Dear, All
There is a question about the charging method of BQ25070.
About Figure.13 of a data sheet on page 10.
Looking at Figure.13 and after full charge looks like a trickle charge.
Is this correct?
If this is correct, there are the following questions.
In normal lithium-ion battery considered a trickle charge is not used.
Whether there is no problem to use a trickle charge the battery of LiFePO4?
It is the other question.
After full-charging, the when the voltage of the battery is lowered.
Whether the battery voltage may be considered to perform recharging after reaching the voltage of Vrch?
Thanks, Masami M.
