Other Parts Discussed in Thread: UCC25600
Hi Team,
Do we have LCC controller with secondary current feedback? Thanks.
BRs,
Francis
Currently we have the UCC25640x devices and the UCC25660x devices that use hysteretic current mode control based on primary sensing. TI also has an LLC controller that is designed for voltage mode control the UCC25600. We do not have any analog power supply controllers designed for secondary current feedback.
Are you trying to do constant current/constant voltage mode control for battery charging?
Hi Mike,
Application is Laser Power, it needs constant current output.
Could you please help explain it more detailed? Thanks in advance.
BRs,
Francis
There are not any application notes or reference design with just current output control using the UCC25660x or any LLC controller; as far as, I know.
The following link will bring you to the reference design library. You can search it to see if there is anything close to your application you can use. You just need to enter your input and output power requirements and hit search.
https://www.ti.com/reference-designs/index.html
You might be able to get a constant current, constant voltage feedback to work for your application. The attached application note discusses how to implement this design technique.
8053.Designing CC-CV Feedback Circuits With the TL103WB.pdf
Thank you for interest in Texas Instruments (TI) products. If you have a related question, please click the "Ask a related question" button in the top right corner. The newly created question will be automatically linked to this question.
