I'm trying to decide which part, BQ24160 or BQ24163 is best for my design. Vsys(reg) for 24160 = 3.7v, and 24163 = 3.4v. I'm using a 10AHR single cell li ion battery so nominal voltage = 3.7v and max = 4.2v.
* What does Vsys represent?
* Does it have anything to do with the battery charging?
* Is Vsys basically a switcher output that can run my logic VDC rail direct without a separate LDO?
Second question?
* Is there a way to monitor the battery vdc through the I2C? I don't see that in the spec sheet? Or at least don't understand how.
