Other Parts Discussed in Thread: LM4040, LM4040-N
hi
Might there be any issue with connecting one voltage reference to couple (or more) A/D converters, assuming the reference is able to sink and source current?
thanks
Hi Tsahi,
Can you shed a little more light on your application, possibly a schematic or design parameters? A shunt reference is more designed to sink current to provide proper reference. The load current provided will be coming from the input .
Ethan
Hi Tsahi,
What kind of issues are you seeing? Have you tried referencing only one ADC at a time? Is it possible to share parts of the schematic?
I do recommend using a newer part like the LM4040 or LM4040-N that shows more support for ADC applications on their datasheet.
Is there a reason you chose the LT1009?
Ethan
