Hi Patrick,
In reference to the thread started by Nicholas Medor "Parts damaged during production testing (LX and VOUT pins shorted)", we were able to determine the root cause of the damaged TPS61158 LED Drivers.
We found that during test, an overvoltage condition occurred where VOUT would approach 32V, exceeding the datasheet's 30V absolute max rating and damaging the part.
This would occur when voltage was applied to the CTRL and VIN pins, before power was applied to the switch node (FTP55 net).
We ran a test to ensure the CTRL pin was grounded prior to power being applied to VIN and switch node (FTP55 net). After power was applied to VIN and FTP55, we applied a PWM signal to the CTRL pin. No voltage spikes were present on VOUT after this sequence.
Our follow up questions for TI are:
1: Does it make sense that applying pulses to the control pin before the switch node is powered will cause voltage spikes on the TPS61158 output?
2: Will driving the control pin low for 3.5ms minimum prior to powering the switch node ensure that no voltage spikes will be generated? 3.5ms is from the TPS61158 "6.5 Electrical Characteristics"
3: Are there any other timing constraints that we should be aware of that could results in damage to the IC?
We look forward to your response. Thank you,
Andy Calder
