Other Parts Discussed in Thread: LM27402
LM27402 + UCC27210 , how to deal with the SW?thanks;
Hi Cris,
I'm an applications engineer in the high power driver group and will try to assist.
Can you please elaborate on your question some more? What part of your circuit do you have questions about? Have there been any failures? Do you have a schematic for the switches?
For general gate driver information, please see http://www.ti.com/power-management/mosfet-igbt-gate-drivers/support-training.html.
As a side note, I would recommend some resistors in your input filters to ensure a consistent cutoff frequency.
John
11.pdfHi John,
Thanks for your help. As attached file is the schematic;SW between two MOS is connected with Pin4 HS of UCC27210.
Would you help to tell what should I connect the SW of UCC27210? many thanks;
Hi Cris,
Your schematic is correct. SW is connected to HS in a typical half bridge.
John
