Hi All,
I am considering using LM2679−ADJ to make a portable 20V, 4A output voltage supply unit running on 24V heavy duty battery. Is this product good for it? I can see from the data sheet how to use it to make a 14.8V, 3.5A power supply unit. However, if you know another product that can handle this output with adjustable current limit feature, kindly let me know, your suggestion will be highly appreciated.
I need your suggestions and recommendations.
Truman.
