Other Parts Discussed in Thread: TPS51623
Hi, we have issue that can’t power on TPS53626. Fail rate is 8/37units from factory reported.
Finally we found that after we change PC100 from 47nF to 100nF, this issue can be fixed.
Below is VCCRAM output measurement when power on, FYR.
Attached the schematic, please help check what cause this issue and how to prevent it since it has fail rate.
We are afraid that 0.1uF is only the solution to make the fail rate become lower…
Sch, FYR.
./cfs-file/__key/communityserver-discussions-components-files/196/1104.VCCSRAM.pdf
Below is fail & pass waveform:
