The TPS92513 data sheet specifies "The dimming frequency range is 100 Hz to 1 kHz". The 1 KHz max frequency is too low for our application. Using the TPS92513EVM-001 we have run the dimming frequency up to 10 KHz (LED current set for 1.0 Amp) and it seems to work fine. What is the reason for the 1 KHz max frequency limitation? What are the issues of exceeding that limit?
Appreciate your help - Duncan
