Hi guys,
I have a couple of questions that were broght up by a customer of mine:
1. Can you verify that the thermal pad should be electrically connected to Ground? Neither the customer or I found that documented in the datasheet, and want to verify that the intention is that the Thermal pad be electrically connected to ground.
2. Can you verify whta happens to the OUT pin and the GATE pin when the device has a VIN below 3V? We are trying not to turn things on unintentionally.
Thank you,
