we are trying to use BQ-EV-SW command line tool to program chip, but we always get error message of Error code = 302 which says adaptor didn't detected, I am using EV2300 for command line. How can I resolve this issue?
Is your EV2300 detected by your computer?
Have you downloaded this FW?
EV2300-084 Support software | TI.com
Diego
See if these links solve your issue.
(+) EV2300 on 64bit Windows 7 - Power management forum - Power management - TI E2E support forums
Diego
Hello Yash,
Let's take a step back. Is the EV2300 being detected by your computer? Do you see it in device manager?
Adrian
Hello Yash,
I recommend you trying to use this with another computer to see if this is resolved.
Robert.
Hello Yash,
We do not support the EV2300, I recommend trying to use the EV2400, or you can use a microcontroller and the Gauge Communication document to achieve this.
Robert.
Do you have BQstudio, can you check if BQstudio autodetects your EV2300?
Diego
Do you get the same error code 302 with the ev2400?
Try updating the ev2400 drivers, as this device is still supported from a FW perspective.
Diego
