TPS2H160-Q1: Is an external clamp diode necessary to protect the drain-source?
Part Number: TPS2H160-Q1
Image.pptx
Is it necessary to mount an external diode between the drain and source of the IPD to protect it from a negative surge that occurs upstream of the relay due to the back electromotive force of the coil when the high-side switch is turned off?
According to the datasheet, the IPD has a built-in diode, so is an external diode unnecessary?
