Dear,
i only read the tps3110 supply current vs supply voltage from the 7.8 Typical Characteristica of the datasheet. But i want to know the tps3106 supply current vs supply voltage. are they the same?or what is the different between them?
Hi Aimee,
There is no difference between the supply current vs. supply voltage of tps3106 and tps3110.
In the 7.8 Typical Characteristics section, Figure 5 is characteristic of the tps31xx family. You can also refer to 7.5 Electrical Characteristics IDD Supply current to see that it is characteristic across the TPS31xx family.
Thank you,
Andrey Volynets
