Hello everyone,
currently, we implemented the driver UCC27511 to drive IGBTs with high pulse currents. To avoid parasitic turn-on, the OUTL gate resistor has a very small value - but still high enough not to exceed the maximum current. The OUTL is protected against negative input voltage by means of fast SiC diodes to ground. The voltage on supply and ground pins looks clean.
However, the device keeps failing randomly by permanently shorting the gate and we are unable to explain why. Have you any information concerning another special sensitivity of the device beyond what is mentioned in the datasheet?
Any help in this matter would be greatly appreciated.
Martin
