In the Application Document:<555 timer eliminates LED driver’s need for microprocessor control>,there is context about the TLC5917's power-up, which is copied as follows: 'At power-up, the internal on/off latches that turn each output on or off default to zero, so you must set these latches to one before the outputs turn on. The 555 timer replaces the microprocessor for this function.'
My question is: (1)Do on/off Latches mean in the data sheet? (2)What does 'set these latches to one' mean? What should be noticed in the Control Signal's Sequences?
