What is the difference between LM4040DEM3-2.5 and LM4040DEM3x-2.5 ?
I found that there is a difference in packaging. But our problem is that we have a difference in forward voltage also. With the same condittions whiile LM4040DEM3-2.5 has 800mV , LM4040DEM3x-2.5 has 740mV. Is it normal or we received a bad batch?
There should be no difference between the two devices. These used to have different reel size but are now exactly the same device.
If you suspect you have a bad batch please contact customer service for next steps
https://www.ti.com/support-quality/additional-information/customer-returns.html
