Other Parts Discussed in Thread: TPS62147
Hi, I just found a problem with TPS62110RSA which used in my project. I tested two boards, the voltages of FB were the same, but the output voltages from SW were not. And I calculated the current through the FB, the calculated value was 1.45uA, which was much higher than 100nA in datasheet.
