Other Parts Discussed in Thread: BQSTUDIO, BQ24104, BQ28Z610
I am working on a BQ28Z620 Battery fuel gauge with BQ24104 Charger.The BQ28Z620 is designed for 1-series to 2 series packs in which I am using a single cell configuration.(I am not using bqstudio)
1) Could you kindly provide guidance on how to configure the fuel gauge correctly for a single cell ?
2) I also tried to configure the fuel gauge and when i try to charge the cell after sending a reset command then the cell is charging but after charging for a certain voltage the gauge has stopped charging and when i checked the gauging status full charge and charge termination flags are raised (MACSubcmd() 0x0056 Gauging Status) , and this flags are not cleared until a reset command is sent although i tried to drain the battery still the flags are raised and charging is stopped. kindly please provide help on this matter.
