Hi Team,
My customer is using our TPS2660 in PLC AI module. Today they tested the plug in function, but they got strange waveform need your kindly support to explain, thanks!
As you can above waveform, the yellow one is the TPS2660's input waveform during plug in test, normally 24V bus voltage, but the pulse will up to about 50V and 50ms long duration. What may be the reason for this spike? Is these any problem? The green waveform is the output waveform of TPS2660.
Thanks a lot for your support!
Sulyn
