BQ2002D: TM pin and CC pin
Part Number: BQ2002D
Hi
I have several questions about this device.
(I already posted about VBAT pin configuration of this device. )
1. TM pin. ; Can we leave this pin open if we do not use ?
2. TM pin. ; Does it mean that the charging stop when the time reach at 440ms if TM is Mid?
3. CC pin. ; At Figure 5. it is shown that CC pin is output the 286us width pulse during the pulse-trickle charging.
                   If BQ2002D, CC does not output the 286us width pulse. Is that correct? (High at charging. Low at not charging.)
4. BQ2002D. ; Does BQ2002D support Trickle-charging and Top-off ? (At table 1, it is mentioned "None". That means "Not support"?)
Koji Hamamoto
  • Hello
    1.) TM pin. ; Can we leave this pin open if we do not use ?----No
    2.)TM pin. ; Does it mean that the charging stop when the time reach at 440ms if TM is Mid?---Yes (but 440 minutes)
    3.) CC pin. ; At Figure 5. it is shown that CC pin is output the 286us width pulse during the pulse-trickle charging---For bq2002D this does not apply
    4.) BQ2002D. ; Does BQ2002D support Trickle-charging and Top-off ? (At table 1, it is mentioned "None". That means "Not support"?)--Trickle-charge and Top-off for BQ2002D NO, does not support.
    Also See:
    www.ti.com/.../sluu229.pdf
  • Hi Bill
    Thank you.
    Koji Hamamoto
