27.6 27.6 27.8 27.9 27.6 27.9 2503 3201 3144 4036 2693 2503 3199 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1378 5632 5632 5632 5632 -507 -660 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -507 6 0.56 225 5632 5632 5632 5632 4037 8324 3084 0 5632 5632 5632 5632 16384 3152 4044 2579 SUCCESS
    334 08/08/2024 15:28 1386705 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1262 1262 1 80 63 2504 3144 65535 65535 68 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13591 13756 1279 1272 1269 1258 438 434 433 429 1721 1722 27.0 27.9 27.6 27.6 27.8 27.9 27.6 27.9 2505 3203 3144 4036 2695 2504 3201 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1382 5632 5632 5632 5632 -508 -662 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -508 6 0.56 225 5632 5632 5632 5632 4037 8320 3084 0 5632 5632 5632 5632 16384 3152 4044 2396 SUCCESS
    335 08/08/2024 15:28 1390713 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13657 1260 1261 1 80 63 2506 3144 65535 65535 68 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13595 13752 1268 1271 1257 1264 434 434 429 431 1722 1722 27.0 27.9 27.6 27.6 27.8 27.9 27.6 27.9 2506 3205 3144 4036 2696 2505 3202 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1386 5632 5632 5632 5632 -509 -663 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -510 6 0.56 225 5632 5632 5632 5632 4037 8316 3084 0 5632 5632 5632 5632 16384 3152 4044 2537 SUCCESS
    336 08/08/2024 15:28 1394720 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13656 1260 1261 1 80 63 2507 3144 65535 65535 68 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3413 3413 13591 13753 1258 1277 1271 1267 430 436 434 432 1719 1722 27.1 27.9 27.7 27.5 27.8 27.9 27.7 27.9 2507 3207 3144 4036 2698 2507 3204 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1389 5632 5632 5632 5632 -511 -665 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -511 6 0.56 225 5632 5632 5632 5632 4037 8312 3084 0 5632 5632 5632 5632 16384 3152 4044 2393 SUCCESS
    337 08/08/2024 15:28 1398728 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1260 1261 1 80 63 2508 3144 65535 65535 68 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3410 3413 3411 13592 13752 1265 1261 1265 1261 433 430 432 430 1721 1721 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2509 3208 3144 4036 2699 2508 3206 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1393 5632 5632 5632 5632 -512 -667 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -512 6 0.56 225 5632 5632 5632 5632 4037 8308 3084 0 5632 5632 5632 5632 16384 3152 4044 2199 SUCCESS
    338 08/08/2024 15:28 1402728 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1260 1260 1 80 63 2510 3144 65535 65535 68 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13595 13753 1270 1261 1262 1274 434 430 431 435 1718 1721 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2510 3210 3144 4036 2700 2510 3208 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1397 5632 5632 5632 5632 -514 -669 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -514 6 0.56 225 5632 5632 5632 5632 4037 8304 3084 0 5632 5632 5632 5632 16384 3152 4044 2466 SUCCESS
    339 08/08/2024 15:28 1406741 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1259 1260 1 80 63 2511 3144 65535 65535 68 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13591 13753 1263 1263 1269 1267 432 431 433 432 1718 1720 27.0 27.9 27.7 27.5 27.8 27.9 27.7 27.9 2512 3212 3144 4036 2702 2511 3210 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1401 5632 5632 5632 5632 -515 -671 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -515 6 0.56 225 5632 5632 5632 5632 4037 8300 3084 0 5632 5632 5632 5632 16384 3152 4044 2435 SUCCESS
    340 08/08/2024 15:28 1410743 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1257 1260 1 80 63 2513 3144 65535 65535 67 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13592 13756 1260 1262 1269 1269 431 430 433 433 1718 1720 27.1 27.9 27.7 27.5 27.8 27.9 27.7 27.9 2513 3214 3144 4036 2703 2512 3211 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1406 5632 5632 5632 5632 -516 -672 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -517 6 0.56 225 5632 5632 5632 5632 4037 8296 3084 0 5632 5632 5632 5632 16384 3152 4044 2602 SUCCESS
    341 08/08/2024 15:28 1414757 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1258 1259 1 80 63 2514 3144 65535 65535 67 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13594 13753 1253 1263 1272 1268 429 431 434 433 1721 1720 27.0 27.9 27.7 27.5 27.8 27.9 27.7 27.9 2514 3216 3144 4036 2705 2514 3214 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1409 5632 5632 5632 5632 -518 -675 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -518 6 0.56 225 5632 5632 5632 5632 4037 8292 3084 0 5632 5632 5632 5632 16384 3152 4044 2454 SUCCESS
    342 08/08/2024 15:28 1418763 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13659 1257 1259 1 80 63 2515 3144 65535 65535 67 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3409 3413 3411 13592 13754 1261 1261 1259 1254 431 430 430 428 1716 1719 27.1 27.9 27.7 27.5 27.8 27.9 27.6 27.9 2516 3217 3144 4036 2706 2515 3215 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1413 5632 5632 5632 5632 -519 -676 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -519 6 0.56 225 5632 5632 5632 5632 4037 8288 3084 0 5632 5632 5632 5632 16384 3152 4044 2557 SUCCESS
    343 08/08/2024 15:28 1422771 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13659 1257 1259 1 81 63 2517 3144 65535 65535 67 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3413 3412 13594 13752 1260 1264 1257 1258 431 431 429 429 1716 1718 27.1 27.9 27.6 27.5 27.8 27.9 27.6 27.9 2517 3219 3144 4036 2707 2516 3216 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1417 5632 5632 5632 5632 -521 -679 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -521 6 0.56 225 5632 5632 5632 5632 4037 8284 3084 0 5632 5632 5632 5632 16384 3152 4044 2390 SUCCESS
    344 08/08/2024 15:29 1426781 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1257 1258 1 81 63 2518 3144 65535 65535 67 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3413 3411 13592 13753 1263 1255 1256 1254 432 428 429 428 1716 1718 27.0 27.9 27.6 27.5 27.8 27.9 27.6 27.9 2519 3221 3144 4036 2709 2518 3219 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1421 5632 5632 5632 5632 -522 -680 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -522 6 0.56 225 5632 5632 5632 5632 4037 8280 3084 0 5632 5632 5632 5632 16384 3152 4044 2422 SUCCESS
    345 08/08/2024 15:29 1430786 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13654 1257 1258 1 81 63 2520 3144 65535 65535 67 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3412 3412 13593 13754 1259 1254 1257 1255 431 428 429 428 1714 1717 27.1 27.9 27.6 27.6 27.8 27.9 27.6 27.9 2520 3223 3144 4036 2710 2519 3220 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1425 5632 5632 5632 5632 -523 -681 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -523 6 0.56 225 5632 5632 5632 5632 4037 8276 3084 0 5632 5632 5632 5632 16384 3152 4044 2364 SUCCESS
    346 08/08/2024 15:29 1434800 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13655 1255 1257 1 81 64 2521 3144 65535 65535 67 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3412 3412 13593 13754 1256 1259 1260 1257 430 429 430 429 1714 1716 27.0 27.9 27.6 27.6 27.8 27.9 27.6 27.9 2521 3225 3144 4036 2711 2521 3223 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1429 5632 5632 5632 5632 -525 -684 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -525 6 0.56 225 5632 5632 5632 5632 4037 8272 3084 0 5632 5632 5632 5632 16384 3152 4044 2266 SUCCESS
    347 08/08/2024 15:29 1438808 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13654 1255 1257 1 81 64 2522 3144 65535 65535 67 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3413 3411 13592 13753 1258 1258 1253 1260 430 429 428 430 1714 1716 27.1 27.8 27.6 27.6 27.8 27.9 27.6 27.9 2523 3226 3144 4036 2713 2522 3224 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1433 5632 5632 5632 5632 -526 -685 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -526 6 0.56 225 5632 5632 5632 5632 4037 8268 3084 0 5632 5632 5632 5632 16384 3152 4044 2336 SUCCESS
    348 08/08/2024 15:29 1442809 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13654 1255 1256 1 81 64 2524 3144 65535 65535 66 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3412 3414 3414 13592 13754 1272 1266 1256 1265 435 432 429 432 1714 1715 27.1 27.9 27.6 27.6 27.8 27.9 27.6 27.9 2524 3228 3144 4036 2714 2523 3225 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1437 5632 5632 5632 5632 -528 -688 6 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -528 6 0.56 225 5632 5632 5632 5632 4037 8264 3084 0 5632 5632 5632 5632 16384 3152 4044 2519 SUCCESS
    349 08/08/2024 15:29 1446821 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13655 1255 1256 1 81 64 2525 3144 65535 65535 66 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3413 3412 13593 13755 1256 1259 1257 1260 430 429 429 430 1715 1715 27.0 27.8 27.6 27.5 27.7 27.8 27.6 27.8 2526 3230 3144 4036 2716 2525 3228 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1441 5632 5632 5632 5632 -529 -689 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -529 7 0.56 225 5632 5632 5632 5632 4037 8260 3084 0 5632 5632 5632 5632 16384 3152 4044 2512 SUCCESS
    350 08/08/2024 15:29 1450831 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13655 1254 1256 1 81 64 2527 3144 65535 65535 66 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3410 3413 3412 13594 13756 1257 1256 1260 1258 430 428 430 429 1714 1715 27.0 27.9 27.7 27.5 27.8 27.9 27.7 27.9 2527 3232 3144 4036 2717 2526 3229 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1445 5632 5632 5632 5632 -530 -690 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -530 7 0.56 225 5632 5632 5632 5632 4037 8256 3084 0 5632 5632 5632 5632 16384 3152 4044 2292 SUCCESS
    351 08/08/2024 15:29 1454836 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13654 1254 1255 1 81 64 2528 3144 65535 65535 66 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3413 3412 13594 13754 1254 1261 1253 1256 429 430 428 429 1714 1714 27.1 27.8 27.6 27.6 27.8 27.8 27.6 27.8 2528 3234 3144 4036 2718 2528 3232 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1449 5632 5632 5632 5632 -532 -693 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -532 7 0.56 225 5632 5632 5632 5632 4037 8252 3084 0 5632 5632 5632 5632 16384 3152 4044 2453 SUCCESS
    352 08/08/2024 15:29 1458843 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13655 1254 1255 1 81 64 2529 3144 65535 65535 66 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3413 3412 13593 13756 1252 1251 1255 1253 428 427 428 428 1712 1714 27.1 27.9 27.6 27.6 27.7 27.9 27.6 27.9 2530 3236 3144 4036 2720 2529 3233 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1453 5632 5632 5632 5632 -533 -694 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -533 7 0.56 225 5632 5632 5632 5632 4037 8248 3084 0 5632 5632 5632 5632 16384 3152 4044 2443 SUCCESS
    353 08/08/2024 15:29 1462848 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13655 1253 1255 1 81 64 2531 3144 65535 65535 66 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3413 3412 13594 13757 1263 1259 1254 1257 432 429 428 429 1711 1713 27.1 27.8 27.6 27.6 27.7 27.8 27.6 27.8 2531 3237 3144 4036 2721 2530 3234 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1457 5632 5632 5632 5632 -534 -695 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -535 7 0.56 225 5632 5632 5632 5632 4037 8244 3084 0 5632 5632 5632 5632 16384 3152 4044 2356 SUCCESS
    354 08/08/2024 15:29 1466864 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13656 1253 1254 1 81 64 2532 3144 65535 65535 66 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3413 3412 13595 13756 1256 1258 1249 1252 430 429 426 427 1711 1713 27.0 27.9 27.6 27.5 27.8 27.9 27.6 27.9 2533 3239 3144 4036 2723 2532 3237 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1461 5632 5632 5632 5632 -536 -698 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -536 7 0.56 225 5632 5632 5632 5632 4037 8240 3084 0 5632 5632 5632 5632 16384 3152 4044 2671 SUCCESS
    355 08/08/2024 15:29 1470879 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13656 1253 1254 1 81 64 2533 3144 65535 65535 66 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3410 3413 3412 13594 13756 1260 1263 1258 1260 431 431 429 430 1713 1713 27.0 27.9 27.6 27.6 27.8 27.9 27.6 27.9 2534 3241 3144 4036 2724 2533 3238 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1465 5632 5632 5632 5632 -537 -699 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -537 7 0.56 225 5632 5632 5632 5632 4037 8236 3084 0 5632 5632 5632 5632 16384 3152 4044 2470 SUCCESS
    356 08/08/2024 15:29 1474886 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13656 1252 1254 1 81 64 2535 3144 65535 65535 65 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3413 3412 13594 13756 1258 1254 1250 1262 430 428 427 431 1713 1712 27.0 27.8 27.6 27.6 27.8 27.8 27.6 27.8 2535 3243 3144 4036 2725 2535 3241 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1469 5632 5632 5632 5632 -539 -702 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -539 7 0.56 225 5632 5632 5632 5632 4037 8232 3084 0 5632 5632 5632 5632 16384 3152 4044 2400 SUCCESS
    357 08/08/2024 15:29 1478887 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13656 1252 1254 1 81 64 2536 3144 65535 65535 65 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3411 3413 3412 13598 13757 1259 1258 1257 1250 431 429 429 427 1710 1712 27.1 27.8 27.6 27.6 27.8 27.8 27.6 27.8 2537 3245 3144 4036 2727 2536 3242 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1473 5632 5632 5632 5632 -540 -703 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -540 7 0.56 225 5632 5632 5632 5632 4037 8229 3084 0 5632 5632 5632 5632 16384 3152 4044 2282 SUCCESS
    358 08/08/2024 15:29 1482901 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13657 1251 1253 1 81 64 2538 3144 65535 65535 65 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3420 3410 3414 3412 13594 13756 1251 1262 1270 1261 428 430 434 430 1711 1711 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2538 3247 3144 4036 2728 2537 3244 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1478 5632 5632 5632 5632 -542 -706 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -542 7 0.56 225 5632 5632 5632 5632 4037 8224 3084 0 5632 5632 5632 5632 16384 3152 4044 2831 SUCCESS
    359 08/08/2024 15:30 1486904 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13657 1252 1253 1 81 64 2539 3144 65535 65535 65 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3413 3412 13594 13760 1255 1252 1244 1251 429 427 425 427 1708 1711 27.1 27.9 27.6 27.6 27.8 27.9 27.6 27.9 2539 3248 3144 4036 2730 2539 3246 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1481 5632 5632 5632 5632 -543 -707 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -543 7 0.56 225 5632 5632 5632 5632 4037 8220 3084 0 5632 5632 5632 5632 16384 3152 4044 2455 SUCCESS
    360 08/08/2024 15:30 1490917 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13657 1251 1253 1 81 64 2540 3144 65535 65535 65 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3410 3413 3412 13595 13757 1254 1259 1259 1251 429 429 430 427 1709 1710 27.0 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2541 3250 3144 4036 2731 2540 3247 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1485 5632 5632 5632 5632 -544 -708 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -544 7 0.56 225 5632 5632 5632 5632 4037 8216 3084 0 5632 5632 5632 5632 16384 3152 4044 3101 SUCCESS
    361 08/08/2024 15:30 1494923 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13657 1251 1252 1 81 64 2542 3144 65535 65535 65 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3414 13595 13760 1260 1254 1258 1256 431 428 430 429 1710 1710 27.2 27.9 27.7 27.7 27.8 27.9 27.7 27.9 2542 3252 3144 4036 2732 2542 3250 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1490 5632 5632 5632 5632 -546 -711 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -546 7 0.56 225 5632 5632 5632 5632 4037 8212 3084 0 5632 5632 5632 5632 16384 3152 4044 3062 SUCCESS
    362 08/08/2024 15:30 1498936 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1251 1252 1 81 64 2543 3144 65535 65535 65 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3412 13594 13758 1262 1256 1254 1260 432 428 428 430 1707 1710 27.2 27.9 27.7 27.7 27.8 27.9 27.7 27.9 2544 3254 3144 4036 2734 2543 3251 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1493 5632 5632 5632 5632 -547 -712 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -547 7 0.56 225 5632 5632 5632 5632 4037 8208 3084 0 5632 5632 5632 5632 16384 3152 4044 2412 SUCCESS
    363 08/08/2024 15:30 1502939 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13657 1250 1252 1 81 64 2545 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3410 3414 3413 13599 13759 1250 1253 1258 1262 428 427 429 431 1709 1709 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2545 3256 3144 4036 2735 2544 3253 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1497 5632 5632 5632 5632 -548 -714 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -548 7 0.56 225 5632 5632 5632 5632 4037 8204 3084 0 5632 5632 5632 5632 16384 3152 4044 2459 SUCCESS
    364 08/08/2024 15:30 1506951 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1250 1251 1 81 64 2546 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3412 13597 13756 1250 1245 1257 1255 428 425 429 428 1707 1709 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2546 3257 3144 4036 2737 2546 3255 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1501 5632 5632 5632 5632 -550 -716 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -550 7 0.56 225 5632 5632 5632 5632 4037 8200 3084 0 5632 5632 5632 5632 16384 3152 4044 2558 SUCCESS
    365 08/08/2024 15:30 1510963 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13657 1250 1251 1 82 64 2547 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3412 13596 13760 1256 1255 1258 1250 430 428 429 427 1706 1708 27.3 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2548 3259 3144 4036 2738 2547 3257 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1505 5632 5632 5632 5632 -551 -718 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -551 7 0.56 225 5632 5632 5632 5632 4037 8197 3084 0 5632 5632 5632 5632 16384 3152 4044 2300 SUCCESS
    366 08/08/2024 15:30 1514976 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13658 1249 1250 1 82 64 2549 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13597 13759 1247 1254 1248 1254 427 428 426 428 1705 1708 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2549 3261 3144 4036 2739 2548 3258 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1509 5632 5632 5632 5632 -553 -720 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -553 7 0.56 225 5632 5632 5632 5632 4037 8192 3084 0 5632 5632 5632 5632 16384 3152 4044 2611 SUCCESS
    367 08/08/2024 15:30 1518986 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13659 1249 1250 1 82 64 2550 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3410 3414 3413 13597 13758 1256 1248 1258 1258 430 426 429 429 1705 1707 27.3 27.9 27.8 27.8 27.8 27.9 27.8 27.9 2551 3263 3144 4036 2741 2550 3261 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1513 5632 5632 5632 5632 -554 -722 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -554 7 0.56 225 5632 5632 5632 5632 4037 8188 3084 0 5632 5632 5632 5632 16384 3152 4044 2498 SUCCESS
    368 08/08/2024 15:30 1522988 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13659 1248 1250 1 82 64 2552 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3414 3413 13596 13762 1250 1255 1260 1258 428 428 430 429 1703 1707 27.3 27.9 27.8 27.8 27.8 27.9 27.8 27.9 2552 3264 3144 4036 2742 2551 3262 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1517 5632 5632 5632 5632 -555 -723 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -555 7 0.56 225 5632 5632 5632 5632 4037 8185 3084 0 5632 5632 5632 5632 16384 3152 4044 2430 SUCCESS
    369 08/08/2024 15:30 1526988 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13659 1248 1249 1 82 64 2553 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13600 13759 1253 1254 1253 1258 429 428 428 429 1703 1706 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2553 3266 3144 4036 2744 2553 3264 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1521 5632 5632 5632 5632 -557 -725 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -557 7 0.56 225 5632 5632 5632 5632 4037 8181 3084 0 5632 5632 5632 5632 16384 3152 4044 2234 SUCCESS
    370 08/08/2024 15:30 1530995 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13659 1248 1249 1 82 64 2554 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3421 3411 3415 3413 13597 13759 1255 1254 1259 1256 429 428 430 429 1705 1706 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2555 3268 3144 4036 2745 2554 3266 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1525 5632 5632 5632 5632 -558 -727 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -558 7 0.56 225 5632 5632 5632 5632 4037 8177 3084 0 5632 5632 5632 5632 16384 3152 4044 2510 SUCCESS
    371 08/08/2024 15:30 1535006 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13660 1248 1249 1 82 64 2555 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3414 13597 13762 1244 1250 1250 1258 426 426 427 429 1705 1705 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2556 3270 3144 4036 2746 2555 3267 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1529 5632 5632 5632 5632 -559 -728 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -559 7 0.56 225 5632 5632 5632 5632 4037 8173 3084 0 5632 5632 5632 5632 16384 3152 4044 2386 SUCCESS
    372 08/08/2024 15:30 1539009 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13660 1248 1248 1 82 64 2557 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13602 13759 1252 1245 1250 1252 428 425 427 427 1704 1705 27.1 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2557 3272 3144 4036 2748 2557 3270 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1533 5632 5632 5632 5632 -561 -731 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -561 7 0.56 225 5632 5632 5632 5632 4037 8169 3084 0 5632 5632 5632 5632 16384 3152 4044 2338 SUCCESS
    373 08/08/2024 15:30 1543019 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13660 1246 1248 1 82 64 2558 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3415 3413 13599 13759 1254 1254 1259 1258 429 428 430 429 1702 1704 27.2 27.9 27.8 27.6 27.9 27.9 27.8 27.9 2559 3274 3144 4036 2749 2558 3271 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1537 5632 5632 5632 5632 -562 -732 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -562 7 0.56 225 5632 5632 5632 5632 4037 8165 3084 0 5632 5632 5632 5632 16384 3152 4044 2343 SUCCESS
    374 08/08/2024 15:31 1547027 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13660 1246 1248 1 82 64 2560 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3414 3413 13597 13764 1261 1262 1255 1248 432 431 428 426 1705 1704 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2560 3275 3144 4036 2750 2560 3274 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1541 5632 5632 5632 5632 -564 -735 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -564 7 0.56 225 5632 5632 5632 5632 4037 8161 3084 0 5632 5632 5632 5632 16384 3152 4044 2512 SUCCESS
    375 08/08/2024 15:31 1551028 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13660 1246 1247 1 82 65 2561 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13601 13760 1257 1261 1244 1255 430 430 425 428 1702 1704 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2562 3277 3144 4036 2752 2561 3275 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1545 5632 5632 5632 5632 -565 -736 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -565 7 0.56 225 5632 5632 5632 5632 4037 8156 3084 0 5632 5632 5632 5632 16384 3152 4044 2665 SUCCESS
    376 08/08/2024 15:31 1555037 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13660 1246 1247 1 82 65 2562 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3413 13598 13760 1247 1246 1252 1247 427 425 427 426 1701 1703 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2563 3279 3144 4036 2753 2562 3276 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1549 5632 5632 5632 5632 -566 -737 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -566 7 0.56 225 5632 5632 5632 5632 4037 8153 3084 0 5632 5632 5632 5632 16384 3152 4044 2300 SUCCESS
    377 08/08/2024 15:31 1559039 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13660 1246 1247 1 82 65 2564 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3414 3413 13597 13763 1245 1257 1245 1249 426 429 425 426 1702 1703 27.1 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2564 3281 3144 4036 2755 2564 3279 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1553 5632 5632 5632 5632 -568 -740 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -568 7 0.56 225 5632 5632 5632 5632 4037 8149 3084 0 5632 5632 5632 5632 16384 3152 4044 2342 SUCCESS
    378 08/08/2024 15:31 1563046 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13661 1245 1246 1 82 65 2565 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3411 3414 3414 13603 13759 1246 1251 1250 1253 427 427 427 428 1701 1702 27.1 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2566 3282 3144 4036 2756 2565 3280 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1557 5632 5632 5632 5632 -569 -741 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -569 7 0.56 225 5632 5632 5632 5632 4037 8145 3084 0 5632 5632 5632 5632 16384 3152 4044 2393 SUCCESS
    379 08/08/2024 15:31 1567060 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13661 1246 1246 1 82 65 2566 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3414 3414 13600 13759 1246 1255 1248 1254 426 428 426 428 1699 1702 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2567 3284 3144 4036 2757 2566 3281 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1561 5632 5632 5632 5632 -571 -744 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -571 7 0.56 225 5632 5632 5632 5632 4037 8141 3084 0 5632 5632 5632 5632 16384 3152 4044 2630 SUCCESS
    380 08/08/2024 15:31 1571067 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1244 1246 1 82 65 2568 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3411 3415 3413 13599 13763 1256 1248 1246 1243 430 426 426 424 1701 1701 27.3 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2568 3286 3144 4036 2758 2568 3284 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1565 5632 5632 5632 5632 -572 -745 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -572 7 0.56 225 5632 5632 5632 5632 4037 8137 3084 0 5632 5632 5632 5632 16384 3152 4044 2313 SUCCESS
    381 08/08/2024 15:31 1575073 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13662 1243 1245 1 82 65 2569 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3414 3414 13602 13761 1245 1243 1251 1239 426 424 427 423 1700 1701 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2570 3288 3144 4036 2760 2569 3285 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1569 5632 5632 5632 5632 -573 -746 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -573 7 0.56 225 5632 5632 5632 5632 4037 8133 3084 0 5632 5632 5632 5632 16384 3152 4044 2458 SUCCESS
    382 08/08/2024 15:31 1579080 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1243 1245 1 82 65 2571 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3413 13599 13762 1245 1254 1249 1244 426 428 427 425 1700 1700 27.2 27.9 27.9 27.7 27.8 27.9 27.8 27.9 2571 3290 3144 4036 2762 2571 3288 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1573 5632 5632 5632 5632 -575 -749 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -575 7 0.56 225 5632 5632 5632 5632 4037 8129 3084 0 5632 5632 5632 5632 16384 3152 4044 2538 SUCCESS
    383 08/08/2024 15:31 1583085 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1242 1244 1 82 65 2572 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3414 13600 13765 1239 1253 1245 1245 424 428 425 425 1697 1699 27.3 27.9 27.8 27.8 27.8 27.9 27.8 27.9 2573 3292 3144 4036 2763 2572 3289 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1577 5632 5632 5632 5632 -576 -750 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -576 7 0.56 225 5632 5632 5632 5632 4037 8125 3084 0 5632 5632 5632 5632 16384 3152 4044 2667 SUCCESS
    384 08/08/2024 15:31 1587098 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13662 1242 1244 1 82 65 2573 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3413 13604 13761 1239 1241 1245 1244 424 423 425 425 1697 1699 27.3 27.9 27.9 27.8 27.8 27.9 27.9 27.9 2574 3293 3144 4036 2764 2573 3291 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1581 5632 5632 5632 5632 -577 -752 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -577 7 0.56 225 5632 5632 5632 5632 4037 8121 3084 0 5632 5632 5632 5632 16384 3152 4044 2378 SUCCESS
    385 08/08/2024 15:31 1591103 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1242 1243 1 82 65 2575 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3414 13600 13761 1242 1243 1243 1246 425 424 424 425 1696 1698 27.4 27.9 27.9 27.8 27.8 27.9 27.9 27.9 2575 3295 3144 4036 2765 2575 3293 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1585 5632 5632 5632 5632 -579 -754 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -579 7 0.56 225 5632 5632 5632 5632 4037 8117 3084 0 5632 5632 5632 5632 16384 3152 4044 2397 SUCCESS
    386 08/08/2024 15:31 1595115 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1240 1243 1 82 65 2576 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3414 13600 13766 1249 1245 1249 1248 427 425 427 426 1696 1697 27.2 27.9 27.9 27.8 27.9 27.9 27.9 27.9 2577 3297 3144 4036 2767 2576 3294 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1589 5632 5632 5632 5632 -580 -755 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -580 7 0.56 225 5632 5632 5632 5632 4037 8113 3084 0 5632 5632 5632 5632 16384 3152 4044 2481 SUCCESS
    387 08/08/2024 15:31 1599125 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1239 1242 1 82 65 2578 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3414 13605 13763 1246 1236 1255 1245 426 422 429 425 1696 1697 27.3 27.9 27.9 27.8 27.8 27.9 27.9 27.9 2578 3299 3144 4036 2768 2577 3296 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1593 5632 5632 5632 5632 -581 -757 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -581 7 0.56 225 5632 5632 5632 5632 4037 8109 3084 0 5632 5632 5632 5632 16384 3152 4044 2364 SUCCESS
    388 08/08/2024 15:31 1603140 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1239 1242 1 83 65 2579 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3416 3414 13600 13762 1245 1244 1247 1252 426 424 426 427 1696 1696 27.3 27.9 27.9 27.8 27.9 27.9 27.9 27.9 2580 3300 3144 4036 2769 2579 3298 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1597 5632 5632 5632 5632 -583 -759 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -583 7 0.56 225 5632 5632 5632 5632 4037 8105 3084 0 5632 5632 5632 5632 16384 3152 4044 2275 SUCCESS
    389 08/08/2024 15:32 1607154 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13663 1240 1241 1 83 65 2580 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3414 13601 13764 1237 1244 1237 1247 423 424 422 426 1691 1696 27.4 27.9 27.9 27.9 27.9 27.9 27.9 27.9 2581 3302 3144 4036 2771 2580 3300 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1601 5632 5632 5632 5632 -584 -761 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -584 7 0.56 225 5632 5632 5632 5632 4037 8101 3084 0 5632 5632 5632 5632 16384 3152 4044 2375 SUCCESS
    390 08/08/2024 15:32 1611157 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13664 1240 1241 1 83 65 2582 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3415 3414 13601 13765 1244 1247 1244 1245 426 425 425 425 1693 1695 27.4 27.9 27.9 27.9 27.9 27.9 27.9 27.9 2582 3304 3144 4036 2773 2582 3302 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1605 5632 5632 5632 5632 -586 -763 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -586 7 0.56 225 5632 5632 5632 5632 4037 8096 3084 0 5632 5632 5632 5632 16384 3152 4044 3215 SUCCESS
    391 08/08/2024 15:32 1615168 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13664 1240 1241 1 83 65 2583 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3416 3414 13603 13763 1251 1246 1247 1250 428 425 426 427 1694 1695 27.4 27.9 27.9 27.9 27.9 27.9 27.9 27.9 2584 3306 3144 4036 2774 2583 3304 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1610 5632 5632 5632 5632 -587 -765 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -587 7 0.56 225 5632 5632 5632 5632 4037 8092 3084 0 5632 5632 5632 5632 16384 3152 4044 3416 SUCCESS
    392 08/08/2024 15:32 1619272 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13664 1240 1240 1 83 65 2585 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3416 3414 13601 13763 1239 1240 1241 1234 424 423 424 421 1693 1694 27.4 27.9 27.9 27.9 27.9 28.0 27.9 28.0 2585 3308 3144 4036 2775 2585 3306 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1613 5632 5632 5632 5632 -589 -767 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -589 7 0.56 225 5632 5632 5632 5632 4037 8088 3084 0 5632 5632 5632 5632 16384 3152 4044 3226 SUCCESS
    393 08/08/2024 15:32 1623247 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13664 1238 1240 1 83 65 2586 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3414 3416 3416 13601 13764 1249 1248 1241 1251 428 426 424 427 1692 1694 27.4 28.0 27.9 27.9 27.9 28.0 27.9 28.0 2587 3310 3144 4036 2777 2586 3307 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1618 5632 5632 5632 5632 -590 -768 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -590 7 0.56 225 5632 5632 5632 5632 4037 8084 3084 0 5632 5632 5632 5632 16384 3152 4044 3301 SUCCESS
    394 08/08/2024 15:32 1627289 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13664 1238 1239 1 83 65 2588 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3414 3417 3416 13602 13767 1241 1252 1246 1243 425 427 426 425 1692 1693 27.4 28.0 28.0 27.9 27.9 28.0 27.9 28.0 2588 3312 3144 4036 2778 2587 3309 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1623 5632 5632 5632 5632 -592 -771 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -592 7 0.56 225 5632 5632 5632 5632 4037 8078 3084 0 5632 5632 5632 5632 16384 3152 4044 5568 SUCCESS
    395 08/08/2024 15:32 1633676 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13665 1236 1239 1 83 65 2590 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3422 3412 3416 3414 13603 13765 1246 1236 1240 1235 426 422 424 422 1689 1692 27.4 28.0 28.0 27.9 27.9 28.0 28.0 28.0 2591 3315 3144 4036 2781 2590 3313 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1629 5632 5632 5632 5632 -594 -774 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -594 7 0.56 225 5632 5632 5632 5632 4037 8072 3084 0 5632 5632 5632 5632 16384 3152 4044 4835 SUCCESS
    396 08/08/2024 15:32 1639166 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13666 1237 1238 1 83 65 2591 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3416 3414 13603 13764 1245 1246 1243 1234 426 425 425 421 1690 1691 27.5 28.0 28.0 27.9 28.0 28.0 28.0 28.0 2592 3317 3144 4036 2782 2591 3314 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1633 5632 5632 5632 5632 -595 -775 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -596 7 0.56 225 5632 5632 5632 5632 4037 8068 3084 0 5632 5632 5632 5632 16384 3152 4044 3259 SUCCESS
    397 08/08/2024 15:32 1643172 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13666 1237 1238 1 83 65 2593 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3416 3414 13603 13764 1246 1235 1244 1240 427 421 425 423 1688 1691 27.4 28.0 28.0 28.0 27.9 28.0 28.0 28.0 2593 3319 3144 4036 2784 2593 3317 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1637 5632 5632 5632 5632 -597 -778 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -597 7 0.56 225 5632 5632 5632 5632 4037 8064 3084 0 5632 5632 5632 5632 16384 3152 4044 3308 SUCCESS
    398 08/08/2024 15:32 1647183 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13667 1235 1237 1 83 65 2594 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3417 3414 13604 13766 1242 1244 1245 1234 425 424 425 421 1689 1690 27.5 28.0 28.0 28.0 28.0 28.0 28.0 28.0 2595 3320 3144 4036 2785 2594 3318 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1641 5632 5632 5632 5632 -598 -779 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -598 7 0.56 225 5632 5632 5632 5632 4037 8060 3084 0 5632 5632 5632 5632 16384 3152 4044 3189 SUCCESS
    399 08/08/2024 15:32 1651147 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13671 1234 1237 1 83 65 2595 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3415 3415 13604 13765 1234 1245 1243 1240 422 425 424 423 1686 1690 27.4 28.0 28.0 28.0 28.0 28.0 28.0 28.0 2596 3322 3144 4036 2786 2595 3319 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1645 5632 5632 5632 5632 -600 -781 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -600 7 0.56 225 5632 5632 5632 5632 4037 8056 3084 0 5632 5632 5632 5632 16384 3152 4044 3302 SUCCESS
    400 08/08/2024 15:32 1655176 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13671 1233 1236 1 83 65 2597 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3412 3416 3414 13604 13766 1240 1238 1238 1235 424 422 423 422 1686 1689 27.4 28.0 28.0 28.0 28.0 28.0 28.0 28.0 2598 3324 3144 4036 2788 2597 3322 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1649 5632 5632 5632 5632 -601 -783 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -601 7 0.56 225 5632 5632 5632 5632 4037 8052 3084 0 5632 5632 5632 5632 16384 3152 4044 3441 SUCCESS
    401 08/08/2024 15:32 1659340 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13667 1233 1235 1 83 65 2598 3144 65535 65535 59 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3416 3414 13604 13765 1231 1243 1239 1232 421 424 423 421 1684 1688 27.5 28.0 28.0 28.0 28.0 28.0 28.0 28.0 2599 3326 3144 4036 2789 2598 3323 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1655 5632 5632 5632 5632 -603 -785 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -603 7 0.56 225 5632 5632 5632 5632 4037 8045 3084 0 5632 5632 5632 5632 16384 3152 4044 6622 SUCCESS
    402 08/08/2024 15:33 1666865 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13667 1232 1234 1 83 66 2601 3144 65535 65535 59 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3416 3415 13605 13766 1243 1231 1237 1246 425 420 423 426 1684 1687 27.4 28.0 28.0 28.0 28.0 28.0 28.0 28.0 2602 3329 3144 4036 2792 2601 3327 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1661 5632 5632 5632 5632 -605 -788 7 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -605 7 0.56 225 5632 5632 5632 5632 4037 8040 3084 0 5632 5632 5632 5632 16384 3152 4044 3609 SUCCESS
    403 08/08/2024 15:33 1671195 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13671 1232 1234 1 83 66 2602 3144 65535 65535 59 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3417 3415 13606 13766 1230 1233 1237 1239 421 421 423 423 1684 1686 27.4 28.0 28.0 28.0 28.0 28.0 28.0 28.0 2603 3331 3144 4036 2793 2602 3328 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1665 5632 5632 5632 5632 -606 -789 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -606 8 0.56 225 5632 5632 5632 5632 4037 8036 3084 0 5632 5632 5632 5632 16384 3152 4044 3507 SUCCESS
    404 08/08/2024 15:33 1675445 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13668 1233 1233 1 83 66 2604 3144 65535 65535 59 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3416 3415 13604 13767 1238 1237 1236 1247 424 422 422 426 1685 1686 27.4 28.1 28.0 28.0 28.0 28.1 28.0 28.1 2604 3333 3144 4036 2795 2604 3331 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1669 5632 5632 5632 5632 -608 -792 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -608 8 0.56 225 5632 5632 5632 5632 4037 8032 3084 0 5632 5632 5632 5632 16384 3152 4044 3236 SUCCESS
    405 08/08/2024 15:33 1679432 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13668 1231 1233 1 83 66 2605 3144 65535 65535 59 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3416 3416 13606 13768 1229 1234 1241 1245 421 421 424 425 1681 1685 27.5 28.1 28.1 28.0 28.0 28.0 28.0 28.0 2606 3335 3144 4036 2796 2605 3332 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1674 5632 5632 5632 5632 -609 -793 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -609 8 0.56 225 5632 5632 5632 5632 4037 8028 3084 0 5632 5632 5632 5632 16384 3152 4044 3500 SUCCESS
    406 08/08/2024 15:33 1683639 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13667 1232 1232 1 83 66 2607 3144 65535 65535 59 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3415 3417 3417 13605 13766 1233 1238 1227 1232 422 423 419 421 1682 1684 27.5 28.0 28.1 28.0 28.0 28.0 28.1 28.0 2607 3337 3144 4036 2797 2606 3334 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1678 5632 5632 5632 5632 -611 -796 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -611 8 0.56 225 5632 5632 5632 5632 4037 8024 3084 0 5632 5632 5632 5632 16384 3152 4044 3230 SUCCESS
    407 08/08/2024 15:33 1687646 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13668 1230 1232 1 83 66 2608 3144 65535 65535 59 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3415 3417 3416 13605 13770 1226 1233 1223 1241 420 421 418 424 1682 1683 27.5 28.1 28.1 28.0 28.0 28.1 28.1 28.1 2609 3338 3144 4036 2799 2608 3336 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1682 5632 5632 5632 5632 -612 -797 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -612 8 0.56 225 5632 5632 5632 5632 4037 8020 3084 0 5632 5632 5632 5632 16384 3152 4044 3443 SUCCESS
    408 08/08/2024 15:33 1691796 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13668 1229 1231 1 83 66 2609 3144 65535 65535 58 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3416 3415 13606 13766 1236 1241 1237 1238 423 424 423 423 1683 1683 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2610 3341 3144 4036 2801 2610 3339 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1688 5632 5632 5632 5632 -614 -800 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -614 8 0.56 225 5632 5632 5632 5632 4037 8013 3084 0 5632 5632 5632 5632 16384 3152 4044 6423 SUCCESS
    409 08/08/2024 15:33 1699275 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13670 1230 1230 1 84 66 2613 3144 65535 65535 58 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3415 3418 3417 13606 13770 1230 1229 1241 1230 421 420 424 420 1680 1681 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2614 3346 3144 4036 2804 2613 3343 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1698 5632 5632 5632 5632 -618 -805 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -618 8 0.56 225 5632 5632 5632 5632 4037 8003 3084 0 5632 5632 5632 5632 16384 3152 4044 8244 SUCCESS
    410 08/08/2024 15:33 1708298 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13674 1228 1230 1 84 66 2615 3144 65535 65535 58 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3417 3415 13607 13768 1226 1219 1234 1231 420 416 422 420 1678 1681 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2616 3347 3144 4036 2806 2615 3345 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1702 5632 5632 5632 5632 -619 -806 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -619 8 0.56 225 5632 5632 5632 5632 4037 7999 3084 0 5632 5632 5632 5632 16384 3152 4044 3323 SUCCESS
    411 08/08/2024 15:33 1712347 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13674 1228 1229 1 84 66 2616 3144 65535 65535 58 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3414 3417 3416 13607 13772 1229 1231 1235 1222 421 420 422 417 1677 1680 27.6 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2617 3349 3144 4036 2807 2616 3347 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1706 5632 5632 5632 5632 -620 -808 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -620 8 0.56 225 5632 5632 5632 5632 4037 7995 3084 0 5632 5632 5632 5632 16384 3152 4044 3441 SUCCESS
    412 08/08/2024 15:33 1716512 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13671 1226 1229 1 84 66 2618 3144 65535 65535 58 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3423 3413 3417 3415 13610 13770 1235 1231 1229 1227 423 420 420 419 1677 1680 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2618 3351 3144 4036 2809 2618 3349 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1710 5632 5632 5632 5632 -622 -810 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -622 8 0.56 225 5632 5632 5632 5632 4037 7991 3084 0 5632 5632 5632 5632 16384 3152 4044 3184 SUCCESS
    413 08/08/2024 15:33 1720405 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13675 1228 1228 1 84 66 2619 3144 65535 65535 58 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3417 3416 13609 13769 1234 1232 1227 1226 423 420 419 419 1676 1679 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2620 3353 3144 4036 2810 2619 3350 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1714 5632 5632 5632 5632 -623 -811 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -623 8 0.56 225 5632 5632 5632 5632 4037 7987 3084 0 5632 5632 5632 5632 16384 3152 4044 3409 SUCCESS
    414 08/08/2024 15:34 1724563 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13671 1226 1228 1 84 66 2620 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3413 3417 3416 13608 13772 1222 1235 1227 1231 418 422 419 421 1675 1678 27.6 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2621 3355 3144 4036 2811 2620 3352 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1718 5632 5632 5632 5632 -624 -813 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -625 8 0.56 225 5632 5632 5632 5632 4037 7983 3084 0 5632 5632 5632 5632 16384 3152 4044 3253 SUCCESS
    415 08/08/2024 15:34 1728573 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13671 1225 1227 1 84 66 2622 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3414 3417 3416 13608 13769 1228 1237 1229 1220 420 422 420 417 1676 1677 27.6 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2623 3356 3144 4036 2813 2622 3354 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1722 5632 5632 5632 5632 -626 -815 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -626 8 0.56 225 5632 5632 5632 5632 4037 7979 3084 0 5632 5632 5632 5632 16384 3152 4044 3388 SUCCESS
    416 08/08/2024 15:34 1732723 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13672 1225 1227 1 84 66 2623 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3414 3417 3415 13609 13770 1229 1238 1229 1224 421 423 420 418 1675 1677 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2624 3358 3144 4036 2814 2623 3356 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1727 5632 5632 5632 5632 -627 -817 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -627 8 0.56 225 5632 5632 5632 5632 4037 7975 3084 0 5632 5632 5632 5632 16384 3152 4044 3423 SUCCESS
    417 08/08/2024 15:34 1736872 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13671 1224 1226 1 84 66 2625 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3419 3418 13612 13771 1227 1232 1227 1237 420 421 420 423 1675 1676 27.6 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2625 3360 3144 4036 2815 2625 3358 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1731 5632 5632 5632 5632 -629 -819 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -629 8 0.56 225 5632 5632 5632 5632 4037 7971 3084 0 5632 5632 5632 5632 16384 3152 4044 3405 SUCCESS
    418 08/08/2024 15:34 1741030 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13672 1224 1226 1 84 66 2626 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3419 3418 13608 13770 1231 1233 1232 1228 422 421 421 420 1674 1675 27.6 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2627 3362 3144 4036 2817 2626 3360 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1735 5632 5632 5632 5632 -630 -821 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -630 8 0.56 225 5632 5632 5632 5632 4037 7967 3084 0 5632 5632 5632 5632 16384 3152 4044 3208 SUCCESS
    419 08/08/2024 15:34 1745000 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13672 1223 1225 1 84 66 2628 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3419 3417 13609 13772 1235 1231 1223 1237 423 420 418 423 1671 1675 27.6 28.1 28.1 28.0 28.1 28.1 28.1 28.1 2628 3364 3144 4036 2818 2627 3361 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1739 5632 5632 5632 5632 -631 -822 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -631 8 0.56 225 5632 5632 5632 5632 4037 7963 3084 0 5632 5632 5632 5632 16384 3152 4044 3309 SUCCESS
    420 08/08/2024 15:34 1749042 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13672 1222 1224 1 84 66 2629 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3415 3419 3418 13612 13772 1239 1230 1226 1229 424 420 419 420 1671 1674 27.4 28.1 28.1 28.0 28.1 28.1 28.1 28.1 2630 3366 3144 4036 2819 2629 3363 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1743 5632 5632 5632 5632 -633 -824 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -633 8 0.56 225 5632 5632 5632 5632 4037 7959 3084 0 5632 5632 5632 5632 16384 3152 4044 3366 SUCCESS
    421 08/08/2024 15:34 1753134 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13672 1222 1224 1 84 66 2630 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3419 3418 13609 13771 1230 1224 1229 1230 421 418 420 420 1670 1673 27.4 28.1 28.1 28.0 28.1 28.1 28.1 28.1 2631 3367 3144 4036 2821 2630 3365 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1747 5632 5632 5632 5632 -634 -826 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -634 8 0.56 225 5632 5632 5632 5632 4037 7955 3084 0 5632 5632 5632 5632 16384 3152 4044 3404 SUCCESS
    422 08/08/2024 15:34 1757258 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13672 1222 1223 1 84 66 2632 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3414 3418 3416 13611 13774 1223 1224 1225 1219 419 418 419 416 1671 1673 27.4 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2632 3369 3144 4036 2822 2631 3366 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1751 5632 5632 5632 5632 -636 -828 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -636 8 0.56 225 5632 5632 5632 5632 4037 7951 3084 0 5632 5632 5632 5632 16384 3152 4044 3275 SUCCESS
    423 08/08/2024 15:34 1761302 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13673 1221 1223 1 84 66 2633 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3419 3418 13612 13772 1222 1222 1218 1223 419 417 416 418 1670 1672 27.4 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2634 3371 3144 4036 2823 2633 3369 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1755 5632 5632 5632 5632 -637 -830 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -637 8 0.56 225 5632 5632 5632 5632 4037 7947 3084 0 5632 5632 5632 5632 16384 3152 4044 3238 SUCCESS
    424 08/08/2024 15:34 1765261 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13674 1221 1222 1 84 66 2634 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3416 3419 3418 13612 13771 1228 1218 1231 1224 421 416 421 418 1669 1671 27.4 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2635 3373 3144 4036 2825 2634 3370 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1759 5632 5632 5632 5632 -638 -831 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -638 8 0.56 225 5632 5632 5632 5632 4037 7943 3084 0 5632 5632 5632 5632 16384 3152 4044 3354 SUCCESS
    425 08/08/2024 15:34 1769345 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13673 1221 1222 1 84 66 2636 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3424 3414 3418 3416 13612 13775 1218 1229 1226 1223 417 420 419 418 1667 1670 27.3 28.1 28.0 27.9 28.0 28.1 28.0 28.1 2636 3374 3144 4036 2826 2636 3373 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1763 5632 5632 5632 5632 -640 -834 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -640 8 0.56 225 5632 5632 5632 5632 4037 7939 3084 0 5632 5632 5632 5632 16384 3152 4044 3204 SUCCESS
    426 08/08/2024 15:34 1773331 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13674 1220 1221 1 84 66 2637 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3418 3417 13613 13774 1214 1227 1218 1231 416 419 416 421 1668 1670 27.3 28.1 28.0 27.9 28.0 28.1 28.0 28.1 2638 3376 3144 4036 2828 2637 3374 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1767 5632 5632 5632 5632 -641 -835 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -641 8 0.56 225 5632 5632 5632 5632 4037 7934 3084 0 5632 5632 5632 5632 16384 3152 4044 3550 SUCCESS
    427 08/08/2024 15:34 1777563 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13678 1218 1221 1 84 66 2638 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3418 3417 13612 13772 1216 1233 1211 1227 416 421 414 419 1667 1669 27.4 28.1 28.0 27.9 28.0 28.1 28.0 28.1 2639 3378 3144 4036 2829 2638 3375 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1771 5632 5632 5632 5632 -642 -836 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -642 8 0.56 225 5632 5632 5632 5632 4037 7930 3084 0 5632 5632 5632 5632 16384 3152 4044 3340 SUCCESS
    428 08/08/2024 15:34 1781645 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13678 1220 1220 1 84 66 2640 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3418 3416 13612 13775 1217 1224 1207 1222 417 418 413 417 1664 1668 27.3 28.0 28.0 27.8 28.0 28.0 28.0 28.0 2641 3380 3144 4036 2831 2640 3378 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1775 5632 5632 5632 5632 -644 -839 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -644 8 0.56 225 5632 5632 5632 5632 4037 7926 3084 0 5632 5632 5632 5632 16384 3152 4044 3692 SUCCESS
    429 08/08/2024 15:35 1786013 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13676 1216 1219 1 85 67 2641 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3414 3419 3417 13612 13772 1222 1219 1228 1225 419 416 420 419 1664 1667 27.3 28.0 28.0 27.8 28.0 28.0 28.0 28.0 2642 3382 3144 4036 2832 2641 3379 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1779 5632 5632 5632 5632 -645 -840 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -645 8 0.56 225 5632 5632 5632 5632 4037 7922 3084 0 5632 5632 5632 5632 16384 3152 4044 3320 SUCCESS
    430 08/08/2024 15:35 1790086 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13675 1217 1219 1 85 67 2642 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3418 3417 13614 13775 1218 1228 1216 1230 417 419 416 420 1663 1666 27.3 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2643 3384 3144 4036 2833 2643 3382 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1784 5632 5632 5632 5632 -647 -843 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -647 8 0.56 225 5632 5632 5632 5632 4037 7918 3084 0 5632 5632 5632 5632 16384 3152 4044 3361 SUCCESS
    431 08/08/2024 15:35 1794188 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13676 1216 1218 1 85 67 2644 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3419 3417 13612 13775 1222 1231 1222 1216 419 420 418 416 1663 1665 27.2 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2645 3385 3144 4036 2835 2644 3383 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1788 5632 5632 5632 5632 -648 -844 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -648 8 0.56 225 5632 5632 5632 5632 4037 7914 3084 0 5632 5632 5632 5632 16384 3152 4044 3348 SUCCESS
    432 08/08/2024 15:35 1798185 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13677 1216 1218 1 85 67 2645 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3419 3417 13613 13774 1221 1228 1221 1217 418 419 417 416 1663 1665 27.2 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2646 3387 3144 4036 2836 2645 3384 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1791 5632 5632 5632 5632 -649 -845 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -649 8 0.56 225 5632 5632 5632 5632 4037 7910 3084 0 5632 5632 5632 5632 16384 3152 4044 3207 SUCCESS
    433 08/08/2024 15:35 1802148 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13677 1214 1217 1 85 67 2647 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3415 3418 3417 13613 13775 1218 1223 1218 1220 417 418 416 417 1663 1664 27.3 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2647 3389 3144 4036 2837 2647 3387 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1795 5632 5632 5632 5632 -651 -848 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -651 8 0.56 225 5632 5632 5632 5632 4037 7906 3084 0 5632 5632 5632 5632 16384 3152 4044 3365 SUCCESS
    434 08/08/2024 15:35 1806225 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13678 1214 1216 1 85 67 2648 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3417 3421 3419 13617 13775 1216 1223 1207 1222 417 418 413 418 1662 1663 27.3 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2649 3391 3144 4036 2839 2648 3388 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1800 5632 5632 5632 5632 -652 -849 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -652 8 0.56 225 5632 5632 5632 5632 4037 7902 3084 0 5632 5632 5632 5632 16384 3152 4044 3328 SUCCESS
    435 08/08/2024 15:35 1810288 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13679 1213 1216 1 85 67 2649 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3415 3419 3417 13615 13775 1225 1224 1210 1216 420 418 414 416 1660 1662 27.4 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2650 3392 3144 4036 2840 2649 3390 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1803 5632 5632 5632 5632 -653 -851 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -653 8 0.56 225 5632 5632 5632 5632 4037 7898 3084 0 5632 5632 5632 5632 16384 3152 4044 3308 SUCCESS
    436 08/08/2024 15:35 1814367 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13676 1211 1215 1 85 67 2651 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3415 3419 3417 13612 13776 1216 1218 1216 1217 417 416 416 416 1656 1661 27.3 28.0 27.9 27.8 28.0 28.0 27.9 28.0 2651 3394 3144 4036 2841 2651 3392 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1808 5632 5632 5632 5632 -655 -853 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -655 8 0.56 225 5632 5632 5632 5632 4037 7894 3084 0 5632 5632 5632 5632 16384 3152 4044 3239 SUCCESS
    437 08/08/2024 15:35 1818303 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13676 1209 1214 1 85 67 2652 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3417 3420 3419 13618 13778 1219 1216 1221 1207 418 416 418 413 1654 1659 27.3 28.0 28.0 27.9 28.0 28.0 28.0 28.0 2653 3396 3144 4036 2843 2652 3393 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1812 5632 5632 5632 5632 -656 -854 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -656 8 0.56 225 5632 5632 5632 5632 4037 7890 3084 0 5632 5632 5632 5632 16384 3152 4044 3383 SUCCESS
    438 08/08/2024 15:35 1822372 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13677 1208 1213 1 85 67 2653 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3419 3418 13615 13775 1206 1214 1214 1216 413 415 415 416 1655 1658 27.4 28.0 28.0 27.9 28.0 28.0 28.0 28.0 2654 3398 3144 4036 2844 2653 3395 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1816 5632 5632 5632 5632 -657 -856 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -657 8 0.56 225 5632 5632 5632 5632 4037 7886 3084 0 5632 5632 5632 5632 16384 3152 4044 3295 SUCCESS
    439 08/08/2024 15:35 1826411 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13677 1208 1212 1 85 67 2655 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3420 3419 13614 13779 1202 1210 1209 1214 412 413 413 415 1653 1657 27.4 28.0 28.0 27.9 28.0 28.0 28.0 28.0 2656 3400 3144 4036 2845 2655 3397 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1820 5632 5632 5632 5632 -659 -858 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -659 8 0.56 225 5632 5632 5632 5632 4037 7882 3084 0 5632 5632 5632 5632 16384 3152 4044 3618 SUCCESS
    440 08/08/2024 15:35 1830730 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13677 1207 1210 1 85 67 2656 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3425 3415 3419 3417 13618 13777 1211 1217 1210 1213 415 416 414 414 1650 1655 27.3 28.0 28.0 27.9 28.0 28.0 28.0 28.0 2657 3401 3144 4036 2847 2656 3399 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1824 5632 5632 5632 5632 -660 -860 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -660 8 0.56 225 5632 5632 5632 5632 4037 7878 3084 0 5632 5632 5632 5632 16384 3152 4044 3426 SUCCESS
    441 08/08/2024 15:35 1834900 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13678 1208 1210 1 85 67 2658 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3415 3419 3417 13615 13777 1208 1215 1206 1214 414 415 412 415 1650 1654 27.4 28.0 28.0 27.9 28.0 28.0 28.0 28.0 2658 3403 3144 4036 2848 2658 3401 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1828 5632 5632 5632 5632 -662 -862 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -662 8 0.56 225 5632 5632 5632 5632 4037 7874 3084 0 5632 5632 5632 5632 16384 3152 4044 3313 SUCCESS
    442 08/08/2024 15:35 1839029 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13683 1207 1209 1 85 67 2659 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3415 3419 3417 13616 13779 1216 1210 1207 1197 417 413 413 409 1648 1653 27.5 28.0 28.0 28.0 28.0 28.0 28.0 28.0 2660 3405 3144 4036 2850 2659 3403 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1832 5632 5632 5632 5632 -663 -864 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -663 8 0.56 225 5632 5632 5632 5632 4037 7869 3084 0 5632 5632 5632 5632 16384 3152 4044 3328 SUCCESS
    443 08/08/2024 15:35 1843049 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13683 1206 1208 1 85 67 2660 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3420 3418 13618 13777 1210 1212 1222 1213 415 414 418 415 1650 1653 27.5 28.0 28.0 28.0 28.0 28.1 28.0 28.1 2661 3407 3144 4036 2851 2660 3404 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1836 5632 5632 5632 5632 -664 -865 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -664 8 0.56 225 5632 5632 5632 5632 4037 7865 3084 0 5632 5632 5632 5632 16384 3152 4044 3247 SUCCESS
    444 08/08/2024 15:36 1846980 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13682 1204 1208 1 85 67 2662 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3419 3418 13617 13778 1206 1216 1216 1206 413 415 416 412 1648 1651 27.5 28.1 28.1 28.0 28.0 28.1 28.1 28.1 2662 3408 3144 4036 2852 2662 3406 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1840 5632 5632 5632 5632 -666 -867 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -666 8 0.56 225 5632 5632 5632 5632 4037 7862 3084 0 5632 5632 5632 5632 16384 3152 4044 3208 SUCCESS
    445 08/08/2024 15:36 1850908 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13679 1203 1207 1 85 67 2663 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3419 3418 13617 13778 1209 1216 1211 1207 414 415 414 413 1647 1650 27.5 28.1 28.1 28.0 28.0 28.1 28.1 28.1 2664 3410 3144 4036 2853 2663 3408 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1844 5632 5632 5632 5632 -667 -869 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -667 8 0.56 225 5632 5632 5632 5632 4037 7858 3084 0 5632 5632 5632 5632 16384 3152 4044 3173 SUCCESS
    446 08/08/2024 15:36 1854809 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13680 1204 1206 1 85 67 2664 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3420 3418 13618 13780 1206 1214 1205 1209 413 415 412 413 1646 1649 27.5 28.1 28.1 28.0 28.0 28.1 28.1 28.1 2665 3412 3144 4036 2855 2664 3409 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1848 5632 5632 5632 5632 -668 -870 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -668 8 0.56 225 5632 5632 5632 5632 4037 7854 3084 0 5632 5632 5632 5632 16384 3152 4044 3496 SUCCESS
    447 08/08/2024 15:36 1859022 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13685 1204 1205 1 85 67 2666 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3419 3418 13617 13779 1202 1210 1206 1208 412 413 412 413 1646 1649 27.5 28.1 28.1 28.0 28.0 28.1 28.1 28.1 2666 3414 3144 4036 2856 2666 3412 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1852 5632 5632 5632 5632 -670 -873 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -670 8 0.56 225 5632 5632 5632 5632 4037 7849 3084 0 5632 5632 5632 5632 16384 3152 4044 3552 SUCCESS
    448 08/08/2024 15:36 1863304 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13681 1203 1205 1 85 67 2667 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3420 3418 13618 13780 1217 1200 1206 1206 417 410 412 412 1646 1648 27.5 28.1 28.1 28.0 28.0 28.1 28.1 28.1 2668 3416 3144 4036 2858 2667 3413 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1856 5632 5632 5632 5632 -671 -874 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -671 8 0.56 225 5632 5632 5632 5632 4037 7845 3084 0 5632 5632 5632 5632 16384 3152 4044 3521 SUCCESS
    449 08/08/2024 15:36 1867555 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13680 1202 1204 1 85 67 2668 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3420 3418 13619 13779 1203 1207 1207 1203 412 412 413 411 1643 1647 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2669 3417 3144 4036 2859 2668 3414 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1860 5632 5632 5632 5632 -672 -875 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -672 8 0.56 225 5632 5632 5632 5632 4037 7841 3084 0 5632 5632 5632 5632 16384 3152 4044 3266 SUCCESS
    450 08/08/2024 15:36 1871482 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13681 1200 1204 1 85 67 2670 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3420 3418 13618 13781 1210 1202 1205 1201 415 411 412 411 1642 1646 27.6 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2671 3419 3144 4036 2860 2670 3417 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1865 5632 5632 5632 5632 -674 -878 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -674 8 0.56 225 5632 5632 5632 5632 4037 7837 3084 0 5632 5632 5632 5632 16384 3152 4044 3502 SUCCESS
    451 08/08/2024 15:36 1875713 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13681 1201 1203 1 85 67 2671 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3418 3421 3420 13621 13780 1213 1211 1203 1210 416 414 412 414 1644 1645 27.6 28.1 28.1 28.1 28.0 28.1 28.1 28.1 2672 3421 3144 4036 2862 2671 3418 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1869 5632 5632 5632 5632 -675 -879 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -675 8 0.56 225 5632 5632 5632 5632 4037 7833 3084 0 5632 5632 5632 5632 16384 3152 4044 3367 SUCCESS
    452 08/08/2024 15:36 1879788 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13680 1201 1202 1 86 67 2673 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3418 3422 3420 13619 13780 1207 1210 1200 1201 414 414 411 411 1641 1644 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2673 3423 3144 4036 2863 2672 3420 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1873 5632 5632 5632 5632 -676 -881 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -677 8 0.56 225 5632 5632 5632 5632 4037 7829 3084 0 5632 5632 5632 5632 16384 3152 4044 3361 SUCCESS
    453 08/08/2024 15:36 1883873 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13682 1199 1201 1 86 67 2674 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3422 3420 13619 13783 1206 1209 1199 1204 413 413 410 412 1641 1643 27.6 28.1 28.1 28.1 28.1 28.1 28.2 28.1 2675 3424 3144 4036 2864 2674 3422 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1877 5632 5632 5632 5632 -678 -883 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -678 8 0.56 225 5632 5632 5632 5632 4037 7825 3084 0 5632 5632 5632 5632 16384 3152 4044 3408 SUCCESS
    454 08/08/2024 15:36 1888026 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13682 1198 1201 1 86 67 2675 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3417 3420 3419 13622 13781 1199 1200 1204 1208 411 410 412 413 1641 1642 27.6 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2676 3426 3144 4036 2866 2675 3423 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1881 5632 5632 5632 5632 -679 -884 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -679 8 0.56 225 5632 5632 5632 5632 4037 7821 3084 0 5632 5632 5632 5632 16384 3152 4044 3339 SUCCESS
    455 08/08/2024 15:36 1892048 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13683 1197 1200 1 86 67 2677 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3416 3421 3419 13621 13782 1198 1207 1199 1204 411 412 410 412 1639 1641 27.6 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2677 3428 3144 4036 2867 2676 3425 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1885 5632 5632 5632 5632 -681 -887 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -681 8 0.56 225 5632 5632 5632 5632 4037 7817 3084 0 5632 5632 5632 5632 16384 3152 4044 3377 SUCCESS
    456 08/08/2024 15:36 1896157 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13683 1198 1199 1 86 67 2678 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3421 3419 13621 13785 1203 1211 1211 1207 412 414 414 413 1639 1641 27.6 28.1 28.2 28.1 28.1 28.1 28.2 28.1 2679 3430 3144 4036 2869 2678 3427 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1889 5632 5632 5632 5632 -682 -888 8 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -682 8 0.56 225 5632 5632 5632 5632 4037 7813 3084 0 5632 5632 5632 5632 16384 3152 4044 3202 SUCCESS
    457 08/08/2024 15:36 1900075 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13682 1197 1199 1 86 67 2679 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3422 3420 13624 13782 1205 1197 1213 1197 413 409 415 409 1638 1640 27.5 28.1 28.1 28.1 28.1 28.1 28.1 28.1 2680 3431 3144 4036 2870 2679 3429 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1893 5632 5632 5632 5632 -683 -890 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -683 9 0.56 225 5632 5632 5632 5632 4037 7809 3084 0 5632 5632 5632 5632 16384 3152 4044 3244 SUCCESS
    458 08/08/2024 15:37 1904046 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13683 1195 1198 1 86 68 2681 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3417 3421 3419 13621 13783 1205 1198 1197 1200 413 409 409 410 1638 1639 27.6 28.1 28.2 28.1 28.1 28.1 28.2 28.1 2681 3433 3144 4036 2871 2680 3430 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1897 5632 5632 5632 5632 -685 -892 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -685 9 0.56 225 5632 5632 5632 5632 4037 7805 3084 0 5632 5632 5632 5632 16384 3152 4044 3461 SUCCESS
    459 08/08/2024 15:37 1908220 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13683 1195 1197 1 86 68 2682 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3418 3421 3419 13621 13787 1204 1205 1192 1199 413 412 408 410 1634 1638 27.6 28.1 28.2 28.1 28.1 28.1 28.2 28.1 2683 3435 3144 4036 2873 2682 3433 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1901 5632 5632 5632 5632 -686 -894 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -686 9 0.56 225 5632 5632 5632 5632 4037 7801 3084 0 5632 5632 5632 5632 16384 3152 4044 3291 SUCCESS
    460 08/08/2024 15:37 1912201 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13684 1193 1197 1 86 68 2683 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3421 3419 13625 13784 1200 1199 1206 1197 411 410 413 409 1634 1637 27.7 28.2 28.2 28.1 28.1 28.2 28.2 28.2 2684 3437 3144 4036 2874 2683 3434 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1905 5632 5632 5632 5632 -687 -895 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -687 9 0.56 225 5632 5632 5632 5632 4037 7797 3084 0 5632 5632 5632 5632 16384 3152 4044 3285 SUCCESS
    461 08/08/2024 15:37 1916174 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13685 1194 1196 1 86 68 2685 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3421 3419 13622 13784 1208 1195 1199 1202 414 408 410 411 1634 1636 27.6 28.2 28.2 28.2 28.1 28.2 28.2 28.2 2685 3438 3144 4036 2875 2685 3436 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1909 5632 5632 5632 5632 -689 -897 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -689 9 0.56 225 5632 5632 5632 5632 4037 7792 3084 0 5632 5632 5632 5632 16384 3152 4044 3520 SUCCESS
    462 08/08/2024 15:37 1920421 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13690 1191 1195 1 86 68 2686 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3421 3419 13621 13788 1204 1195 1198 1196 413 408 410 409 1633 1635 27.6 28.2 28.2 28.2 28.1 28.2 28.2 28.2 2687 3440 3144 4036 2877 2686 3438 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1913 5632 5632 5632 5632 -690 -899 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -690 9 0.56 225 5632 5632 5632 5632 4037 7788 3084 0 5632 5632 5632 5632 16384 3152 4044 3297 SUCCESS
    463 08/08/2024 15:37 1924465 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13690 1191 1194 1 86 68 2687 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3421 3419 13626 13786 1207 1196 1191 1199 414 409 407 410 1629 1634 27.7 28.2 28.2 28.2 28.1 28.2 28.2 28.2 2688 3442 3144 4036 2878 2687 3439 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1917 5632 5632 5632 5632 -691 -900 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -691 9 0.56 225 5632 5632 5632 5632 4037 7784 3084 0 5632 5632 5632 5632 16384 3152 4044 3412 SUCCESS
    464 08/08/2024 15:37 1928603 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13690 1190 1193 1 86 68 2689 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3421 3420 13625 13784 1193 1189 1191 1203 409 406 407 411 1629 1633 27.7 28.2 28.2 28.2 28.2 28.2 28.2 28.2 2689 3444 3144 4036 2879 2689 3442 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1921 5632 5632 5632 5632 -693 -903 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -693 9 0.56 225 5632 5632 5632 5632 4037 7780 3084 0 5632 5632 5632 5632 16384 3152 4044 3453 SUCCESS
    465 08/08/2024 15:37 1932776 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13687 1189 1192 1 86 68 2690 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3421 3419 13624 13784 1198 1194 1188 1192 411 408 406 408 1627 1631 27.7 28.2 28.2 28.2 28.1 28.2 28.2 28.2 2691 3445 3144 4036 2881 2690 3443 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1925 5632 5632 5632 5632 -694 -904 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -694 9 0.56 225 5632 5632 5632 5632 4037 7776 3084 0 5632 5632 5632 5632 16384 3152 4044 3366 SUCCESS
    466 08/08/2024 15:37 1936872 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13687 1188 1191 1 86 68 2691 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3424 3421 13624 13786 1190 1195 1204 1195 408 409 412 409 1628 1630 27.6 28.2 28.2 28.2 28.1 28.2 28.2 28.2 2692 3447 3144 4036 2882 2691 3444 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1930 5632 5632 5632 5632 -695 -905 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -695 9 0.56 225 5632 5632 5632 5632 4037 7772 3084 0 5632 5632 5632 5632 16384 3152 4044 3481 SUCCESS
    467 08/08/2024 15:37 1941054 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13687 1187 1190 1 86 68 2693 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3423 3421 13625 13789 1204 1203 1198 1189 413 411 410 407 1624 1629 27.6 28.2 28.2 28.1 28.2 28.2 28.2 28.2 2693 3449 3144 4036 2883 2693 3447 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1934 5632 5632 5632 5632 -697 -908 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -697 9 0.56 225 5632 5632 5632 5632 4037 7768 3084 0 5632 5632 5632 5632 16384 3152 4044 3293 SUCCESS
    468 08/08/2024 15:37 1945042 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13689 1186 1190 1 86 68 2694 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3422 3420 13625 13787 1195 1190 1186 1188 410 407 406 406 1625 1628 27.6 28.2 28.2 28.1 28.1 28.2 28.2 28.2 2695 3451 3144 4036 2885 2694 3448 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1938 5632 5632 5632 5632 -698 -909 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -698 9 0.56 225 5632 5632 5632 5632 4037 7764 3084 0 5632 5632 5632 5632 16384 3152 4044 3311 SUCCESS
    469 08/08/2024 15:37 1949086 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13689 1186 1189 1 86 68 2695 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3422 3420 13625 13788 1192 1183 1178 1182 409 404 403 404 1622 1627 27.5 28.2 28.2 28.1 28.1 28.2 28.2 28.2 2696 3452 3144 4036 2886 2695 3450 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1942 5632 5632 5632 5632 -699 -911 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -699 9 0.56 225 5632 5632 5632 5632 4037 7760 3084 0 5632 5632 5632 5632 16384 3152 4044 3244 SUCCESS
    470 08/08/2024 15:37 1953033 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13690 1185 1188 1 86 68 2697 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3422 3420 13627 13787 1184 1191 1181 1190 406 407 404 407 1622 1626 27.5 28.2 28.2 28.1 28.1 28.2 28.2 28.2 2697 3454 3144 4036 2887 2697 3452 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1946 5632 5632 5632 5632 -701 -913 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -701 9 0.56 225 5632 5632 5632 5632 4037 7756 3084 0 5632 5632 5632 5632 16384 3152 4044 3312 SUCCESS
    471 08/08/2024 15:37 1957047 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13690 1184 1187 1 86 68 2698 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3422 3420 13626 13788 1188 1193 1185 1192 407 408 406 408 1619 1625 27.5 28.2 28.1 28.0 28.1 28.2 28.1 28.2 2699 3456 3144 4036 2889 2698 3453 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1949 5632 5632 5632 5632 -702 -914 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -702 9 0.56 225 5632 5632 5632 5632 4037 7752 3084 0 5632 5632 5632 5632 16384 3152 4044 3292 SUCCESS
    472 08/08/2024 15:37 1961123 0x0187 0 10 0x6001 0 65535 65535 1 28.2 13690 1184 1187 1 86 68 2699 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3420 3424 3422 13628 13788 1191 1186 1191 1197 409 406 408 410 1621 1624 27.4 28.2 28.1 28.0 28.1 28.2 28.1 28.2 2700 3457 3144 4036 2890 2699 3455 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1954 5632 5632 5632 5632 -703 -916 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -703 9 0.56 225 5632 5632 5632 5632 4037 7748 3084 0 5632 5632 5632 5632 16384 3152 4044 3422 SUCCESS
    473 08/08/2024 15:38 1965307 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13690 1182 1185 1 86 68 2701 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3420 3424 3422 13627 13792 1194 1191 1193 1192 409 407 408 408 1619 1623 27.4 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2701 3459 3144 4036 2891 2701 3457 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1958 5632 5632 5632 5632 -705 -918 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -705 9 0.56 225 5632 5632 5632 5632 4037 7744 3084 0 5632 5632 5632 5632 16384 3152 4044 3387 SUCCESS
    474 08/08/2024 15:38 1969403 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13690 1183 1185 1 86 68 2702 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3423 3421 13630 13791 1183 1186 1179 1190 406 405 404 407 1616 1622 27.3 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2703 3461 3144 4036 2893 2702 3459 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1962 5632 5632 5632 5632 -706 -920 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -706 9 0.56 225 5632 5632 5632 5632 4037 7739 3084 0 5632 5632 5632 5632 16384 3152 4044 3609 SUCCESS
    475 08/08/2024 15:38 1973673 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13696 1179 1184 1 87 68 2704 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3423 3421 13627 13791 1192 1181 1174 1195 409 404 402 409 1616 1620 27.3 28.1 28.0 27.9 28.1 28.1 28.0 28.1 2704 3463 3144 4036 2894 2703 3460 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1966 5632 5632 5632 5632 -707 -921 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -707 9 0.56 225 5632 5632 5632 5632 4037 7735 3084 0 5632 5632 5632 5632 16384 3152 4044 3530 SUCCESS
    476 08/08/2024 15:38 1977907 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13693 1179 1183 1 87 68 2705 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3419 3423 3421 13630 13792 1186 1182 1197 1185 407 404 410 405 1616 1619 27.3 28.1 28.0 27.8 28.0 28.1 28.0 28.1 2706 3465 3144 4036 2896 2705 3463 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1970 5632 5632 5632 5632 -709 -924 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -709 9 0.56 225 5632 5632 5632 5632 4037 7731 3084 0 5632 5632 5632 5632 16384 3152 4044 3367 SUCCESS
    477 08/08/2024 15:38 1982013 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13692 1180 1182 1 87 68 2706 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3423 3421 13630 13790 1180 1182 1185 1180 405 404 406 404 1614 1618 27.3 28.1 28.0 27.8 28.0 28.1 28.0 28.1 2707 3466 3144 4036 2897 2706 3464 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1974 5632 5632 5632 5632 -710 -925 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -710 9 0.56 225 5632 5632 5632 5632 4037 7727 3084 0 5632 5632 5632 5632 16384 3152 4044 3510 SUCCESS
    478 08/08/2024 15:38 1986239 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13694 1178 1181 1 87 68 2707 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3420 3425 3422 13630 13794 1192 1186 1185 1178 409 406 406 403 1614 1617 27.4 28.1 28.0 27.8 28.0 28.1 28.0 28.1 2708 3468 3144 4036 2898 2707 3465 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1979 5632 5632 5632 5632 -711 -926 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -712 9 0.56 225 5632 5632 5632 5632 4037 7723 3084 0 5632 5632 5632 5632 16384 3152 4044 3519 SUCCESS
    479 08/08/2024 15:38 1990431 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13692 1177 1180 1 87 68 2709 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3420 3425 3422 13632 13792 1180 1172 1176 1179 405 401 403 403 1612 1616 27.2 28.1 27.9 27.8 28.0 28.1 27.9 28.1 2710 3470 3144 4036 2899 2709 3468 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1983 5632 5632 5632 5632 -713 -929 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -713 9 0.56 225 5632 5632 5632 5632 4037 7719 3084 0 5632 5632 5632 5632 16384 3152 4044 3461 SUCCESS
    480 08/08/2024 15:38 1994627 0x0187 0 10 0x6001 0 65535 65535 1 28.1 13692 1175 1179 1 87 68 2710 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3423 3421 13630 13792 1174 1175 1179 1181 403 402 404 404 1608 1614 27.2 28.1 28.0 27.8 28.0 28.1 28.0 28.1 2711 3472 3144 4036 2901 2710 3469 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1987 5632 5632 5632 5632 -714 -930 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -714 9 0.56 225 5632 5632 5632 5632 4037 7715 3084 0 5632 5632 5632 5632 16384 3152 4044 3258 SUCCESS
    481 08/08/2024 15:38 1998607 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13694 1175 1178 1 87 68 2712 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3420 3424 3422 13631 13795 1175 1171 1183 1193 403 400 405 408 1608 1613 27.2 28.0 27.9 27.7 28.0 28.0 27.9 28.0 2712 3473 3144 4036 2902 2711 3470 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1991 5632 5632 5632 5632 -715 -931 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -716 9 0.56 225 5632 5632 5632 5632 4037 7711 3084 0 5632 5632 5632 5632 16384 3152 4044 3354 SUCCESS
    482 08/08/2024 15:38 2002643 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13694 1172 1177 1 87 68 2713 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3420 3424 3422 13636 13793 1168 1184 1175 1179 401 405 402 403 1608 1612 27.2 28.0 27.9 27.6 28.0 28.0 27.9 28.0 2714 3475 3144 4036 2904 2713 3473 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1995 5632 5632 5632 5632 -717 -934 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -717 9 0.56 225 5632 5632 5632 5632 4037 7707 3084 0 5632 5632 5632 5632 16384 3152 4044 3409 SUCCESS
    483 08/08/2024 15:38 2006783 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13694 1173 1176 1 87 68 2714 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3419 3424 3422 13633 13794 1177 1173 1167 1176 404 401 400 402 1605 1610 27.1 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2715 3477 3144 4036 2905 2714 3474 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 1999 5632 5632 5632 5632 -718 -935 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -718 9 0.56 225 5632 5632 5632 5632 4037 7702 3084 0 5632 5632 5632 5632 16384 3152 4044 3554 SUCCESS
    484 08/08/2024 15:38 2011080 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13697 1171 1175 1 87 68 2716 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3419 3425 3422 13631 13794 1187 1177 1177 1170 407 402 403 400 1604 1608 27.2 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2716 3479 3144 4036 2906 2715 3476 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2003 5632 5632 5632 5632 -720 -938 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -720 9 0.56 225 5632 5632 5632 5632 4037 7698 3084 0 5632 5632 5632 5632 16384 3152 4044 3380 SUCCESS
    485 08/08/2024 15:38 2015206 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13697 1170 1174 1 87 68 2717 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3419 3424 3422 13633 13795 1180 1185 1170 1165 405 405 401 399 1602 1607 27.2 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2718 3480 3144 4036 2908 2717 3478 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2007 5632 5632 5632 5632 -721 -939 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -721 9 0.56 225 5632 5632 5632 5632 4037 7694 3084 0 5632 5632 5632 5632 16384 3152 4044 3460 SUCCESS
    486 08/08/2024 15:38 2019419 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13696 1169 1173 1 87 68 2719 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3421 3426 3424 13634 13797 1166 1170 1164 1179 400 400 399 404 1600 1605 27.1 28.0 27.8 27.7 27.9 28.0 27.8 28.0 2719 3482 3144 4036 2909 2718 3479 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2012 5632 5632 5632 5632 -722 -940 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -722 9 0.56 225 5632 5632 5632 5632 4037 7690 3084 0 5632 5632 5632 5632 16384 3152 4044 3456 SUCCESS
    487 08/08/2024 15:38 2023632 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13697 1167 1171 1 87 68 2720 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3420 3425 3422 13636 13795 1169 1171 1168 1182 401 400 400 404 1599 1604 27.1 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2720 3484 3144 4036 2910 2720 3482 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2016 5632 5632 5632 5632 -724 -943 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -724 9 0.56 225 5632 5632 5632 5632 4037 7686 3084 0 5632 5632 5632 5632 16384 3152 4044 3336 SUCCESS
    488 08/08/2024 15:39 2027719 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13697 1167 1170 1 87 69 2721 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3420 3425 3423 13634 13796 1179 1164 1166 1171 405 398 399 401 1597 1603 27.2 28.0 27.8 27.6 27.9 28.0 27.8 28.0 2722 3486 3144 4036 2912 2721 3483 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2020 5632 5632 5632 5632 -725 -944 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -725 9 0.56 225 5632 5632 5632 5632 4037 7681 3084 0 5632 5632 5632 5632 16384 3152 4044 3583 SUCCESS
    489 08/08/2024 15:39 2032034 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13702 1165 1169 1 87 69 2722 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3420 3425 3422 13635 13798 1164 1179 1171 1177 399 403 401 403 1599 1601 27.1 28.0 27.8 27.6 27.8 28.0 27.8 28.0 2723 3488 3144 4036 2913 2722 3485 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2024 5632 5632 5632 5632 -726 -946 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -726 9 0.56 225 5632 5632 5632 5632 4037 7677 3084 0 5632 5632 5632 5632 16384 3152 4044 3487 SUCCESS
    490 08/08/2024 15:39 2036237 0x0187 0 10 0x6001 0 65535 65535 1 28.0 13700 1165 1169 1 87 69 2724 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3420 3425 3422 13635 13797 1166 1167 1174 1160 400 399 402 397 1595 1600 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2725 3489 3144 4036 2914 2724 3487 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2028 5632 5632 5632 5632 -728 -948 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -728 9 0.56 225 5632 5632 5632 5632 4037 7673 3084 0 5632 5632 5632 5632 16384 3152 4044 3460 SUCCESS
    491 08/08/2024 15:39 2040431 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13700 1164 1168 1 87 69 2725 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3421 3425 3423 13636 13798 1165 1171 1161 1159 400 401 398 397 1593 1598 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2726 3491 3144 4036 2916 2725 3489 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2033 5632 5632 5632 5632 -729 -950 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -729 9 0.56 225 5632 5632 5632 5632 4037 7669 3084 0 5632 5632 5632 5632 16384 3152 4044 3417 SUCCESS
    492 08/08/2024 15:39 2044611 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13699 1162 1167 1 87 69 2727 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3422 3427 3424 13639 13799 1165 1176 1175 1168 400 402 403 400 1592 1597 27.1 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2727 3493 3144 4036 2917 2726 3490 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2037 5632 5632 5632 5632 -730 -951 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -730 9 0.56 225 5632 5632 5632 5632 4037 7665 3084 0 5632 5632 5632 5632 16384 3152 4044 3396 SUCCESS
    493 08/08/2024 15:39 2048752 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13700 1162 1165 1 87 69 2728 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3422 3427 3424 13638 13799 1173 1166 1162 1158 403 399 398 396 1591 1596 27.1 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2728 3495 3144 4036 2918 2728 3493 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2041 5632 5632 5632 5632 -732 -954 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -732 9 0.56 225 5632 5632 5632 5632 4037 7661 3084 0 5632 5632 5632 5632 16384 3152 4044 3273 SUCCESS
    494 08/08/2024 15:39 2052748 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13702 1160 1164 1 87 69 2729 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3423 3427 3425 13638 13803 1171 1171 1160 1175 402 401 398 402 1590 1594 27.1 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2730 3496 3144 4036 2920 2729 3494 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2045 5632 5632 5632 5632 -733 -955 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -733 9 0.56 225 5632 5632 5632 5632 4037 7657 3084 0 5632 5632 5632 5632 16384 3152 4044 3218 SUCCESS
    495 08/08/2024 15:39 2056682 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13702 1160 1163 1 87 69 2731 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3433 3423 3427 3425 13642 13801 1177 1167 1150 1168 404 399 394 400 1587 1593 27.0 27.9 27.6 27.5 27.8 27.9 27.6 27.9 2731 3498 3144 4036 2921 2730 3495 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2049 5632 5632 5632 5632 -734 -956 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -734 9 0.56 225 5632 5632 5632 5632 4037 7653 3084 0 5632 5632 5632 5632 16384 3152 4044 3318 SUCCESS
    496 08/08/2024 15:39 2060695 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13702 1158 1162 1 87 69 2732 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3421 3426 3423 13639 13801 1165 1163 1156 1165 400 398 396 399 1583 1591 27.1 27.9 27.6 27.5 27.8 27.9 27.6 27.9 2732 3499 3144 4036 2922 2731 3496 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2053 5632 5632 5632 5632 -735 -957 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -736 9 0.56 225 5632 5632 5632 5632 4037 7649 3084 0 5632 5632 5632 5632 16384 3152 4044 3252 SUCCESS
    497 08/08/2024 15:39 2064698 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13703 1158 1161 1 87 69 2733 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3433 3423 3428 3425 13641 13805 1169 1160 1162 1168 401 397 398 400 1587 1590 27.0 27.9 27.7 27.5 27.8 27.9 27.7 27.9 2734 3501 3144 4036 2923 2733 3499 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2057 5632 5632 5632 5632 -737 -960 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -737 9 0.56 225 5632 5632 5632 5632 4037 7645 3084 0 5632 5632 5632 5632 16384 3152 4044 3480 SUCCESS
    498 08/08/2024 15:39 2068939 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13703 1155 1159 1 87 69 2734 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3422 3426 3424 13643 13801 1167 1156 1157 1166 401 396 396 399 1584 1588 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2735 3503 3144 4036 2925 2734 3500 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2061 5632 5632 5632 5632 -738 -961 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -738 9 0.56 225 5632 5632 5632 5632 4037 7640 3084 0 5632 5632 5632 5632 16384 3152 4044 3840 SUCCESS
    499 08/08/2024 15:39 2073486 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13705 1153 1158 1 88 69 2736 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3421 3427 3424 13642 13801 1161 1158 1162 1156 398 396 398 396 1583 1587 27.0 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2736 3505 3144 4036 2926 2735 3502 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2065 5632 5632 5632 5632 -740 -964 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -740 9 0.56 225 5632 5632 5632 5632 4037 7636 3084 0 5632 5632 5632 5632 16384 3152 4044 3268 SUCCESS
    500 08/08/2024 15:39 2077495 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13706 1153 1157 1 88 69 2737 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3422 3427 3424 13640 13805 1155 1149 1152 1163 396 393 395 398 1579 1585 27.0 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2738 3506 3144 4036 2928 2737 3504 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2069 5632 5632 5632 5632 -741 -965 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -741 9 0.56 225 5632 5632 5632 5632 4037 7632 3084 0 5632 5632 5632 5632 16384 3152 4044 3175 SUCCESS
    501 08/08/2024 15:39 2080805 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13705 1151 1156 1 88 69 2738 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3434 3423 3429 3426 13645 13803 1162 1158 1162 1156 399 396 398 396 1577 1583 27.0 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2739 3508 3144 4036 2929 2738 3506 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2073 5632 5632 5632 5632 -742 -967 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -742 9 0.56 225 5632 5632 5632 5632 4037 7629 3084 0 5632 5632 5632 5632 16384 3152 4044 3406 SUCCESS
    502 08/08/2024 15:40 2084970 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13706 1150 1154 1 88 69 2739 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3433 3422 3427 3424 13645 13804 1159 1154 1159 1149 398 395 397 393 1575 1581 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2741 3511 3144 4036 2931 2740 3508 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2080 5632 5632 5632 5632 -744 -969 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -745 9 0.56 225 5632 5632 5632 5632 4037 7621 3084 0 5632 5632 5632 5632 16384 3152 4044 7547 SUCCESS
    503 08/08/2024 15:40 2093203 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13707 1148 1152 1 88 69 2742 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3433 3422 3428 3424 13647 13805 1148 1156 1150 1145 394 396 394 392 1575 1579 27.2 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2743 3513 3144 4036 2933 2742 3511 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2085 5632 5632 5632 5632 -746 -972 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -746 9 0.56 225 5632 5632 5632 5632 4037 7617 3084 0 5632 5632 5632 5632 16384 3152 4044 3302 SUCCESS
    504 08/08/2024 15:40 2097253 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13712 1146 1151 1 88 69 2743 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3434 3424 3429 3426 13646 13808 1157 1159 1143 1152 397 397 392 395 1570 1577 27.2 27.9 27.7 27.6 27.7 27.9 27.7 27.9 2744 3515 3144 4036 2934 2743 3512 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2090 5632 5632 5632 5632 -747 -973 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -748 9 0.56 225 5632 5632 5632 5632 4037 7611 3084 0 5632 5632 5632 5632 16384 3152 4044 4488 SUCCESS
    505 08/08/2024 15:40 2102447 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13714 1145 1149 1 88 69 2745 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3433 3423 3428 3425 13648 13808 1147 1156 1163 1147 394 396 399 393 1568 1575 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2746 3517 3144 4036 2936 2745 3515 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2094 5632 5632 5632 5632 -749 -976 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -749 9 0.56 225 5632 5632 5632 5632 4037 7607 3084 0 5632 5632 5632 5632 16384 3152 4044 3223 SUCCESS
    506 08/08/2024 15:40 2106391 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13714 1143 1148 1 88 69 2746 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3434 3423 3428 3425 13646 13807 1147 1137 1137 1141 394 389 390 391 1567 1573 27.1 27.9 27.7 27.6 27.8 27.9 27.8 27.9 2747 3518 3144 4036 2937 2746 3516 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2098 5632 5632 5632 5632 -750 -977 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -750 9 0.56 225 5632 5632 5632 5632 4037 7604 3084 0 5632 5632 5632 5632 16384 3152 4044 3256 SUCCESS
    507 08/08/2024 15:40 2110378 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13715 1143 1147 1 88 69 2747 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3434 3424 3428 3425 13648 13810 1150 1155 1140 1140 395 395 391 390 1566 1572 27.2 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2748 3520 3144 4036 2938 2747 3517 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2102 5632 5632 5632 5632 -751 -978 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -751 9 0.56 225 5632 5632 5632 5632 4037 7599 3084 0 5632 5632 5632 5632 16384 3152 4044 3423 SUCCESS
    508 08/08/2024 15:40 2114553 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13715 1141 1145 1 88 69 2749 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3433 3423 3428 3425 13647 13809 1141 1145 1144 1139 392 392 392 390 1563 1569 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2749 3522 3144 4036 2939 2749 3520 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2106 5632 5632 5632 5632 -753 -981 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -753 9 0.56 225 5632 5632 5632 5632 4037 7595 3084 0 5632 5632 5632 5632 16384 3152 4044 3430 SUCCESS
    509 08/08/2024 15:40 2118674 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13712 1139 1144 1 88 69 2750 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3434 3423 3429 3425 13649 13809 1146 1141 1139 1143 394 391 391 391 1559 1568 27.0 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2751 3523 3144 4036 2941 2750 3521 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2110 5632 5632 5632 5632 -754 -982 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -754 9 0.56 225 5632 5632 5632 5632 4037 7591 3084 0 5632 5632 5632 5632 16384 3152 4044 3135 SUCCESS
    510 08/08/2024 15:40 2122587 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13714 1106 1136 1 88 69 2751 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3434 3423 3428 3425 13646 13809 1142 1130 1147 1131 392 387 393 387 1546 1557 27.0 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2752 3525 3144 4036 2942 2751 3522 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2114 5632 5632 5632 5632 -755 -983 9 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -755 10 0.56 225 5632 5632 5632 5632 4037 7587 3084 0 5632 5632 5632 5632 16384 3152 4044 3475 SUCCESS
    511 08/08/2024 15:40 2126832 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13708 1107 1133 1 88 69 2752 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3421 3427 3424 13645 13803 1094 1100 1097 1100 375 376 376 377 1498 1550 27.2 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2753 3527 3144 4036 2943 2752 3524 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2118 5632 5632 5632 5632 -756 -985 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -756 10 0.56 225 5632 5632 5632 5632 4037 7583 3084 0 5632 5632 5632 5632 16384 3152 4044 3074 SUCCESS
    512 08/08/2024 15:40 2130622 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13708 1086 1123 1 88 69 2754 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3421 3427 3423 13639 13800 1086 1092 1080 1084 373 374 370 371 1481 1536 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2754 3528 3144 4036 2944 2753 3525 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2122 5632 5632 5632 5632 -757 -986 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -758 10 0.56 225 5632 5632 5632 5632 4037 7579 3084 0 5632 5632 5632 5632 16384 3152 4044 3356 SUCCESS
    513 08/08/2024 15:40 2134651 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13706 1076 1112 1 88 69 2755 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3421 3426 3423 13637 13800 1076 1080 1076 1085 369 369 369 371 1471 1521 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2756 3530 3144 4036 2946 2755 3528 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2126 5632 5632 5632 5632 -759 -989 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -759 10 0.56 225 5632 5632 5632 5632 4037 7575 3084 0 5632 5632 5632 5632 16384 3152 4044 3314 SUCCESS
    514 08/08/2024 15:40 2138679 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13705 1067 1103 1 88 69 2756 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3420 3427 3422 13639 13797 1074 1068 1075 1074 368 365 368 368 1459 1508 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2757 3531 3144 4036 2947 2756 3529 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2130 5632 5632 5632 5632 -760 -990 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -760 10 0.56 225 5632 5632 5632 5632 4037 7571 3084 0 5632 5632 5632 5632 16384 3152 4044 3228 SUCCESS
    515 08/08/2024 15:40 2142703 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13704 1062 1093 1 88 69 2757 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3421 3426 3422 13636 13796 1075 1063 1074 1065 369 364 368 364 1453 1495 27.1 27.8 27.8 27.7 27.8 27.8 27.8 27.8 2758 3533 3144 4036 2948 2757 3530 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2134 5632 5632 5632 5632 -761 -991 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -761 10 0.56 225 5632 5632 5632 5632 4037 7567 3084 0 5632 5632 5632 5632 16384 3152 4044 3420 SUCCESS
    516 08/08/2024 15:41 2146843 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13699 1056 1085 1 88 69 2758 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3420 3426 3422 13635 13799 1057 1062 1060 1062 363 363 363 363 1445 1485 27.2 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2759 3534 3144 4036 2949 2758 3532 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2138 5632 5632 5632 5632 -762 -993 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -762 10 0.56 225 5632 5632 5632 5632 4037 7563 3084 0 5632 5632 5632 5632 16384 3152 4044 3380 SUCCESS
    517 08/08/2024 15:41 2150948 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13698 1047 1077 1 88 69 2760 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3420 3425 3422 13635 13795 1059 1046 1050 1045 363 358 360 358 1434 1471 27.1 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2760 3536 3144 4036 2950 2759 3533 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2142 5632 5632 5632 5632 -763 -994 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -764 10 0.56 225 5632 5632 5632 5632 4037 7559 3084 0 5632 5632 5632 5632 16384 3152 4044 3288 SUCCESS
    518 08/08/2024 15:41 2155009 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13698 1048 1070 1 88 70 2761 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3420 3425 3422 13635 13794 1053 1053 1057 1052 361 360 362 360 1438 1463 27.1 27.9 27.8 27.7 27.8 27.8 27.8 27.8 2762 3538 3144 4036 2951 2761 3536 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2146 5632 5632 5632 5632 -765 -997 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -765 10 0.56 225 5632 5632 5632 5632 4037 7555 3084 0 5632 5632 5632 5632 16384 3152 4044 3416 SUCCESS
    519 08/08/2024 15:41 2159173 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13698 1047 1065 1 88 70 2762 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3421 3427 3423 13636 13796 1050 1053 1046 1046 360 360 358 358 1433 1456 27.1 27.9 27.8 27.7 27.8 27.9 27.8 27.9 2763 3539 3144 4036 2953 2762 3537 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2151 5632 5632 5632 5632 -766 -998 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -766 10 0.56 225 5632 5632 5632 5632 4037 7551 3084 0 5632 5632 5632 5632 16384 3152 4044 3361 SUCCESS
    520 08/08/2024 15:41 2163220 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13697 1039 1060 1 88 70 2763 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3420 3426 3422 13634 13794 1043 1034 1041 1041 358 354 357 356 1423 1448 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2764 3541 3144 4036 2954 2763 3538 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2155 5632 5632 5632 5632 -767 -999 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -767 10 0.56 225 5632 5632 5632 5632 4037 7547 3084 0 5632 5632 5632 5632 16384 3152 4044 3343 SUCCESS
    521 08/08/2024 15:41 2167316 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13697 1033 1053 1 88 70 2765 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3421 3427 3423 13633 13796 1041 1039 1039 1037 357 355 356 355 1415 1441 27.2 27.9 27.8 27.6 27.8 27.9 27.8 27.9 2765 3542 3144 4036 2955 2764 3539 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2159 5632 5632 5632 5632 -768 -1000 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -768 10 0.56 225 5632 5632 5632 5632 4037 7543 3084 0 5632 5632 5632 5632 16384 3152 4044 3415 SUCCESS
    522 08/08/2024 15:41 2171489 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13696 1027 1048 1 88 70 2766 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3421 3426 3423 13634 13794 1024 1032 1031 1023 351 353 353 350 1401 1433 27.1 27.9 27.7 27.6 27.8 27.9 27.7 27.9 2766 3544 3144 4036 2956 2765 3541 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2163 5632 5632 5632 5632 -769 -1002 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -769 10 0.56 225 5632 5632 5632 5632 4037 7539 3084 0 5632 5632 5632 5632 16384 3152 4044 3262 SUCCESS
    523 08/08/2024 15:41 2175519 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13695 1020 1041 1 89 70 2767 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3425 3421 13633 13791 1016 1022 1020 1013 348 349 349 347 1389 1424 27.0 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2767 3545 3144 4036 2957 2766 3542 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2167 5632 5632 5632 5632 -770 -1003 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -771 10 0.56 225 5632 5632 5632 5632 4037 7535 3084 0 5632 5632 5632 5632 16384 3152 4044 3280 SUCCESS
    524 08/08/2024 15:41 2179558 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13693 1011 1034 1 89 70 2768 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3425 3421 13632 13793 1010 1019 1010 1014 346 348 346 347 1382 1414 27.1 27.9 27.7 27.6 27.7 27.9 27.7 27.9 2768 3547 3144 4036 2959 2768 3545 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2171 5632 5632 5632 5632 -772 -1006 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -772 10 0.56 225 5632 5632 5632 5632 4037 7531 3084 0 5632 5632 5632 5632 16384 3152 4044 3385 SUCCESS
    525 08/08/2024 15:41 2183668 0x0187 0 10 0x6001 0 65535 65535 1 27.9 13693 1009 1028 1 89 70 2769 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3430 3418 3425 3421 13632 13791 1016 1009 1010 1013 348 345 346 347 1378 1406 27.2 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2770 3548 3144 4036 2960 2769 3546 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2175 5632 5632 5632 5632 -773 -1007 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -773 10 0.56 225 5632 5632 5632 5632 4037 7527 3084 0 5632 5632 5632 5632 16384 3152 4044 3367 SUCCESS
    526 08/08/2024 15:41 2187774 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13693 1003 1023 1 89 70 2770 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3418 3425 3421 13631 13791 997 1002 1005 1005 342 342 344 344 1369 1399 27.0 27.8 27.8 27.6 27.7 27.8 27.8 27.8 2771 3550 3144 4036 2961 2770 3547 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2179 5632 5632 5632 5632 -774 -1008 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -774 10 0.56 225 5632 5632 5632 5632 4037 7523 3084 0 5632 5632 5632 5632 16384 3152 4044 3309 SUCCESS
    527 08/08/2024 15:41 2191824 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13696 987 1016 1 89 70 2771 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3424 3420 13627 13789 981 988 975 974 336 338 334 333 1340 1389 27.0 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2772 3551 3144 4036 2962 2771 3549 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2183 5632 5632 5632 5632 -775 -1010 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -775 10 0.56 225 5632 5632 5632 5632 4037 7518 3084 0 5632 5632 5632 5632 16384 3152 4044 3442 SUCCESS
    528 08/08/2024 15:41 2196025 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13695 979 1007 1 89 70 2772 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3424 3420 13628 13786 984 975 979 980 337 333 335 335 1339 1377 27.1 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2773 3553 3144 4036 2963 2772 3550 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2187 5632 5632 5632 5632 -776 -1011 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -776 10 0.56 225 5632 5632 5632 5632 4037 7514 3084 0 5632 5632 5632 5632 16384 3152 4044 3427 SUCCESS
    529 08/08/2024 15:41 2200193 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13691 976 1000 1 89 70 2774 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3424 3420 13625 13787 982 986 971 991 337 337 332 339 1329 1364 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2774 3554 3144 4036 2964 2773 3551 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2191 5632 5632 5632 5632 -777 -1012 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -777 10 0.56 225 5632 5632 5632 5632 4037 7510 3084 0 5632 5632 5632 5632 16384 3152 4044 3382 SUCCESS
    530 08/08/2024 15:42 2204305 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13690 971 993 1 89 70 2775 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3424 3419 13626 13787 966 987 972 984 331 337 333 336 1325 1356 27.0 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2775 3555 3144 4036 2965 2774 3552 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2195 5632 5632 5632 5632 -778 -1013 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -778 10 0.56 225 5632 5632 5632 5632 4037 7506 3084 0 5632 5632 5632 5632 16384 3152 4044 3405 SUCCESS
    531 08/08/2024 15:42 2208395 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13689 969 988 1 89 70 2776 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3424 3420 13627 13786 988 961 987 977 339 328 338 334 1325 1349 27.1 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2776 3557 3144 4036 2966 2775 3554 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2199 5632 5632 5632 5632 -779 -1015 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -779 10 0.56 225 5632 5632 5632 5632 4037 7502 3084 0 5632 5632 5632 5632 16384 3152 4044 3240 SUCCESS
    532 08/08/2024 15:42 2212386 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13690 967 983 1 89 70 2777 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3424 3420 13625 13786 983 972 977 971 337 332 335 332 1321 1342 27.2 27.8 27.7 27.6 27.6 27.8 27.8 27.8 2777 3558 3144 4036 2967 2776 3555 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2204 5632 5632 5632 5632 -781 -1017 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -781 10 0.56 225 5632 5632 5632 5632 4037 7498 3084 0 5632 5632 5632 5632 16384 3152 4044 3511 SUCCESS
    533 08/08/2024 15:42 2216600 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13689 963 977 1 89 70 2778 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3419 3426 3421 13630 13786 968 963 969 960 332 329 332 328 1316 1337 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2779 3560 3144 4036 2968 2778 3558 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2208 5632 5632 5632 5632 -782 -1019 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -782 10 0.56 225 5632 5632 5632 5632 4037 7494 3084 0 5632 5632 5632 5632 16384 3152 4044 3398 SUCCESS
    534 08/08/2024 15:42 2220678 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13689 960 973 1 89 70 2779 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3419 3426 3421 13627 13786 954 951 964 963 327 325 330 329 1310 1331 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2780 3561 3144 4036 2969 2779 3559 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2212 5632 5632 5632 5632 -783 -1020 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -783 10 0.56 225 5632 5632 5632 5632 4037 7490 3084 0 5632 5632 5632 5632 16384 3152 4044 3363 SUCCESS
    535 08/08/2024 15:42 2224774 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13689 957 969 1 89 70 2780 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3426 3421 13627 13791 949 953 959 971 325 326 329 332 1306 1326 27.2 27.8 27.8 27.6 27.6 27.8 27.8 27.8 2781 3563 3144 4036 2970 2780 3560 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2216 5632 5632 5632 5632 -784 -1021 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -784 10 0.56 225 5632 5632 5632 5632 4037 7486 3084 0 5632 5632 5632 5632 16384 3152 4044 3205 SUCCESS
    536 08/08/2024 15:42 2228666 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13689 952 965 1 89 70 2781 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3425 3421 13630 13785 960 968 942 951 329 331 323 325 1301 1320 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2782 3564 3144 4036 2972 2781 3562 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2220 5632 5632 5632 5632 -785 -1023 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -785 10 0.56 225 5632 5632 5632 5632 4037 7482 3084 0 5632 5632 5632 5632 16384 3152 4044 3424 SUCCESS
    537 08/08/2024 15:42 2232814 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13690 950 961 1 89 70 2782 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3418 3424 3420 13626 13787 966 949 941 963 331 324 322 329 1297 1315 27.2 27.8 27.6 27.6 27.6 27.8 27.6 27.8 2783 3565 3144 4036 2973 2782 3563 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2224 5632 5632 5632 5632 -786 -1024 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -786 10 0.56 225 5632 5632 5632 5632 4037 7478 3084 0 5632 5632 5632 5632 16384 3152 4044 3384 SUCCESS
    538 08/08/2024 15:42 2236952 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13690 942 958 1 89 70 2783 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3429 3419 3425 3422 13627 13788 941 955 945 945 323 327 324 323 1289 1309 27.1 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2784 3567 3144 4036 2974 2783 3564 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2228 5632 5632 5632 5632 -787 -1025 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -787 10 0.56 225 5632 5632 5632 5632 4037 7474 3084 0 5632 5632 5632 5632 16384 3152 4044 3458 SUCCESS
    539 08/08/2024 15:42 2241156 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13694 938 954 1 89 70 2784 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3424 3419 13629 13785 943 943 949 934 323 322 325 319 1280 1304 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2785 3568 3144 4036 2975 2784 3566 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2232 5632 5632 5632 5632 -788 -1027 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -788 10 0.56 225 5632 5632 5632 5632 4037 7470 3084 0 5632 5632 5632 5632 16384 3152 4044 3187 SUCCESS
    540 08/08/2024 15:42 2245060 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13689 936 949 1 89 70 2785 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3418 3424 3420 13627 13785 947 944 936 935 325 323 320 320 1279 1298 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2786 3569 3144 4036 2976 2785 3567 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2236 5632 5632 5632 5632 -789 -1028 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -789 10 0.56 225 5632 5632 5632 5632 4037 7466 3084 0 5632 5632 5632 5632 16384 3152 4044 3207 SUCCESS
    541 08/08/2024 15:42 2249001 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13689 929 945 1 89 70 2787 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3424 3419 13626 13788 931 921 930 931 319 315 318 318 1270 1292 27.2 27.8 27.6 27.6 27.6 27.8 27.6 27.8 2787 3571 3144 4036 2977 2786 3568 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2240 5632 5632 5632 5632 -790 -1029 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -790 10 0.56 225 5632 5632 5632 5632 4037 7461 3084 0 5632 5632 5632 5632 16384 3152 4044 3644 SUCCESS
    542 08/08/2024 15:42 2253345 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13694 927 941 1 89 70 2788 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3418 3424 3419 13627 13787 935 925 926 923 320 316 317 316 1266 1285 27.1 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2788 3572 3144 4036 2978 2787 3569 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2244 5632 5632 5632 5632 -791 -1030 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -791 10 0.56 225 5632 5632 5632 5632 4037 7457 3084 0 5632 5632 5632 5632 16384 3152 4044 3495 SUCCESS
    543 08/08/2024 15:42 2257565 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13691 923 937 1 89 70 2789 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3424 3419 13627 13786 924 915 919 924 317 313 315 316 1261 1280 27.2 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2789 3574 3144 4036 2979 2788 3571 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2248 5632 5632 5632 5632 -792 -1032 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -792 10 0.56 225 5632 5632 5632 5632 4037 7453 3084 0 5632 5632 5632 5632 16384 3152 4044 3197 SUCCESS
    544 08/08/2024 15:42 2261525 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13691 915 933 1 89 70 2790 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3417 3424 3419 13627 13787 922 916 915 925 316 313 313 316 1255 1275 27.2 27.8 27.7 27.7 27.6 27.8 27.7 27.8 2790 3575 3144 4036 2980 2789 3572 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2252 5632 5632 5632 5632 -793 -1033 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -793 10 0.56 225 5632 5632 5632 5632 4037 7449 3084 0 5632 5632 5632 5632 16384 3152 4044 3162 SUCCESS
    545 08/08/2024 15:43 2265441 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13693 910 928 1 89 70 2791 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3428 3417 3424 3419 13628 13784 912 908 912 905 313 310 312 309 1237 1269 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2791 3576 3144 4036 2981 2790 3573 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2257 5632 5632 5632 5632 -795 -1036 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -795 10 0.56 225 5632 5632 5632 5632 4037 7444 3084 0 5632 5632 5632 5632 16384 3152 4044 5694 SUCCESS
    546 08/08/2024 15:43 2271961 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13690 883 917 1 89 70 2793 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3427 3416 3424 3419 13624 13784 892 899 897 889 306 307 307 304 1215 1249 27.1 27.8 27.7 27.7 27.6 27.8 27.7 27.8 2793 3579 3144 4036 2983 2792 3576 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2264 5632 5632 5632 5632 -796 -1037 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -796 10 0.56 225 5632 5632 5632 5632 4037 7437 3084 0 5632 5632 5632 5632 16384 3152 4044 4902 SUCCESS
    547 08/08/2024 15:43 2277591 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13686 886 908 1 89 70 2794 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3423 3418 13622 13779 873 874 879 884 299 299 301 302 1202 1241 27.2 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2794 3580 3144 4036 2984 2793 3577 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2268 5632 5632 5632 5632 -797 -1038 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -797 10 0.56 225 5632 5632 5632 5632 4037 7433 3084 0 5632 5632 5632 5632 16384 3152 4044 3171 SUCCESS
    548 08/08/2024 15:43 2281480 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13687 874 900 1 89 70 2795 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3416 3424 3418 13621 13781 881 876 882 871 302 299 302 298 1196 1230 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2795 3581 3144 4036 2985 2794 3579 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2272 5632 5632 5632 5632 -798 -1040 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -798 10 0.56 225 5632 5632 5632 5632 4037 7429 3084 0 5632 5632 5632 5632 16384 3152 4044 3527 SUCCESS
    549 08/08/2024 15:43 2285744 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13685 872 894 1 89 70 2796 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3426 3417 3424 3418 13623 13781 889 876 881 878 305 299 302 300 1196 1220 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2796 3583 3144 4036 2986 2795 3580 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2276 5632 5632 5632 5632 -799 -1041 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -799 10 0.56 225 5632 5632 5632 5632 4037 7425 3084 0 5632 5632 5632 5632 16384 3152 4044 3222 SUCCESS
    550 08/08/2024 15:43 2289671 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13696 894 887 1 89 70 2797 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3431 3420 3428 3422 13638 13797 957 961 968 978 328 329 332 335 1326 1222 27.1 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2797 3584 3144 4036 2987 2796 3581 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2280 5632 5632 5632 5632 -800 -1042 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -800 10 0.56 225 5632 5632 5632 5632 4037 7421 3084 0 5632 5632 5632 5632 16384 3152 4044 3098 SUCCESS
    551 08/08/2024 15:43 2293509 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13708 959 906 1 89 70 2798 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3421 3429 3423 13642 13802 971 971 969 955 333 332 332 327 1313 1246 27.1 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2798 3585 3144 4036 2988 2797 3582 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2284 5632 5632 5632 5632 -801 -1043 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -801 10 0.56 225 5632 5632 5632 5632 4037 7417 3084 0 5632 5632 5632 5632 16384 3152 4044 3377 SUCCESS
    552 08/08/2024 15:43 2297618 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13708 951 918 1 90 70 2799 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3432 3422 3429 3424 13644 13806 968 963 954 958 332 330 327 328 1305 1261 27.2 27.8 27.7 27.6 27.6 27.8 27.7 27.8 2799 3587 3144 4036 2989 2798 3584 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2288 5632 5632 5632 5632 -802 -1045 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -802 10 0.56 225 5632 5632 5632 5632 4037 7413 3084 0 5632 5632 5632 5632 16384 3152 4044 3323 SUCCESS
    553 08/08/2024 15:43 2301700 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13710 950 926 1 90 70 2800 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3433 3422 3431 3424 13645 13806 955 945 956 965 328 323 328 330 1298 1273 27.1 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2800 3588 3144 4036 2990 2799 3585 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2292 5632 5632 5632 5632 -803 -1046 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -803 10 0.56 225 5632 5632 5632 5632 4037 7409 3084 0 5632 5632 5632 5632 16384 3152 4044 3436 SUCCESS
    554 08/08/2024 15:43 2305835 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13712 944 931 1 90 71 2801 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3433 3422 3431 3424 13648 13807 955 953 948 952 328 326 325 326 1296 1278 27.1 27.8 27.7 27.6 27.6 27.7 27.7 27.7 2801 3590 3144 4036 2991 2800 3586 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2296 5632 5632 5632 5632 -804 -1047 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -805 10 0.56 225 5632 5632 5632 5632 4037 7405 3084 0 5632 5632 5632 5632 16384 3152 4044 3364 SUCCESS
    555 08/08/2024 15:43 2309936 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13713 941 934 1 90 71 2802 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3434 3423 3431 3424 13648 13809 938 951 952 945 322 326 327 324 1289 1281 27.1 27.8 27.7 27.6 27.7 27.8 27.7 27.8 2802 3591 3144 4036 2992 2801 3588 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2300 5632 5632 5632 5632 -806 -1050 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -806 10 0.56 225 5632 5632 5632 5632 4037 7401 3084 0 5632 5632 5632 5632 16384 3152 4044 3229 SUCCESS
    556 08/08/2024 15:43 2313928 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13714 939 936 1 90 71 2803 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3435 3423 3431 3425 13651 13809 939 951 950 931 323 326 326 319 1285 1283 27.1 27.7 27.7 27.6 27.7 27.7 27.7 27.7 2803 3592 3144 4036 2993 2802 3589 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2305 5632 5632 5632 5632 -807 -1051 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -807 10 0.56 225 5632 5632 5632 5632 4037 7397 3084 0 5632 5632 5632 5632 16384 3152 4044 3359 SUCCESS
    557 08/08/2024 15:43 2318027 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13715 937 936 1 90 71 2804 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3435 3424 3432 3425 13650 13811 946 958 934 952 325 328 321 326 1281 1283 27.2 27.7 27.6 27.6 27.7 27.7 27.7 27.7 2805 3594 3144 4036 2994 2804 3592 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2309 5632 5632 5632 5632 -808 -1053 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -808 10 0.56 225 5632 5632 5632 5632 4037 7393 3084 0 5632 5632 5632 5632 16384 3152 4044 3248 SUCCESS
    558 08/08/2024 15:43 2322068 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13716 934 935 1 90 71 2805 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3435 3425 3434 3427 13653 13813 940 942 940 933 323 323 323 320 1280 1282 27.1 27.7 27.7 27.6 27.7 27.7 27.7 27.7 2806 3595 3144 4036 2995 2805 3593 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2313 5632 5632 5632 5632 -809 -1054 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -809 10 0.56 225 5632 5632 5632 5632 4037 7389 3084 0 5632 5632 5632 5632 16384 3152 4044 3405 SUCCESS
    559 08/08/2024 15:44 2326200 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13717 931 935 1 90 71 2806 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3436 3425 3434 3427 13655 13811 947 931 939 925 325 319 322 317 1278 1281 27.0 27.7 27.7 27.6 27.7 27.7 27.7 27.7 2807 3596 3144 4036 2996 2806 3594 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2317 5632 5632 5632 5632 -810 -1055 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -810 10 0.56 225 5632 5632 5632 5632 4037 7385 3084 0 5632 5632 5632 5632 16384 3152 4044 3225 SUCCESS
    560 08/08/2024 15:44 2330143 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13718 929 934 1 90 71 2807 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3436 3426 3435 3427 13653 13816 950 927 937 929 326 318 322 318 1275 1279 27.1 27.7 27.7 27.5 27.7 27.7 27.7 27.7 2808 3598 3144 4036 2997 2807 3595 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2321 5632 5632 5632 5632 -811 -1056 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -811 10 0.56 225 5632 5632 5632 5632 4037 7381 3084 0 5632 5632 5632 5632 16384 3152 4044 3197 SUCCESS
    561 08/08/2024 15:44 2334076 0x0187 0 10 0x6001 0 65535 65535 1 27.8 13719 926 932 1 90 71 2808 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3436 3424 3434 3426 13657 13817 923 932 933 927 317 319 320 318 1269 1277 27.1 27.7 27.7 27.5 27.7 27.7 27.7 27.7 2809 3599 3144 4036 2999 2808 3597 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2325 5632 5632 5632 5632 -812 -1058 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -812 10 0.56 225 5632 5632 5632 5632 4037 7377 3084 0 5632 5632 5632 5632 16384 3152 4044 3401 SUCCESS
    562 08/08/2024 15:44 2338234 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13720 924 931 1 90 71 2809 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3437 3426 3435 3428 13658 13815 925 929 932 925 318 318 320 317 1270 1275 27.1 27.7 27.7 27.6 27.7 27.7 27.7 27.7 2810 3600 3144 4036 3000 2809 3598 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2329 5632 5632 5632 5632 -813 -1059 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -813 10 0.56 225 5632 5632 5632 5632 4037 7373 3084 0 5632 5632 5632 5632 16384 3152 4044 3343 SUCCESS
    563 08/08/2024 15:44 2342294 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13721 922 928 1 90 71 2810 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3437 3426 3436 3428 13657 13822 922 943 919 923 317 323 316 316 1267 1273 27.1 27.7 27.7 27.6 27.7 27.7 27.7 27.7 2811 3602 3144 4036 3001 2810 3599 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2333 5632 5632 5632 5632 -814 -1060 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -814 10 0.56 225 5632 5632 5632 5632 4037 7369 3084 0 5632 5632 5632 5632 16384 3152 4044 3427 SUCCESS
    564 08/08/2024 15:44 2346486 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13723 918 926 1 90 71 2811 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3437 3425 3435 3427 13662 13819 939 931 920 925 323 319 316 317 1260 1270 27.0 27.7 27.7 27.6 27.7 27.7 27.7 27.7 2812 3603 3144 4036 3002 2811 3601 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2337 5632 5632 5632 5632 -815 -1062 10 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -815 10 0.56 225 5632 5632 5632 5632 4037 7365 3084 0 5632 5632 5632 5632 16384 3152 4044 3292 SUCCESS
    565 08/08/2024 15:44 2350516 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13724 916 924 1 90 71 2812 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3437 3426 3435 3427 13662 13821 923 921 917 919 317 316 315 315 1259 1267 27.0 27.7 27.6 27.6 27.7 27.7 27.6 27.7 2813 3604 3144 4036 3003 2812 3602 1146 1493 3142 4032 27.8 27.7 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2341 5632 5632 5632 5632 -816 -1063 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -816 11 0.56 225 5632 5632 5632 5632 4037 7361 3084 0 5632 5632 5632 5632 16384 3152 4044 3260 SUCCESS
    566 08/08/2024 15:44 2354555 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13726 914 922 1 90 71 2813 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3437 3426 3435 3427 13662 13823 919 916 924 924 316 314 317 317 1255 1265 27.1 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2814 3606 3144 4036 3004 2813 3603 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2345 5632 5632 5632 5632 -817 -1064 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -817 11 0.56 225 5632 5632 5632 5632 4037 7356 3084 0 5632 5632 5632 5632 16384 3152 4044 3527 SUCCESS
    567 08/08/2024 15:44 2358789 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13731 913 920 1 90 71 2814 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3438 3426 3436 3427 13665 13822 910 916 915 919 313 314 314 315 1252 1262 26.9 27.7 27.6 27.6 27.6 27.7 27.6 27.7 2815 3607 3144 4036 3005 2814 3605 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2349 5632 5632 5632 5632 -818 -1066 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -818 11 0.56 225 5632 5632 5632 5632 4037 7352 3084 0 5632 5632 5632 5632 16384 3152 4044 3311 SUCCESS
    568 08/08/2024 15:44 2362845 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13732 910 918 1 90 71 2815 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3438 3426 3436 3428 13664 13824 910 914 913 900 313 313 314 309 1248 1259 27.1 27.7 27.6 27.6 27.6 27.7 27.6 27.7 2816 3609 3144 4036 3006 2815 3606 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2353 5632 5632 5632 5632 -819 -1067 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -819 11 0.56 225 5632 5632 5632 5632 4037 7348 3084 0 5632 5632 5632 5632 16384 3152 4044 3394 SUCCESS
    569 08/08/2024 15:44 2366920 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13734 909 916 1 90 71 2816 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3438 3426 3437 3428 13667 13826 910 902 914 919 313 309 314 315 1247 1257 27.1 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2817 3610 3144 4036 3007 2816 3607 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2357 5632 5632 5632 5632 -820 -1068 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -820 11 0.56 225 5632 5632 5632 5632 4037 7344 3084 0 5632 5632 5632 5632 16384 3152 4044 3151 SUCCESS
    570 08/08/2024 15:44 2370835 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13735 906 914 1 90 71 2817 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3438 3427 3437 3429 13670 13826 907 912 907 910 312 313 312 312 1244 1254 27.2 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2818 3611 3144 4036 3008 2817 3609 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2361 5632 5632 5632 5632 -821 -1070 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -821 11 0.56 225 5632 5632 5632 5632 4037 7340 3084 0 5632 5632 5632 5632 16384 3152 4044 3369 SUCCESS
    571 08/08/2024 15:44 2374891 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13735 904 912 1 90 71 2818 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3439 3427 3438 3429 13671 13829 916 908 910 916 315 311 313 314 1240 1251 27.2 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2819 3612 3144 4036 3009 2818 3610 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2365 5632 5632 5632 5632 -822 -1071 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -822 11 0.56 225 5632 5632 5632 5632 4037 7337 3084 0 5632 5632 5632 5632 16384 3152 4044 3130 SUCCESS
    572 08/08/2024 15:44 2378733 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13733 903 910 1 90 71 2819 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3440 3427 3438 3428 13671 13831 913 896 911 903 314 307 313 310 1236 1248 27.2 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2820 3614 3144 4036 3010 2819 3611 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2369 5632 5632 5632 5632 -823 -1072 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -823 11 0.56 225 5632 5632 5632 5632 4037 7333 3084 0 5632 5632 5632 5632 16384 3152 4044 3301 SUCCESS
    573 08/08/2024 15:44 2382759 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13739 898 907 1 90 71 2820 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3439 3427 3439 3429 13674 13831 898 905 899 905 309 310 309 310 1233 1245 27.1 27.6 27.7 27.6 27.6 27.6 27.7 27.6 2821 3615 3144 4036 3011 2820 3612 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2373 5632 5632 5632 5632 -824 -1073 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -824 11 0.56 225 5632 5632 5632 5632 4037 7329 3084 0 5632 5632 5632 5632 16384 3152 4044 3385 SUCCESS
    574 08/08/2024 15:45 2386876 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13735 897 905 1 90 71 2821 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3440 3428 3439 3429 13673 13832 908 900 901 909 312 309 310 312 1231 1242 27.1 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2822 3616 3144 4036 3012 2821 3614 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2377 5632 5632 5632 5632 -825 -1075 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -825 11 0.56 225 5632 5632 5632 5632 4037 7324 3084 0 5632 5632 5632 5632 16384 3152 4044 3344 SUCCESS
    575 08/08/2024 15:45 2390944 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13742 894 903 1 90 71 2822 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3441 3428 3439 3430 13674 13837 909 898 894 900 313 308 307 309 1228 1239 27.2 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2823 3618 3144 4036 3013 2822 3615 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2381 5632 5632 5632 5632 -826 -1076 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -826 11 0.56 225 5632 5632 5632 5632 4037 7320 3084 0 5632 5632 5632 5632 16384 3152 4044 3426 SUCCESS
    576 08/08/2024 15:45 2395155 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13742 892 900 1 90 71 2823 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3441 3429 3440 3430 13678 13835 904 911 896 897 311 312 308 308 1223 1236 27.1 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2824 3619 3144 4036 3014 2823 3616 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2385 5632 5632 5632 5632 -827 -1077 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -827 11 0.56 225 5632 5632 5632 5632 4037 7316 3084 0 5632 5632 5632 5632 16384 3152 4044 3149 SUCCESS
    577 08/08/2024 15:45 2399088 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13744 891 898 1 90 71 2824 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3441 3429 3441 3430 13677 13838 893 898 891 898 307 308 307 308 1220 1233 27.1 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2825 3620 3144 4036 3015 2824 3618 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2389 5632 5632 5632 5632 -828 -1079 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -828 11 0.56 225 5632 5632 5632 5632 4037 7312 3084 0 5632 5632 5632 5632 16384 3152 4044 3262 SUCCESS
    578 08/08/2024 15:45 2403115 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13745 888 896 1 90 71 2825 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3442 3429 3441 3430 13679 13840 895 889 893 890 308 305 307 305 1218 1230 27.1 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2826 3622 3144 4036 3016 2825 3619 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2393 5632 5632 5632 5632 -829 -1080 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -829 11 0.56 225 5632 5632 5632 5632 4037 7308 3084 0 5632 5632 5632 5632 16384 3152 4044 3355 SUCCESS
    579 08/08/2024 15:45 2407200 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13748 885 893 1 90 71 2826 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3442 3429 3442 3430 13683 13839 892 877 888 889 307 301 306 305 1215 1226 27.2 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2827 3623 3144 4036 3017 2826 3620 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2397 5632 5632 5632 5632 -830 -1081 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -830 11 0.56 225 5632 5632 5632 5632 4037 7304 3084 0 5632 5632 5632 5632 16384 3152 4044 3284 SUCCESS
    580 08/08/2024 15:45 2411243 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13746 882 891 1 90 71 2827 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3443 3429 3441 3431 13683 13841 881 884 889 890 303 303 306 305 1210 1223 27.2 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2828 3624 3144 4036 3018 2827 3622 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2401 5632 5632 5632 5632 -831 -1083 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -831 11 0.56 225 5632 5632 5632 5632 4037 7300 3084 0 5632 5632 5632 5632 16384 3152 4044 3988 SUCCESS
    581 08/08/2024 15:45 2416050 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13747 877 887 1 90 71 2829 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3444 3430 3443 3431 13685 13843 881 884 883 875 303 303 304 300 1206 1218 27.2 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2829 3626 3144 4036 3019 2828 3623 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2406 5632 5632 5632 5632 -832 -1084 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -832 11 0.56 225 5632 5632 5632 5632 4037 7295 3084 0 5632 5632 5632 5632 16384 3152 4044 3521 SUCCESS
    582 08/08/2024 15:45 2420293 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13753 874 885 1 91 71 2830 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3444 3430 3443 3431 13686 13844 880 878 881 870 303 301 303 298 1200 1215 27.1 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2830 3627 3144 4036 3020 2829 3624 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2410 5632 5632 5632 5632 -833 -1085 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -833 11 0.56 225 5632 5632 5632 5632 4037 7291 3084 0 5632 5632 5632 5632 16384 3152 4044 3317 SUCCESS
    583 08/08/2024 15:45 2424307 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13755 872 882 1 91 71 2831 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3445 3430 3444 3432 13686 13850 876 872 881 880 302 299 303 302 1200 1211 27.1 27.7 27.7 27.6 27.6 27.7 27.7 27.7 2831 3628 3144 4036 3021 2830 3625 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2414 5632 5632 5632 5632 -834 -1086 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -834 11 0.56 225 5632 5632 5632 5632 4037 7287 3084 0 5632 5632 5632 5632 16384 3152 4044 3270 SUCCESS
    584 08/08/2024 15:45 2428281 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13756 871 879 1 91 71 2832 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3445 3431 3444 3432 13692 13848 868 865 877 879 299 297 302 302 1194 1208 27.0 27.7 27.6 27.6 27.6 27.7 27.6 27.7 2832 3629 3144 4036 3022 2831 3627 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2418 5632 5632 5632 5632 -835 -1088 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -835 11 0.56 225 5632 5632 5632 5632 4037 7283 3084 0 5632 5632 5632 5632 16384 3152 4044 3198 SUCCESS
    585 08/08/2024 15:45 2432172 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13758 868 877 1 91 71 2833 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3445 3431 3446 3432 13692 13850 870 873 876 868 300 300 302 298 1192 1204 27.1 27.6 27.6 27.6 27.6 27.6 27.6 27.6 2833 3631 3144 4036 3023 2832 3628 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2422 5632 5632 5632 5632 -836 -1089 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -836 11 0.56 225 5632 5632 5632 5632 4037 7280 3084 0 5632 5632 5632 5632 16384 3152 4044 3182 SUCCESS
    586 08/08/2024 15:45 2436088 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13755 866 874 1 91 71 2833 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3446 3431 3446 3433 13692 13856 879 868 879 858 303 298 303 295 1190 1201 27.1 27.6 27.6 27.6 27.6 27.6 27.6 27.6 2834 3632 3144 4036 3024 2833 3629 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2426 5632 5632 5632 5632 -837 -1090 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -837 11 0.56 225 5632 5632 5632 5632 4037 7276 3084 0 5632 5632 5632 5632 16384 3152 4044 3298 SUCCESS
    587 08/08/2024 15:45 2440133 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13757 863 872 1 91 71 2834 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3446 3432 3446 3433 13697 13853 866 870 877 874 298 299 302 300 1186 1198 27.1 27.6 27.7 27.5 27.6 27.6 27.7 27.6 2835 3633 3144 4036 3025 2834 3631 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2430 5632 5632 5632 5632 -838 -1092 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -838 11 0.56 225 5632 5632 5632 5632 4037 7272 3084 0 5632 5632 5632 5632 16384 3152 4044 3212 SUCCESS
    588 08/08/2024 15:46 2444091 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13758 861 869 1 91 71 2835 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3446 3433 3447 3434 13695 13854 866 866 870 854 298 297 300 293 1182 1194 27.0 27.6 27.6 27.5 27.6 27.6 27.6 27.6 2836 3634 3144 4036 3026 2835 3632 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2434 5632 5632 5632 5632 -839 -1093 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -839 11 0.56 225 5632 5632 5632 5632 4037 7268 3084 0 5632 5632 5632 5632 16384 3152 4044 3332 SUCCESS
    589 08/08/2024 15:46 2448150 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13760 857 866 1 91 71 2836 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3448 3433 3448 3434 13698 13862 861 869 861 861 297 298 297 296 1178 1191 27.0 27.7 27.6 27.5 27.6 27.7 27.6 27.7 2837 3636 3144 4036 3027 2836 3633 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2438 5632 5632 5632 5632 -840 -1094 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -840 11 0.56 225 5632 5632 5632 5632 4037 7263 3084 0 5632 5632 5632 5632 16384 3152 4044 3427 SUCCESS
    590 08/08/2024 15:46 2452245 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13763 852 864 1 91 71 2837 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3448 3433 3449 3434 13702 13858 863 865 850 845 298 297 293 290 1173 1187 27.0 27.6 27.6 27.5 27.6 27.6 27.6 27.6 2838 3637 3144 4036 3028 2837 3635 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2442 5632 5632 5632 5632 -841 -1096 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -841 11 0.56 225 5632 5632 5632 5632 4037 7259 3084 0 5632 5632 5632 5632 16384 3152 4044 3349 SUCCESS
    591 08/08/2024 15:46 2456268 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13769 849 861 1 91 71 2838 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3448 3434 3449 3434 13702 13861 850 859 862 857 293 295 297 294 1169 1183 27.0 27.7 27.6 27.5 27.6 27.7 27.6 27.7 2839 3638 3144 4036 3029 2838 3636 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2446 5632 5632 5632 5632 -842 -1097 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -842 11 0.56 225 5632 5632 5632 5632 4037 7255 3084 0 5632 5632 5632 5632 16384 3152 4044 3645 SUCCESS
    592 08/08/2024 15:46 2460643 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13767 847 858 1 91 71 2839 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3449 3434 3450 3434 13703 13863 857 847 845 842 296 291 292 289 1165 1178 26.9 27.7 27.6 27.4 27.6 27.7 27.6 27.7 2840 3639 3144 4036 3030 2839 3637 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2450 5632 5632 5632 5632 -843 -1098 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -843 11 0.56 225 5632 5632 5632 5632 4037 7251 3084 0 5632 5632 5632 5632 16384 3152 4044 3234 SUCCESS
    593 08/08/2024 15:46 2464639 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13770 845 855 1 91 71 2840 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3449 3434 3450 3435 13705 13866 850 839 843 836 293 288 291 287 1161 1175 27.0 27.6 27.6 27.4 27.6 27.6 27.6 27.6 2841 3641 3144 4036 3031 2840 3638 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2454 5632 5632 5632 5632 -844 -1099 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -844 11 0.56 225 5632 5632 5632 5632 4037 7247 3084 0 5632 5632 5632 5632 16384 3152 4044 3178 SUCCESS
    594 08/08/2024 15:46 2468371 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13770 840 852 1 91 72 2841 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3450 3435 3451 3435 13707 13867 843 840 846 843 291 289 292 290 1158 1172 27.0 27.7 27.6 27.4 27.6 27.7 27.6 27.7 2841 3642 3144 4036 3031 2840 3638 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2457 5632 5632 5632 5632 -844 -1099 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -844 11 0.56 225 5632 5632 5632 5632 4037 7244 3084 0 5632 5632 5632 5632 16384 3152 4044 2442 SUCCESS
    595 08/08/2024 15:46 2471573 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13776 839 850 1 91 72 2842 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3452 3436 3453 3437 13709 13869 858 855 850 844 296 294 294 290 1156 1169 26.9 27.7 27.6 27.4 27.6 27.7 27.6 27.7 2842 3643 3144 4036 3032 2841 3640 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2460 5632 5632 5632 5632 -845 -1101 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -845 11 0.56 225 5632 5632 5632 5632 4037 7241 3084 0 5632 5632 5632 5632 16384 3152 4044 2326 SUCCESS
    596 08/08/2024 15:46 2474573 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13778 835 847 1 91 72 2842 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3451 3435 3453 3436 13710 13870 836 841 840 834 289 289 290 287 1150 1166 27.0 27.7 27.6 27.4 27.6 27.7 27.6 27.7 2843 3644 3144 4036 3033 2842 3641 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2463 5632 5632 5632 5632 -846 -1102 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -846 11 0.56 225 5632 5632 5632 5632 4037 7238 3084 0 5632 5632 5632 5632 16384 3152 4044 2354 SUCCESS
    597 08/08/2024 15:46 2477176 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13776 835 846 1 91 72 2843 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3451 3436 3453 3436 13713 13872 840 848 839 844 290 291 290 290 1149 1164 27.0 27.7 27.6 27.4 27.6 27.7 27.6 27.7 2843 3644 3144 4036 3033 2842 3641 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2466 5632 5632 5632 5632 -846 -1102 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -846 11 0.56 225 5632 5632 5632 5632 4037 7236 3084 0 5632 5632 5632 5632 16384 3152 4044 2362 SUCCESS
    598 08/08/2024 15:46 2480865 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13778 831 843 1 91 72 2844 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3451 3436 3454 3436 13715 13874 819 826 833 836 283 284 288 287 1144 1159 27.0 27.6 27.6 27.4 27.6 27.6 27.6 27.6 2844 3645 3144 4036 3034 2843 3642 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2470 5632 5632 5632 5632 -847 -1103 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -847 11 0.56 225 5632 5632 5632 5632 4037 7232 3084 0 5632 5632 5632 5632 16384 3152 4044 2388 SUCCESS
    599 08/08/2024 15:46 2484869 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13779 828 840 1 91 72 2845 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3452 3436 3455 3436 13717 13877 819 825 828 826 283 283 286 284 1140 1155 27.0 27.7 27.6 27.4 27.5 27.7 27.6 27.7 2845 3647 3144 4036 3035 2844 3644 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2474 5632 5632 5632 5632 -848 -1105 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -848 11 0.56 225 5632 5632 5632 5632 4037 7228 3084 0 5632 5632 5632 5632 16384 3152 4044 2379 SUCCESS
    600 08/08/2024 15:46 2488882 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13782 824 836 1 91 72 2846 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3453 3436 3456 3436 13721 13878 823 827 829 813 284 284 287 279 1136 1151 26.9 27.6 27.6 27.4 27.6 27.6 27.6 27.6 2846 3648 3144 4036 3036 2845 3645 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2478 5632 5632 5632 5632 -849 -1106 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -849 11 0.56 225 5632 5632 5632 5632 4037 7224 3084 0 5632 5632 5632 5632 16384 3152 4044 2344 SUCCESS
    601 08/08/2024 15:46 2492886 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13785 820 833 1 91 72 2847 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3454 3437 3456 3437 13720 13881 818 827 831 826 283 284 287 284 1130 1146 26.9 27.7 27.6 27.4 27.5 27.7 27.6 27.7 2847 3649 3144 4036 3037 2846 3646 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2482 5632 5632 5632 5632 -850 -1107 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -850 11 0.56 225 5632 5632 5632 5632 4037 7220 3084 0 5632 5632 5632 5632 16384 3152 4044 2560 SUCCESS
    602 08/08/2024 15:46 2496890 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13787 816 830 1 91 72 2848 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3454 3438 3457 3438 13723 13885 816 822 811 815 282 283 280 280 1125 1142 26.9 27.7 27.5 27.4 27.5 27.7 27.5 27.7 2848 3650 3144 4036 3038 2847 3648 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2486 5632 5632 5632 5632 -851 -1109 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -851 11 0.56 225 5632 5632 5632 5632 4037 7216 3084 0 5632 5632 5632 5632 16384 3152 4044 2439 SUCCESS
    603 08/08/2024 15:46 2500898 0x0187 0 10 0x6001 0 65535 65535 1 27.7 13789 814 826 1 91 72 2848 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3455 3438 3458 3438 13727 13885 809 815 808 824 280 280 279 283 1120 1137 26.9 27.6 27.5 27.3 27.5 27.6 27.5 27.6 2849 3651 3144 4036 3039 2848 3649 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2490 5632 5632 5632 5632 -852 -1110 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -852 11 0.56 225 5632 5632 5632 5632 4037 7212 3084 0 5632 5632 5632 5632 16384 3152 4044 2294 SUCCESS
    604 08/08/2024 15:47 2504906 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13792 809 823 1 91 72 2849 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3457 3440 3461 3440 13727 13887 817 812 808 811 282 279 280 279 1116 1132 26.9 27.6 27.5 27.3 27.5 27.6 27.5 27.6 2850 3652 3144 4036 3040 2849 3650 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2494 5632 5632 5632 5632 -853 -1111 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -853 11 0.56 225 5632 5632 5632 5632 4037 7208 3084 0 5632 5632 5632 5632 16384 3152 4044 2287 SUCCESS
    605 08/08/2024 15:47 2508913 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13794 804 819 1 91 72 2850 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3458 3440 3462 3440 13729 13893 817 803 814 811 283 276 282 279 1111 1128 26.8 27.6 27.5 27.3 27.5 27.6 27.5 27.6 2851 3654 3144 4036 3040 2850 3652 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2498 5632 5632 5632 5632 -854 -1113 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -854 11 0.56 225 5632 5632 5632 5632 4037 7204 3084 0 5632 5632 5632 5632 16384 3152 4044 2405 SUCCESS
    606 08/08/2024 15:47 2512917 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13796 801 815 1 91 72 2851 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3458 3441 3462 3440 13736 13891 801 801 804 801 277 276 278 276 1104 1123 26.9 27.6 27.5 27.3 27.5 27.6 27.5 27.6 2851 3655 3144 4036 3041 2850 3652 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2502 5632 5632 5632 5632 -855 -1114 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -855 11 0.56 225 5632 5632 5632 5632 4037 7200 3084 0 5632 5632 5632 5632 16384 3152 4044 2354 SUCCESS
    607 08/08/2024 15:47 2516925 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13803 797 811 1 91 72 2852 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3459 3442 3463 3441 13734 13894 798 808 795 799 276 278 275 275 1103 1118 26.9 27.6 27.5 27.4 27.5 27.6 27.5 27.6 2852 3656 3144 4036 3042 2851 3653 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2505 5632 5632 5632 5632 -855 -1114 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -855 11 0.56 225 5632 5632 5632 5632 4037 7196 3084 0 5632 5632 5632 5632 16384 3152 4044 2204 SUCCESS
    608 08/08/2024 15:47 2520930 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13805 795 808 1 91 72 2853 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3459 3442 3465 3441 13737 13901 799 800 800 805 276 275 277 277 1096 1113 27.0 27.6 27.5 27.4 27.5 27.6 27.5 27.6 2853 3657 3144 4036 3043 2852 3654 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2509 5632 5632 5632 5632 -856 -1115 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -856 11 0.56 225 5632 5632 5632 5632 4037 7192 3084 0 5632 5632 5632 5632 16384 3152 4044 2259 SUCCESS
    609 08/08/2024 15:47 2524932 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13808 791 804 1 91 72 2854 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3460 3442 3465 3441 13744 13898 795 784 801 787 275 270 278 271 1089 1108 27.0 27.6 27.5 27.4 27.5 27.6 27.5 27.6 2854 3658 3144 4036 3044 2853 3655 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2514 5632 5632 5632 5632 -857 -1116 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -857 11 0.56 225 5632 5632 5632 5632 4037 7188 3084 0 5632 5632 5632 5632 16384 3152 4044 2444 SUCCESS
    610 08/08/2024 15:47 2528944 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13809 787 800 1 91 72 2855 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3461 3443 3466 3442 13741 13901 795 781 789 795 275 269 273 274 1083 1102 27.0 27.6 27.5 27.4 27.5 27.6 27.5 27.6 2855 3659 3144 4036 3045 2854 3657 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2518 5632 5632 5632 5632 -858 -1118 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -858 11 0.56 225 5632 5632 5632 5632 4037 7184 3084 0 5632 5632 5632 5632 16384 3152 4044 2440 SUCCESS
    611 08/08/2024 15:47 2532947 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13812 782 796 1 91 72 2856 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3461 3442 3467 3442 13745 13907 790 789 783 793 273 272 271 273 1079 1097 26.9 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2856 3661 3144 4036 3046 2855 3658 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2521 5632 5632 5632 5632 -859 -1119 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -859 11 0.56 225 5632 5632 5632 5632 4037 7180 3084 0 5632 5632 5632 5632 16384 3152 4044 2403 SUCCESS
    612 08/08/2024 15:47 2536959 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13815 779 792 1 91 72 2856 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3463 3443 3468 3443 13751 13905 789 789 783 790 273 272 272 272 1072 1092 27.0 27.6 27.6 27.5 27.5 27.6 27.6 27.6 2857 3662 3144 4036 3047 2856 3659 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2526 5632 5632 5632 5632 -860 -1120 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -860 11 0.56 225 5632 5632 5632 5632 4037 7176 3084 0 5632 5632 5632 5632 16384 3152 4044 2471 SUCCESS
    613 08/08/2024 15:47 2540972 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13818 774 788 1 91 72 2857 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3463 3443 3468 3441 13749 13910 780 778 769 784 270 268 267 270 1065 1086 27.1 27.6 27.5 27.5 27.5 27.6 27.5 27.6 2858 3663 3144 4036 3047 2857 3661 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2530 5632 5632 5632 5632 -861 -1122 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -861 11 0.56 225 5632 5632 5632 5632 4037 7172 3084 0 5632 5632 5632 5632 16384 3152 4044 2765 SUCCESS
    614 08/08/2024 15:47 2544976 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13821 769 784 1 91 72 2858 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3465 3444 3471 3443 13754 13915 776 771 781 778 269 266 271 268 1063 1081 27.0 27.6 27.6 27.5 27.5 27.6 27.6 27.6 2858 3664 3144 4036 3048 2857 3661 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2534 5632 5632 5632 5632 -861 -1122 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -861 11 0.56 225 5632 5632 5632 5632 4037 7168 3084 0 5632 5632 5632 5632 16384 3152 4044 2459 SUCCESS
    615 08/08/2024 15:47 2548989 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13824 764 780 1 91 72 2859 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3465 3445 3472 3444 13759 13915 770 780 772 772 267 269 268 266 1056 1075 27.0 27.6 27.5 27.4 27.5 27.6 27.5 27.6 2859 3665 3144 4036 3049 2858 3662 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2537 5632 5632 5632 5632 -862 -1123 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -862 11 0.56 225 5632 5632 5632 5632 4037 7164 3084 0 5632 5632 5632 5632 16384 3152 4044 2365 SUCCESS
    616 08/08/2024 15:47 2553000 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13826 759 776 1 91 72 2860 3144 65535 65535 46 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3466 3445 3473 3444 13760 13917 763 775 772 754 264 267 268 260 1052 1070 26.8 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2860 3666 3144 4036 3050 2859 3663 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2541 5632 5632 5632 5632 -863 -1124 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -863 11 0.56 225 5632 5632 5632 5632 4037 7160 3084 0 5632 5632 5632 5632 16384 3152 4044 2443 SUCCESS
    617 08/08/2024 15:47 2557004 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13829 755 771 1 91 72 2861 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3467 3446 3474 3444 13761 13924 762 760 762 760 264 262 265 262 1044 1064 26.9 27.6 27.6 27.5 27.5 27.6 27.6 27.6 2861 3667 3144 4036 3051 2860 3665 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2545 5632 5632 5632 5632 -864 -1126 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -864 11 0.56 225 5632 5632 5632 5632 4037 7156 3084 0 5632 5632 5632 5632 16384 3152 4044 2534 SUCCESS
    618 08/08/2024 15:47 2561004 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13832 752 767 1 92 72 2862 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3469 3446 3475 3444 13768 13924 768 753 762 748 266 259 265 258 1036 1058 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2862 3668 3144 4036 3052 2861 3666 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2549 5632 5632 5632 5632 -865 -1127 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -865 11 0.56 225 5632 5632 5632 5632 4037 7152 3084 0 5632 5632 5632 5632 16384 3152 4044 2447 SUCCESS
    619 08/08/2024 15:48 2565018 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13835 746 762 1 92 72 2862 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3468 3445 3474 3443 13766 13925 751 747 752 748 260 257 261 258 1030 1052 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2863 3669 3144 4036 3052 2862 3667 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2553 5632 5632 5632 5632 -866 -1128 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -866 11 0.56 225 5632 5632 5632 5632 4037 7148 3084 0 5632 5632 5632 5632 16384 3152 4044 2331 SUCCESS
    620 08/08/2024 15:48 2569026 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13840 741 758 1 92 72 2863 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3471 3448 3478 3445 13771 13933 747 752 737 755 259 259 256 260 1021 1046 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2863 3670 3144 4036 3053 2862 3667 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2558 5632 5632 5632 5632 -867 -1129 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -867 11 0.56 225 5632 5632 5632 5632 4037 7144 3084 0 5632 5632 5632 5632 16384 3152 4044 2519 SUCCESS
    621 08/08/2024 15:48 2573028 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13842 735 753 1 92 72 2864 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3470 3446 3478 3443 13773 13932 743 737 731 738 258 254 254 254 1017 1039 26.9 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2864 3671 3144 4036 3054 2863 3668 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2561 5632 5632 5632 5632 -867 -1129 11 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -867 11 0.56 225 5632 5632 5632 5632 4037 7140 3084 0 5632 5632 5632 5632 16384 3152 4044 2448 SUCCESS
    622 08/08/2024 15:48 2577028 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13845 730 748 1 92 72 2865 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3471 3447 3479 3444 13776 13934 725 728 742 731 252 251 258 252 1009 1033 26.9 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2865 3673 3144 4036 3055 2864 3670 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2566 5632 5632 5632 5632 -868 -1131 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -868 12 0.56 225 5632 5632 5632 5632 4037 7136 3084 0 5632 5632 5632 5632 16384 3152 4044 3135 SUCCESS
    623 08/08/2024 15:48 2581039 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13847 725 743 1 92 72 2866 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3473 3448 3481 3444 13780 13942 738 726 725 731 256 250 252 252 1004 1026 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2866 3674 3144 4036 3056 2865 3671 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2570 5632 5632 5632 5632 -869 -1132 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -869 12 0.56 225 5632 5632 5632 5632 4037 7131 3084 0 5632 5632 5632 5632 16384 3152 4044 3289 SUCCESS
    624 08/08/2024 15:48 2585057 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13851 722 738 1 92 72 2866 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3473 3448 3482 3445 13786 13940 726 723 728 718 252 249 253 247 994 1020 26.9 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2867 3675 3144 4036 3057 2866 3672 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2574 5632 5632 5632 5632 -870 -1133 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -870 12 0.56 225 5632 5632 5632 5632 4037 7127 3084 0 5632 5632 5632 5632 16384 3152 4044 3274 SUCCESS
    625 08/08/2024 15:48 2589057 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13854 716 733 1 92 72 2867 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3474 3449 3483 3445 13784 13944 710 725 720 724 247 250 251 249 988 1013 26.9 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2868 3676 3144 4036 3058 2867 3674 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2578 5632 5632 5632 5632 -871 -1135 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -871 12 0.56 225 5632 5632 5632 5632 4037 7124 3084 0 5632 5632 5632 5632 16384 3152 4044 3226 SUCCESS
    626 08/08/2024 15:48 2593064 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13857 709 728 1 92 72 2868 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3476 3450 3485 3444 13788 13951 714 702 721 715 248 242 251 246 981 1006 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2868 3677 3144 4036 3058 2867 3674 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2582 5632 5632 5632 5632 -871 -1135 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -871 12 0.56 225 5632 5632 5632 5632 4037 7119 3084 0 5632 5632 5632 5632 16384 3152 4044 3384 SUCCESS
    627 08/08/2024 15:48 2597167 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13860 704 723 1 92 72 2869 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3476 3450 3486 3446 13795 13952 699 712 698 713 243 246 243 246 971 999 27.0 27.6 27.6 27.5 27.5 27.6 27.6 27.6 2869 3678 3144 4036 3059 2868 3675 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2586 5632 5632 5632 5632 -872 -1136 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -872 12 0.56 225 5632 5632 5632 5632 4037 7115 3084 0 5632 5632 5632 5632 16384 3152 4044 3233 SUCCESS
    628 08/08/2024 15:48 2601147 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13864 699 717 1 92 72 2870 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3477 3450 3488 3446 13796 13955 705 705 711 701 245 243 248 242 967 992 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2870 3679 3144 4036 3060 2869 3676 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2590 5632 5632 5632 5632 -873 -1137 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -873 12 0.56 225 5632 5632 5632 5632 4037 7112 3084 0 5632 5632 5632 5632 16384 3152 4044 3072 SUCCESS
    629 08/08/2024 15:48 2605100 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13863 694 712 1 92 72 2870 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3478 3451 3489 3445 13799 13957 696 703 692 695 242 243 241 239 959 984 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2871 3680 3144 4036 3060 2870 3678 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2593 5632 5632 5632 5632 -874 -1139 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -874 12 0.56 225 5632 5632 5632 5632 4037 7108 3084 0 5632 5632 5632 5632 16384 3152 4044 2401 SUCCESS
    630 08/08/2024 15:48 2609101 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13865 688 707 1 92 72 2871 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3479 3451 3490 3446 13801 13960 685 696 690 693 238 240 241 239 950 977 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2871 3681 3144 4036 3061 2870 3678 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2597 5632 5632 5632 5632 -874 -1139 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -874 12 0.56 225 5632 5632 5632 5632 4037 7104 3084 0 5632 5632 5632 5632 16384 3152 4044 2510 SUCCESS
    631 08/08/2024 15:48 2613104 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13869 683 701 1 92 72 2872 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3481 3453 3493 3448 13805 13965 689 698 675 686 240 241 236 237 944 970 26.9 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2872 3682 3144 4036 3062 2871 3679 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2602 5632 5632 5632 5632 -875 -1140 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -875 12 0.56 225 5632 5632 5632 5632 4037 7100 3084 0 5632 5632 5632 5632 16384 3152 4044 3165 SUCCESS
    632 08/08/2024 15:48 2617105 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13872 675 696 1 92 72 2873 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3482 3453 3494 3446 13808 13970 685 684 678 679 239 236 237 234 935 962 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2873 3683 3144 4036 3063 2872 3680 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2606 5632 5632 5632 5632 -876 -1141 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -876 12 0.56 225 5632 5632 5632 5632 4037 7095 3084 0 5632 5632 5632 5632 16384 3152 4044 3646 SUCCESS
    633 08/08/2024 15:48 2621434 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13878 669 690 1 92 72 2873 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3483 3453 3496 3447 13813 13972 676 661 672 678 235 228 235 234 926 953 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2874 3684 3144 4036 3064 2873 3681 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2610 5632 5632 5632 5632 -877 -1142 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -877 12 0.56 225 5632 5632 5632 5632 4037 7091 3084 0 5632 5632 5632 5632 16384 3152 4044 3518 SUCCESS
    634 08/08/2024 15:49 2625657 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13881 663 684 1 92 72 2874 3144 65535 65535 47 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3484 3453 3497 3447 13816 13975 661 660 663 667 230 228 232 230 919 945 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2875 3685 3144 4036 3064 2874 3683 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2615 5632 5632 5632 5632 -878 -1144 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -878 12 0.56 225 5632 5632 5632 5632 4037 7087 3084 0 5632 5632 5632 5632 16384 3152 4044 3432 SUCCESS
    635 08/08/2024 15:49 2629829 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13884 658 679 1 92 72 2875 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3486 3454 3499 3447 13819 13979 658 658 652 656 229 227 228 226 910 937 27.0 27.6 27.6 27.4 27.5 27.6 27.6 27.6 2875 3686 3144 4036 3065 2874 3683 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2618 5632 5632 5632 5632 -878 -1144 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -878 12 0.56 225 5632 5632 5632 5632 4037 7083 3084 0 5632 5632 5632 5632 16384 3152 4044 3192 SUCCESS
    636 08/08/2024 15:49 2633781 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13887 651 673 1 92 72 2876 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3487 3456 3502 3449 13822 13982 653 655 648 661 228 226 227 228 902 929 26.9 27.6 27.6 27.4 27.4 27.6 27.6 27.6 2876 3687 3144 4036 3066 2875 3684 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2623 5632 5632 5632 5632 -879 -1145 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -879 12 0.56 225 5632 5632 5632 5632 4037 7079 3084 0 5632 5632 5632 5632 16384 3152 4044 3401 SUCCESS
    637 08/08/2024 15:49 2637872 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13890 645 665 1 92 72 2876 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3489 3457 3504 3449 13827 13991 642 651 641 655 224 225 225 226 894 921 27.0 27.6 27.5 27.4 27.4 27.6 27.6 27.6 2877 3688 3144 4036 3067 2876 3685 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2627 5632 5632 5632 5632 -880 -1146 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -880 12 0.56 225 5632 5632 5632 5632 4037 7075 3084 0 5632 5632 5632 5632 16384 3152 4044 3501 SUCCESS
    638 08/08/2024 15:49 2642095 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13896 639 659 1 92 72 2877 3144 65535 65535 48 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3489 3456 3505 3448 13836 13989 641 647 642 641 224 224 225 221 884 913 27.0 27.6 27.6 27.4 27.4 27.6 27.6 27.6 2878 3689 3144 4036 3067 2876 3685 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2631 5632 5632 5632 5632 -881 -1148 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -881 12 0.56 225 5632 5632 5632 5632 4037 7071 3084 0 5632 5632 5632 5632 16384 3152 4044 3488 SUCCESS
    639 08/08/2024 15:49 2646249 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13899 630 653 1 92 72 2878 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3490 3456 3506 3448 13833 13994 640 622 635 628 223 215 223 217 876 905 27.0 27.6 27.6 27.4 27.4 27.6 27.6 27.6 2878 3690 3144 4036 3068 2877 3687 1146 1493 3142 4032 27.8 27.6 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2635 5632 5632 5632 5632 -881 -1148 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -881 12 0.56 225 5632 5632 5632 5632 4037 7066 3084 0 5632 5632 5632 5632 16384 3152 4044 3607 SUCCESS
    640 08/08/2024 15:49 2650575 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13905 625 647 1 92 72 2879 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3491 3458 3508 3448 13839 13997 616 632 630 616 215 219 221 212 866 895 26.9 27.5 27.6 27.4 27.4 27.5 27.6 27.5 2879 3691 3144 4036 3069 2878 3688 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2639 5632 5632 5632 5632 -882 -1149 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -882 12 0.56 225 5632 5632 5632 5632 4037 7062 3084 0 5632 5632 5632 5632 16384 3152 4044 3316 SUCCESS
    641 08/08/2024 15:49 2654651 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13909 619 641 1 92 72 2879 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3493 3458 3510 3448 13842 14000 622 618 620 618 217 214 218 213 857 886 27.1 27.6 27.6 27.4 27.4 27.6 27.6 27.6 2880 3692 3144 4036 3070 2879 3689 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2643 5632 5632 5632 5632 -883 -1150 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -883 12 0.56 225 5632 5632 5632 5632 4037 7058 3084 0 5632 5632 5632 5632 16384 3152 4044 3389 SUCCESS
    642 08/08/2024 15:49 2658891 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13911 612 635 1 92 72 2880 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3496 3460 3513 3450 13847 14009 619 623 622 619 216 216 219 214 848 878 27.0 27.6 27.6 27.4 27.4 27.6 27.6 27.6 2880 3692 3144 4036 3070 2879 3689 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2648 5632 5632 5632 5632 -883 -1150 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -883 12 0.56 225 5632 5632 5632 5632 4037 7054 3084 0 5632 5632 5632 5632 16384 3152 4044 3285 SUCCESS
    643 08/08/2024 15:49 2662941 0x0187 0 10 0x6001 0 65535 65535 1 27.6 13915 604 629 1 92 73 2881 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3497 3460 3515 3450 13853 14009 617 610 610 607 216 211 214 209 839 869 27.0 27.5 27.6 27.5 27.4 27.5 27.6 27.5 2881 3693 3144 4036 3071 2880 3691 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2652 5632 5632 5632 5632 -884 -1152 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -884 12 0.56 225 5632 5632 5632 5632 4037 7050 3084 0 5632 5632 5632 5632 16384 3152 4044 3363 SUCCESS
    644 08/08/2024 15:49 2667031 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13918 597 622 1 92 73 2881 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3498 3461 3517 3450 13854 14013 608 595 595 611 213 206 209 211 831 860 27.0 27.5 27.6 27.5 27.4 27.5 27.6 27.5 2882 3694 3144 4036 3072 2881 3692 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2656 5632 5632 5632 5632 -885 -1153 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -885 12 0.56 225 5632 5632 5632 5632 4037 7046 3084 0 5632 5632 5632 5632 16384 3152 4044 3170 SUCCESS
    645 08/08/2024 15:49 2670987 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13922 592 615 1 92 73 2882 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3499 3461 3519 3450 13858 14020 599 598 588 589 210 207 207 203 822 852 27.1 27.5 27.6 27.5 27.4 27.5 27.6 27.5 2882 3695 3144 4036 3072 2881 3692 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2660 5632 5632 5632 5632 -885 -1153 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -885 12 0.56 225 5632 5632 5632 5632 4037 7042 3084 0 5632 5632 5632 5632 16384 3152 4044 3507 SUCCESS
    646 08/08/2024 15:49 2675250 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13926 584 607 1 92 73 2883 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3499 3460 3519 3449 13866 14020 584 579 589 585 204 200 207 202 812 843 27.0 27.5 27.6 27.5 27.4 27.5 27.6 27.5 2883 3696 3144 4036 3073 2882 3693 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2664 5632 5632 5632 5632 -886 -1154 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -886 12 0.56 225 5632 5632 5632 5632 4037 7038 3084 0 5632 5632 5632 5632 16384 3152 4044 3399 SUCCESS
    647 08/08/2024 15:49 2679369 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13931 578 601 1 92 73 2883 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3501 3461 3522 3448 13865 14025 578 576 581 582 202 199 205 201 803 834 27.0 27.5 27.6 27.5 27.4 27.5 27.6 27.5 2884 3697 3144 4036 3074 2883 3695 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2668 5632 5632 5632 5632 -887 -1156 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -887 12 0.56 225 5632 5632 5632 5632 4037 7034 3084 0 5632 5632 5632 5632 16384 3152 4044 3198 SUCCESS
    648 08/08/2024 15:49 2683324 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13934 571 594 1 92 73 2884 3144 65535 65535 49 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3502 3461 3524 3448 13871 14030 575 574 570 573 201 199 201 198 792 825 27.0 27.5 27.6 27.5 27.4 27.5 27.6 27.5 2885 3698 3144 4036 3074 2884 3696 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2674 5632 5632 5632 5632 -888 -1157 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -888 12 0.56 225 5632 5632 5632 5632 4037 7027 3084 0 5632 5632 5632 5632 16384 3152 4044 6265 SUCCESS
    649 08/08/2024 15:50 2690452 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13942 557 582 1 92 73 2885 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3506 3464 3529 3450 13878 14035 553 565 563 562 194 196 199 194 774 807 27.1 27.5 27.6 27.5 27.4 27.5 27.6 27.5 2886 3699 3144 4036 3075 2885 3697 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2680 5632 5632 5632 5632 -889 -1158 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -889 12 0.56 225 5632 5632 5632 5632 4037 7022 3084 0 5632 5632 5632 5632 16384 3152 4044 4105 SUCCESS
    650 08/08/2024 15:50 2695253 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13945 552 574 1 92 73 2886 3144 65535 65535 50 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3507 3464 3531 3450 13880 14041 552 552 543 546 194 191 192 188 765 797 27.0 27.5 27.6 27.5 27.4 27.5 27.6 27.5 2886 3700 3144 4036 3076 2885 3697 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2684 5632 5632 5632 5632 -889 -1158 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -889 12 0.56 225 5632 5632 5632 5632 4037 7018 3084 0 5632 5632 5632 5632 16384 3152 4044 3246 SUCCESS
    651 08/08/2024 15:50 2699226 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13949 544 569 1 92 73 2887 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3509 3465 3533 3450 13886 14044 544 548 541 540 191 190 191 186 755 788 27.0 27.5 27.6 27.4 27.4 27.5 27.6 27.5 2887 3701 3144 4036 3077 2886 3698 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2688 5632 5632 5632 5632 -890 -1159 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -890 12 0.56 225 5632 5632 5632 5632 4037 7014 3084 0 5632 5632 5632 5632 16384 3152 4044 3232 SUCCESS
    652 08/08/2024 15:50 2703270 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13953 537 560 1 92 73 2887 3144 65535 65535 51 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3510 3465 3535 3449 13889 14046 544 533 525 538 191 185 186 186 747 779 26.9 27.5 27.6 27.4 27.4 27.5 27.6 27.5 2887 3702 3144 4036 3077 2886 3698 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2692 5632 5632 5632 5632 -890 -1159 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -890 12 0.56 225 5632 5632 5632 5632 4037 7010 3084 0 5632 5632 5632 5632 16384 3152 4044 3352 SUCCESS
    653 08/08/2024 15:50 2707355 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13958 531 554 1 92 73 2888 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3511 3464 3536 3448 13893 14053 538 526 529 538 189 182 187 186 737 770 27.0 27.5 27.6 27.4 27.4 27.5 27.6 27.5 2888 3702 3144 4036 3078 2887 3700 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2696 5632 5632 5632 5632 -891 -1161 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -891 12 0.56 225 5632 5632 5632 5632 4037 7006 3084 0 5632 5632 5632 5632 16384 3152 4044 3570 SUCCESS
    654 08/08/2024 15:50 2711657 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13965 521 547 1 92 73 2888 3144 65535 65535 52 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3512 3464 3539 3448 13899 14056 510 516 520 520 179 179 184 179 725 760 27.0 27.5 27.5 27.4 27.4 27.5 27.5 27.5 2889 3703 3144 4036 3079 2888 3701 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2700 5632 5632 5632 5632 -892 -1162 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -892 12 0.56 225 5632 5632 5632 5632 4037 7001 3084 0 5632 5632 5632 5632 16384 3152 4044 3353 SUCCESS
    655 08/08/2024 15:50 2715783 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13969 514 540 1 92 73 2889 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3514 3465 3540 3449 13899 14060 524 518 512 505 184 179 181 174 717 750 26.9 27.5 27.5 27.4 27.4 27.5 27.6 27.5 2889 3704 3144 4036 3079 2888 3701 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2704 5632 5632 5632 5632 -892 -1162 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -892 12 0.56 225 5632 5632 5632 5632 4037 6997 3084 0 5632 5632 5632 5632 16384 3152 4044 3263 SUCCESS
    656 08/08/2024 15:50 2719743 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13974 508 533 1 92 73 2889 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3515 3466 3542 3448 13904 14066 507 510 516 525 178 177 183 181 706 741 26.9 27.5 27.5 27.3 27.4 27.5 27.5 27.5 2890 3705 3144 4036 3080 2889 3702 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2708 5632 5632 5632 5632 -893 -1163 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -893 12 0.56 225 5632 5632 5632 5632 4037 6994 3084 0 5632 5632 5632 5632 16384 3152 4044 3235 SUCCESS
    657 08/08/2024 15:50 2723806 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13978 499 526 1 92 73 2890 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3517 3466 3545 3448 13909 14066 512 517 511 512 180 179 181 177 695 729 26.9 27.5 27.5 27.3 27.4 27.5 27.5 27.5 2890 3706 3144 4036 3080 2889 3702 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2712 5632 5632 5632 5632 -893 -1163 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -893 12 0.56 225 5632 5632 5632 5632 4037 6989 3084 0 5632 5632 5632 5632 16384 3152 4044 3623 SUCCESS
    658 08/08/2024 15:50 2728184 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13977 492 519 1 92 73 2891 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3518 3466 3547 3448 13913 14071 502 497 496 500 177 172 176 172 688 720 26.9 27.5 27.5 27.3 27.4 27.5 27.5 27.5 2891 3706 3144 4036 3081 2890 3704 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2716 5632 5632 5632 5632 -894 -1165 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -894 12 0.56 225 5632 5632 5632 5632 4037 6985 3084 0 5632 5632 5632 5632 16384 3152 4044 3315 SUCCESS
    659 08/08/2024 15:50 2732237 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13981 485 512 1 92 73 2891 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3520 3468 3550 3449 13920 14075 477 487 502 472 168 169 178 163 676 710 26.9 27.5 27.5 27.2 27.4 27.5 27.5 27.5 2892 3707 3144 4036 3081 2890 3704 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2721 5632 5632 5632 5632 -894 -1165 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -894 12 0.56 225 5632 5632 5632 5632 4037 6981 3084 0 5632 5632 5632 5632 16384 3152 4044 3451 SUCCESS
    660 08/08/2024 15:50 2736373 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13985 478 505 1 92 73 2892 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3522 3468 3553 3449 13921 14079 475 489 475 474 167 170 169 163 667 700 26.9 27.5 27.5 27.2 27.4 27.5 27.5 27.5 2892 3708 3144 4036 3082 2891 3705 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2725 5632 5632 5632 5632 -895 -1166 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -895 12 0.56 225 5632 5632 5632 5632 4037 6977 3084 0 5632 5632 5632 5632 16384 3152 4044 3637 SUCCESS
    661 08/08/2024 15:50 2740696 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13990 471 496 1 92 73 2892 3144 65535 65535 53 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3522 3469 3554 3448 13924 14088 473 466 470 478 167 162 167 165 656 691 26.8 27.5 27.5 27.2 27.4 27.5 27.5 27.5 2893 3708 3144 4036 3082 2892 3706 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2729 5632 5632 5632 5632 -896 -1167 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -896 12 0.56 225 5632 5632 5632 5632 4037 6972 3084 0 5632 5632 5632 5632 16384 3152 4044 3531 SUCCESS
    662 08/08/2024 15:51 2744951 0x0187 0 10 0x6001 0 65535 65535 1 27.5 13998 464 489 1 93 73 2893 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3524 3468 3556 3447 13931 14088 460 459 460 461 162 159 164 159 647 681 26.8 27.5 27.5 27.2 27.4 27.5 27.5 27.5 2893 3709 3144 4036 3083 2892 3706 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2733 5632 5632 5632 5632 -896 -1167 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -896 12 0.56 225 5632 5632 5632 5632 4037 6968 3084 0 5632 5632 5632 5632 16384 3152 4044 3227 SUCCESS
    663 08/08/2024 15:51 2748907 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14002 458 482 1 93 73 2893 3144 65535 65535 54 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3525 3468 3559 3447 13931 14089 463 462 476 472 163 160 169 163 637 671 26.9 27.5 27.5 27.2 27.4 27.5 27.5 27.5 2894 3710 3144 4036 3084 2893 3708 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2737 5632 5632 5632 5632 -897 -1169 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -897 12 0.56 225 5632 5632 5632 5632 4037 6965 3084 0 5632 5632 5632 5632 16384 3152 4044 3153 SUCCESS
    664 08/08/2024 15:51 2752792 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14001 449 475 1 93 73 2894 3144 65535 65535 55 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3527 3469 3561 3446 13936 14097 453 442 461 453 160 153 164 156 626 662 27.0 27.5 27.5 27.2 27.4 27.5 27.5 27.5 2894 3710 3144 4036 3084 2893 3708 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2741 5632 5632 5632 5632 -897 -1169 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -897 12 0.56 225 5632 5632 5632 5632 4037 6961 3084 0 5632 5632 5632 5632 16384 3152 4044 3243 SUCCESS
    665 08/08/2024 15:51 2756778 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14005 443 468 1 93 73 2894 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3528 3469 3563 3446 13943 14099 446 448 446 441 157 155 159 152 615 652 26.9 27.5 27.5 27.2 27.4 27.5 27.5 27.5 2895 3711 3144 4036 3085 2894 3709 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2745 5632 5632 5632 5632 -898 -1170 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -898 12 0.56 225 5632 5632 5632 5632 4037 6956 3084 0 5632 5632 5632 5632 16384 3152 4044 3586 SUCCESS
    666 08/08/2024 15:51 2761123 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14010 433 461 1 93 73 2895 3144 65535 65535 56 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3530 3469 3566 3446 13944 14101 435 446 436 422 154 155 155 145 607 640 26.8 27.5 27.5 27.3 27.3 27.5 27.5 27.5 2895 3712 3144 4036 3085 2894 3709 1146 1493 3142 4032 27.8 27.5 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2749 5632 5632 5632 5632 -898 -1170 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -898 12 0.56 225 5632 5632 5632 5632 4037 6952 3084 0 5632 5632 5632 5632 16384 3152 4044 3306 SUCCESS
    667 08/08/2024 15:51 2765152 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14017 427 454 1 93 73 2895 3144 65535 65535 57 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3531 3470 3568 3445 13947 14106 437 437 415 430 154 152 148 148 594 630 27.0 27.5 27.5 27.3 27.3 27.5 27.5 27.5 2896 3712 3144 4036 3085 2895 3710 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2753 5632 5632 5632 5632 -899 -1171 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -899 12 0.56 225 5632 5632 5632 5632 4037 6948 3084 0 5632 5632 5632 5632 16384 3152 4044 3438 SUCCESS
    668 08/08/2024 15:51 2769322 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14017 421 447 1 93 73 2896 3144 65535 65535 58 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3534 3470 3570 3445 13951 14110 428 426 422 429 151 148 151 148 587 620 27.0 27.5 27.5 27.3 27.3 27.5 27.5 27.5 2896 3713 3144 4036 3086 2895 3710 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2757 5632 5632 5632 5632 -899 -1171 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -899 12 0.56 225 5632 5632 5632 5632 4037 6944 3084 0 5632 5632 5632 5632 16384 3152 4044 3283 SUCCESS
    669 08/08/2024 15:51 2773356 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14020 413 440 1 93 73 2896 3144 65535 65535 59 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3534 3470 3573 3445 13954 14113 421 405 411 412 149 141 147 142 578 611 26.9 27.5 27.5 27.4 27.3 27.5 27.5 27.5 2897 3714 3144 4036 3086 2895 3710 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2761 5632 5632 5632 5632 -899 -1171 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -900 12 0.56 225 5632 5632 5632 5632 4037 6940 3084 0 5632 5632 5632 5632 16384 3152 4044 3274 SUCCESS
    670 08/08/2024 15:51 2777344 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14024 408 433 1 93 73 2897 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3535 3470 3575 3444 13957 14116 414 411 410 410 146 143 147 141 569 601 27.0 27.5 27.5 27.4 27.3 27.5 27.5 27.5 2897 3714 3144 4036 3087 2896 3711 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2765 5632 5632 5632 5632 -900 -1172 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -900 12 0.56 225 5632 5632 5632 5632 4037 6936 3084 0 5632 5632 5632 5632 16384 3152 4044 3302 SUCCESS
    671 08/08/2024 15:51 2781407 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14027 401 426 1 93 73 2897 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3537 3470 3578 3444 13961 14119 395 399 400 404 140 138 143 139 558 592 27.0 27.5 27.5 27.4 27.3 27.5 27.5 27.5 2897 3715 3144 4036 3087 2896 3711 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2769 5632 5632 5632 5632 -900 -1172 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -900 12 0.56 225 5632 5632 5632 5632 4037 6932 3084 0 5632 5632 5632 5632 16384 3152 4044 3231 SUCCESS
    672 08/08/2024 15:51 2785339 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14032 394 419 1 93 73 2898 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3537 3471 3580 3443 13965 14123 402 397 399 400 142 138 143 138 550 585 27.1 27.5 27.5 27.4 27.3 27.5 27.5 27.5 2898 3715 3144 4036 3088 2897 3713 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2773 5632 5632 5632 5632 -901 -1174 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -901 12 0.56 225 5632 5632 5632 5632 4037 6928 3084 0 5632 5632 5632 5632 16384 3152 4044 3259 SUCCESS
    673 08/08/2024 15:51 2789379 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14035 388 412 1 93 73 2898 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3539 3471 3583 3443 13969 14127 387 386 388 389 137 134 139 134 542 573 27.0 27.5 27.5 27.4 27.3 27.5 27.5 27.5 2898 3716 3144 4036 3088 2897 3713 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2777 5632 5632 5632 5632 -901 -1174 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -901 12 0.56 225 5632 5632 5632 5632 4037 6924 3084 0 5632 5632 5632 5632 16384 3152 4044 3265 SUCCESS
    674 08/08/2024 15:51 2793404 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14038 381 405 1 93 73 2898 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3541 3472 3585 3443 13972 14129 380 392 392 384 135 136 141 132 531 566 27.0 27.5 27.5 27.4 27.3 27.5 27.5 27.5 2899 3716 3144 4036 3089 2898 3714 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2781 5632 5632 5632 5632 -902 -1175 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -902 12 0.56 225 5632 5632 5632 5632 4037 6920 3084 0 5632 5632 5632 5632 16384 3152 4044 3319 SUCCESS
    675 08/08/2024 15:51 2797476 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14042 372 398 1 93 73 2899 3144 65535 65535 60 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3542 3471 3587 3442 13975 14134 373 377 372 380 132 131 133 131 520 554 26.9 27.5 27.5 27.4 27.3 27.5 27.5 27.5 2899 3717 3144 4036 3089 2898 3714 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2785 5632 5632 5632 5632 -902 -1175 12 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -902 12 0.56 225 5632 5632 5632 5632 4037 6916 3084 0 5632 5632 5632 5632 16384 3152 4044 3203 SUCCESS
    676 08/08/2024 15:51 2801491 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14046 366 391 1 93 73 2899 3144 65535 65535 61 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3543 3471 3590 3442 13980 14138 366 368 367 374 130 128 132 129 513 545 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2900 3717 3144 4036 3089 2898 3714 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2790 5632 5632 5632 5632 -903 -1176 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -903 13 0.56 225 5632 5632 5632 5632 4037 6912 3084 0 5632 5632 5632 5632 16384 3152 4044 3450 SUCCESS
    677 08/08/2024 15:52 2805680 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14049 360 385 1 93 73 2900 3144 65535 65535 62 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3546 3472 3593 3443 13983 14140 361 362 348 355 128 126 125 122 502 535 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2900 3718 3144 4036 3090 2899 3715 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2794 5632 5632 5632 5632 -903 -1176 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -903 13 0.56 225 5632 5632 5632 5632 4037 6908 3084 0 5632 5632 5632 5632 16384 3152 4044 3353 SUCCESS
    678 08/08/2024 15:52 2809795 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14052 354 378 1 93 73 2900 3144 65535 65535 63 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3547 3473 3596 3442 13985 14148 358 350 363 363 127 122 131 125 493 526 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2900 3719 3144 4036 3090 2899 3715 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2798 5632 5632 5632 5632 -903 -1176 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -903 13 0.56 225 5632 5632 5632 5632 4037 6904 3084 0 5632 5632 5632 5632 16384 3152 4044 3258 SUCCESS
    679 08/08/2024 15:52 2813818 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14055 347 372 1 93 73 2901 3144 65535 65535 64 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0004 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3549 3473 3599 3442 13989 14147 350 337 350 370 123 117 126 127 485 517 26.9 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2901 3719 3144 4036 3091 2900 3717 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2802 5632 5632 5632 5632 -904 -1178 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -904 13 0.56 225 5632 5632 5632 5632 4037 6900 3084 0 5632 5632 5632 5632 16384 3152 4044 3246 SUCCESS
    680 08/08/2024 15:52 2817795 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14058 342 365 1 93 73 2901 3144 65535 65535 65 4004 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3550 3473 3601 3441 13992 14151 339 331 333 356 120 115 120 122 477 508 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2901 3720 3144 4036 3091 2900 3717 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2806 5632 5632 5632 5632 -904 -1178 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -904 13 0.56 225 5632 5632 5632 5632 4037 6896 3084 0 5632 5632 5632 5632 16384 3152 4044 3344 SUCCESS
    681 08/08/2024 15:52 2821894 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14062 336 357 1 93 73 2901 3144 65535 65535 66 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3551 3474 3604 3441 13995 14157 328 341 333 346 116 118 120 119 466 499 27.0 27.4 27.5 27.4 27.2 27.4 27.5 27.4 2902 3720 3144 4036 3091 2900 3717 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2810 5632 5632 5632 5632 -904 -1178 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -904 13 0.56 225 5632 5632 5632 5632 4037 6892 3084 0 5632 5632 5632 5632 16384 3152 4044 3361 SUCCESS
    682 08/08/2024 15:52 2826009 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14066 328 351 1 93 73 2902 3144 65535 65535 67 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3552 3472 3605 3438 14000 14157 327 341 336 327 116 118 121 112 459 490 27.1 27.4 27.5 27.5 27.3 27.5 27.5 27.5 2902 3720 3144 4036 3092 2901 3718 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2814 5632 5632 5632 5632 -905 -1179 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -905 13 0.56 225 5632 5632 5632 5632 4037 6888 3084 0 5632 5632 5632 5632 16384 3152 4044 3366 SUCCESS
    683 08/08/2024 15:52 2830157 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14070 320 344 1 93 73 2902 3144 65535 65535 68 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3553 3472 3607 3438 14002 14161 329 330 331 323 117 115 119 111 449 482 26.9 27.4 27.5 27.5 27.3 27.5 27.5 27.5 2902 3721 3144 4036 3092 2901 3718 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2818 5632 5632 5632 5632 -905 -1179 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -905 13 0.56 225 5632 5632 5632 5632 4037 6884 3084 0 5632 5632 5632 5632 16384 3152 4044 3266 SUCCESS
    684 08/08/2024 15:52 2834194 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14072 317 338 1 93 73 2902 3144 65535 65535 69 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3554 3472 3609 3438 14007 14166 323 326 318 319 115 113 115 110 443 473 27.0 27.4 27.5 27.5 27.3 27.5 27.5 27.5 2903 3721 3144 4036 3092 2902 3719 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2822 5632 5632 5632 5632 -906 -1180 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -906 13 0.56 225 5632 5632 5632 5632 4037 6880 3084 0 5632 5632 5632 5632 16384 3152 4044 3265 SUCCESS
    685 08/08/2024 15:52 2838234 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14075 310 332 1 93 73 2903 3144 65535 65535 70 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3556 3472 3612 3437 14011 14167 305 323 311 318 108 112 112 109 435 464 27.1 27.4 27.4 27.4 27.3 27.4 27.4 27.4 2903 3722 3144 4036 3093 2902 3719 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2826 5632 5632 5632 5632 -906 -1180 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -906 13 0.56 225 5632 5632 5632 5632 4037 6876 3084 0 5632 5632 5632 5632 16384 3152 4044 3298 SUCCESS
    686 08/08/2024 15:52 2842230 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14078 305 326 1 93 73 2903 3144 65535 65535 70 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3557 3472 3614 3436 14011 14171 306 317 303 308 109 110 110 106 424 456 27.0 27.4 27.5 27.5 27.3 27.5 27.5 27.5 2903 3722 3144 4036 3093 2902 3719 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2830 5632 5632 5632 5632 -906 -1180 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -906 13 0.56 225 5632 5632 5632 5632 4037 6871 3084 0 5632 5632 5632 5632 16384 3152 4044 3586 SUCCESS
    687 08/08/2024 15:52 2846531 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14086 299 320 1 93 73 2903 3144 65535 65535 71 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3558 3472 3617 3435 14016 14174 290 297 289 297 103 103 105 102 417 448 27.0 27.4 27.4 27.4 27.3 27.4 27.4 27.4 2904 3723 3144 4036 3094 2903 3721 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2834 5632 5632 5632 5632 -907 -1182 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -907 13 0.56 225 5632 5632 5632 5632 4037 6867 3084 0 5632 5632 5632 5632 16384 3152 4044 3253 SUCCESS
    688 08/08/2024 15:52 2850603 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14088 292 314 1 93 73 2904 3144 65535 65535 71 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3560 3472 3620 3436 14019 14175 300 302 297 301 107 105 108 103 409 439 27.1 27.4 27.4 27.5 27.3 27.5 27.4 27.5 2904 3723 3144 4036 3094 2903 3721 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2838 5632 5632 5632 5632 -907 -1182 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -907 13 0.56 225 5632 5632 5632 5632 4037 6863 3084 0 5632 5632 5632 5632 16384 3152 4044 3189 SUCCESS
    689 08/08/2024 15:52 2854525 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14092 286 308 1 93 73 2904 3144 65535 65535 72 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3560 3471 3622 3434 14021 14180 285 291 293 287 101 101 106 99 400 431 27.0 27.4 27.4 27.5 27.3 27.5 27.4 27.5 2904 3724 3144 4036 3094 2903 3721 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2842 5632 5632 5632 5632 -907 -1182 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -907 13 0.56 225 5632 5632 5632 5632 4037 6860 3084 0 5632 5632 5632 5632 16384 3152 4044 2917 SUCCESS
    690 08/08/2024 15:52 2858111 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14090 282 303 1 93 73 2904 3144 65535 65535 73 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3561 3471 3624 3434 14024 14182 281 286 280 283 100 99 101 97 395 424 27.1 27.4 27.4 27.5 27.3 27.5 27.4 27.5 2905 3724 3144 4036 3094 2903 3721 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2845 5632 5632 5632 5632 -907 -1182 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -907 13 0.56 225 5632 5632 5632 5632 4037 6857 3084 0 5632 5632 5632 5632 16384 3152 4044 2358 SUCCESS
    691 08/08/2024 15:52 2861654 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14098 276 297 1 93 73 2905 3144 65535 65535 68 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3563 3473 3628 3435 14025 14187 273 274 273 279 97 95 99 96 388 416 27.1 27.3 27.4 27.5 27.3 27.5 27.4 27.5 2905 3724 3144 4036 3095 2904 3722 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2848 5632 5632 5632 5632 -908 -1183 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -908 13 0.56 225 5632 5632 5632 5632 4037 6853 3084 0 5632 5632 5632 5632 16384 3152 4044 2430 SUCCESS
    692 08/08/2024 15:53 2865660 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14100 271 291 1 93 73 2905 3144 65535 65535 69 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3565 3472 3630 3434 14032 14186 279 256 271 273 99 89 98 94 378 408 27.0 27.4 27.5 27.5 27.3 27.5 27.5 27.5 2905 3725 3144 4036 3095 2904 3722 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2852 5632 5632 5632 5632 -908 -1183 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -908 13 0.56 225 5632 5632 5632 5632 4037 6849 3084 0 5632 5632 5632 5632 16384 3152 4044 2420 SUCCESS
    693 08/08/2024 15:53 2869664 0x0187 0 10 0x6001 0 65535 65535 1 27.5 14102 264 286 1 93 73 2905 3144 65535 65535 69 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3565 3471 3632 3433 14031 14191 265 268 262 264 94 93 95 91 369 400 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2905 3725 3144 4036 3095 2904 3722 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2857 5632 5632 5632 5632 -908 -1183 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -908 13 0.56 225 5632 5632 5632 5632 4037 6844 3084 0 5632 5632 5632 5632 16384 3152 4044 3473 SUCCESS
    694 08/08/2024 15:53 2873812 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14104 260 280 1 93 73 2906 3144 65535 65535 70 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3567 3471 3633 3431 14034 14194 271 250 256 264 97 87 93 91 364 392 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2906 3725 3144 4036 3096 2905 3723 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2861 5632 5632 5632 5632 -909 -1184 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -909 13 0.56 225 5632 5632 5632 5632 4037 6840 3084 0 5632 5632 5632 5632 16384 3152 4044 3257 SUCCESS
    695 08/08/2024 15:53 2877837 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14106 255 274 1 93 73 2906 3144 65535 65535 71 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3568 3471 3637 3431 14037 14194 253 268 254 255 90 93 92 87 355 383 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2906 3726 3144 4036 3096 2905 3723 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2865 5632 5632 5632 5632 -909 -1184 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -909 13 0.56 225 5632 5632 5632 5632 4037 6836 3084 0 5632 5632 5632 5632 16384 3152 4044 3316 SUCCESS
    696 08/08/2024 15:53 2881895 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14108 249 269 1 93 73 2906 3144 65535 65535 72 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3569 3471 3640 3430 14038 14198 257 254 248 254 92 88 90 87 348 375 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2906 3726 3144 4036 3096 2905 3723 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2869 5632 5632 5632 5632 -909 -1184 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -909 13 0.56 225 5632 5632 5632 5632 4037 6832 3084 0 5632 5632 5632 5632 16384 3152 4044 3394 SUCCESS
    697 08/08/2024 15:53 2886031 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14110 244 263 1 93 73 2906 3144 65535 65535 73 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3571 3472 3643 3431 14043 14201 241 244 243 247 86 85 89 85 342 367 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2907 3727 3144 4036 3096 2905 3723 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2874 5632 5632 5632 5632 -910 -1186 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -910 13 0.56 225 5632 5632 5632 5632 4037 6828 3084 0 5632 5632 5632 5632 16384 3152 4044 3835 SUCCESS
    698 08/08/2024 15:53 2890559 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14117 239 257 1 93 73 2907 3144 65535 65535 73 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3571 3471 3644 3428 14045 14204 248 245 238 249 89 85 87 85 333 358 27.0 27.4 27.5 27.4 27.3 27.4 27.5 27.4 2907 3727 3144 4036 3097 2906 3725 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2878 5632 5632 5632 5632 -910 -1186 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -910 13 0.56 225 5632 5632 5632 5632 4037 6823 3084 0 5632 5632 5632 5632 16384 3152 4044 3820 SUCCESS
    699 08/08/2024 15:53 2895058 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14117 233 252 1 93 73 2907 3144 65535 65535 75 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3573 3470 3648 3428 14048 14207 242 235 234 236 86 82 85 81 328 351 27.0 27.4 27.5 27.3 27.3 27.4 27.5 27.4 2907 3727 3144 4036 3097 2906 3725 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2882 5632 5632 5632 5632 -910 -1186 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -910 13 0.56 225 5632 5632 5632 5632 4037 6819 3084 0 5632 5632 5632 5632 16384 3152 4044 3114 SUCCESS
    700 08/08/2024 15:53 2898325 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14117 229 246 1 93 73 2907 3144 65535 65535 75 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3575 3471 3650 3428 14052 14210 239 221 226 231 85 77 82 79 322 346 26.9 27.4 27.5 27.3 27.3 27.4 27.5 27.4 2907 3728 3144 4036 3097 2906 3725 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2886 5632 5632 5632 5632 -910 -1186 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -910 13 0.56 225 5632 5632 5632 5632 4037 6816 3084 0 5632 5632 5632 5632 16384 3152 4044 3146 SUCCESS
    701 08/08/2024 15:53 2902197 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14121 224 243 1 93 73 2907 3144 65535 65535 76 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3575 3470 3651 3426 14053 14210 233 234 224 218 83 81 82 75 315 339 27.0 27.4 27.5 27.2 27.3 27.4 27.5 27.4 2908 3728 3144 4036 3097 2907 3726 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2890 5632 5632 5632 5632 -911 -1187 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -911 13 0.56 225 5632 5632 5632 5632 4037 6812 3084 0 5632 5632 5632 5632 16384 3152 4044 3341 SUCCESS
    702 08/08/2024 15:53 2906251 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14123 219 238 1 93 73 2908 3144 65535 65535 77 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3576 3470 3655 3427 14054 14217 221 220 221 218 79 76 81 75 308 332 26.9 27.4 27.5 27.2 27.2 27.4 27.5 27.4 2908 3728 3144 4036 3098 2907 3726 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2894 5632 5632 5632 5632 -911 -1187 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -911 13 0.56 225 5632 5632 5632 5632 4037 6808 3084 0 5632 5632 5632 5632 16384 3152 4044 3269 SUCCESS
    703 08/08/2024 15:53 2910256 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14125 214 233 1 93 73 2908 3144 65535 65535 78 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3577 3469 3656 3425 14056 14216 215 216 221 219 77 75 81 75 302 325 26.9 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2908 3729 3144 4036 3098 2907 3726 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2897 5632 5632 5632 5632 -911 -1187 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -911 13 0.56 225 5632 5632 5632 5632 4037 6804 3084 0 5632 5632 5632 5632 16384 3152 4044 3169 SUCCESS
    704 08/08/2024 15:53 2914180 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14128 210 228 1 93 73 2908 3144 65535 65535 79 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3578 3468 3658 3424 14061 14218 215 213 218 203 77 74 80 70 295 319 26.8 27.4 27.5 27.2 27.2 27.4 27.5 27.4 2908 3729 3144 4036 3098 2907 3726 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2901 5632 5632 5632 5632 -911 -1187 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -911 13 0.56 225 5632 5632 5632 5632 4037 6800 3084 0 5632 5632 5632 5632 16384 3152 4044 3374 SUCCESS
    705 08/08/2024 15:53 2918316 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14129 205 223 1 93 73 2908 3144 65535 65535 80 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3579 3469 3662 3425 14061 14223 207 211 208 216 74 73 76 74 286 312 26.9 27.4 27.5 27.2 27.2 27.4 27.5 27.4 2909 3729 3144 4036 3098 2907 3726 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2906 5632 5632 5632 5632 -911 -1187 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -911 13 0.56 225 5632 5632 5632 5632 4037 6796 3084 0 5632 5632 5632 5632 16384 3152 4044 3348 SUCCESS
    706 08/08/2024 15:53 2922417 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14131 200 219 1 93 73 2909 3144 65535 65535 81 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3580 3469 3664 3424 14068 14222 196 204 206 213 70 71 75 73 281 305 26.9 27.4 27.5 27.2 27.2 27.4 27.4 27.4 2909 3729 3144 4036 3099 2908 3727 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2910 5632 5632 5632 5632 -912 -1188 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -912 13 0.56 225 5632 5632 5632 5632 4037 6792 3084 0 5632 5632 5632 5632 16384 3152 4044 3185 SUCCESS
    707 08/08/2024 15:54 2926328 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14134 197 214 1 93 73 2909 3144 65535 65535 82 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3581 3469 3667 3424 14066 14223 202 192 203 211 72 67 74 72 276 299 26.9 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2909 3730 3144 4036 3099 2908 3727 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2914 5632 5632 5632 5632 -912 -1188 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -912 13 0.56 225 5632 5632 5632 5632 4037 6788 3084 0 5632 5632 5632 5632 16384 3152 4044 3378 SUCCESS
    708 08/08/2024 15:54 2930405 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14136 193 209 1 93 73 2909 3144 65535 65535 83 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3582 3468 3669 3422 14069 14229 197 194 197 194 71 67 72 66 267 293 26.9 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2909 3730 3144 4036 3099 2908 3727 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2918 5632 5632 5632 5632 -912 -1188 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -912 13 0.56 225 5632 5632 5632 5632 4037 6784 3084 0 5632 5632 5632 5632 16384 3152 4044 3340 SUCCESS
    709 08/08/2024 15:54 2934500 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14138 188 204 1 93 73 2909 3144 65535 65535 84 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3583 3468 3671 3422 14075 14229 195 191 182 189 70 66 67 65 264 286 26.8 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2909 3730 3144 4036 3099 2908 3727 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2922 5632 5632 5632 5632 -912 -1188 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -912 13 0.56 225 5632 5632 5632 5632 4037 6780 3084 0 5632 5632 5632 5632 16384 3152 4044 3382 SUCCESS
    710 08/08/2024 15:54 2938631 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14141 183 199 1 93 73 2910 3144 65535 65535 78 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3583 3467 3672 3419 14072 14231 185 192 179 189 66 67 66 65 259 280 26.9 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2910 3731 3144 4036 3100 2909 3728 1146 1493 3142 4032 27.8 27.4 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2926 5632 5632 5632 5632 -913 -1189 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -913 13 0.56 225 5632 5632 5632 5632 4037 6776 3084 0 5632 5632 5632 5632 16384 3152 4044 3456 SUCCESS
    711 08/08/2024 15:54 2942809 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14142 181 195 1 93 73 2910 3144 65535 65535 79 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3584 3466 3675 3419 14075 14238 186 184 189 177 67 64 69 61 253 274 26.9 27.4 27.4 27.1 27.2 27.4 27.4 27.4 2910 3731 3144 4036 3100 2909 3728 1146 1493 3142 4032 27.8 27.3 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2930 5632 5632 5632 5632 -913 -1189 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -913 13 0.56 225 5632 5632 5632 5632 4037 6772 3084 0 5632 5632 5632 5632 16384 3152 4044 3181 SUCCESS
    712 08/08/2024 15:54 2946740 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14144 176 191 1 93 73 2910 3144 65535 65535 80 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3585 3465 3676 3418 14080 14233 193 180 173 190 69 62 64 65 249 269 26.7 27.3 27.4 27.1 27.2 27.4 27.4 27.4 2910 3731 3144 4036 3100 2909 3728 1146 1493 3142 4032 27.8 27.3 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2934 5632 5632 5632 5632 -913 -1189 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -913 13 0.56 225 5632 5632 5632 5632 4037 6768 3084 0 5632 5632 5632 5632 16384 3152 4044 3370 SUCCESS
    713 08/08/2024 15:54 2950835 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14146 173 187 1 93 73 2910 3144 65535 65535 81 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3586 3466 3679 3417 14079 14235 178 172 181 180 64 60 67 62 243 263 26.8 27.3 27.4 27.1 27.1 27.3 27.4 27.3 2910 3731 3144 4036 3100 2909 3728 1146 1493 3142 4032 27.8 27.3 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2938 5632 5632 5632 5632 -913 -1189 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -913 13 0.56 225 5632 5632 5632 5632 4037 6763 3084 0 5632 5632 5632 5632 16384 3152 4044 3476 SUCCESS
    714 08/08/2024 15:54 2955032 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14153 170 183 1 93 73 2910 3144 65535 65535 83 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3587 3464 3682 3417 14079 14241 179 174 177 179 64 60 65 61 238 257 26.8 27.3 27.4 27.2 27.2 27.3 27.4 27.3 2910 3732 3144 4036 3100 2909 3728 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2942 5632 5632 5632 5632 -913 -1189 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -913 13 0.56 225 5632 5632 5632 5632 4037 6759 3084 0 5632 5632 5632 5632 16384 3152 4044 3482 SUCCESS
    715 08/08/2024 15:54 2959238 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14150 165 179 1 93 73 2911 3144 65535 65535 84 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3588 3464 3683 3416 14084 14241 171 162 175 169 61 56 64 58 235 252 26.9 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2911 3732 3144 4036 3100 2909 3728 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2946 5632 5632 5632 5632 -914 -1191 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -914 13 0.56 225 5632 5632 5632 5632 4037 6755 3084 0 5632 5632 5632 5632 16384 3152 4044 3269 SUCCESS
    716 08/08/2024 15:54 2963287 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14153 163 175 1 93 73 2911 3144 65535 65535 86 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3589 3463 3685 3415 14085 14241 162 173 162 157 58 60 60 54 226 245 26.8 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2911 3732 3144 4036 3101 2910 3730 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2950 5632 5632 5632 5632 -914 -1191 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -914 13 0.56 225 5632 5632 5632 5632 4037 6751 3084 0 5632 5632 5632 5632 16384 3152 4044 3330 SUCCESS
    717 08/08/2024 15:54 2967371 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14154 157 172 1 93 73 2911 3144 65535 65535 87 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3589 3463 3688 3414 14085 14242 166 166 164 161 60 57 60 55 224 240 26.8 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2911 3732 3144 4036 3101 2910 3730 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2954 5632 5632 5632 5632 -914 -1191 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -914 13 0.56 225 5632 5632 5632 5632 4037 6747 3084 0 5632 5632 5632 5632 16384 3152 4044 3430 SUCCESS
    718 08/08/2024 15:54 2971553 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14155 155 168 1 93 73 2911 3144 65535 65535 89 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3590 3462 3690 3413 14087 14245 158 157 149 150 57 54 55 51 218 235 26.9 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2911 3733 3144 4036 3101 2910 3730 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2959 5632 5632 5632 5632 -914 -1191 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -914 13 0.56 225 5632 5632 5632 5632 4037 6743 3084 0 5632 5632 5632 5632 16384 3152 4044 3322 SUCCESS
    719 08/08/2024 15:54 2975635 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14158 152 164 1 93 73 2911 3144 65535 65535 91 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3591 3464 3693 3415 14090 14248 159 154 165 158 57 53 61 54 211 230 26.8 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2911 3733 3144 4036 3101 2910 3730 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2963 5632 5632 5632 5632 -914 -1191 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -914 13 0.56 225 5632 5632 5632 5632 4037 6739 3084 0 5632 5632 5632 5632 16384 3152 4044 3530 SUCCESS
    720 08/08/2024 15:54 2979872 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14159 148 160 1 93 73 2911 3144 65535 65535 93 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3592 3464 3695 3414 14093 14248 155 163 167 144 56 56 62 49 208 225 26.8 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2911 3733 3144 4036 3101 2910 3730 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2967 5632 5632 5632 5632 -914 -1191 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -914 13 0.56 225 5632 5632 5632 5632 4037 6735 3084 0 5632 5632 5632 5632 16384 3152 4044 3434 SUCCESS
    721 08/08/2024 15:55 2984027 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14160 145 157 1 93 73 2912 3144 65535 65535 94 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3592 3462 3696 3411 14092 14249 146 142 137 154 52 49 51 53 201 221 26.9 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2912 3733 3144 4036 3102 2911 3731 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2971 5632 5632 5632 5632 -915 -1192 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -915 13 0.56 225 5632 5632 5632 5632 4037 6731 3084 0 5632 5632 5632 5632 16384 3152 4044 3187 SUCCESS
    722 08/08/2024 15:55 2988006 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14162 141 153 1 93 73 2912 3144 65535 65535 96 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3593 3461 3698 3410 14094 14253 147 138 134 143 53 48 50 49 198 216 26.9 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2912 3733 3144 4036 3102 2911 3731 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2975 5632 5632 5632 5632 -915 -1192 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -915 13 0.56 225 5632 5632 5632 5632 4037 6726 3084 0 5632 5632 5632 5632 16384 3152 4044 3618 SUCCESS
    723 08/08/2024 15:55 2992338 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14169 138 150 1 93 73 2912 3144 65535 65535 97 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3594 3460 3701 3410 14096 14254 148 144 139 140 53 50 51 48 194 211 26.8 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2912 3734 3144 4036 3102 2911 3731 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2979 5632 5632 5632 5632 -915 -1192 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -915 13 0.56 225 5632 5632 5632 5632 4037 6722 3084 0 5632 5632 5632 5632 16384 3152 4044 3442 SUCCESS
    724 08/08/2024 15:55 2996487 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14166 135 147 1 93 73 2912 3144 65535 65535 99 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3594 3460 3702 3410 14096 14255 144 143 134 144 52 49 50 49 188 207 26.9 27.3 27.4 27.3 27.1 27.3 27.4 27.3 2912 3734 3144 4036 3102 2911 3731 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2983 5632 5632 5632 5632 -915 -1192 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -915 13 0.56 225 5632 5632 5632 5632 4037 6718 3084 0 5632 5632 5632 5632 16384 3152 4044 3225 SUCCESS
    725 08/08/2024 15:55 3000438 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14171 132 144 1 93 73 2912 3144 65535 65535 101 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3596 3459 3704 3409 14099 14257 148 135 132 150 53 47 49 51 187 202 26.9 27.3 27.4 27.3 27.2 27.3 27.4 27.3 2912 3734 3144 4036 3102 2911 3731 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2987 5632 5632 5632 5632 -915 -1192 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -915 13 0.56 225 5632 5632 5632 5632 4037 6714 3084 0 5632 5632 5632 5632 16384 3152 4044 3247 SUCCESS
    726 08/08/2024 15:55 3004458 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14169 130 141 1 93 73 2912 3144 65535 65535 103 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3596 3459 3707 3408 14101 14257 133 131 135 124 48 45 50 42 184 197 26.9 27.3 27.4 27.3 27.2 27.3 27.4 27.3 2912 3734 3144 4036 3102 2911 3731 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2992 5632 5632 5632 5632 -915 -1192 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -915 13 0.56 225 5632 5632 5632 5632 4037 6710 3084 0 5632 5632 5632 5632 16384 3152 4044 3644 SUCCESS
    727 08/08/2024 15:55 3008799 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14170 129 138 1 93 73 2913 3144 65535 65535 105 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3596 3458 3708 3407 14100 14259 126 126 122 130 45 44 45 44 179 193 26.8 27.4 27.4 27.3 27.2 27.4 27.4 27.4 2913 3734 3144 4036 3102 2911 3731 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 2996 5632 5632 5632 5632 -915 -1192 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -915 13 0.56 225 5632 5632 5632 5632 4037 6706 3084 0 5632 5632 5632 5632 16384 3152 4044 3298 SUCCESS
    728 08/08/2024 15:55 3012854 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14171 123 134 1 93 73 2913 3144 65535 65535 107 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3597 3458 3710 3406 14106 14260 126 128 120 128 45 44 45 44 176 189 27.0 27.4 27.4 27.3 27.2 27.4 27.4 27.4 2913 3735 3144 4036 3103 2912 3732 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3000 5632 5632 5632 5632 -916 -1193 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -916 13 0.56 225 5632 5632 5632 5632 4037 6702 3084 0 5632 5632 5632 5632 16384 3152 4044 3598 SUCCESS
    729 08/08/2024 15:55 3017202 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14177 120 131 1 93 73 2913 3144 65535 65535 109 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3598 3457 3712 3406 14104 14264 132 114 121 126 47 39 45 43 169 184 26.9 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2913 3735 3144 4036 3103 2912 3732 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3005 5632 5632 5632 5632 -916 -1193 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -916 13 0.56 225 5632 5632 5632 5632 4037 6696 3084 0 5632 5632 5632 5632 16384 3152 4044 4684 SUCCESS
    730 08/08/2024 15:55 3022608 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14176 119 128 1 93 73 2913 3144 65535 65535 111 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3599 3457 3714 3405 14107 14264 127 111 129 121 46 38 48 41 167 179 26.9 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2913 3735 3144 4036 3103 2912 3732 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3009 5632 5632 5632 5632 -916 -1193 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -916 13 0.56 225 5632 5632 5632 5632 4037 6692 3084 0 5632 5632 5632 5632 16384 3152 4044 3565 SUCCESS
    731 08/08/2024 15:55 3026919 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14175 116 125 1 93 73 2913 3144 65535 65535 114 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3601 3458 3717 3406 14107 14268 118 115 116 118 42 40 43 40 163 175 26.9 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2913 3735 3144 4036 3103 2912 3732 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3014 5632 5632 5632 5632 -916 -1193 13 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -916 13 0.56 225 5632 5632 5632 5632 4037 6688 3084 0 5632 5632 5632 5632 16384 3152 4044 3480 SUCCESS
    732 08/08/2024 15:55 3031116 0x0187 0 10 0x6001 0 65535 65535 1 27.4 14177 113 122 1 93 73 2913 3144 65535 65535 116 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3601 3457 3720 3405 14111 14265 111 116 112 116 40 40 42 39 160 172 26.7 27.4 27.4 27.2 27.2 27.4 27.4 27.4 2913 3735 3144 4036 3103 2912 3732 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3018 5632 5632 5632 5632 -916 -1193 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -916 14 0.56 225 5632 5632 5632 5632 4037 6684 3084 0 5632 5632 5632 5632 16384 3152 4044 3419 SUCCESS
    733 08/08/2024 15:55 3035305 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14183 112 119 1 93 73 2913 3144 65535 65535 118 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3601 3455 3720 3403 14108 14268 110 120 118 104 40 41 44 35 157 168 26.8 27.3 27.4 27.1 27.2 27.3 27.4 27.3 2913 3736 3144 4036 3103 2912 3732 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3022 5632 5632 5632 5632 -916 -1193 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -916 14 0.56 225 5632 5632 5632 5632 4037 6680 3084 0 5632 5632 5632 5632 16384 3152 4044 3318 SUCCESS
    734 08/08/2024 15:55 3039396 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14179 110 117 1 93 73 2914 3144 65535 65535 120 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3601 3454 3722 3402 14110 14271 114 109 113 115 41 38 42 39 152 165 26.8 27.3 27.4 27.1 27.2 27.3 27.4 27.3 2914 3736 3144 4036 3103 2912 3732 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3026 5632 5632 5632 5632 -916 -1193 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -916 14 0.56 225 5632 5632 5632 5632 4037 6675 3084 0 5632 5632 5632 5632 16384 3152 4044 3524 SUCCESS
    735 08/08/2024 15:55 3043656 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14185 106 115 1 93 73 2914 3144 65535 65535 121 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3602 3453 3724 3401 14110 14270 110 118 109 105 40 41 41 36 149 161 26.8 27.3 27.3 27.1 27.1 27.3 27.3 27.3 2914 3736 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3030 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6671 3084 0 5632 5632 5632 5632 16384 3152 4044 3515 SUCCESS
    736 08/08/2024 15:56 3047912 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14182 104 112 1 93 73 2914 3144 65535 65535 124 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3603 3454 3725 3401 14114 14270 114 115 101 110 41 40 38 37 148 158 26.8 27.3 27.4 27.1 27.1 27.3 27.4 27.3 2914 3736 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3035 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6667 3084 0 5632 5632 5632 5632 16384 3152 4044 3500 SUCCESS
    737 08/08/2024 15:56 3052084 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14183 101 110 1 93 73 2914 3144 65535 65535 126 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3604 3454 3729 3402 14116 14271 114 107 94 121 41 37 35 41 142 154 26.9 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2914 3736 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3039 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6663 3084 0 5632 5632 5632 5632 16384 3152 4044 3354 SUCCESS
    738 08/08/2024 15:56 3056207 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14184 99 108 1 93 73 2914 3144 65535 65535 129 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3605 3454 3730 3402 14114 14274 102 93 106 105 37 32 40 36 140 151 26.7 27.3 27.4 27.1 27.1 27.3 27.4 27.3 2914 3736 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3043 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6659 3084 0 5632 5632 5632 5632 16384 3152 4044 3436 SUCCESS
    739 08/08/2024 15:56 3060310 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14185 97 105 1 93 73 2914 3144 65535 65535 131 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3604 3451 3730 3399 14116 14276 106 100 110 100 38 35 41 34 138 148 26.7 27.3 27.3 27.1 27.1 27.3 27.3 27.3 2914 3736 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3047 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6654 3084 0 5632 5632 5632 5632 16384 3152 4044 3568 SUCCESS
    740 08/08/2024 15:56 3064565 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14191 96 103 1 93 73 2914 3144 65535 65535 133 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3605 3451 3732 3398 14119 14276 98 98 105 91 35 34 39 31 135 145 26.8 27.3 27.4 27.1 27.1 27.3 27.4 27.2 2914 3737 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3051 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6650 3084 0 5632 5632 5632 5632 16384 3152 4044 3430 SUCCESS
    741 08/08/2024 15:56 3068732 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14191 94 101 1 93 73 2914 3144 65535 65535 136 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3606 3451 3734 3397 14117 14275 94 94 87 98 34 32 32 33 132 141 26.7 27.2 27.3 27.1 27.1 27.2 27.3 27.2 2914 3737 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3056 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6646 3084 0 5632 5632 5632 5632 16384 3152 4044 3870 SUCCESS
    742 08/08/2024 15:56 3073344 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14187 82 98 1 93 73 2914 3144 65535 65535 140 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3606 3451 3736 3398 14119 14274 73 97 84 77 26 33 31 26 112 137 26.8 27.2 27.3 27.1 27.1 27.2 27.3 27.2 2914 3737 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3060 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6642 3084 0 5632 5632 5632 5632 16384 3152 4044 3404 SUCCESS
    743 08/08/2024 15:56 3077472 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14185 81 93 1 93 73 2915 3144 65535 65535 148 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3605 3448 3735 3395 14116 14273 94 74 88 73 34 26 33 25 113 131 26.8 27.2 27.3 27.1 27.1 27.3 27.3 27.3 2915 3737 3144 4036 3104 2913 3734 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3064 5632 5632 5632 5632 -917 -1195 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -917 14 0.56 225 5632 5632 5632 5632 4037 6638 3084 0 5632 5632 5632 5632 16384 3152 4044 3435 SUCCESS
    744 08/08/2024 15:56 3081645 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14189 80 90 1 93 73 2915 3144 65535 65535 152 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3606 3450 3738 3397 14115 14276 92 87 86 81 33 30 32 28 114 127 26.8 27.2 27.3 27.2 27.1 27.2 27.3 27.2 2915 3737 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3067 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6634 3084 0 5632 5632 5632 5632 16384 3152 4044 2640 SUCCESS
    745 08/08/2024 15:56 3084930 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14190 80 88 1 93 73 2915 3144 65535 65535 155 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0008 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3607 3449 3739 3396 14116 14277 90 102 80 92 32 35 30 31 115 124 26.8 27.2 27.3 27.1 27.1 27.2 27.3 27.2 2915 3737 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3070 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6631 3084 0 5632 5632 5632 5632 16384 3152 4044 2406 SUCCESS
    746 08/08/2024 15:56 3087996 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14189 78 86 1 93 73 2915 3144 65535 65535 159 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3607 3448 3740 3396 14116 14278 88 84 75 82 32 29 28 28 114 122 26.8 27.3 27.3 27.2 27.1 27.3 27.3 27.3 2921 3745 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3074 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6628 3084 0 5632 5632 5632 5632 16384 3152 4044 2444 SUCCESS
    747 08/08/2024 15:56 3090695 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14185 78 85 1 94 74 2926 3144 65535 65535 161 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3606 3447 3739 3393 14116 14273 82 66 95 80 30 23 36 27 112 120 26.8 27.2 27.3 27.2 27.1 27.2 27.3 27.2 2938 3767 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3076 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6625 3084 0 5632 5632 5632 5632 16384 3152 4044 2338 SUCCESS
    748 08/08/2024 15:56 3094131 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14190 77 84 1 94 74 2944 3144 65535 65535 163 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3607 3448 3742 3395 14117 14277 89 82 81 70 32 28 30 24 112 118 26.9 27.3 27.4 27.2 27.1 27.3 27.4 27.3 2955 3790 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3080 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6622 3084 0 5632 5632 5632 5632 16384 3152 4044 2248 SUCCESS
    749 08/08/2024 15:56 3098144 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14187 78 83 1 95 75 2967 3144 65535 65535 165 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3607 3446 3741 3393 14120 14274 83 75 92 74 27 26 34 25 109 117 26.9 27.2 27.4 27.2 27.1 27.2 27.4 27.2 2978 3820 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3084 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6618 3084 0 5632 5632 5632 5632 16384 3152 4044 2512 SUCCESS
    750 08/08/2024 15:56 3102159 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14178 39 77 1 96 75 2990 3144 65535 65535 178 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3603 3443 3739 3391 14107 14263 40 59 55 56 14 20 21 19 58 105 26.8 27.2 27.4 27.2 27.1 27.3 27.4 27.3 3001 3850 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3088 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6614 3084 0 5632 5632 5632 5632 16384 3152 4044 2533 SUCCESS
    751 08/08/2024 15:57 3106164 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14173 43 68 1 96 76 3013 3144 65535 65535 201 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3603 3442 3738 3389 14101 14262 27 49 46 62 10 17 17 21 64 95 26.7 27.3 27.3 27.1 27.1 27.3 27.3 27.3 3024 3879 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3092 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6610 3084 0 5632 5632 5632 5632 16384 3152 4044 2607 SUCCESS
    752 08/08/2024 15:57 3110171 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14168 46 63 1 97 76 3036 3144 65535 65535 217 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3603 3442 3739 3390 14103 14254 66 44 59 59 24 15 22 20 65 88 26.8 27.2 27.4 27.1 27.1 27.2 27.4 27.2 3047 3909 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3096 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6606 3084 0 5632 5632 5632 5632 16384 3152 4044 2363 SUCCESS
    753 08/08/2024 15:57 3114175 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14170 49 59 1 98 77 3059 3144 65535 65535 232 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3602 3441 3739 3389 14096 14254 63 53 70 51 23 18 26 17 68 83 26.8 27.2 27.3 27.2 27.1 27.2 27.3 27.2 3070 3939 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3100 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6602 3084 0 5632 5632 5632 5632 16384 3152 4044 2688 SUCCESS
    754 08/08/2024 15:57 3118177 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14168 50 57 1 99 78 3082 3144 65535 65535 240 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3600 3439 3737 3386 14093 14254 42 43 55 49 15 15 21 17 72 80 26.9 27.3 27.3 27.1 27.1 27.3 27.3 27.3 3093 3969 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3104 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6598 3084 0 5632 5632 5632 5632 16384 3152 4044 2694 SUCCESS
    755 08/08/2024 15:57 3122185 0x0187 0 10 0x6001 0 65535 65535 1 27.3 14163 52 56 1 99 78 3110 3144 65535 65535 249 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3600 3438 3737 3386 14092 14248 76 63 65 59 27 22 24 20 75 78 26.7 27.2 27.3 27.1 27.1 27.2 27.3 27.2 3127 4014 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3109 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6592 3084 0 5632 5632 5632 5632 16384 3152 4044 4164 SUCCESS
    756 08/08/2024 15:57 3126875 0x0187 0 10 0x6001 0 65535 65535 1 27.2 14160 53 55 1 100 79 3133 3144 65535 65535 249 2992 14400 0x0080 2 -1045 -1045 -871 -871 79 0x0187 0x1000 0x10 0x0808 0x10 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3599 3437 3738 3386 14092 14248 36 55 77 63 13 19 29 21 75 77 26.8 27.3 27.3 27.1 27.1 27.2 27.3 27.2 3145 4037 3144 4036 3105 2914 3735 1146 1493 3142 4032 27.8 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3112 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6590 3084 0 5632 5632 5632 5632 16384 3152 4044 2767 SUCCESS
    757 08/08/2024 15:57 3130330 0x4183 0 10 0x6001 0 65535 65535 1 27.2 14154 28 54 1 100 79 3145 3145 65535 65535 253 0 0 0x40A0 2 -1045 -1045 -871 -871 79 0x4183 0x1000 0x10 0x00C8 0x1A 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3597 3434 3735 3383 14079 14325 0 0 0 0 0 0 0 0 0 72 26.8 27.2 27.3 27.1 27.1 27.2 27.3 27.2 3145 4029 3145 4029 3105 3145 4029 1146 1492 3145 4029 27.3 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3115 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6587 3084 0 5632 5632 5632 5632 16384 3152 4044 2448 SUCCESS
    758 08/08/2024 15:57 3134201 0x4183 0 10 0x6001 0 65535 65535 1 27.2 14144 0 41 1 100 79 3145 3145 65535 65535 334 0 0 0x40A0 2 -1045 -1045 -871 -871 79 0x4183 0x1000 0x10 0x00C8 0x1A 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3594 3433 3732 3383 14071 14320 0 0 0 0 0 0 0 0 0 55 26.8 27.2 27.3 27.1 27.1 27.2 27.3 27.2 3145 4029 3145 4029 3105 3145 4029 1146 1492 3145 4029 27.3 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3119 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6582 3084 0 5632 5632 5632 5632 16384 3152 4044 3421 SUCCESS
    759 08/08/2024 15:57 3138213 0x4183 0 10 0x6001 0 65535 65535 1 27.2 14128 0 31 1 100 79 3145 3145 65535 65535 472 0 0 0x40A0 2 -1045 -1045 -871 -871 79 0x4183 0x1000 0x10 0x00C8 0x1A 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3590 3431 3728 3381 14057 14325 0 0 0 0 0 0 0 0 0 39 26.8 27.2 27.3 27.1 27.1 27.2 27.3 27.2 3145 4029 3145 4029 3105 3145 4029 1146 1492 3145 4029 27.3 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3124 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6578 3084 0 5632 5632 5632 5632 16384 3152 4044 3857 SUCCESS
    760 08/08/2024 15:57 3142574 0x4183 0 10 0x6001 0 65535 65535 1 27.2 14119 0 24 1 100 79 3145 3145 65535 65535 570 0 0 0x40A0 2 -1045 -1045 -871 -871 79 0x4183 0x1000 0x10 0x00C8 0x1A 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3587 3428 3724 3379 14046 14323 0 0 0 0 0 0 0 0 0 31 26.7 27.2 27.3 27.1 27.1 27.2 27.3 27.2 3145 4029 3145 4029 3105 3145 4029 1146 1492 3145 4029 27.3 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3127 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6575 3084 0 5632 5632 5632 5632 16384 3152 4044 2515 SUCCESS
    761 08/08/2024 15:57 3146226 0x4183 0 10 0x6001 0 65535 65535 1 27.3 14115 0 18 1 100 79 3145 3145 65535 65535 760 0 0 0x40A0 2 -1045 -1045 -871 -871 79 0x4183 0x1000 0x10 0x00C8 0x1A 0x1014 0x02B8 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 0x0000 3584 3426 3721 3377 14040 14320 0 0 0 0 0 0 0 0 0 24 26.7 27.2 27.2 27.1 27.1 27.2 27.2 27.2 3145 4029 3145 4029 3105 3145 4029 1146 1492 3145 4029 27.3 27.2 1000 1000 1000 1000 0 0 0 0 0 14 0 0 0 0 3130 5632 5632 5632 5632 -918 -1196 14 0 0 0 0 3356 3333 3371 3388 0 0 0 0 -918 14 0.56 225 5632 5632 5632 5632 4037 6571 3084 0 5632 5632 5632 5632 16384 3152 4044 2375 SUCCESS
    If possible, can you please send the data in an excel file? We do most of our data analyzation through excel and we cannot convert the data above into excel.
    Anthony
    It seems like this is being caused by the difference in the Full Charge Capacity and the Design Capacity. Has the cell in use been aged at all or been in use for an extended amount of time?
    Just to confirm, has a learning cycle been completed for this cell as well?
    Anthony
