Hi Support team
My customer and I are a bit confused when it comes to the Iq in the data sheet. and you answer and explain the three questions below?
- Can you confirm the lower current is PFM mode an the higher current is PWM mode?
- Also, what effect does the input voltage have on this, one stated 5V in and the other 4.2volts in?
- Last, what does the comment VOUT = NO SUPPLY, do you mean no load?
Jeff Coletti
