Hi, i have the bq.fs and df.fs files and i need to write them. First thing: Do i need to write both to the gauge?(data and program) and i do not understand some lines of the file:
This line i understand:
Hello Anon,
You will need to only program the bq.fs file since this file contains both data flash and instruction flash (firmware). df.fs only contains the data flash.
The formatting is the same for the lines you are confused with. 16 is the device address (this is the address when the device is in ROM mode). Where is an FAQ about this: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1107251/faq-bqstudio-how-do-i-interpret-the-lines-in-a-bq-fs-df-fs-file-for-use-with-my-i2c-or-hdq-gauge
Adrian
