Is there any concern for adding bead BLM18KG121TN1(datasheet is attached) that location as below? If not recommend, why? What is the concern about?
Randy Chen
Randy Chen
We don't recommend adding ferrite beads in series with the schottky. We have not simulated or verified proper loop stability with such configuration. It should be okay to add a place holder for it on the pcb as long as doing so does not violate the suggested layout guidelines. Then, evaluate proper operation and decide on the use of such configuration.
Angelos Tsiros
