I have a question about I2C on TPS56720.
When I2C function is not used, SCL and SDA should be "pull-down", and A0 and A1 should be "open". Is it correct?
Hide
Hide
From the datasheet:
"When only external regulation mode is used in a TPS56X20 application, the VOUT terminal should be tied to the
output voltage of the converter and SDA & SCL terminals should be grounded. A0 & A1 terminals may be
floating."
