In our application using LP2951CSD/NOPB, we've found that if the current limit is in the lower range of the allowable limit, the output can get stuck at power on, due to a heavy load on the output.
In the datasheet regarding the current limit, there is this note:
(4) Ensured and 100% production tested.
Is there a way to buy specific lots that have a relatively high current limit for the part?
We do not offer this part with screened current limit. However, if you'd like, I can see if there is something else that would work. I would just need to know your VIN, VOUT and IOUT to get started.
~ Aaron
