Other Parts Discussed in Thread: LM3409, LM3414HV, TPS92510, TPS92513HV
Hi e2e team,
I received a inquiry from a customer who used LM3404HV, and also made me confused about it.
The lm3404HV is used to output DC42 volts in his design, and he found only when input voltage reaches 47-48v, the 42v output can be get. A 5-6v dropout voltage is too high for him, he wanted to know if we have a lower dropout voltage LED driver could meet his design, that is to say a higher duty cycle LED driver will be better.
And I seek for many products in LED driver field, but they rarely mention the duty cycle in the datasheet, instead of that the duty cycle of PWM dimming was interpreted in real detail. Could you give some directions about it, and is there other drivers similar to LM3404HV but has a higher duty cycle?
Thanks a lot.
Jenny
